4 Replies Latest reply on Oct 11, 2012 3:50 AM by Bill joy
    Rectangle text Content problem
    Bill joy
      Hi All,
      I want to insert text in rectangle.
      After setting ContentType "Text" How insert text in rectangle?
      I am not  found content method for rectangle like TextFrame.content="indesign";
      var myDocument = app.documents.add();
      var myRectangle = myDocument.pages.item(0).rectangles.add();
      myRectangle.geometricBounds = ["70p", "20p", "40p", "40p"];
      myRectangle.contentType=(1952412773);//for text 1952412773,
      //myRectangle.place(File("/C/version.jpg")); //for place image
      How add text in rectangle ?
      Thanks in advance
        • 1. Re: Rectangle text Content problem
          TᴀW Adobe Community Professional & MVP
          I haven't tested what I'm about to say, but my gut instinct is that when
          you set the rectangle contentType to text, it turns into a textFrame.
          Then when you place a file, perhaps it turns back into a rectangle?
          At any rate, you can't "place" an image into a text frame, and you can't
          have text in a rectangle.
          Hope that points you in the right direction.
          Ariel
          • 2. Re: Rectangle text Content problem
            Bill joy Level 1
            Thanks for Reply
            I try this
            var myTextFrame=myRectangle.contentType=(1952412773);
            myTextFrame.content="Indesign";
            Script run sucessfully with answer  Execution finished. Result : Indesign
            But text "Indesign" is not written in Rectangle.
            Thanks.
            • 3. Re: Rectangle text Content problem
              Jump_Over Level 5
              To create a rectangle, change its content type and place text into - it is not a shortest way;
              you can do it easier by creating a textFrame instead of rectangle;
              but if it is your way from some reason:
              you have to resolve rectangle after changing content type to let InDesign know about this change.
              So it should be like this:
              myRectangle.contentType = ContentType.TEXT_TYPE;
              var myTextFrame = resolve(myRectangle.toSpecifier());
              myTextFrame.contents = "InDesign";
              hope...
              • 4. Re: Rectangle text Content problem
                Bill joy Level 1
                Thanks Jump_Over
                Its work sucessfully.
