1. Re: Is it possible to author a form on behalf on someone else?
Brian Havlin Oct 5, 2012 1:52 PM (in response to Sushmar)Yes, this is possible. Please take a look at the following FAQ:
http://forums.adobe.com/docs/DOC-1424
Regards,
Brian
2. Re: Is it possible to author a form on behalf on someone else?
Sushmar Oct 5, 2012 1:58 PM (in response to Brian Havlin)Thanks Brian. I figured out the sharing feature, but in this case, I (even though an author) should not be able to see the responses. It seems that if I author the form there is no way for me to make sure ONLY another person sees the responses and have them hidden from the original author.
Really I want to create this form on behalf of someone else, but not use their account.
(I understand this is a 'off the main path' request).
Sushma
3. Re: Is it possible to author a form on behalf on someone else?
Brian Havlin Oct 5, 2012 2:11 PM (in response to Sushmar)> It seems that if I author the form there is no way for me to make sure ONLY another person sees the responses and have them hidden from the original author.
That's correct. You could set things up such that only your manager receives the notification emails, but you would still be able to access the responses within FormsCentral.
This probably isn't what you're looking for but I'll mention it just in case. If you don't need to continue to administer the form once it has been authored, you could consider having your manager become the owner of a copy of the form, as described in the following FAQ:
http://forums.adobe.com/docs/DOC-1390
Regards,
Brian
