1. Re: Flash player wont update on Mac 10.5.8
VikramGaur Oct 11, 2012 7:57 AM (in response to kitgrill)Hello,
Did you try a clean install ?
Uninstall for MAC available here :
http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-mac-os.html
Offline installer for MAC : http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-mac.html
Vikram
2. Re: Flash player wont update on Mac 10.5.8
Sunil_Bhaskaran Oct 11, 2012 11:39 PM (in response to VikramGaur)Hi,
Ideally you should have Flash Player plug-in in the Library/Internet Plugins folder after a successful installation. I doubt you are just downloading Flash Player, but not really installing it. After the download, you need to double-click the file you downloaded and should follow the prompts. The following link has step-by-step info: http://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-mac.html#main-pa rs_heading_5
Could you please confirm if you did that?
Sunil
3. Re: Flash player wont update on Mac 10.5.8
hailthegoer Oct 17, 2012 9:51 AM (in response to Sunil_Bhaskaran)I have the exact same problem as kitgrill and have followed those steps exactly. Flash Player will still not install or update. I have tried uninstalling and installing as well.
4. Re: Flash player wont update on Mac 10.5.8
thebec88 Oct 18, 2012 12:59 PM (in response to hailthegoer)I have also tried all of that numerous times... and It. Will. Not. Work. Beyond frustrated, here. Please advise and thank you!
5. Re: Flash player wont update on Mac 10.5.8
Chris Campbell Oct 18, 2012 5:54 PM (in response to thebec88)Can you please try the steps outlined here to make sure we're starting with a clean system:
How do I do a clean install of Flash Player?
Then install this version of Flash Player:
Chris
6. Re: Flash player wont update on Mac 10.5.8
qwertykiller Oct 18, 2012 8:03 PM (in response to Chris Campbell)I am having the same problem.
Chris,
I followed your directions but the problem is not resolved. The message is given that my Shockwave Flash is up to date (version 10.3.183.29) but when I go to watch something (regardless of firefox/chrome/safari) it says that it requires an update.
Paul
7. Re: Flash player wont update on Mac 10.5.8
VikramGaur Oct 19, 2012 6:52 AM (in response to qwertykiller)Hello Paul,
Could you upload a screenshot of that prompt ?
Also have you tried a different user account on your MAC (As a testing).
Vikram
8. Re: Flash player wont update on Mac 10.5.8
thebec88 Oct 19, 2012 2:46 PM (in response to VikramGaur)Have found out why we're not able to update to 11. Need at least 10.6 now, since Adobe is no longer dealing with older than that. Not fair, in my opinion. Guess I'll be forced to upgrade.
9. Re: Flash player wont update on Mac 10.5.8
UntoCae Oct 23, 2012 9:18 AM (in response to thebec88)yeah but i think its rediculous to just assume all of your 10.5 customers can and will be able to upgrade. it's quite expensive and not everyone is economically able to purchase an upgrade just so they can use flash player
10. Re: Flash player wont update on Mac 10.5.8
VikramGaur Oct 23, 2012 10:46 AM (in response to UntoCae)Hello,
Users who are using MAC 10.5 or below, then you can Flash Player 10.3
You can download Flash Player 10.3.189.29 from this document : http://helpx.adobe.com/flash-player/kb/archived-flash-player-versions.html
Note : You will get a .zip file and once it is extracted you need to double click on the .dmg file (flashplayer10_3r183_29_mac.dmg)
Vikram
11. Re: Flash player wont update on Mac 10.5.8
thebec88 Oct 24, 2012 12:34 PM (in response to VikramGaur)Yes, we know can only have 10.3 - and most sites are now 11+!!! Do you not see the problem, here? Without an upgrade for OSX, you've effectively blocked a whole lotta people from using Flash - and I for one, am highly annoyed at Adobe for this decision to not support my OS. Since there's not a whole lot of choice in the matter, I will have to upgrade; but I will not forget.
12. Re: Flash player wont update on Mac 10.5.8
kitgrill Nov 16, 2012 3:05 AM (in response to thebec88)think i found the answer, go to
right click on adobe flash manager application> get info > click open with rosetta
should work fine
fingers crossed!
13. Re: Flash player wont update on Mac 10.5.8
oscar Baquedano Sep 25, 2014 10:40 PM (in response to kitgrill)de igual forma no puedo ver videos mac os x 10.5.8 no puedo instalar nigun plugin
flash player.... alguien puede ayudar
14. Re: Flash player wont update on Mac 10.5.8
m_vargas Sep 26, 2014 11:30 AM (in response to oscar Baquedano)Hello Oscar,
Please see Vikam's post on Oct 23, 2012. Flash Player 10.3.189.29 is the last version supported on OS X 10.5.8. In order to install a newer version of Flash Player, you'll need to update to a newer version of OS X.
Maria
