11 Replies Latest reply on Oct 19, 2012 12:43 PM by brian.e.
    Script to work around Illustrator bugs
    brian.e.
      Newbee here,   We are working in Illustrator CS5.  I have put together some scripts & Actions to automate several parts of our work.
           I'll start with what we have now.  Plus what we have now works on both Mac & PC & if there is a way to work around these BUGS it will need to work on both the Mac's & PC's.
      1)  We have an .ai file (our default format) that we can open up & inside some text will automatically fill in when we run a script. (see custom script at bottom) Some text boxes will fill in the date based on the present date on our computer, some text boxes will fill in a name based on the name of the electronic .ai file.
      See red boxes.
      One difficulty that I worked out is, sometimes in one of the fields in the file, it needs to have a name consisting of only 4 sections (or 3 dashes). In example:  ILSLIM = 1,  EXAMPLE = 2, TEST = 3, & AA01 = 4.
      So when this happens then the last dash in this one text box on our format (Not any of the other text boxes) will need the 3rd dash removed (now it is only 3 sections because TESTAA01 are now one).
      So I created an Illustrator "Action" that will after the "ChangeFileNameDate" script is run, the "Action" will select the one text box & then run the "Find and Replace" to delete the 3rd dash as seen above.
      NOW THE PROBLEMS!  (Illustrator bugs)
      1)  In the Illustrator "Actions" when you record an "Action" & use the "Insert Menu Item..." to put a Script in, it will work.  BUT when you quit out of Illustrator & then relaunch it the custom Script will disappear. I looked into this & this is a known bug for years in Illustrator that is still not fixed.
      http://js4ai.blogspot.com/2012/03/how-to-permanently-tie-script-to-action.html
      Works untill you quit out & relaunch.
      BEFORE QUIT.
      AFTER RELAUNCH.
      SO the only work around I can get to work for now is to "Insert Menu Item..." "Other Script..." & this will stay even after relaunch BUT then every time we run the "Action" we have to manually select the script. (CRAP)
      Still here after relaunch.
      PLUS A BUG with recording the "Find and Replace".  In case you do not know, when you save "Actions" in Illustrator you can; save any of the actions that require a dialog box; 1) to either have the dialog box come up so you can enter whatever you need into it or 2) you can have the dialog box NOT come up & the action will just do what it had in it when you recorded it.  This feature is turned on or off by clicking the box next to the check mark on or off (see pic).
      So the BUG is, for my "Actions" that use the "Find and Replace" to delete the dash to work for some reason I have to have the first "Find and Replace" steps dialog botton ON so that the "Find and Replace" dialog box will open up.
           Let me explain, when you record to use the "Find and Replace" it will work fine even with the dialog box option clicked off; but if you quit Illustrator & then relaunch it & try to run the "Actions" that have the "Find and Replace" in them then Illustrator will crash.  So the only work around that I found for this CRAPPY BUG is to simply have the 1st "Find and Replace" in the recorded "Action" with the dialog box set to on (to open up when Action is run) & then we have to manually close it.  We don't have to type anything inside of it.  We simply have to have it open & then close.  Then for some reason the rest of the recorded "Actions" will run with out the dialog boxes opening with the deleteing of the 3rd dash as like when I 1st recorded it.
           So basically, if I want the "Actions" to work at this point I would have to do this;  every time I relaunch Illustrator I would need to manually load the custom script into the "Actions" & I would need to open & close the "Find and Replace" box.  This is CRAP the whole point of "Actions" & Scripts are so I can do everything MANUALLY, NO.  We should be able to have it work for us!
      OR maybe this would be the best solution!
           If inside the "ChangeFileNameDate" custom script it could simply open & then close the "Find and Replace" box (that would solve the crashing with "Find and Replace" in "actions")  then the custom script could cause the "Action" to play instead of the "Action" causing the custom script to play.  Then all we would have to do is drag down to the custom script from "File" & run that.  No crashing, No babysitting.
      DOES ANYONE KNOW HOW OR IF THIS IS POSSIBLE?  To add to the attached script:
      1)  At the beginning to open & close the "Find and Replace" box.
      2)  At the end to cause a saved "action" to run.
      WE WOULD BE SO VERY, INCREDIBLY, EXTREMELY GRATEFUL!
