2 Replies Latest reply: Oct 8, 2012 1:32 PM by nikolaig RSS
    2 vars for the same SWF Loader?
    nikolaig Community Member
      I can not figure out how to load different SWF files into the same SWF loader from different sections in my site. I have two sections "sectionA" and "sectionB". SectionB is the one where SWF loader is located.
      I figured out how to load different SWF files from "sectionA".
      I specify the var which I can use for any number of buttons:
      [AS]
      var sourceVar_ProductsPopUps:String;
      [/AS]
      Then I specify a function in each button using this var:
      [AS]
      myButton1.addEventListener(MouseEvent.CLICK, onClick_myButton1PopUp);
      function onClick_myButton1PopUp(event:MouseEvent):void {
                          sourceVar_ProductsPopUps="prdcts_popups/sumix1-popup_tl.swf";
                          gotoAndPlay("sectionB");
      [/AS]
      In sectionB, where SWF loader is located I use this code in SWF loader set up:
      [AS]
      loaderProductPopUps = new SWFLoader(sourceVar_ProductsPopUps,
      [/AS]
      Second step, where I get stuck is this - I want to have a thumb scroller in sectionB with images which act as buttons and reload additional different SWF files into the same SWF loader (so I don't have to constract a separate page for each image loaded)
      I tried to specify the same var in sectionB:
      [AS]
      [/AS]
      But as expected got a conflict in names.
      What can I use for two different vars in the same SWF loader? Is it some kind of if function or there is much more to it?
        • 1. Re: 2 vars for the same SWF Loader?
          Andrei1 Community Member
          What is SWFLoader? Where does this class coming from? Is it Flex SWFLoader?
          • 2. Re: 2 vars for the same SWF Loader?
            Hi, thanks for answering my post.
            SWF loader comes from greensock.com platform
            Just in case here is full code for the loader which I have used:
            var loaderProductPopUps:SWFLoader;
            if (loaderProductPopUps){
            if(loaderProductPopUps.content){
               loaderProductPopUps.unload();
            loaderProductPopUps = new SWFLoader(sourceVar_ProductsPopUps, //the value of sourceVar_ProductsPopUps allows to load mulitple SWFs from the products page.
        estimatedBytes:5000,
        container:holderMovieClip,// more convinient and easier to manage if to place the LoaderMax into an empty mc (holderMovieClip)
        // if not will work as well. Then the line container:holderMovieClip, has to be replaced with container:this,
        // can be any size, can not be scaled as it distorts the content
        onProgress:progressHandler,
        onComplete:completeHandler,
        centerRegistration:true,
        //x:-260, y:-320, //no need for this is if used: centerRegistration:true,
        alpha:1,
        scaleMode:"none",
        //scaleX:0, scaleY:0,
        //vAlign:"top",
        width:540,
        height:730,//scales proportionally but I need to cut off the edges
        crop:true,
        autoPlay:false
            function progressHandler(event:LoaderEvent):void{
                      progressBarPopUp_mc.gradientbar_appLoader_mcPopUp_mc.scaleX = loaderProductPopUps.progress;
            function completeHandler(event:LoaderEvent):void{
                      var loadedImage:ContentDisplay = event.target.content;
                      //TweenMax.to(loadedImage, 1.5, {alpha:1, scaleX:1, scaleY:1});//only need this line if corresponding values are changed in SWF loader constructor
                      TweenMax.to(progressBarPopUp_mc, 1.5, {alpha:0, scaleX:0.25, scaleY:0.25});
            loaderProductPopUps.load();
