i am really really mad because i have been trying to make a turret game from a series of 30 tutorials and im on the 13th one and the code is messing up and i re did the code 2 times wich was over 2 hours of doing a code that works for this guy just fine and i need it to work, http://www.youtube.com/watch?v=SMo5FU8H_d8
my code is
package {
import flash.display.Sprite;
import Explosion;
import ReusableCode.myMaths;
import flash.events.Event;
public class ExplosionChain extends Sprite {
// variables
private var lifespan:int;
private var birthrate:Number;
private var blastRadius:Number;
private var minBlast:int;
private var maxBlast:int;
private var birthCounter:Number=1;
public function ExplosionChain(l:int=20, b:Number=0.5, br:Number=20, minB:int=5, maxB:int=20) {
// constructor code
lifespan=1;
birthrate=b;
blastRadius = br;
minBlast=minB;
maxBlast=maxB;
addEventListener(Event.ENTER_FRAME, update)
public function update(e:Event) {
lifespan--;
if (lifespan>0) {
while(birthCounter>=0) {
birthCounter-=birthrate;
var ex = new Explosion(minBlast+(maxBlast-minBlast)*Math.random());
ex.rotation = Math.random()*360;
myMaths.moveFoward(ex, Math.random()*blastRadius);
addChild(ex);
birthCounter+=1;
}else if (numChildren==0) {
parent.removeChild(this);
the error says
/Users/baileypandiscio/Desktop/Turret Game/ExplosionChain.as, Line 33 | 1137: Incorrect number of arguments. Expected no more than 0. |
and the guy's code from the tutorial works just great for him. please help.
There's the problem... in the Explosion class, the constructor does not take arguments...
public function Explosion() {
But in your other class you are calling that class function using arguments...
var ex = new Explosion(minBlast+(maxBlast-minBlast)*Math.random() );
That red stuff is not accomodated by the class.
Which is line 33? What does the function that it calls look like?
line 33 is var ex = new Explosion(minBlast+(maxBlast-minBlast)*Math.random());
What does the function/class that it calls look like?
if u mean what is the code called Explosion that it plays rapidly if it works it is
package {
import fl.transitions.Tween;
import fl.transitions.TweenEvent;
import fl.transitions.easing.*;
public class Explosion extends Sprite {
//make tween variables
private var tweenAlpha:Tween;
private var tweenSize:Tween;
// constructor code
// use the graphics of this sprite to draw a circle
graphics.beginFill(0xFFFFFF);
graphics.drawCircle(0,0,10);
graphics.endFill();
// add an event listener for when the explosion is added to the screen
addEventListener(Event.ADDED_TO_STAGE, Init);
private function Init(e:Event) {
// set up alpha tween
tweenAlpha = new Tween(this, "alpha", Regular.easeInOut, 1, 0, 20);
tweenAlpha.addEventListener(TweenEvent.MOTION_FINISH, removeExplosion);
// set up the tween to scale the explosion
tweenSize = new Tween(this, "scaleX", Regular.easeInOut, 0, 1, 10);
tweenSize.addEventListener(TweenEvent.MOTION_CHANGE, applyScale);
private function applyScale(t:TweenEvent) {
scaleY = scaleX;
private function removeExplosion(t:TweenEvent) {
Sprite(parent).removeChild(this);
O.O im 13 and am not too good with as3 but im amazing with as2 and im trying to learn as3 and its a lot more confusing but way more usefull. so what do i need to do to the explosion class to get it working?
so do i need to make public function Explosion() { not public or something? excuse me if i do not sound verry knowlegable about this topic, i just started as3 yesterday and want to make a game to impress my teacher
If you want to be able to call the Explosion class from other classes, then you need to keep it as a public class/function.
For now what you should do to get rid of the error is to remove the argument(s) from the function call on line 33...
var ex = new Explosion();
and
import flash.events.MouseEvent;
stage.addEventListener(MouseEvent.CLICK, explode);
function explode(m:MouseEvent) {
var e = new Explosion();
var ex = new ExplosionChain();
e.x = mouseX
e.y = mouseY
addChild(e);
is the fuction for the stage for when you click, it makes doezens of little explosions
