3 Replies Latest reply on Oct 10, 2012 11:41 PM by vinoth_mannu
    Folder name as to be file name
    vinoth_mannu Level 1
      Hi All,
      The below script saves the files but if we have multiple files the files are not saved.
      #target photoshop
      inputFolder = Folder.selectDialog("Select a folder contains '*.tif' files ");
      //var inputFolder = Folder ( 'D:/Work/In/');
      //var outputFolder = Folder( ['D:/Work/out/'] );
      if (inputFolder != null){
      fileType = ( '*.tif' );
      var fileList = inputFolder.getFiles(fileType);
      //$.writeln(fileList);fileList
          if(fileList.length == 0 )
                  alert ("No files found in the folder", "test", "errorIcon")
          else
              for (var i = 0; i < fileList.length; i++)
                      if (fileList[i] instanceof File && fileList[i].hidden == false)
              var TiffOptions = new TiffSaveOptions()
                          TiffOptions.imageCompression = TIFFEncoding.TIFFLZW
                          TiffOptions.embedColorProfile = false
                      var docRef = open( fileList[i] )
                      app.preferences.rulerUnits = Units.PICAS
                      docRef.flatten()
                      docRef.resizeImage (null, null, 600)
                      var Wid = docRef.width;
                      var Hig = docRef.height;
                      if (Number(Wid) > 30)
                               docRef.resizeImage(29,null);
                      else if(Number(Hig) > 50)
                              docRef.resizeImage(null,50);
                      //$.writeln(Wid);Wid
                      //$.writeln(Hig);Hig
                    var newName = removeExtension(inputFolder.name);
                    $.writeln(newName);newName
      for(a=1; a<12; a++){
          docRef.saveAs(new File(inputFolder+"/"+newName+'_f00'+a+".tif"), TiffOptions, true, Extension.LOWERCASE)
          docRef.close(SaveOptions.DONOTSAVECHANGES)
      //var newcmd = fileList[i].remove()
              alert ("Process completed", "test")
      function removeExtension(myDoc)
          var str = myDoc.split(".tif");
          var ext = str[0]
          return ext;
      function removeExt(myDoc)
          var str = myDoc.split(".");
          var ext = str[1]
          return ext;
      function removebit(myDoc)
          var ext = str[1]
          return ext;
      Please help me in solving this issue.
        • 1. Re: Folder name as to be file name
          c.pfaffenbichler Level 9
          I haven’t tested it but at a cursory glance I suspect you are wrong and the files are being saved, but as per
          you are using the same name, so they get overwritten.
          Edit: Well, I stand corrected.
          • 2. Re: Folder name as to be file name
            Look like you have a for loop to save 11 copies of the document but you close the document after the first save so the second save should fail for there is no open document to save.
            #target photoshop
                else
                            docRef.flatten()
            //for(a=1; a<12; a++){
                var a = i +1;
                var ext = str[0]
                return ext;
                var ext = str[1]
                return ext;
                var ext = str[1]
                return ext;
            • 3. Re: Folder name as to be file name
              Excellent
              That worked perfect
              Thanks Mack
