1 Reply Latest reply on Oct 10, 2012 1:19 PM by Raghu Nagireddy
    Livecycle components
    Priyanka Agarwal Level 1
      We have below requirements. Please anyone can validate that below requirements can be served by Adobe liveCycle Output ES3 module
      1. ALC trigger point – Watch folder and web Service
      2. Mode – Batch ,On Demand (Online)
      3. Input data – xml
      4. Channels – Print, Achieve, Email  and Fax
      5. Output format – PDF ,Excel and Doc
      6. Printer Configuration – Workflow printer ,Non workflow printer
      7. Printing – Local ,Remote ,Bulk printing (local or remote) ,Batch (Scheduled printing)
      8. Return the generated output stream to calling system
      Or suggest which module have to choose for the same.
        • 1. Re: Livecycle components
          Raghu Nagireddy Level 3
          Step 1 Its LiveCycle(LC)/Workbench capabilities, not from output service (Watch Folder is one of the start point, Webservice is from LC Foundation).
          Step 2 done by LC or it will perform/Run by java or any?
          Step 3 Its just xml can be produced in one of the way and to view Form Template(PDF/XDP) required here
          Step 4 Is this used to send the o/p? if so can be configured using LC (Ex: email is from LC Foundation) not from output service. Its based on the compatability what system using to Archive (ex: Filenet, Content Manager) and Fax.
          Step 5 only as PDF, To convert as Doc it requires "LC PDF Generator" module, not sure about Excel
          Step 6 can be configured in Output Service operations
          Step 7 Thats printer capabilities configured in Step 6
          Step 8 Output Service returns o/p, end system has to handle this.
          Hope this helps.
