11 Replies Latest reply on Nov 11, 2012 9:22 AM by Peter Grainge
    What are the rules to build a merged project?
    Krischu Level 1
      In another thread I'm asking for help regarding the mapped IDs not being seen when the merged help project is being openend from the application.
      Now I'm wondering what might be wrong with my setup.
      Where do the subprojects have to put their resulting .chm files? In their respective project directory?
      Christoph
        • 1. Re: What are the rules to build a merged project?
          There is some information about merged CHMs at the end of my tutorial about merged webhelp. See my site.
          @petergrainge
          • 2. Re: What are the rules to build a merged project?
            Krischu Level 1
            Thanks. I visited your site and tried out the rh9_merge sample project.
            May I discussit here further or do you suggest another place or means?
            I compiled the child projects and then built the parent project afterwards. During building the parent project I'm getting:
            Processing keywords...
            Generating full-text search data...
            HHC6000: Error:
            An internal file could not be created. Make certain there is enough disk space on the drive where you are compiling your file.
            HHC5007: Error:
            Fatal navigational compilation error. This is likely the result of an invalid contents (.hhc) file.
            Compacting file system...
            The following files were not compiled:
            Kompilierung von HTML-Hilfe in 1 Sek. abgeschlossen.
            Kompilierung abgeschlossen
            Christoph
            • 3. Re: What are the rules to build a merged project?
              Those errors are not normal encountered with the demo. My guesses are that you have not amended some path and are generating to drive that does not exist, not removed the redirect which  is not needed with a CHM merge, or your project is on a network drive.
              @petergrainge
              • 4. Re: What are the rules to build a merged project?
                Priyank Shrivastava. Adobe Employee
                Hi Chris,
                As Peter has already suggested however you can try and generate the CHM in C:\New folder location, you won't get this error. I am not sure why it is not able to resolve this long directory.
                Hope this helps.
                Priyank
                • 5. Re: What are the rules to build a merged project?
                  Krischu Level 1
                  I was able to build the WebHelp Demo but the HTMLHelp failed with the above error.
                  The generated chm file  is in:
                  C:\Users\kuku\Documents\Eigene RoboHelp-Projekte\rh9_merge\source\parent\!SSL!\Microsoft_HTML_Help\parent.chm
                  but
                  RH9 created a directory C:\rh9_merge\generate but the child1.chm etc
                  are in
                  C:\Users\kuku\Documents\Eigene RoboHelp-Projekte\rh9_merge\source\projects\child_1\!SSL!\Microsoft_HTML_Help\child1.chm.
                  Invoking parent.chm shows the typical empty info page that the web site cannot be opened.
                  In every child projects target directory is child1.chm, not child2.chm and child3.chm as one would expect.
                  Christoph
                  • 6. Re: What are the rules to build a merged project?
                    Chris,
                    Can you please copy that CHM in your C: drive and then open it. also right click on it and check if you have Unblock button enable, if it is that unblock and then try it.
                    Priyank
                    • 7. Re: What are the rules to build a merged project?
                      Krischu Level 1
                      Priyank Srivastava wrote:
                      Chris,
                      Priyank
                      Hi Priyank,
                      I don't quite understand,what you are saying. What do you mean by
                      "Copy that CHM in your C: drive" ? I have everything on my C: drive.
                      Which .CHM do you mean? That one in the weird directory path, Child1.chm?
                      Right click on it? What do you mean by "Unblock-Button"? Is that within RH9 or in
                      Windows Explorer?
                      I found meanwhile that the demo has errors in it, as far as the configuration for
                      Microsoft HTMLhelp is concerned. The target file is named child1.chm for every child project and not child1,child2,child3 as it should be. That's probably a side problem.
                      While I was trying to change that name in the options dialog (output folder and filename) I was told by an alert box that the file Microsoft HTML Help.ssl  should be writeable.
                      Well, I looked at it and it was full access for me as owner. I also could change the file name to Child3.chm (Child2.chm). Seems that this is a one time alert which appeared only once as a warning(?). Wonder why it appeared at all when the file was writeable anyway.
                      So far so good, I'm trying to get that demo project working with merged CHM files.
                      • 8. Re: What are the rules to build a merged project?
                        Krischu Level 1
                        Hi Peter,
                        I turned back today to the rh_merge project demo.
                        I took the rh9_merge.zip file. Unpacked everything into
                        c:\rh9_merge, went into source\projects\child[123] subsequently, built every child
                        (the Microsoft HTML Help output->Generate) and they built fine.
                        Going into source\parent afterwards, clicking on the parent.xpj file and clicking then on Generate in the Microsoft HTML Help output section, yields the reported error:
                        Kompilierung wird gestartet...
                        HTML-Hilfe-Vorprozessor 9.0.1.262
                        C:\rh9_merge\source\parent\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_0\Parent.chm wird kompiliert...
                        Erstellung von HTML-Hilfe wird vorbereitet...
                        Ausgabeordner wird gelöscht...
                        Dateien für HTML-Hilfe werden vorbereitet...
                        Dateien werden kopiert...
                        Dateien werden aktualisiert...
                        Vorbereitung nach 0 Sekunde(n) abgeschlossen
                        Compiler wird initialisiert...
                        HTMLHELP (9.0.1.262) wird generiert...
                        Themen werden aktualisiert...
                        parent_redirect.htm wird aktualisiert...
                        Warnung: Die Größe der Stoppdatei muss auf 512 Byte begrenzt sein.
                        C:\rh9_merge\source\parent\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_0\Parent.hhp
                        Microsoft HTML Help Compiler 4.74.8702
                        Compiling c:\rh9_merge\source\parent\!SSL!\Microsoft_HTML_Help\Parent.chm
                        Parent.hhc
                        Parent.hhk
                        parent_redirect.htm
                        Parent.glo
                        Parent.brs
                        #BSSC
                        default.css
                        RoboHHRE.lng
                        ehlpdhtm.js
                        HHC6000: Error:
                        HHC5007: Error:
                        I can build the Webhelp Output project without error but the error on the
                        Microsoft HTML Help project persists.
                        I checked all permissions on the files to no avail. I'm stuck.
                        Edit: FWIW, I tried to run the example on a different computer (Windows 7/64, and RH10, of which I installed
                        a trial version). The same error.
                        Christoph
                        • 9. Re: What are the rules to build a merged project?
                          The project is set up for merged webhelp and there are things that need to be changed if you are merging CHMs.
                          In the TOC of the parent, you need to delete the existing links to the children and create links to the child projects again. The links are different. You will need to create the child CHMs before you can do that.
                          Also the cross project links need to be recreated in a different way.
                          @petergrainge
                          • 10. Re: What are the rules to build a merged project?
                            Krischu Level 1
                            Thanks for commenting. I hope I can manage it myself to modify the links.
                            Christoph
