19 Replies Latest reply on Nov 6, 2012 10:25 AM by asankara
    exchange problems
    jsoccer645
      whenever i try to use adobe exchange in cs6; it says the program has stopped working, and shuts it down. why?? i want/need it to work!
      Also, here is an example of a screenshot before it closes:
        • 1. Re: exchange problems
          asankara
          Are you on win/mac and which version?  Which version of Adobe Exchange do you have? You can check this by opening Adobe Extension Manager installed in your machine.
          Archana
          • 2. Re: exchange problems
            jsoccer645 Level 1
            i am on windows 7; with the newest version of exchange
            • 3. Re: exchange problems
              asankara Level 1
              Thanks. Will check right now.
              Can you give me a few things that will help me debug faster?
              1. A screenshot of the Adobe Extension Manager screen
              2. Version of extension manager
              3. Version of Adobe Exchange as shown in Adobe Extension Manager
              4. Version of Photoshop (just to be sure)
              Archana
              • 4. Re: exchange problems
                jsoccer645 Level 1
                • 5. Re: exchange problems
                  asankara Level 1
                  Can you try opening Adobe Exchange in one of your other CS6 application like Illustrator/Dreamweaver? If you are able to open Adobe Exchange ok in the other applications, I suggest you uninstall and reinstall Photoshop again.
                  Archana
                  • 6. Re: exchange problems
                    jsoccer645 Level 1
                    it does the same in all others as well!
                    • 7. Re: exchange problems
                      jsoccer645 Level 1
                      would it have something to do with a crappy processor speed?
                      • 8. Re: exchange problems
                        asankara Level 1
                        Could be.  I am unable to reproduce this error. One thing I suggest you try is uninstall One product , may be photoshop and reinstall it again. Let's see what happens.
                        Sent from my iPhone
                        • 9. Re: exchange problems
                          jsoccer645 Level 1
                          i will try that and get back to you
                          • 10. Re: exchange problems
                            lrymarz Level 1
                            I remember seeing a crash a long time ago that was caused essentially by interacting with Photoshop while it was initializing.  In my case it was clicking in the Window menu during initialization (I was trying to open the Adobe Exchange panel).
                            It's a shot in the dark, but easy to try -- does the crash still occur if you launch Photoshop but don't touch the keyboard/mouse for, say, 3 minutes?
                            • 11. Re: exchange problems
                              asankara Level 1
                              Few things that will help us resolve this issue are :
                              1. Send us the AdobeExchange.log file present in this location: C:\Users\labuser\AppData\Roaming\Adobe\Exchange\Adobeexchange.log
                              2. Try opening Adobe Kuler extension in one of the CS products and let me know if you can access that without any hang. (Do not open Adobe Exchange when you are trying this, just so that it doesnt hang again)
                              3. As lrymarz suggested, can you try opening the photoshop and not open exchange and wait for a few minutes to see if you can reproduce it?
                              4. Get us the application crash file : Type event log in your search box and click View event logs. A photoshop crash should show up in the Windows Logs or Application logs as Application error. Copy the text description (it should include the Faulting module) and send it to us.
                              In addition to the above, the following will be super helpful too :
                              1. Did you install Adobe products in a non-default location? (Did you specify a specific directory for installation of photoshop/illustrator etc.)
                              2. Which version of Flash/AIR are you using ?
                              3. Did you install the products as an admin or normal user?
                              • 12. Re: exchange problems
                                jsoccer645 Level 1
                                alright, i tried kuler; and it worked; exchange did not, even after waiting.
                                Here is the contents of the log file (couldnt figure out how to send it)
                                10/11/2012,13:17:51.009,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = mx.logging::ILoggingTarget, id = logger)] and 0 processor(s)
                                10/11/2012,13:17:51.011,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PopupPM, id = _ParsleyConfig_MxmlRootObjectTag10)] and 2 processor(s)
                                10/11/2012,13:17:51.012,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PopupPM, id = _ParsleyConfig_MxmlRootObjectTag10)]
                                10/11/2012,13:17:51.013,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PopupPM, id = _ParsleyConfig_MxmlRootObjectTag10)]
                                10/11/2012,13:17:51.014,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag8)] and 0 processor(s)
                                10/11/2012,13:17:51.018,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.parsers::ReviewParser, id = _ParsleyConfig_ReviewParser1)] and 0 processor(s)
                                10/11/2012,13:17:51.019,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag2)] and 0 processor(s)
                                10/11/2012,13:17:51.020,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag16)] and 0 processor(s)
                                10/11/2012,13:17:51.022,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.parsers::AgoraProductParser, id = _ParsleyConfig_AgoraProductParser1)] and 1 processor(s)
                                10/11/2012,13:17:51.024,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property properties in class com.adobe.agora.parsers::AgoraProductParser],value={Injection(type=com.adobe.agora.model: :Properties)})] to managed object with [ObjectDefinition(type = com.adobe.agora.parsers::AgoraProductParser, id = _ParsleyConfig_AgoraProductParser1)]
                                10/11/2012,13:17:51.025,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag3)] and 0 processor(s)
                                10/11/2012,13:17:51.027,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.application::DownloadProductController, id = _ParsleyConfig_MxmlRootObjectTag18)] and 6 processor(s)
                                10/11/2012,13:17:51.028,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = com.adobe.agora.application::DownloadProductController, id = _ParsleyConfig_MxmlRootObjectTag18)]
                                10/11/2012,13:17:51.029,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.application::DownloadProductController, id = _ParsleyConfig_MxmlRootObjectTag18)]
                                10/11/2012,13:17:51.030,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.application::DownloadProductController, id = _ParsleyConfig_MxmlRootObjectTag18)]
                                10/11/2012,13:17:51.031,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.application::DownloadProductController, id = _ParsleyConfig_MxmlRootObjectTag18)]
                                10/11/2012,13:17:51.032,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.application::DownloadProductController, id = _ParsleyConfig_MxmlRootObjectTag18)]
                                10/11/2012,13:17:51.033,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag17)] and 0 processor(s)
                                10/11/2012,13:17:51.037,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag15)] and 0 processor(s)
                                10/11/2012,13:17:51.040,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.presentation::HomeViewPM, id = _ParsleyConfig_MxmlRootObjectTag6)] and 6 processor(s)
                                10/11/2012,13:17:51.041,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property properties in class com.adobe.agora.presentation::HomeViewPM],value={Injection(type=com.adobe.agora.model::Pr operties)})] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::HomeViewPM, id = _ParsleyConfig_MxmlRootObjectTag6)]
                                10/11/2012,13:17:51.044,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::HomeViewPM, id = _ParsleyConfig_MxmlRootObjectTag6)]
                                10/11/2012,13:17:51.045,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::HomeViewPM, id = _ParsleyConfig_MxmlRootObjectTag6)]
                                10/11/2012,13:17:51.046,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::HomeViewPM, id = _ParsleyConfig_MxmlRootObjectTag6)]
