1 Reply Latest reply on Dec 1, 2012 11:51 AM by Charles Myers 4th
    Alternate for reader extension
    IAMPallav Level 1
      I want to use the capability of loading some input fields of my form at time of rendering either via web service or from database, it's required only for one of the form. Is there any alternate solution for reader extention to achieve this?
        • 1. Re: Alternate for reader extension
          Charles Myers 4th Level 3
          If you want to have the form dynamically connect to the database or make web service calls, you either need to have the form reader-extended or use the full Acrobat.
          An alternative that you could use (this is a very narrow use case) would be to have your server put the data into a form data packet that referenced the form and dynamically serve that up, letting reader do the merge. We can chat more on this on the opff-hand chance that this could fill your need.