      //////////////////////////////////////////////////////////// english //
      // -=> WR-DateAndTime <=-
      // A Javascript for Adobe Illustrator
      // by Wolfgang Reszel (ai-js@rumborak.de)
      // Version 0.9 from 22.9.2011
      // This script inserts the actual date or the actual time to a
      // predefined position in the document.
      // To define the position, you'll have to create an textobject and
      // execute this script while the object is selected. The whole object
      // has to be selected and not words or letters. You can mark more
      // objects, if you select each object separate and execute
      // the script on it.
      // With the placeholders {DATE} and {TIME} you are able to define a
      // particular point, where the date or the time should be replaced.
      // If there is no placeholder in the textobject
      // "{FILENAME}{FILEEXT} ({DATE}, {TIME})" will be used as standard placeholders.
      // To update the date and time execute this script without any object
      // selected.
      // There are some additional placeholders:
      //   {FILE}     - complete document-filename with path
      //   {FILEPATH} - only the documents filepath
      //   {FILENAME} - the filename of the document
      //   {FILEEXT}  - the file extension of the document inclusive dot
      // On my system this script can't see the path of the document, when
      // it was opened directly from windows Explorer (double click).
      // In Illustrator CS it is now possible to edit a DateAndTime-Object.
      // To enable the english messages and date-format change the "de"
      // into "en" in line 90.
      // Sorry for my bad english. For any corrections send an email to:
      // ai-js@rumborak.de
      //////////////////////////////////////////////////////////// Deutsch //
      // Ein Javascript fuer Adobe Illustrator
      // von Wolfgang Reszel (ai-js@rumborak.de)
      // Version 0.9 vom 30.9.2011
      // Dieses Skript fuegt das aktuelle Datum und die aktuelle Uhrzeit an
      // eine vorher bestimmte Stelle im Dokument ein.
      // Um eine Stelle zu bestimmen, muss man ein Textobjekt erzeugen, es
      // markieren und dann dieses Skript aufrufen. Es muss das gesamte Objekt
      // ausgewaehlt sein, nicht etwa Buchstaben oder Woerter. Es lassen sich
      // nacheinander auch mehrere Objekte als Datum/Uhrzeit markieren.
      // Mit den Platzhaltern {DATE} und {TIME} (in geschweiften Klammern)
      // kann man bestimmen, wo genau im Text das Datum und die Uhrzeit
      // erscheinen soll. Sind die Platzhalter nicht vorhanden, wird
      // automatisch "{FILENAME}{FILEEXT} ({DATE} - {TIME})" verwendet.
      // Zum Aktualisieren des Datums/Uhrzeit muss man dieses Skript aufrufen
      // wenn kein Objekt ausgewaehlt ist.
      // Es gibt noch einige zusaetzliche Platzhalter:
      //   {FILE}     - kompletter Dateiname mit Pfad
      //   {FILEPATH} - nur der Verzeichnispfad des Dokuments
      //   {FILENAME} - der Dateiname des Dokuments
      //   {FILEEXT}  - die Dateiendung des Dokuments inklusive Punkt
      // Auf meinem System kann der Pfad nicht ermittelt werden, wenn das
      // Dokument vom Windows Explorer geoeffnet wird (Doppel-Klick).
      // InÿIllustrator CSÿkann man nun ein Datum/Uhrzeit-Objekt bearbeiten.
      // Um dieses Skript mit deutschen Meldungen und Datumsformat zu
      // versehen, muss in Zeile 90 das "en" durch ein "de" ersetzt werden.