                                10/11/2012,13:17:51.047,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::HomeViewPM, id = _ParsleyConfig_MxmlRootObjectTag6)]
                                10/11/2012,13:17:51.047,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag13)] and 0 processor(s)
                                10/11/2012,13:17:51.057,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag7)] and 0 processor(s)
                                10/11/2012,13:17:51.058,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag6)] and 0 processor(s)
                                10/11/2012,13:17:51.059,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = mx.logging.targets::TraceTarget, id = logTarget)] and 0 processor(s)
                                10/11/2012,13:17:51.061,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.presentation::LoginViewPM, id = _ParsleyConfig_MxmlRootObjectTag7)] and 5 processor(s)
                                10/11/2012,13:17:51.062,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::LoginViewPM, id = _ParsleyConfig_MxmlRootObjectTag7)]
                                10/11/2012,13:17:51.066,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::LoginViewPM, id = _ParsleyConfig_MxmlRootObjectTag7)]
                                10/11/2012,13:17:51.067,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::LoginViewPM, id = _ParsleyConfig_MxmlRootObjectTag7)]
                                10/11/2012,13:17:51.083,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::LoginViewPM, id = _ParsleyConfig_MxmlRootObjectTag7)]
                                10/11/2012,13:17:51.085,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.utils::AppLocale, id = _ParsleyConfig_MxmlRootObjectTag17)] and 0 processor(s)
                                10/11/2012,13:17:51.086,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag10)] and 0 processor(s)
                                10/11/2012,13:17:51.088,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag14)] and 0 processor(s)
                                10/11/2012,13:17:51.089,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag9)] and 0 processor(s)
                                10/11/2012,13:17:51.091,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PaidProductListPM, id = _ParsleyConfig_MxmlRootObjectTag4)] and 6 processor(s)
                                10/11/2012,13:17:51.092,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Subscriber(property=searchTerm,type=String,id=searchTerm)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PaidProductListPM, id = _ParsleyConfig_MxmlRootObjectTag4)]
                                10/11/2012,13:17:51.093,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PaidProductListPM, id = _ParsleyConfig_MxmlRootObjectTag4)]
                                10/11/2012,13:17:51.094,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Publisher(property=currentListOfProducts,type=com.adobe.agora.presentation::ListOfProduc tsPM)] with matching [Subscriber] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PaidProductListPM, id = _ParsleyConfig_MxmlRootObjectTag4)]
                                10/11/2012,13:17:51.098,[INFO],org.spicefactory.parsley.binding.impl.SubscriberCollection, Updated value for [Publisher(property=currentListOfProducts,type=com.adobe.agora.presentation::ListOfProduc tsPM)] with matching [Subscriber]
                                10/11/2012,13:17:51.098,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PaidProductListPM, id = _ParsleyConfig_MxmlRootObjectTag4)]
                                10/11/2012,13:17:51.099,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PaidProductListPM, id = _ParsleyConfig_MxmlRootObjectTag4)]
                                10/11/2012,13:17:51.100,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.presentation::PaidProductListPM, id = _ParsleyConfig_MxmlRootObjectTag4)]
                                10/11/2012,13:17:51.496,[DEBUG],com.headlight.utils.LogUtil,find file count=7
                                10/11/2012,13:17:51.534,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.logging::HeadlightsHelper, id = _ParsleyConfig_MxmlRootObjectTag16)] and 5 processor(s)
                                10/11/2012,13:17:51.535,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property platform in class com.adobe.agora.logging::HeadlightsHelper],value={Injection(type=com.adobe.agora.model::P latform)})] to managed object with [ObjectDefinition(type = com.adobe.agora.logging::HeadlightsHelper, id = _ParsleyConfig_MxmlRootObjectTag16)]
                                10/11/2012,13:17:51.536,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property properties in class com.adobe.agora.logging::HeadlightsHelper],value={Injection(type=com.adobe.agora.model::P roperties)})] to managed object with [ObjectDefinition(type = com.adobe.agora.logging::HeadlightsHelper, id = _ParsleyConfig_MxmlRootObjectTag16)]
                                10/11/2012,13:17:51.541,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = com.adobe.agora.logging::HeadlightsHelper, id = _ParsleyConfig_MxmlRootObjectTag16)]
                                10/11/2012,13:17:51.542,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.logging::HeadlightsHelper, id = _ParsleyConfig_MxmlRootObjectTag16)]
                                10/11/2012,13:17:51.543,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = com.adobe.agora.logging::HeadlightsHelper, id = _ParsleyConfig_MxmlRootObjectTag16)]
                                10/11/2012,13:17:51.544,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag4)] and 0 processor(s)
                                10/11/2012,13:17:51.545,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag5)] and 0 processor(s)
                                10/11/2012,13:17:51.546,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.parsley.tag.core::NestedObjectTag, id = _ParsleyConfig_NestedObjectTag11)] and 0 processor(s)
                                10/11/2012,13:17:51.579,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:51.591,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add AgoraPanel to cache for [Domain 2]
                                10/11/2012,13:17:51.602,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:51.608,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add mx.core::UIComponent to cache for [Domain 2]
                                10/11/2012,13:17:51.609,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add spark.components::SkinnableContainer to cache for [Domain 2]
                                10/11/2012,13:17:51.609,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add flash.display::InteractiveObject to cache for [Domain 2]
                                10/11/2012,13:17:51.610,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add flash.display::DisplayObjectContainer to cache for [Domain 2]
                                10/11/2012,13:17:51.612,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add flash.display::Sprite to cache for [Domain 2]
                                10/11/2012,13:17:51.612,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add spark.components.supportClasses::SkinnableComponent to cache for [Domain 2]
                                10/11/2012,13:17:51.613,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add spark.components::Application to cache for [Domain 2]
                                10/11/2012,13:17:51.613,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.csxs.core::CSExtension to cache for [Domain 2]
                                10/11/2012,13:17:51.614,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add flash.display::DisplayObject to cache for [Domain 2]
                                10/11/2012,13:17:51.621,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add spark.components.supportClasses::SkinnableContainerBase to cache for [Domain 2]
                                10/11/2012,13:17:51.635,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add mx.core::FlexSprite to cache for [Domain 2]
                                10/11/2012,13:17:51.636,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:51.642,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = AgoraPanel, id = [[Object 41]])] and 8 processor(s)
                                10/11/2012,13:17:51.645,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property properties in class AgoraPanel],value={Injection(type=com.adobe.agora.model::Properties)})] to managed object with [ObjectDefinition(type = AgoraPanel, id = [[Object 41]])]
                                10/11/2012,13:17:51.646,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property themePM in class AgoraPanel],value={Injection(type=com.adobe.agora.presentation::ThemePM)})] to managed object with [ObjectDefinition(type = AgoraPanel, id = [[Object 41]])]
