5 Replies Latest reply on Oct 5, 2006 2:34 AM by Newsgroup_User
    Login with conditions problems
    Level 7
      What is wrong with this function? I am trying to create a user login that
      checks to make sure the user is in the database first, then check the active
      level. If the level is 1 then set sessions and redirect, if 2 then redirect
      to the login page and send a URL variable of account=suspended, if 0 then
      redirect to the login page sending a URL variable of account=inactive, etc.
      I want to query the db first to see if the user is in the datasbase. If yes,
      then check the active number. I am getting this error in the conditional
      statement to check the 'active' column.
      'You have attempted to dereference a scalar variable of type class
      java.lang.String as a structure with members'
      What am I missing?
      <cffunction name="UserLogin" access="remote" returntype="void">
      <cfargument name="username" type="string" required="yes">
      <cfargument name="password" type="string" required="yes">
      <cfquery name="login" datasource="***">
      Select username, password, priv FROM users_database
      WHERE username='#arguments.username#' AND password='#arguments.password#'
      <cfif login.recordcount NEQ 0>
      <cfif login.active EQ 1>
      <cflock scope="session" timeout="30" type="exclusive">
      <cfset Session.MM_Username = #arguments.username#>
      <cfset Session.SitePriv = #login.priv#>
      <cflocation url="/clinic/contribute/main/index.cfm" addtoken="no">
      <cfelseif login.active EQ 0>
      <cflocation url="/clinic/contribute/index.cfm?account=inactive"
      <cfelseif login.active EQ 2>
      <cflocation url="/clinic/contribute/index.cfm?account=suspended"
      <cfelseif login.active EQ 3>
      <cflocation url="/clinic/contribute/index.cfm?account=banned"
      <cflocation url="/clinic/contribute/index.cfm?login=failed" addtoken="no">
        • 1. Re: Login with conditions problems
          azadisaryev Level 1
          there is no "active" column in your "login" query's recordset... you have "priv" column instead...
          so try changing login.active to login.priv
          • 2. Re: Login with conditions problems
            azadisaryev Level 1
            oh, and another thing:
            do not have "username" and "password" as arguments. same names are used for attributes in the <cffunction> tag, and that can cause problems. rename them to something like "uname" and "pwd" instead...
            • 3. Re: Login with conditions problems
              Level 7
              Thanks you for the heads-up on not selecting the active column in the table.
              I added that is it worked fine.
              I don't have any problems with using username and password as arguments.
              Thanks for the heads up though, probably better to change it anyways.
              • 4. Re: Login with conditions problems
                azadisaryev Level 1
                glad i could help.
                re "username" and "password" as function arguments:
                you will run into problems if you try to pass any of those inline inside the <cfinvoke> tag when invoking the cfc that contains your function. that is, if it is in a cfc...
                • 5. Re: Login with conditions problems
                  Level 7
                  Sabaidee as covered why your code didn't work. here's some more pointers
                  where your code could be improved...
                  Set output="false" on all methods unless you actually are outputting stuff
                  from them (which generally you should not).
                  I doubt this method would be appropriate for calling as a webservice (given
                  it ends with a <cflocation>), so don't expose it as one. access="public".
                  Add hints to all your <cffunction> and <cfargument> tags. It assists
                  sanity checking and code documentation.
                  You have not VARed the login variable. This is poor practice unless you
                  explicitly mean to not VAR it.
                  Always use <cfqueryparam> tags. It improves performance and reduces memory
                  consumption on your DB server.
                  > </cflock>
                  There's no need to lock this sort of variable assignment.
                  It's pretty poor practice to use <cflocation> within a function. You CFM
                  page should call a method, and get a response back from it. And then the
                  CFM page should decide whether to <cflocation> or not. Possibly your
                  function should set the URL for the <cflocation> and return the value.
                  Then the calling code should use than in a <cflocation> call.
                  This if/elseif/else construct would be better done as a switch. Rule of
                  thumb: evaluating the same variable for many conditions: switch.
                  evaluating different variables for many conditions: if/elseif/else.
