3 Replies Latest reply on Oct 8, 2012 12:17 PM by Daniel Farkas
    beforeDeletion not runs the effect
    Daniel Farkas
      I have a symbol (autoplay timeline off ), the main stage I insert an instance of that symbol.
      In symbol is a short animation, a fade.
      I call on the creationComplete event sym.play (); ok works
      I call the event beforeDeletion sym.playReverse ();
      but the symbol is deleted immediately, the fade does not appear.
      The event beforeDelete is called, if I place an alert () it appears, but not fade effect.
      any ideas?
      tanks
        • 1. Re: beforeDeletion not runs the effect
          Peter Flynn (Adobe) Adobe Employee
          I've moved this from Edge Code to the Edge Animate forum, since I think that's the tool your question pertains to.
          - Peter
          • 2. Re: beforeDeletion not runs the effect
            elainecc Adobe Employee
            Hi, Daniel-
            You're hitting a race condition right now.  The deletion will not wait for the animation to play.  Instead, you're probably better off not using beforeDeletion and instead setting up a trigger in the symbol to delete itself, then call a label that will play that selection.
            Hope that helps,
            -Elaine
            • 3. Re: beforeDeletion not runs the effect
              Daniel Farkas Level 1
              Hello Elaine,
              I skirted the situation by putting on stage method deletes the object that the call to
              sym.getSymbol ("SimbolName"). playReverse (500, true);
              I put a symbol on the timeline trigger position 0
              sym.getParentSymbol (). getSymbol (sym.getSymbolElement ()). deleteSymbol ();
              It works perfectly, however I think a workaround.
              Tanks.
              I forgot this,
              The Symbols must be false as autoplay timeline, in creationComplete (symbol method), i call sym.play (0, false), not to run the deletion trigger in position 0 in play moment.