                                10/11/2012,13:17:51.647,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property appPM in class AgoraPanel],value={Injection(type=com.adobe.agora.presentation::AppPM)})] to managed object with [ObjectDefinition(type = AgoraPanel, id = [[Object 41]])]
                                10/11/2012,13:17:51.648,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatcher)] to managed object with [ObjectDefinition(type = AgoraPanel, id = [[Object 41]])]
                                10/11/2012,13:17:51.649,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property headlights in class AgoraPanel],value={Injection(type=com.adobe.agora.logging::HeadlightsHelper)})] to managed object with [ObjectDefinition(type = AgoraPanel, id = [[Object 41]])]
                                10/11/2012,13:17:51.650,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property platform in class AgoraPanel],value={Injection(type=com.adobe.agora.model::Platform)})] to managed object with [ObjectDefinition(type = AgoraPanel, id = [[Object 41]])]
                                10/11/2012,13:17:51.651,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = AgoraPanel, id = [[Object 41]])]
                                10/11/2012,13:17:51.652,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageReceiver(scope=global)] to managed object with [ObjectDefinition(type = AgoraPanel, id = [[Object 41]])]
                                10/11/2012,13:17:51.652,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.messages::ZoomMessage to cache for [Domain 2]
                                10/11/2012,13:17:51.666,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.lib.xml.mapper.metadata::XmlMapping to cache for [Domain 1]
                                10/11/2012,13:17:51.667,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.lib.xml.mapper.metadata::IgnoreDecorator to cache for [Domain 1]
                                10/11/2012,13:17:51.668,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.lib.xml.mapper.metadata::AttributeDecorator to cache for [Domain 1]
                                10/11/2012,13:17:51.669,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.lib.xml.mapper.metadata::ChildTextNodeDecorator to cache for [Domain 1]
                                10/11/2012,13:17:51.670,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.lib.xml.mapper.metadata::TextNodeDecorator to cache for [Domain 1]
                                10/11/2012,13:17:51.671,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.lib.xml.mapper.metadata::ChoiceIdDecorator to cache for [Domain 1]
                                10/11/2012,13:17:51.672,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.lib.xml.mapper.metadata::ChoiceTypeDecorator to cache for [Domain 1]
                                10/11/2012,13:17:51.674,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.parsley.flex.logging::LogTargetTag to cache for [Domain 1]
                                10/11/2012,13:17:51.679,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add int to cache for [Domain 1]
                                10/11/2012,13:17:51.681,[DEBUG],com.adobe.csxs.core.CSInterface,instance()
                                10/11/2012,13:17:51.682,[INFO],com.adobe.csxs.command.csxs3.GetHostEnvironmentCommand,Call ing execute() for com.adobe.exchange
                                10/11/2012,13:17:51.682,[INFO],com.adobe.csxs.internally.dom.PlugPlug,Calling [getHostEnvironment] with arguments [com.adobe.exchange]
                                10/11/2012,13:17:51.686,[INFO],com.adobe.csxs.internally.dom.PlugPlug,Call [getHostEnvironment] returned [(com.adobe.csxs.types::HostEnvironment)#0
                                  appAPEVersion = "3.3.8r"
                                  appId = "PHXS"
                                  appLocale = "en_IL"
                                  appName = "PHXS"
                                  appSkinInfo = (com.adobe.csxs.types::AppSkinInfo)#1
                                    appBarBackgroundColor = (com.adobe.csxs.types::UIColor)#2
                                      antiAliasLevel = "PlugPlugAntialiasLevel_None"
                                      color = (com.adobe.csxs.types::RGBColor)#3
                                        alpha = 255
                                        blue = 83
                                        green = 83
                                        red = 83
                                        rgb = 5460819
                                      type = "PlugPlugColorType_RGB"
                                    appBarBackgroundColorSRGB = (com.adobe.csxs.types::UIColor)#4
                                      color = (com.adobe.csxs.types::RGBColor)#5
                                        alpha = 255
                                        blue = 83
                                        green = 83
                                        red = 83
                                        rgb = 5460819
                                    baseFontFamily = "Tahoma"
                                    baseFontSize = 10
                                    contentBackgroundColor = (null)
                                    focusRingColor = (null)
                                    fontColor = (null)
                                    panelBackgroundColor = (com.adobe.csxs.types::UIColor)#6
                                      color = (com.adobe.csxs.types::RGBColor)#7
                                        alpha = 255
                                        blue = 83
                                        green = 83
                                        red = 83
                                        rgb = 5460819
                                    panelBackgroundColorSRGB = (com.adobe.csxs.types::UIColor)#8
                                      color = (com.adobe.csxs.types::RGBColor)#9
                                        alpha = 255
                                        blue = 83
                                        green = 83
                                        red = 83
                                        rgb = 5460819
                                    symbolColor = (null)
                                    systemHighlightColor = (com.adobe.csxs.types::RGBColor)#10
                                      alpha = 0
                                      blue = 255
                                      green = 153
                                      red = 51
                                      rgb = 3381759
                                  appUILocale = "en_US"
                                  appVersion = "13.0.1"
                                  isAppOffline = false
                                  plugPlugVersion = "3.0.0.383"]
                                10/11/2012,13:17:51.690,[INFO],com.adobe.csxs.command.csxs3.GetHostEnvironmentCommand,exec ute() successfully called PlugPlug for extension com.adobe.exchange
                                10/11/2012,13:17:51.694,[DEBUG],com.adobe.csxs.core.CSInterface,instance()
                                10/11/2012,13:17:51.696,[INFO],com.adobe.csxs.command.csxs3.GetExtensionsCommand,Calling execute() for com.adobe.exchange
                                10/11/2012,13:17:51.697,[DEBUG],com.adobe.csxs.core.CSXSInterface,getInstance()
                                10/11/2012,13:17:51.702,[DEBUG],com.adobe.csxs.core.CSXSInterface,CSXSInterface()
                                10/11/2012,13:17:51.702,[DEBUG],com.adobe.csxs.core.CSXSInterface,Creating instance of CSXSInterface...
                                10/11/2012,13:17:51.703,[DEBUG],com.adobe.csxs.core.CSXSInterface,Application has parameters.
                                10/11/2012,13:17:51.703,[DEBUG],com.adobe.csxs.core.CSXSInterface,appID PHXS
                                10/11/2012,13:17:51.703,[DEBUG],com.adobe.csxs.core.CSXSInterface,extID com.adobe.exchange
                                10/11/2012,13:17:51.704,[DEBUG],com.adobe.csxs.internally.comm.stagemanager.SWFBridgeDeleg ate,getInstance()
                                10/11/2012,13:17:51.704,[DEBUG],com.adobe.csxs.internally.events.CSXSEventDispatcher,CSXSE ventDispatcher()
                                10/11/2012,13:17:51.707,[INFO],com.adobe.csxs.external.DispatchExternalRequestAsync,Dispat chExternalRequestAsync singleton instantiated successfully.
                                10/11/2012,13:17:51.708,[INFO],com.adobe.csxs.core.CSXSInterface,CSXSInterface singleton instantiated successfully. CSXSInterface is ready to receive commands
                                10/11/2012,13:17:51.711,[DEBUG],com.adobe.csxs.command.csxs1.RetrieveExtensionsCommand,exe cute()
                                10/11/2012,13:17:51.716,[DEBUG],com.adobe.csxs.command.RetrieveExtensionsCommand,calling GetExtensions through ExternalInterface
                                10/11/2012,13:17:51.729,[DEBUG],com.adobe.csxs.command.RetrieveExtensionsCommand,0 : com.adobe.exchange
                                10/11/2012,13:17:51.741,[DEBUG],com.adobe.csxs.command.RetrieveExtensionsCommand,execute() List of available extensions successfully retrieved from PlugPlug.
