0 Replies Latest reply on Oct 5, 2012 9:02 AM by abkaniki
    Please Help - "page error" / a system error occurred
    abkaniki
      I am very basic with Coldfusion Developed websites and pretty awesome on HTML and PHP. While working on a website I made an HTML change and added a line to a page. All works well on the test website/server but after uploading the changed page the page went offline/errored a day later.
      I have an error receipt and am hoping to resolve this issue with some insight from a good Coldfusion Developer or Programmer.
      PLEASE HELP, see error below.
      A system error occurred: http://www.mix.co.zm/mix_schools.cfm?
      Error - struct
      Detail    Note: If you wish to use an absolute template path (for example, template="/mypath/index.cfm") with CFINCLUDE, you must create a mapping for the path using the ColdFusion Administrator. Or, you can use per-application settings to specify mappings specific to this application by specifying a mappings struct to THIS.mappings in Application.cfc. <br> Using relative paths (for example, template="index.cfm" or template="../index.cfm") does not require the creation of any special mappings. It is therefore recommended that you use relative paths with CFINCLUDE whenever possible.
      Message    Could not find the included template components/mix_documents2.cfm.
      MissingFileName    components/mix_documents2.cfm
      StackTrace    coldfusion.tagext.lang.IncludeTag$NoSuchIncludeTemplateException: Could not find the included template components/mix_documents2.cfm. at coldfusion.tagext.lang.IncludeTag.setTemplate(IncludeTag.java:349) at cfmix_schools2ecfm527774291.runPage(D:\hshome\mixnet\mix.co.zm\mix_schools.cfm:15) at coldfusion.runtime.CfJspPage.invoke(CfJspPage.java:231) at coldfusion.tagext.lang.IncludeTag.doStartTag(IncludeTag.java:416) at coldfusion.filter.CfincludeFilter.invoke(CfincludeFilter.java:65) at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:360) at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48) at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40) at coldfusion.filter.PathFilter.invoke(PathFilter.java:94) at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70) at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:79) at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:2 8) at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38) at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46) at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38) at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22) at coldfusion.filter.CachingFilter.invoke(CachingFilter.java:62) at coldfusion.CfmServlet.service(CfmServlet.java:200) at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89) at jrun.servlet.FilterChain.doFilter(FilterChain.java:86) at com.intergral.fusionreactor.filter.FusionReactorFilter.i(FusionReactorFilter.java:566) at com.intergral.fusionreactor.filter.FusionReactorFilter.c(FusionReactorFilter.java:258) at com.intergral.fusionreactor.filter.FusionReactorFilter.doFilter(FusionReactorFilter.java: 164) at jrun.servlet.FilterChain.doFilter(FilterChain.java:94) at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42 ) at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46) at jrun.servlet.FilterChain.doFilter(FilterChain.java:94) at jrun.servlet.FilterChain.service(FilterChain.java:101) at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106) at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42) at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286) at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543) at jrun.servlet.jrpp.JRunProxyService.invokeRunnable(JRunProxyService.java:203) at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320) at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428) at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266) at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
      TagContext    Error - array
      1    Error - struct
      COLUMN    0
      ID    CFINCLUDE
      LINE    15
      RAW_TRACE    at cfmix_schools2ecfm527774291.runPage(D:\hshome\mixnet\mix.co.zm\mix_schools.cfm:15)
      TEMPLATE    D:\hshome\mixnet\mix.co.zm\mix_schools.cfm
      TYPE    CFML
      TagName    CFINCLUDE
      Type    MissingInclude
