2 Replies Latest reply on Oct 8, 2012 11:02 PM by Supreet R
    API documentation
    Supreet R Level 1
          I am generating an API documentation for the custom
          Datagrid component created, so I want to include
          an example of that component and the swf file for the
          same in API documentation.
          How can this be done...?
      Supreet R
        • 1. Re: API documentation
          Abhishek Chaudhary
          Hi Supreet,
          Its done using ASDOC
          You can either do it using command prompt or using Flash Builder
          To do it Flash Builder Way :
          Go to external tools configuration, New Launch Configuation
          Specify following parameters:
          Location : Location of asdoc.exe (C:\Program Files\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0\bin\asdoc.exe)
          Working Directory : ${project_loc}/src
          Arguments :
          -source-path .
          -doc-sources .
          DOCS
          -strict=false
          (here . symbolizes current directory, DOCS specifies folder under which ASDOCS needs to be generated)
          There are many issues with ASDOCs, for a simple/complex projects, definitions of few basic libraries like objects, commands are not found.
          You need to explicitly include swcs or libraries
          like -external-library-path "C:/Users/achaudhary/trunk/24thJul/MBM/libs/robotlegs-framework-v1.5.2.swc"
          Regards,
          Abhishek Chaudhary
          InfoCepts.
          • 2. Re: API documentation
            Supreet R Level 1
            Hi Abhishek,
                 Thank you for the reply.
            I generated the API documentation using the procedure you described, but i was not able to include examples(both mxml and swf files)
            in the API documentation.
            http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/spark/components/DataGr id.html#includeExamplesSummary
            The above link shows both mxml and swf files included for DataGrid  - AS3 Flex API documentation provided by Adobe,
            I want to generate the API documentation in the same way.
            Could you please help me in solving this problem?
            Supreet R