                                10/11/2012,13:17:51.743,[INFO],com.adobe.csxs.command.csxs3.GetExtensionsCommand,execute() successfully called PlugPlug for extension com.adobe.exchange
                                10/11/2012,13:17:51.757,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object LoadPropertiesFileMessage]' with 1 receiver(s)
                                10/11/2012,13:17:51.762,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::LoadPropertiesFileCommand, id = [[Object 33]])] and 1 processor(s)
                                10/11/2012,13:17:51.764,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property locale in class com.adobe.agora.commands::LoadPropertiesFileCommand],value={Injection(type=com.adobe.agor a.utils::AppLocale)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::LoadPropertiesFileCommand, id = [[Object 33]])]
                                10/11/2012,13:17:51.780,[DEBUG],org.spicefactory.parsley.core.scope.impl.DefaultScope,Disc arding command status execute for message '[object LoadPropertiesFileMessage]': no matching observer
                                10/11/2012,13:17:51.782,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:51.789,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:51.790,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views::AppView to cache for [Domain 2]
                                10/11/2012,13:17:51.795,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:51.799,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add spark.components.supportClasses::GroupBase to cache for [Domain 2]
                                10/11/2012,13:17:51.800,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add spark.components::Group to cache for [Domain 2]
                                10/11/2012,13:17:51.825,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:51.826,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views::AppView, id = [[Object 42]])] and 3 processor(s)
                                10/11/2012,13:17:51.828,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property themePM in class com.adobe.agora.views::AppView],value={Injection(type=com.adobe.agora.presentation::Theme PM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views::AppView, id = [[Object 42]])]
                                10/11/2012,13:17:51.859,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property pm in class com.adobe.agora.views::AppView],value={Injection(type=com.adobe.agora.presentation::AppPM )})] to managed object with [ObjectDefinition(type = com.adobe.agora.views::AppView, id = [[Object 42]])]
                                10/11/2012,13:17:51.867,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property popupPM in class com.adobe.agora.views::AppView],value={Injection(type=com.adobe.agora.presentation::Popup PM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views::AppView, id = [[Object 42]])]
                                10/11/2012,13:17:51.870,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:51.872,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_AppToolBar 1' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:51.872,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views.ui::AppToolBar to cache for [Domain 2]
                                10/11/2012,13:17:51.879,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:51.901,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:51.902,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppToolBar, id = [[Object 43]])] and 2 processor(s)
                                10/11/2012,13:17:51.904,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property myProductsPM in class com.adobe.agora.views.ui::AppToolBar],value={Injection(type=com.adobe.agora.presentation: :MyProductsPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppToolBar, id = [[Object 43]])]
                                10/11/2012,13:17:51.908,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property locale in class com.adobe.agora.views.ui::AppToolBar],value={Injection(type=com.adobe.agora.utils::AppLoc ale)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppToolBar, id = [[Object 43]])]
                                10/11/2012,13:17:51.917,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_AppToolBar 1' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:51.920,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_AppToolBar 1.searchBar' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:51.921,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views.ui::SearchBar to cache for [Domain 2]
                                10/11/2012,13:17:51.927,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:51.932,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add spark.components::HGroup to cache for [Domain 2]
                                10/11/2012,13:17:51.949,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:51.950,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::SearchBar, id = [[Object 44]])] and 3 processor(s)
                                10/11/2012,13:17:51.952,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property appPM in class com.adobe.agora.views.ui::SearchBar],value={Injection(type=com.adobe.agora.presentation:: AppPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::SearchBar, id = [[Object 44]])]
                                10/11/2012,13:17:51.955,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Publisher(property=searchString,type=String,id=searchTerm)] with matching [Subscriber] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::SearchBar, id = [[Object 44]])]
                                10/11/2012,13:17:51.987,[INFO],org.spicefactory.parsley.binding.impl.SubscriberCollection, Updated value for [Publisher(property=searchString,type=String,id=searchTerm)] with matching [Subscriber]
                                10/11/2012,13:17:51.988,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property locale in class com.adobe.agora.views.ui::SearchBar],value={Injection(type=com.adobe.agora.utils::AppLoca le)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::SearchBar, id = [[Object 44]])]
                                10/11/2012,13:17:51.991,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_AppToolBar 1.searchBar' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:51.992,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_AppToolBar 1.tabTogs' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:51.995,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views.ui::TabbableToggles to cache for [Domain 2]
                                10/11/2012,13:17:52.001,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:52.022,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:52.023,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::TabbableToggles, id = [[Object 45]])] and 3 processor(s)
                                10/11/2012,13:17:52.026,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property themePM in class com.adobe.agora.views.ui::TabbableToggles],value={Injection(type=com.adobe.agora.presenta tion::ThemePM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::TabbableToggles, id = [[Object 45]])]
                                10/11/2012,13:17:52.029,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property pm in class com.adobe.agora.views.ui::TabbableToggles],value={Injection(type=com.adobe.agora.presenta tion::AppPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::TabbableToggles, id = [[Object 45]])]
                                10/11/2012,13:17:52.032,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property locale in class com.adobe.agora.views.ui::TabbableToggles],value={Injection(type=com.adobe.agora.utils::A ppLocale)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::TabbableToggles, id = [[Object 45]])]
                                10/11/2012,13:17:52.035,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_AppToolBar 1.tabTogs' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:52.037,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_AppToolBar 1._AppToolBar_OptionsComponent1' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:52.038,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views.ui::OptionsComponent to cache for [Domain 2]
                                10/11/2012,13:17:52.043,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:52.062,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:52.063,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::OptionsComponent, id = [[Object 46]])] and 4 processor(s)
                                10/11/2012,13:17:52.067,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property themePM in class com.adobe.agora.views.ui::OptionsComponent],value={Injection(type=com.adobe.agora.present ation::ThemePM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::OptionsComponent, id = [[Object 46]])]
                                10/11/2012,13:17:52.073,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Subscriber(property=pm,type=com.adobe.agora.presentation::ListOfProductsPM)] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::OptionsComponent, id = [[Object 46]])]
                                10/11/2012,13:17:52.074,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property myProductsPM in class com.adobe.agora.views.ui::OptionsComponent],value={Injection(type=com.adobe.agora.present ation::MyProductsPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::OptionsComponent, id = [[Object 46]])]
                                10/11/2012,13:17:52.079,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property locale in class com.adobe.agora.views.ui::OptionsComponent],value={Injection(type=com.adobe.agora.utils:: AppLocale)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::OptionsComponent, id = [[Object 46]])]
                                10/11/2012,13:17:52.081,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_AppToolBar 1._AppToolBar_OptionsComponent1' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:52.083,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_TiledProdu ctListView1' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:52.084,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views::TiledProductListView to cache for [Domain 2]
                                10/11/2012,13:17:52.090,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:52.094,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add spark.components::VGroup to cache for [Domain 2]
                                10/11/2012,13:17:52.110,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:52.110,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views::TiledProductListView, id = [[Object 47]])] and 3 processor(s)
