2 Replies Latest reply on Oct 11, 2012 11:44 AM by Steve Werner
    create running exercise numbers
    hscross
      I'm working on a textbook that has exercises scattered throughout, and I'd like the numbers of the exercises to be automatic so that if I remove one, I don't have to renumber all the others. At the moment, the exercises are numbered like this: 2B where 2 is the chapter and B is the second exercise in that chapter.
      I'm using cs 5.5 on Mac. I see text variables for many things, but I'm confused about how to set up something like this. Any help much appreciated!
        • 1. Re: create running exercise numbers
          peter minneapolis Level 4
          You do this with paragraph styles that include the numering property. Search Google for terms like "InDesign multi-level numbered lists" for information. Depending on the specific way you assign numbers to chapters, you'll need to create a numbered list numbering expression to capture that number. It's a common task, but InDesign's numbered list format syntax takes a while to master. Save files before experimenting; better, yet, work on file copies until you get it right. It's worth the effort to learn this.
          HTH
          Regards,
          Peter
          _______________________
          Peter Gold
          KnowHow ProServices
          • 2. Re: create running exercise numbers
            Steve Werner Adobe Community Professional & MVP
            Follow Peter's suggestion, and look for Bob Bringhurst's tutorials on numbered lists in InDesign.
