4 Replies Latest reply: Oct 26, 2012 8:44 AM by curiousaaron RSS
    symbolItem.exportToPNGSequence()
    community help Community Member
      This question was posted in response to the following article: http://help.adobe.com/en_US/flash/cs/extend/WSd5f4b6c52cfaa4b16a883d5c135312fa05c-8000.htm l
        • 1. Re:  symbolItem.exportToPNGSequence()
          morieris Community Member
          there's a typo in the example, it should read "items" instead of "item":
          fl.getDocumentDOM().library.items[0].exportToPNGSequence("file:///c|/tests/mytest.png");
          Also the export seems to fail on 1-pixel tall symbols.  I have tested this by making a new .fla with a single symbol, drawing a rect, and setting it's height or width to 1 pixel.  The export fails with the error:
          The bitmap is too large. The largest bitmap that can be created is 8000x8000 pixels.
          The following JavaScript error(s) occurred:
          At line 1 of file "test.jsfl":
          Error creating PNG sequence.
          There seems to be no way to catch this via try/catch, which would be nice.  Also a more descriptive error message would be helpful.
          • 2. Re:  symbolItem.exportToPNGSequence()
            jrunrandy Employee Hosts
            @morieris,
            Thanks for the tip. I have fixed the example and the updated page should be live in a few minutes.
            I will contact Development regarding the 1-pixel high symbols.
            Regards,
            Randy Nielsen
            Senior Content and Community Manager
            Adobe
            • 3. Re:  symbolItem.exportToPNGSequence()
              sudeshna sarkar Employee Hosts
              Hi Morieris ,
              In Flash , we allow exporting of any image greater than 1 pixel(either height or width) and less than 8000 pixels(again either height or width) using the exportToPNGSequence jsfl api. For anything that falls outside this range , we show a error message dialog. However , the dialog is not so intuitive in cases where the image width or height is less than 1 pixel. The workaround for this problem is to export a symbol of size greater than 1x1.
              Thanks and Regards,
              Sudeshna Sarkar
              Adobe Flash Professional Team.
              • 4. Re:  symbolItem.exportToPNGSequence()
                curiousaaron Community Member
                I'm getting this same error with symbols that are well within those size limitations using both of these methods:       document.exportInstanceToPNGSequence()      document.exportPNG()  Any suggestions?