                                10/11/2012,13:17:52.112,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property themePM in class com.adobe.agora.views::TiledProductListView],value={Injection(type=com.adobe.agora.presen tation::ThemePM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views::TiledProductListView, id = [[Object 47]])]
                                10/11/2012,13:17:52.122,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Subscriber(property=pm,type=com.adobe.agora.presentation::ListOfProductsPM)] to managed object with [ObjectDefinition(type = com.adobe.agora.views::TiledProductListView, id = [[Object 47]])]
                                10/11/2012,13:17:52.123,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property locale in class com.adobe.agora.views::TiledProductListView],value={Injection(type=com.adobe.agora.utils: :AppLocale)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views::TiledProductListView, id = [[Object 47]])]
                                10/11/2012,13:17:52.125,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_TiledProdu ctListView1' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:52.130,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1.AppStatusBar33' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:52.131,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views.ui::AppStatusBar to cache for [Domain 2]
                                10/11/2012,13:17:52.137,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:52.157,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:52.158,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])] and 9 processor(s)
                                10/11/2012,13:17:52.161,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property themePM in class com.adobe.agora.views.ui::AppStatusBar],value={Injection(type=com.adobe.agora.presentatio n::ThemePM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])]
                                10/11/2012,13:17:52.163,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property productDetailsPM in class com.adobe.agora.views.ui::AppStatusBar],value={Injection(type=com.adobe.agora.presentatio n::ProductDetailsPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])]
                                10/11/2012,13:17:52.166,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property appPM in class com.adobe.agora.views.ui::AppStatusBar],value={Injection(type=com.adobe.agora.presentatio n::AppPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])]
                                10/11/2012,13:17:52.168,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property token in class com.adobe.agora.views.ui::AppStatusBar],value={Injection(type=com.adobe.agora.model::Toke n)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])]
                                10/11/2012,13:17:52.169,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property locale in class com.adobe.agora.views.ui::AppStatusBar],value={Injection(type=com.adobe.agora.utils::AppL ocale)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])]
                                10/11/2012,13:17:52.173,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Subscriber(property=listOfProductsPM,type=com.adobe.agora.presentation::ListOfProductsPM )] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])]
                                10/11/2012,13:17:52.174,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property twitterPM in class com.adobe.agora.views.ui::AppStatusBar],value={Injection(type=com.adobe.agora.presentatio n::TwitterPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])]
                                10/11/2012,13:17:52.176,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property context in class com.adobe.agora.views.ui::AppStatusBar],value={Injection(type=org.spicefactory.parsley.co re.context::Context)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])]
                                10/11/2012,13:17:52.177,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::AppStatusBar, id = [[Object 48]])]
                                10/11/2012,13:17:52.178,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1.AppStatusBar33' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:52.180,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1.AppStatusBar33.HGro up42.PaginationComponent43' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:52.180,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views.ui::PaginationComponent to cache for [Domain 2]
                                10/11/2012,13:17:52.186,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:52.207,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:52.208,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::PaginationComponent, id = [[Object 49]])] and 3 processor(s)
                                10/11/2012,13:17:52.210,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property appPM in class com.adobe.agora.views.ui::PaginationComponent],value={Injection(type=com.adobe.agora.pres entation::AppPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::PaginationComponent, id = [[Object 49]])]
                                10/11/2012,13:17:52.213,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property locale in class com.adobe.agora.views.ui::PaginationComponent],value={Injection(type=com.adobe.agora.util s::AppLocale)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::PaginationComponent, id = [[Object 49]])]
                                10/11/2012,13:17:52.216,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Subscriber(property=listOfProductsPM,type=com.adobe.agora.presentation::ListOfProductsPM )] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::PaginationComponent, id = [[Object 49]])]
                                10/11/2012,13:17:52.217,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1.AppStatusBar33.HGro up42.PaginationComponent43' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:52.380,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object LoadPropertiesFileMessage]' for command status 'complete' to 2 observer(s)
                                10/11/2012,13:17:52.388,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Destroy managed object with [ObjectDefinition(type = com.adobe.agora.commands::LoadPropertiesFileCommand, id = [[Object 33]])]
                                10/11/2012,13:17:52.391,[DEBUG],com.adobe.csxs.core.CSInterface,instance()
                                10/11/2012,13:17:52.392,[INFO],com.adobe.csxs.command.csxs3.GetHostEnvironmentCommand,Call ing execute() for com.adobe.exchange
                                10/11/2012,13:17:52.393,[INFO],com.adobe.csxs.internally.dom.PlugPlug,Calling [getHostEnvironment] with arguments [com.adobe.exchange]
                                10/11/2012,13:17:52.398,[INFO],com.adobe.csxs.internally.dom.PlugPlug,Call [getHostEnvironment] returned [(com.adobe.csxs.types::HostEnvironment)#0
                                  appId = "PHXS"
                                  appLocale = "en_IL"
                                  appName = "PHXS"
                                        alpha = 255
                                        blue = 83
                                        green = 83
                                        red = 83
                                        rgb = 5460819
                                        alpha = 255
                                        blue = 83
                                        green = 83
                                        red = 83
                                        rgb = 5460819
                                    baseFontSize = 10
                                    fontColor = (null)
                                        alpha = 255
                                        blue = 83
                                        green = 83
                                        red = 83
                                        rgb = 5460819
                                        alpha = 255
                                        blue = 83
                                        green = 83
                                        red = 83
                                        rgb = 5460819
                                      alpha = 0
                                      blue = 255
                                      green = 153
                                      red = 51
                                      rgb = 3381759
                                10/11/2012,13:17:52.405,[INFO],com.adobe.csxs.command.csxs3.GetHostEnvironmentCommand,exec ute() successfully called PlugPlug for extension com.adobe.exchange
                                10/11/2012,13:17:52.415,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object ThemeChangeEvent]' with 1 receiver(s)
                                10/11/2012,13:17:52.522,[INFO],com.adobe.csxs.command.csxs3.SetPanelMenuCommand,Calling execute() for com.adobe.exchange
                                10/11/2012,13:17:52.523,[INFO],com.adobe.csxs.internally.dom.PlugPlug,Calling [setPanelMenu] with arguments [com.adobe.exchange, <Menu>
                                  <MenuItem Id="SHOW_EXMAN_ID" Label="Launch Extension Manager" Enabled="true" Checked="false"/>
                                  <MenuItem Id="CHECK_FOR_UPDATES_ID" Label="Check for updates..." Enabled="true" Checked="false"/>
                                </Menu>]
                                10/11/2012,13:17:52.524,[INFO],com.adobe.csxs.internally.dom.PlugPlug,Call [setPanelMenu] returned [(null)]
                                10/11/2012,13:17:52.524,[INFO],com.adobe.csxs.command.csxs3.SetPanelMenuCommand,execute() successfully called PlugPlug for extension com.adobe.exchange
                                10/11/2012,13:17:52.526,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object FindInstalledExtensionsMessage]' with 1 receiver(s)
                                10/11/2012,13:17:52.527,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::FindInstalledExtensionsCommand, id = [[Object 24]])] and 0 processor(s)
                                10/11/2012,13:17:52.531,[INFO],com.adobe.agora.commands.FindInstalledExtensionsCommand,Rea ding system database from: C:\ProgramData\Adobe\Extension Manager CS6\Configuration\DB\ExMan.db
                                10/11/2012,13:17:52.531,[INFO],com.adobe.agora.commands.FindInstalledExtensionsCommand,Rea ding user database from: C:\Users\jvb\AppData\Roaming\Adobe\Extension Manager CS6\Configuration\DB\ExManUser.db
                                10/11/2012,13:17:52.546,[DEBUG],org.spicefactory.lib.task.TaskGroup,Adding task: [Task]
                                10/11/2012,13:17:52.547,[DEBUG],org.spicefactory.lib.task.TaskGroup,Adding task: [Task]
