Hope someone can help.
We would like to have a help file with mini-TOCs, like an FAQ page.
However we would also like to have an external webpage access these sections.
The HTML produced for each link reads
/Help.htm#MiniTOCBookMark1
/Help.htm#MiniTOCBookMark2
/Help.htm#MiniTOCBookMark3
when you click on these links it jumps to that section.
Does anyone know how I can change the code MiniTOCBookMark1 to something I set?
For example, I would like each of the links to be;
/Help.htm#Surname
/Help.htm#Forname
/Help.htm#Date_of_birth
This may be a strange request, but there is a very good reason I would like to do this. Basically if there is a way in RH to set my own mini-Toc codes that would be great.
Hi there
The mini-TOC codes are programmed into RoboHelp and I doubt they can be changed. But there is nothing preventing you from manually inserting bookmarks using the names you desire. Then you link to the bookmarks.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
Hi Rick,
That's great, thanks. Having looked at this, it's Bookmarks we need to use, and works as required.
Andrew