      // Verbesserungsvorschlaege an: ai-js@rumborak.de
      //$.bp();
      var language="en";   // "de" fuer Deutsch
      var WR="WR-DateAndTime v0.9\n\n";
      var AIversion=version.slice(0,2);
      if (language == "de") {
        var format_preset = "{FILENAME}{FILEEXT} ({DATE} - {TIME})";
        var MSG_unsetmark = WR+"Dieses Objekt ist als aktuelles Datum/Uhrzeit markiert, soll die Markierung aufgehoben werden?";
        var MSG_setmark = WR+"Soll dieses Textobjekt als aktuelles Datum/Uhrzeit markiert werden?";
        var MSG_askformat = WR+"Soll das Textobjekt als Datum/Uhrzeit formatiert werden? Formate:\n{DATE}, {TIME}, {FILE}, {FILEPATH}, {FILENAME} und {FILEEXT}:"
        var MSG_editformat = WR+"Datums-/Uhrzeitformat bearbeiten (Leer = entfernen). Formate:\n{DATE}, {TIME}, {FILE}, {FILEPATH}, {FILENAME} und {FILEEXT}:"
        var MSG_notexto = WR+"Kein Textobjekt!";
        var MSG_selectedmany = "Zum Markieren als aktuelles Datum/Uhrzeit darf nur ein Textobjekt ausgew\xE4hlt sein und falls Sie die Daten aktualisieren wollen, darf kein Objekt ausgew\xE4hlt sein.";
        var MSG_nodocs = WR+"Kein Dokument ge\xF6ffnet."
        var Timeformat = 24;
        var TimeSep = ":";
        var AM = " am";
        var PM = " pm";
        var Dateformat = "dd.mm.yyyy";
      } else {
        var format_preset = "{FILENAME} ({DATE}, {TIME})";
        var MSG_unsetmark = WR+"This object is marked as actual date'n'time, do you want to remove the mark?";
        var MSG_setmark = WR+"Do you want to mark the selected textobject as actual date'n'time?";
        var MSG_askformat = WR+"Do you want to mark the textobject as actual date'n'time? Formats:\n{DATE}, {TIME}, {FILE}, {FILEPATH}, {FILENAME} and {FILEEXT}:"
        var MSG_editformat = WR+"Edit date'n'time (empty = remove). Formats:\n{DATE}, {TIME}, {FILE}, {FILEPATH}, {FILENAME} and {FILEEXT}:"
        var MSG_notexto = WR+"No textobject!";
        var MSG_selectedmany = "To mark as actual date'n'time, you have to select only one textobject. If you want to update the date'n'time-objects, there must be no object selected.";
        var MSG_nodocs = WR+"You have no open document."
        var Timeformat = 12;
        var TimeSep = ":";
        var AM = " am";
        var PM = " pm";
        var Dateformat = "yyyymmdd";
      var error=0;
      if (documents.length<1) {
        error++;
        alert(MSG_nodocs)
      if (error < 1) {
        date_n_time();
      function TodayDate()
        var Today = new Date();
        var Day = Today.getDate();
        var Month = Today.getMonth() + 1;
        var Year = Today.getYear();
        var PreMon = ((Month < 10) ? "0" : "");
        var PreDay = ((Day < 10) ? "0" : "");
        if(Year < 999) Year += 1900;
       var theDate = Dateformat.replace(/dd/,PreDay+Day);
       theDate = theDate.replace(/mm/,PreMon+Month);
       theDate = theDate.replace(/d/,Day);
       theDate = theDate.replace(/m/,Month);
       theDate = theDate.replace(/yyyy/,Year);
       theDate = theDate.replace(/yy/,Year.toString().substr(2,2));
       return theDate;
      function TodayTime()
        var Hours = Today.getHours();
        var Minutes = Today.getMinutes();
        var Suffix = "";
        if (Timeformat == 12) {
          if (Hours >= 12 ) {
       Suffix = PM;
       } else {
       Suffix = AM;
       if (Hours >= 13) {
       Hours = Hours - 12;
       if (Hours < 1) {
       Hours = Hours + 12;
        var PreHour = ((Hours < 10) ? "0" : "");
        var PreMin = ((Minutes < 10) ? "0" : "");
        return PreHour+Hours+TimeSep+PreMin+Minutes+Suffix;
      function DateUpdate(Name) {
        var docpath = activeDocument.path.fsName;
        var docname = activeDocument.name.replace(/(.*?)(?:\.([^.]+))?$/,'$1');
        var extension = activeDocument.name.replace(/(.*?)(?:(\.[^.]+))?$/,'$2');
        if (docpath.slice(2,3) == "\\") {
          docsep = "\\";
        } else {
          docsep = ":";
        var content = Name.slice(11);
        var content = content.replace(/\{FILE\}/,docpath+docsep+docname);
        var content = content.replace(/\{FILEPATH\}/,docpath);
        var content = content.replace(/\{FILENAME\}/,docname);
        var content = content.replace(/\{FILEEXT\}/,extension);
        var content = content.replace(/\{DATE\}/,TodayDate());
        var content = content.replace(/\{TIME\}/,TodayTime());