                                10/11/2012,13:17:52.554,[INFO],.FindInstalledExtensionsTask,Starting to look for extensions
                                10/11/2012,13:17:52.849,[INFO],.FindInstalledExtensionsTask,Starting to look for extensions
                                10/11/2012,13:17:53.039,[DEBUG],org.spicefactory.parsley.core.scope.impl.DefaultScope,Disc arding command status execute for message '[object FindInstalledExtensionsMessage]': no matching observer
                                10/11/2012,13:17:53.047,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object ContainerHasResizedMessage]' with 2 receiver(s)
                                10/11/2012,13:17:53.762,[DEBUG],com.headlight.utils.LogUtil,unique file name =ulog_CS6_Adobe Exchange Panel_E47F303A-1B3E-8160-DC05-C4AD50DD2AA4_58F18039-6095-92CE-B14E-50D518DDECF5
                                10/11/2012,13:17:53.859,[DEBUG],com.adobe.csxs.core.CSInterface,instance()
                                10/11/2012,13:17:53.860,[DEBUG],com.adobe.csxs.core.CSInterface,instance()
                                10/11/2012,13:17:53.862,[INFO],com.adobe.csxs.command.csxs3.GetNetworkPreferencesCommand,C alling execute() for com.adobe.exchange
                                10/11/2012,13:17:53.862,[INFO],com.adobe.csxs.internally.dom.PlugPlug,Calling [getNetworkPreferences] with arguments [com.adobe.exchange]
                                10/11/2012,13:17:53.863,[INFO],com.adobe.csxs.internally.dom.PlugPlug,Call [getNetworkPreferences] returned [(Array)#0
                                  [0] true
                                  [1] true
                                  [2] true]
                                10/11/2012,13:17:53.867,[DEBUG],com.adobe.csxs.command.csxs3.GetNetworkPreferencesCommand, Received the following network preferences:
                                (com.adobe.csxs.types::NetworkPreferences)#0
                                  adminOnlinePreference = true
                                  isAppOnline = true
                                  overallOnlinePreference = true
                                  userOnlinePreference = true
                                10/11/2012,13:17:53.868,[INFO],com.adobe.csxs.command.csxs3.GetNetworkPreferencesCommand,e xecute() successfully called PlugPlug for extension com.adobe.exchange
                                10/11/2012,13:17:53.871,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object ChangeViewMessage]' with 3 receiver(s)
                                10/11/2012,13:17:53.872,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Suspend message '[object ChangeViewMessage]' with 3 receiver(s)
                                10/11/2012,13:17:53.874,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Resume message '[object ChangeViewMessage]' with 3 receiver(s)
                                10/11/2012,13:17:53.878,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object GetProductsMessage]' with 1 receiver(s)
                                10/11/2012,13:17:53.880,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::GetProductsTask, id = [[Object 31]])] and 3 processor(s)
                                10/11/2012,13:17:53.881,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property platform in class com.adobe.agora.commands::GetProductsTask],value={Injection(type=com.adobe.agora.model::P latform)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::GetProductsTask, id = [[Object 31]])]
                                10/11/2012,13:17:53.882,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property authToken in class com.adobe.agora.commands::GetProductsTask],value={Injection(type=com.adobe.agora.model::T oken)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::GetProductsTask, id = [[Object 31]])]
                                10/11/2012,13:17:53.883,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property service in class com.adobe.agora.commands::GetProductsTask],value={Injection(type=com.adobe.agora.services ::Service)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::GetProductsTask, id = [[Object 31]])]
                                10/11/2012,13:17:53.884,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::ParseProductsTask, id = [[Object 32]])] and 1 processor(s)
                                10/11/2012,13:17:53.885,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property parser in class com.adobe.agora.commands::ParseProductsTask],value={Injection(type=com.adobe.agora.parser s::ProductParser)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::ParseProductsTask, id = [[Object 32]])]
                                10/11/2012,13:17:53.887,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::SequentialTaskGroupCommand, id = [[Object 30]])] and 1 processor(s)
                                10/11/2012,13:17:53.888,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property context in class com.adobe.agora.commands::SequentialTaskGroupCommand],value={Injection(type=org.spicefact ory.parsley.core.context::Context)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::SequentialTaskGroupCommand, id = [[Object 30]])]
                                10/11/2012,13:17:53.891,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup to cache for [Domain 2]
                                10/11/2012,13:17:53.892,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:53.893,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add org.spicefactory.lib.task::TaskGroup to cache for [Domain 2]
                                10/11/2012,13:17:53.896,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:53.896,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 50]])] and 2 processor(s)
                                10/11/2012,13:17:53.897,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property appPM in class org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup],value={Injection(type= com.adobe.agora.presentation::AppPM)})] to managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 50]])]
                                10/11/2012,13:17:53.898,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 50]])]
                                10/11/2012,13:17:53.900,[DEBUG],org.spicefactory.lib.task.TaskGroup,Adding task: [Task]
                                10/11/2012,13:17:53.901,[DEBUG],org.spicefactory.lib.task.TaskGroup,Adding task: [Task]
                                10/11/2012,13:17:53.902,[INFO],org.spicefactory.lib.task.SequentialTaskGroup,Starting next task: [Task]
                                10/11/2012,13:17:53.911,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object GetProductsMessage]' for command status 'execute' to 1 observer(s)
                                10/11/2012,13:17:53.914,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object GetProductsMessage]' with 1 receiver(s)
                                10/11/2012,13:17:53.914,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::GetProductsTask, id = [[Object 31]])] and 3 processor(s)
                                10/11/2012,13:17:53.915,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property platform in class com.adobe.agora.commands::GetProductsTask],value={Injection(type=com.adobe.agora.model::P latform)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::GetProductsTask, id = [[Object 31]])]
                                10/11/2012,13:17:53.916,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property authToken in class com.adobe.agora.commands::GetProductsTask],value={Injection(type=com.adobe.agora.model::T oken)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::GetProductsTask, id = [[Object 31]])]
                                10/11/2012,13:17:53.917,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property service in class com.adobe.agora.commands::GetProductsTask],value={Injection(type=com.adobe.agora.services ::Service)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::GetProductsTask, id = [[Object 31]])]
                                10/11/2012,13:17:53.918,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::ParseProductsTask, id = [[Object 32]])] and 1 processor(s)
                                10/11/2012,13:17:53.919,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property parser in class com.adobe.agora.commands::ParseProductsTask],value={Injection(type=com.adobe.agora.parser s::ProductParser)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::ParseProductsTask, id = [[Object 32]])]
                                10/11/2012,13:17:53.920,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::SequentialTaskGroupCommand, id = [[Object 30]])] and 1 processor(s)
                                10/11/2012,13:17:53.921,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property context in class com.adobe.agora.commands::SequentialTaskGroupCommand],value={Injection(type=org.spicefact ory.parsley.core.context::Context)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::SequentialTaskGroupCommand, id = [[Object 30]])]
                                10/11/2012,13:17:53.922,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:53.925,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:53.926,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 51]])] and 2 processor(s)
                                10/11/2012,13:17:53.927,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property appPM in class org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup],value={Injection(type= com.adobe.agora.presentation::AppPM)})] to managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 51]])]
                                10/11/2012,13:17:53.927,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 51]])]
                                10/11/2012,13:17:53.928,[DEBUG],org.spicefactory.lib.task.TaskGroup,Adding task: [Task]
                                10/11/2012,13:17:53.929,[INFO],org.spicefactory.lib.task.SequentialTaskGroup,Starting next task: [Task]
                                10/11/2012,13:17:53.931,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object GetProductsMessage]' for command status 'execute' to 1 observer(s)
                                10/11/2012,13:17:54.063,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_HomeView1. _HomeView_VGroup3.VGroup210.FeaturedList212' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:54.064,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views.ui::FeaturedList to cache for [Domain 2]
                                10/11/2012,13:17:54.070,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:54.091,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:54.092,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::FeaturedList, id = [[Object 52]])] and 2 processor(s)
