3 Replies Latest reply on Oct 9, 2012 7:58 PM by bluzdawg
    Audio mix different on DVD than on computer
    bluzdawg Level 1
      On playback, i have unexpected audio mix results when i play the DVD on different players.  At points, the music comes out way
      louder than on the original mix, or the dialog drops down way too low.   It may be simply the difference in acoustics
      in 3 different rooms (?)  The same DVD played on my computer sounds exactly the same as mixed.
      It's a simple mix of video dialog on Audio 1 and a single music soundtrack on Audio 2.   All of the mixing was done on the Audio mixer
      for the entire sequence,  using "Touch" as the automation mode.
      Quite possible  I'm not understanding HOW to mix properly.  (Rookie here).    I can see the  keyframes on both tracks in the sequence
      BUT the master track shows none, since i didn't directly manipulate the Master fader at any point,  assuming that the mix i was sending
      to the Master track would come out sounding just as i heard it when mixing.   I had been advised to keep the total volume level down
      to -12db, and basically did that all the way through.   This is a 30 minute movie,  and about half has music soundtrack under the dialog,
      or replaces the dialog.    My computer has a Logitech 5.1 system, and the default is "simulated surround" (front is duplicated in rear),
      in a small carpeted office.  The DVD player is in a much larger room, with a basic stereo setup,.  and the 3rd room is a cable tv office
      where we were observing the same audio discrepancy.     Do I need to "normalize" my master track?  Or apply a compressor or
      limiter of some sort?
