4 Replies Latest reply on Oct 10, 2012 12:30 PM by Fuzzy Barsik
    Replace Clip with AE Comp
    mythster Level 1
      I have a clip in Premiere that is in a timeline and has some time remapping effects on it.
      I took the original quicktime file into a comp in After Effects and applied some motion tracking to it to fix a visual aspect of it. I didn't change the time of the clip or anything.
      Now I would like to replace the clip in the Premiere timeline with the active AE comp, but I'd like to retain the time remapping and the cuts that are in premiere. Is there a way to replace the clip with this live AE composition?
        • 1. Re: Replace Clip with AE Comp
          Jim_Simon Level 9
          You might try Replace with Clip From Bin, but I've never done that with effects applied, so I don't know if they'll carry over.
          • 2. Re: Replace Clip with AE Comp
            NilsW
            import your AE-comp and drag it on the original clip in your sequence with pessing the alt-key...
            • 3. Re: Replace Clip with AE Comp
              mythster Level 1
              That is a good answer, the only thing it didn't do was find the proper in and out points. The inpoint of the clip in my Premiere timeline was just the inpoint of the AE clip, the clip length stayed the same but it just slipped everything to the beginning of the clip. I can probably work with that, but is there a way for it to retain the original in and out point?
              • 4. Re: Replace Clip with AE Comp
                Fuzzy Barsik Level 4
                You have two options here:
                1. Open up your dynamically linked composition in the Source monitor, place the CTI to a correct In point (if you're not sure where it is, select the clip in the Timeline you want to replace and use either Info panel or, if you are on CS6, the Timecode panel), then with the clip on the Timeline selected right-click and choose Replace With Clip -> From Source Monitor, Match Frame.
                2. After Alt/Opt + drag & drop dynamically linked comp from the Project panel use Slip Tool to correct the shift.