                                10/11/2012,13:17:54.093,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property themePM in class com.adobe.agora.views.ui::FeaturedList],value={Injection(type=com.adobe.agora.presentatio n::ThemePM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::FeaturedList, id = [[Object 52]])]
                                10/11/2012,13:17:54.097,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property pm in class com.adobe.agora.views.ui::FeaturedList],value={Injection(type=com.adobe.agora.presentatio n::HomeViewPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views.ui::FeaturedList, id = [[Object 52]])]
                                10/11/2012,13:17:54.100,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_HomeView1. _HomeView_VGroup3.VGroup210.FeaturedList212' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:54.250,[DEBUG],org.spicefactory.parsley.core.view.handler.ViewConfigurati onHandler,Process view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_HomeView1' with [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:54.251,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.agora.views::HomeView to cache for [Domain 2]
                                10/11/2012,13:17:54.257,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:54.277,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:54.279,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.views::HomeView, id = [[Object 53]])] and 3 processor(s)
                                10/11/2012,13:17:54.284,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property themePM in class com.adobe.agora.views::HomeView],value={Injection(type=com.adobe.agora.presentation::Them ePM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views::HomeView, id = [[Object 53]])]
                                10/11/2012,13:17:54.289,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property pm in class com.adobe.agora.views::HomeView],value={Injection(type=com.adobe.agora.presentation::Home ViewPM)})] to managed object with [ObjectDefinition(type = com.adobe.agora.views::HomeView, id = [[Object 53]])]
                                10/11/2012,13:17:54.294,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property locale in class com.adobe.agora.views::HomeView],value={Injection(type=com.adobe.agora.utils::AppLocale)} )] to managed object with [ObjectDefinition(type = com.adobe.agora.views::HomeView, id = [[Object 53]])]
                                10/11/2012,13:17:54.298,[DEBUG],org.spicefactory.parsley.core.view.processor.DefaultViewPr ocessor,Add view 'com.adobe.exchange.swfLoader.FlexLoader34.instance1119.AgoraPanel0.WindowedApplicationSk in2.Group3.contentGroup.AppView7._AppView_LoadCanvas1._AppView_VGroup1._AppView_HomeView1' to [Context(FlexConfig{ParsleyConfig})]
                                10/11/2012,13:17:54.300,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object TaskGroupMessage]' with 1 receiver(s)
                                10/11/2012,13:17:54.302,[DEBUG],org.spicefactory.lib.reflect.cache.DefaultReflectionCache, Add com.adobe.vulcan::IVulcanMessageDispatcher to cache for [Domain 2]
                                10/11/2012,13:17:54.307,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::CheckExManVersionTask, id = [[Object 26]])] and 1 processor(s)
                                10/11/2012,13:17:54.308,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property service in class com.adobe.agora.commands::CheckExManVersionTask],value={Injection(type=com.adobe.agora.se rvices::Service)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::CheckExManVersionTask, id = [[Object 26]])]
                                10/11/2012,13:17:54.310,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::SequentialTaskGroupCommand, id = [[Object 25]])] and 1 processor(s)
                                10/11/2012,13:17:54.312,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property context in class com.adobe.agora.commands::SequentialTaskGroupCommand],value={Injection(type=org.spicefact ory.parsley.core.context::Context)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::SequentialTaskGroupCommand, id = [[Object 25]])]
                                10/11/2012,13:17:54.313,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:54.314,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:54.314,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 54]])] and 2 processor(s)
                                10/11/2012,13:17:54.315,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property appPM in class org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup],value={Injection(type= com.adobe.agora.presentation::AppPM)})] to managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 54]])]
                                10/11/2012,13:17:54.316,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 54]])]
                                10/11/2012,13:17:54.317,[DEBUG],org.spicefactory.lib.task.TaskGroup,Adding task: [Task]
                                10/11/2012,13:17:54.318,[INFO],org.spicefactory.lib.task.SequentialTaskGroup,Starting next task: [Task]
                                10/11/2012,13:17:54.321,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object TaskGroupMessage]' for command status 'execute' to 1 observer(s)
                                10/11/2012,13:17:54.322,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object LoginMessage]' with 1 receiver(s)
                                10/11/2012,13:17:54.324,[DEBUG],com.adobe.cep.ims.core.IMSInterface,get instance()
                                10/11/2012,13:17:54.325,[DEBUG],com.adobe.cep.ims.core.IMSInterface,IMSInterface()
                                10/11/2012,13:17:54.326,[DEBUG],com.adobe.cep.ims.core.IMSInterface,Creating instance of IMSInterface...
                                10/11/2012,13:17:54.326,[DEBUG],com.adobe.cep.ims.core.IMSInterface,Application has parameters.
                                10/11/2012,13:17:54.326,[DEBUG],com.adobe.cep.ims.core.IMSInterface,extID com.adobe.exchange
                                10/11/2012,13:17:54.328,[INFO],com.adobe.cep.ims.internally.DispatchExternalRequest,initSW FBridge()
                                10/11/2012,13:17:54.328,[INFO],com.adobe.cep.ims.core.IMSInterface,IMSInterface singleton instantiated successfully. IMSInterface is ready to receive commands
                                10/11/2012,13:17:54.329,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::LoginWithIMSTask, id = [[Object 6]])] and 2 processor(s)
                                10/11/2012,13:17:54.334,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property properties in class com.adobe.agora.commands::LoginWithIMSTask],value={Injection(type=com.adobe.agora.model:: Properties)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::LoginWithIMSTask, id = [[Object 6]])]
                                10/11/2012,13:17:54.336,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property imsToken in class com.adobe.agora.commands::LoginWithIMSTask],value={Injection(type=com.adobe.agora.model:: Token)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::LoginWithIMSTask, id = [[Object 6]])]
                                10/11/2012,13:17:54.337,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = com.adobe.agora.commands::SequentialTaskGroupCommand, id = [[Object 5]])] and 1 processor(s)
                                10/11/2012,13:17:54.338,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property context in class com.adobe.agora.commands::SequentialTaskGroupCommand],value={Injection(type=org.spicefact ory.parsley.core.context::Context)})] to managed object with [ObjectDefinition(type = com.adobe.agora.commands::SequentialTaskGroupCommand, id = [[Object 5]])]
                                10/11/2012,13:17:54.344,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: [object ApplicationDomain]
                                10/11/2012,13:17:54.345,[INFO],org.spicefactory.lib.reflect.Converters,Setting processing domain: null
                                10/11/2012,13:17:54.345,[INFO],org.spicefactory.parsley.core.lifecycle.impl.DefaultManaged ObjectHandler,Configure managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 55]])] and 2 processor(s)
                                10/11/2012,13:17:54.346,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [Property(name=[Property appPM in class org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup],value={Injection(type= com.adobe.agora.presentation::AppPM)})] to managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 55]])]
                                10/11/2012,13:17:54.348,[DEBUG],org.spicefactory.parsley.core.lifecycle.impl.DefaultManage dObjectHandler,Applying [MessageDispatcher(property=dispatch)] to managed object with [ObjectDefinition(type = org.spicefactory.lib.task::ProgressDispatchingSequentialTaskGroup, id = [[Object 55]])]
                                10/11/2012,13:17:54.348,[DEBUG],org.spicefactory.lib.task.TaskGroup,Adding task: [Task]
                                10/11/2012,13:17:54.349,[INFO],org.spicefactory.lib.task.SequentialTaskGroup,Starting next task: [Task]
                                10/11/2012,13:17:54.350,[INFO],org.spicefactory.parsley.core.messaging.impl.DefaultMessage Processor,Dispatch message '[object ProgressMessage]' with 1 receiver(s)
                                10/11/2012,13:17:54.353,[INFO],com.adobe.agora.commands.LoginWithIMSTask,Starting login task
                                10/11/2012,13:17:54.355,[DEBUG],com.adobe.cep.ims.internally.DispatchExternalRequest,addEv entListener() is CSXSEvent
                                10/11/2012,13:17:54.360,[DEBUG],com.adobe.cep.ims.internally.DispatchExternalRequest,calli ng IMS connect() for com.adobe.exchange
                                10/11/2012,13:17:54.362,[INFO],com.adobe.cep.ims.command.IMSConnectCommand,Calling IMSConnectCommand.execute() for com.adobe.exchange
                                10/11/2012,13:17:54.364,[INFO],com.adobe.cep.ims.internally.IMSPlugPlug,Acquiring HostObject com.adobe.cep.dom.PlugPlug
                                10/11/2012,13:17:54.365,[INFO],com.adobe.cep.ims.internally.IMSPlugPlug,Calling [imsConnect] with arguments [com.adobe.exchange]
                                10/11/2012,13:17:57.075,[INFO],com.adobe.cep.ims.internally.IMSPlugPlug,Call [imsConnect] returned ["4009808"]
                                10/11/2012,13:17:57.077,[INFO],com.adobe.agora.commands.LoginWithIMSTask,Successfully connected to IMS
                                10/11/2012,13:17:57.078,[INFO],com.adobe.agora.commands.LoginWithIMSTask,Fetching accounts...
