3 Replies Latest reply on Oct 17, 2012 9:09 AM by Kirsti-CA
    Hash Rules - Adobe signed virus files
    teckchick72 Level 1
      In order to create a hash rule, you must use the hash as determined by the Software Restriction Policy software. You can’t just import a hash that was calculated by another software component, even if the hash matches and uses the same hash algorithm. What is the suggested recommendation for including the 3 virus files that were signed with Adobe certs if manually entering the hash is not an option?
        • 1. Re: Hash Rules - Adobe signed virus files
          Kirsti-CA Adobe Employee
          We have confirmed that you do need the original source file in order to generate the hash value. Our engineering team has generated the hash value and extracted it from the MS rule.
          I've attached the file.  Please let us know if it helps!
          • 2. Re: Hash Rules - Adobe signed virus files
            teckchick72 Level 1
            Hello,
            I assume the registry key attached was meant to prohibit the registry
            changes made by the malware by creating a registry path rule for the
            software?
            Example path:%HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
            NT\CurrentVersion\SystemRoot\XXX%
            There is no real use case for this problem, so no rush but I am curious
            how this is meant to work.
            I was hoping to know the actual path and the hash values. I had imported
            this into my personal machine hoping I could then search for the values in
            order to verify and test. ( pwdump, libeay32.dll & myGeeksmail.dll )
            I had no luck with that plan.
            I am looking for other solutions and will send updates if I have any luck.
            Thank you,
            Lori Wolcott |  Systems Engineer
            direct
            (716)805-2545
            mobile
            +17166019879
            e-mail
            LWolcott@moog.com
            • 3. Re: Hash Rules - Adobe signed virus files
              Those are the corresponding registry settings for a software restriction policy hash rule. Although, it only provides signatures for two of the files.
