1 Reply Latest reply on Feb 29, 2008 4:13 AM by peterent
    NEWBIE: Flex/AIR and databses
    TimDixon
      Hi all,
      I'm a Director(lingo) user and use flash with actionscript for UI in app.
      I'm now playing with Flex3 to see how it compares etc.
      OK, one of the things I think i'm getting confused with and need some clarity (in not too technical terms!), is the ability to connect to a database online(with flex) and offline(with AIR).
      For example, if I have a simple database with 'name', 'age' and 'sex', with Director I could use a simple ADO Xtra to connect to the database and add/ammend the records. - In this example, Director would be running as an .exe on the users PC with the database either local or on a network. The database could be a simple mdb (access) or sql etc.
      So, is it possible to have an AIR application connecting to a local database? and does that database have to be a specificv type? or can it be an mdb? If so, how is this implemented?
      When it's web based with flex, am i right in thinking that flex does not actually connect to a database, but instead uses a 'third party' such as php, asp etc to do this?
      As you can see, im confused!! Can someone explain in simple terms?
      Thanks everyone,
      Tim