                                10/11/2012,13:17:57.082,[DEBUG],com.adobe.cep.ims.internally.DispatchExternalRequest,calli ng IMS fetchAccounts() for com.adobe.exchange
                                10/11/2012,13:17:57.085,[INFO],com.adobe.cep.ims.command.FetchAccountsCommand,Calling FetchAccountsCommand.execute() for com.adobe.exchange
                                10/11/2012,13:17:57.086,[INFO],com.adobe.cep.ims.internally.IMSPlugPlug,Calling [imsFetchAccounts] with arguments [4009808, com.adobe.exchange, Agora]
                                10/11/2012,13:17:57.985,[INFO],com.adobe.cep.ims.internally.IMSPlugPlug,Call [imsFetchAccounts] returned [(Array)#0
                                  [0] 70
                                  [1] ""]
                                10/11/2012,13:17:57.986,[DEBUG],com.adobe.cep.ims.internally.DispatchExternalRequest,Fetch Accounts() returned status 70
                                10/11/2012,13:17:57.987,[ERROR],com.adobe.cep.ims.internally.DispatchExternalRequest,Error status returned from IMS when attempting to fetch accounts
                                10/11/2012,13:17:57.991,[INFO],com.adobe.agora.commands.LoginWithIMSTask,Fetch accounts threw an error. Status: IMS_ERROR_IN_FETCH_USER_ACCOUNTS message:
                                10/11/2012,13:17:57.994,[DEBUG],com.adobe.cep.ims.internally.DispatchExternalRequest,calli ng ShowAAM API for com.adobe.exchange
                                10/11/2012,13:17:58.006,[INFO],com.adobe.cep.ims.command.ShowAAMCommand,Calling ShowAAMCommand.execute() for
                                10/11/2012,13:17:58.008,[INFO],com.adobe.cep.ims.internally.IMSPlugPlug,Calling [invokeAMT] with arguments [com.adobe.exchange, <PlugPlugEnvelope xsi:noNamespaceSchemaLocation="./AmtlibPlugPlug.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
                                  <request id="2" functionName="showAAM">
                                    <arguments>
                                      <CEPData>PENFUEluZm8+CiAgPFNlcnZpY2VDb2RlPkFnb3JhPC9TZXJ2aWNlQ29kZT4KICA8Q2xpZW50U2Vj
                                cmV0PjkwZTVhN2VjLTMwNmYtNDk2ZC1iZTkxLWMyYWYwZTcwZDE1YTwvQ2xpZW50U2VjcmV0Pgog
                                IDxSZWRpcmVjdFVSST5odHRwczovL3d3dy5hZG9iZWV4Y2hhbmdlLmNvbTwvUmVkaXJlY3RVUkk+
                                CiAgPFVzZXJHVUlELz4KICA8U2FvR1VJRC8+CiAgPFNjb3BlPm9wZW5pZCxBZG9iZUlELHNhby5B
                                Z29yYV9VU0VSLGNyZWF0aXZlX2Nsb3VkPC9TY29wZT4KICA8Q2FsbGVySUQ+RDM0QzMzMDItMzBD
                                MC01RTdFLTkwMDktNTBENTI5NkM3Qzk1LmNvbS5hZG9iZS5leGNoYW5nZTwvQ2FsbGVySUQ+CiAg
                                PFZ1bGNhbklELz4KPC9DRVBJbm
                                • 13. Re: exchange problems
                                  jsoccer645 Level 1
                                  here is the text description of the app crash file:
                                  Faulting application name: Photoshop.exe, version: 13.0.1.0, time stamp: 0x5022da52
                                  Faulting module name: amtlib.dll, version: 6.0.0.75, time stamp: 0x4f140972
                                  Exception code: 0xc0000005
                                  Fault offset: 0x0006ee23
                                  Faulting process id: 0x1470
                                  Faulting application start time: 0x01cda7d375482354
                                  Faulting application path: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\Photoshop.exe
                                  Faulting module path: C:\Program Files (x86)\Adobe\Adobe Photoshop CS6\amtlib.dll
                                  Report Id: 9b5f6250-13c7-11e2-82a0-14dae9e8a355
                                  also: 1. they are in the default locations
                                  2. adobe flash professional cs6
                                  3. i installed as administrator
                                  • 14. Re: exchange problems
                                    asankara Level 1
                                    please install the new version of Adobe Exchange 0.9.2 we released yesterday. Let me know if you are still facing any issues.
                                    Once you get the latest panel, please click on "My Stuff" tab to see if you can log in ok.
                                    • 15. Re: exchange problems
                                      jsoccer645 Level 1
                                      it works looking into all the programs; but every time i try to download, or log in (in My Stuff) it does the same thing..
                                      • 16. Re: exchange problems
                                        alwaysadobe
                                        I have almost the same problem. I can see all the plugins in the list  but when I want to purchase or just use the trial version it gives me SIGN IN button and when I click it it gives me a "Sorry, we are unable to log you in" message.
                                        I have the latest Adobe Exchange installed, I tried to create another Adobe ID even - all the same. I removed alll the cookies from Chrome browser I use (if it is any help) and accepted all cookies also.
                                        I would appreciate any help please...
                                        • 17. Re: exchange problems
                                          asankara Level 1
                                          Please try the following and tell me how it goes:
                                          Open "Adobe Application Manager" from your applications. It will list all the Creative Suite software installed on your machine on the left will display your name with a dropdown. Click the dropdown and select "Sign Out". A popup will ask you to provide your credentials. re-enter your username and password and now try accessing Exchange again.
                                          • 18. Re: exchange problems
                                            asankara Level 1
                                            @alwaysadobe, could you also please send us your AdobeExchange log file present here: C:\Users\labuser\AppData\Roaming\Adobe\Exchange\Adobeexchange.log
                                            • 19. Re: exchange problems
                                              asankara Level 1
                                              Could you please try this?
                                              Please close all applications and Repair Disk Permissions on OSX:
                                              1. Open Disk Utility, located at /Applications/Utilities/Disk Utility
                                              2. Select your startup disk on the left of the Disk Utility window
                                              3. Select First Aid from the tabs
                                              4. Click the "Repair Disk Permissions" button
                                              It is always a good idea to run Repair Disk Permissions on OSX after an update, say from 10.8 to 10.8.x.
                                              On Windows you can Run sfc /scannow In the command prompt.
                                              1. Type sfc /scannow and hit Enter.
                                              You could also try and disable any 3rd party firewall, antivirus programs.
