Hi All,
We have an input request xml file which has a # in it name for example "IM#33400null01.xml". We fire a request to LBQ(Load Balancer) to Indesign Server CS5 as follows :
Here we can see the name of the input xml->IM#34400null0.xml is part of the http request.
This xml file is an input to one of the methods in the JSX script file (which is also part of the above request) as follows
function AveryProcessGetOutputRequest(exportFolderName, xmlFileName, outFileName, resultFileName)
xmlFileName-> is the input filename
.On firing the request the LBQ throws an Exception stating "Unterminated string constant".
Oct 08, 2012 7:21:06 PM com.adobe.clover.queue.JobMgrImpl submitJob
INFO: Submitted job "null" to queue "Default"
Oct 08, 2012 7:21:08 PM com.adobe.clover.queue.JobConsumer run
WARN: Job 1 on instance "D:\IDS_repository_temp\LBQ\j1.txt" failed with error: U
Oct 08, 2012 7:21:08 PM com.adobe.idsqueue.EnqueueJobController handle
ERROR: Job 1 failed to execute "null" error code 4 error message : "Unterminated
string constant" exception : "com.adobe.clover.queue.JobMgrException: com.adobe
.ids.IdsException: IDL:com/adobe/ids/IdsException:1.0"
INFO: Job 1 job name : "null" start time : Mon Oct 08 19:21:06 IST 2012 priority
0.5 queue name : "Default"
Manjunath
have you tried to urlencode the hash char?
Might be interesting as well if the problem also occours when you point to a local script in your url. The script should then contain a static link to your xml file.
cheers,
jossif
