1. Re: CS6 (64bit) text rendering problem
Curt Y Oct 8, 2012 7:20 PM (in response to ogunduz)Screen shot looks OK, or am I not picky enough? Have 24 in monitor.
2. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 7:28 PM (in response to Curt Y)It should look like this: http://i.imgur.com/LCJCo.png
3. Re: CS6 (64bit) text rendering problem
Curt Y Oct 8, 2012 7:33 PM (in response to ogunduz)Guess I am blind, put them up on 2 sceens side by side and did not see any difference.
4. Re: CS6 (64bit) text rendering problem
conroy Oct 8, 2012 7:38 PM (in response to ogunduz)1 person found this helpfulThe Ps type is clearly not as heavy as the other example, plus the Ps antialiasing is crap.
The latter can be improved by using gamma 1 blending. The control is in the Advanced section of Edit > Color Settings.
5. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 7:39 PM (in response to Curt Y)Guess you need to zoom in, because the first one looks like a disaster to me.
6. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 7:48 PM (in response to conroy)Blend text colors using Gamma was 1,45. I changed it to 1. Stil same, exactly same crappy rendering
7. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 7:50 PM (in response to ogunduz)I've just upgraded to CS6, but there is no way I can use this. Nightmare.
8. Re: CS6 (64bit) text rendering problem
Curt Y Oct 8, 2012 7:51 PM (in response to ogunduz)Enlarged them to 2.75 inches on F on my screen and they look about the same. Maybe some one else will have a different opinion.
Perhaps loose something on a screen save.
9. Re: CS6 (64bit) text rendering problem
Chris CoxOct 8, 2012 7:53 PM (in response to ogunduz)
1 person found this helpfulSharp would have the best antialiasing.
And that looks like the other sample is at a higher resolution (not seeing pixels, like you do in the PS sample).
10. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 7:59 PM (in response to Chris Cox)I think I've fixed it. Thank you guys
I switched to sharp, and set blending option to 2, way better now.
11. Re: CS6 (64bit) text rendering problem
Noel Carboni Oct 8, 2012 8:25 PM (in response to ogunduz)Chris Cox: Why would text edges blend poorly on one system at gamma 1.0 and require 2.0 to look right, yet on another system look best at 1.0? Sounds like an interaction with something else...
-Noel
13. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 9:02 PM (in response to ogunduz)What worked for me Photoshop: Turning off gamma-blending, and setting anti-aliasing to sharp.
The problem persists in Illustrator and Flash if I break apart text.
14. Re: CS6 (64bit) text rendering problem
There's something wrong if gamma 1.0 and 1.45 look the same, especially if they look "exactly same". They should look different and they do look different on my setup, and 1.0 has best anti-aliasing.
15. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 9:11 PM (in response to conroy)My fault, these two options are not exactly same.
But turning it off and 2,10 are exactly same. So far the best option is turning it off altogether (or 2,10)
16. Re: CS6 (64bit) text rendering problem
conroy Oct 8, 2012 9:16 PM (in response to ogunduz)See my example above. Do you see that, there at least, gamma 1.0 gives far better edges than gamma 2.2?
By the way, disabling the text option results in text using the general RGB blending option, which defaults to 2.2, not 2.1.
17. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 9:18 PM (in response to conroy)In your example, gamma 2.2 is better- gamma 1.0 is crap.
Do I need a calibration or something?
18. Re: CS6 (64bit) text rendering problem
You must be joking!
The images I posted show distinct stair steps on the 2.2 edges. The edges are much smoother at gamma 1.0.
19. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 9:32 PM (in response to conroy)No I'm not, gamma 1.0 text edges are crap. 2.2 is way better
20. Re: CS6 (64bit) text rendering problem
Wade_Zimmerman Oct 8, 2012 9:54 PM (in response to ogunduz)I am pretty good with typography I spent many years doing this a when I started out using computer type, photo type and hot type. I can tell you from personal experience that what you call better and what the next person calls better will only rarely match.
What you are seeing can also be, in these times a question of screen draw and may not be seen the same way on another screen and even if they did appear the same they may not be agreed upon by all parties.
It is like Nikon versus Canon. Tell a Canon user Nikon is sharper and they say no tell Nikon users Canon is sharper and they know better.
The best way though to find out if which rendering is best is to get a match print if printing on press. Honest do not trust what you see on screen.
21. Re: CS6 (64bit) text rendering problem
ogunduz Oct 8, 2012 10:22 PM (in response to Wade_Zimmerman)If I set gamma too low, yes gamma 1.0 version is clearly winner, but with my current configuration/calibration gamma 2.2 is the way to go.
22. Re: CS6 (64bit) text rendering problem
Noel Carboni Oct 9, 2012 6:35 AM (in response to ogunduz)We are obviously seeing different things. To me the gamma 1.0 rendering looks smoothest.
I'm thinking it must be a monitor calibration issue, or some other kind of signal issue.
-Noel