        return content;
      function date_n_time()
        if (selection.length == 1) {
          if (selection[0].typename == "TextArtItem" || selection[0].typename == "TextFrame") {
            if (selection[0].name.slice(0,11) == "actualDate:") {
              dateformat = selection[0].name.slice(11);
              Check = false;
              if (AIversion == "10") {
                Check = confirm( MSG_unsetmark );
              } else {
                dateformat = prompt(MSG_editformat, dateformat);
              if(dateformat != "" && Check) {
                selection[0].contents = selection[0].name.slice(11);
                selection[0].name="";
                selection[0].selected = false;
              if(dateformat == "" && !Check) {
              if(dateformat && dateformat !="" && !Check) {
                selection[0].name="actualDate:"+dateformat;
                selection[0].contents = DateUpdate(selection[0].name);
            } else {
              dateformat = selection[0].contents;
              if(dateformat.search(/\{DATE\}/) == -1 && dateformat.search(/\{TIME\}/) == -1 && dateformat.search(/\{FILE[A-Z]*\}/) == -1) dateformat = format_preset;
              Check = false;
                Check = confirm( MSG_setmark );
              } else {
                dateformat = prompt(MSG_askformat, dateformat);
              if (dateformat || Check) {
          } else {
            alert ( MSG_notexto );
        } else if (selection.length > 1) {
          alert ( MSG_selectedmany );
        } else {
            var textArtItems = activeDocument.textArtItems;
            for (var i = 0 ; i < textArtItems.length; i++)
              if (textArtItems[i].name.slice(0,11) == "actualDate:") {
                textArtItems[i].selected = true;
                textArtItems[i].contents = DateUpdate(textArtItems[i].name);
          } else {
            var textFrames = activeDocument.textFrames;
            for (var i = 0 ; i < textFrames.length; i++)
              if (textFrames[i].name.slice(0,11) == "actualDate:") {
                textFrames[i].selected = true;
                textFrames[i].contents = DateUpdate(textFrames[i].name);
        • 1. Re: Script to work around Illustrator bugs
          CarlosCanto Adobe Community Professional & MVP
          Hi brian, it is unfortunate that these bugs haven't been fixed in eons, and will probably never get fixed...
          ...you don't need to double-post, but good to see you started a new thread for this, please see your other post
          http://forums.adobe.com/message/4754974?tstart=0#4754974
          • 2. Re: Script to work around Illustrator bugs
            brian.e. Level 1
            Thanks for your response, the other post was a start but I thought it would be better to explain it all.  So I think this may be a better post to work on all these issues.
            Your response was only for a PC.  I was hoping & thinking that there may be a way to have one script to open & close the "Find and Replace" on both Mac & PC.  Otherwise our crappy babysitting method is going to have to due for now.  It seems like a simple thing, but I have come to find out that so many things that should be simple in the scripting world are not.  But I will not lose HOPE!
            • 3. Re: Script to work around Illustrator bugs
              brian.e. Level 1
              Carlos or anyone,  I've been working on several ideas & think that I have come up with the best approach to work around these bugs.  But need it to work in java script.
              1)  In AppleSript I can build a script that will trigger an "Action" to run.  The "Action" will select an object by its "Attributes" "Note".  The selected text box in picture is called "UPPER FORDDOC NAME" so it will select this object only.
              activate application "Adobe Illustrator"
              on doAction(scriptName, actionSet)
                        tell application "Adobe Illustrator"
                do script scriptName from actionSet
                        end tell
              end doAction
                        tell me to doAction("Save Part # Delete -", "TIC Color 03-13-12")
              end tell
              Can this be done in Java?
              If so then:
              2)  I built an AppleScript that can open the "Find and Replace" then simply close it; by using "System Events" to select the keystrokes.
              Is this possible to do in Java with out buying an extra program?  This AppleScript works great but need it to work also on the PC's.
              tell application "System Events"
                tell process "Adobe Illustrator"
                --This is the quick key to open the "Find and Replace" window
                keystroke "K" using {command down, shift down, option down}
                delay 1
                --This is the esc key
                key code 53
                end tell
              end tell
              I HOPE SO ssssssssoooooooo MUCH!
              • 4. Re: Script to work around Illustrator bugs
                was that a typo or you meant to say "java"? if so, I don't know, I don't do Java.
                javascript can't run actions, at least up to CS5, so now you have a working AS and similar VBscript I posted in your other post...you could run these files from JS, here's a sample
                http://forums.adobe.com/message/3889892#3889892
                you'll need to test if "sendkeys" still work when called this way.
                • 5. Re: Script to work around Illustrator bugs
                  brian.e. Level 1
                  You are right I mean JavaScript, sorry.  Thank you for the link, not sure I want to go this route.
                  How about this, is it possible to select a certain text box inside Illustrator some how using JavaScript.
                  The 1 text box does have a unique "Attributes" "Note" called "UPPER FORDDOC NAME" or maybe there is some other way to single it out.  We already have thousands of this format so it would have to be able to select this text box in all the pre-worked formats.
                  If this is possible then maybe I can figure out this regular expression,
                  echo "abc-def-ghi-jkl.ai" | sed "s/\(.*-.*-.*\)-\(.*\)/\1\2/"
                  So then it can check the selected text box & if it has only 2 dashes in it it will not do anything, but if it has 3 dashes in it then it will delete the 3rd dash.
                  Example:  If the text field has ILDG93-030301-AA01  it will stay ILDG93-030301-AA01 (2 dashes)  but if the text field has  ILDG93-030301-18B225-AA01 (3 dashes) it will change to ILDG93-030301-18B225AA01.  Deleting the 3rd dash & leaving the first 2 dashes.
                  • 6. Re: Script to work around Illustrator bugs
                    brian.e. Level 1
                    THANK GOD ALMIGHTY!  A friend that knows AppleScript helped me figure it out!!
                            if (textFrames[i].note == "UPPER FORDDOC NAME") {
                              var frameName = textFrames[i].contents ;
                              newFrame = frameName.replace (/(.*-.*-.*)-(.*)/, "$1$2") ;
                              textFrames[i].contents=newFrame
                    • 7. Re: Script to work around Illustrator bugs
                      Muppet Mark Level 5
                      Don't thank god unless he posted the solution… Gets credit for all sorts he never did… If he AppleScripts thank jobs he's only been there 12 months…
                      • 8. Re: Script to work around Illustrator bugs
                        brian.e. Level 1
                        I will THANK MUPPET MARK then!  Esspecially if you or anyone could help me with this last piece to the puzzle.
                        In the format file we have another field that represents the person who worked the illustration.  So I was going to create a file or folder on everyones system with their name Ex. JDOE then the script when ran can look to that file or folder & return the name of it then place that into this text field.
                        I think maybe just the 3rd (for other text box) & 5th line (Regular expression) would need to be changed but not sure to what.
                        So when I run it on my computer it will see my file or folder which is BLAU then put that into the text box in Illustrator but if JOHN DOE ran it on his computer it would put JDOE.
                        • 9. Re: Script to work around Illustrator bugs
                          Muppet Mark Level 5
                          Regular Expressions are like a mini sub language of script… To be honest more than scripters should look at leaning these… ID has both find and replace plus styling based on these… Like everything else they take a little getting you head around… but well worth the effort… I see expressions all the time that I don't get unless I go look them up and even then it can go over my head… Useful and powerful stuff but it does take some time…
                          What system are you running? OSX has the user name in the file path… but you may be able to get an enviroment variable?
                          • 10. Re: Script to work around Illustrator bugs
                            brian.e. Level 1
                            If I just made a line in the Script add the name there then it can apply that name & I'll just make everyone a custom script to run on their computer. Is this possible how would this look?
                            I've tried
                                    if (textFrames[i].note == "DETAIL") {
                                      newFrame = frameName.replace (*)(BLAU) ;
                            • 11. Re: Script to work around Illustrator bugs
                              brian.e. Level 1
                              WOW all I had to do is:
                                        var frameName = textFrames[i].contents = "BLAU";
                              So simple. Thanks? I guess.
