0 Replies Latest reply on Oct 12, 2012 2:52 AM by mon_zy
    Flex Automation: submenu cannot be recognized when automating custom menu
    mon_zy
      I have scrollable menu class which extends flex menu. user can specify the menu height. when there are too many menu item, a vertical scrollbar will show.
      here is the main method in my ScrollableMenu.as:
      public static function createMenu(parent:DisplayObjectContainer, mdp:Object, showRoot:Boolean=true):ScrollableMenu
                  var menu:ScrollableMenu = new ScrollableMenu();
                  menu.tabEnabled = false;
                  menu.owner = DisplayObjectContainer(FlexGlobals.topLevelApplication);
                  menu.showRoot = showRoot;
                  menu.isMainMenu = true;
                  popUpMenu(menu, parent, mdp);
                  return menu;
      override mx_internal function openSubMenu(row:IListItemRenderer):void
                  supposedToLoseFocus = true;
                  var r:Menu = getRootMenu();
                  var menu:ScrollableMenu;
                  // check to see if the menu exists, if not create it
                  if (!IMenuItemRenderer(row).menu)
                  {  trace("no menu")
                      menu = new ScrollableMenu();
                      menu.maxHeight = this.maxHeight;
                      menu.parentMenu = this;
                      menu.owner = this;
                      menu.dataDescriptor = r.dataDescriptor;
                      menu.styleName = r;
                      menu.labelField = r.labelField;
                      menu.labelFunction = r.labelFunction;
                      menu.iconField = r.iconField;
                      menu.iconFunction = r.iconFunction;
                      menu.itemRenderer = r.itemRenderer;
                      menu.rowHeight = r.rowHeight;
                      menu.scaleY = r.scaleY;
                      menu.scaleX = r.scaleX;
                      // if there's data and it has children then add the items
                      if (row.data &&
                          _dataDescriptor.isBranch(row.data) &&
                          _dataDescriptor.hasChildren(row.data))
                          menu.dataProvider = _dataDescriptor.getChildren(row.data);
                      menu.sourceMenuBar = sourceMenuBar;
                      menu.sourceMenuBarItem = sourceMenuBarItem;
                      IMenuItemRenderer(row).menu = menu;
                      PopUpManager.addPopUp(menu, r, false);
                  subMenu = IMenuItemRenderer(row).menu as ScrollableMenu;
                  super.openSubMenu(row);
                  //adjust the submenu position if scrollbar exists
                  if(verticalScrollBar) {
                      var menu_x:Number = IMenuItemRenderer(row).menu.x + verticalScrollBar.width;
                      var menu_y:Number = IMenuItemRenderer(row).menu.y ;
                      IMenuItemRenderer(row).menu.move(menu_x,menu_y);
      //--------------------------------------------------------------end----------------------- -------------------------------------------------------------------//
      I created a delegate for the scrollablemenu, and I added xml definition in RFT's flexEnv.xml(I basically copy the def for menu and added scroll event)
      public class TestScrollableMenuDelegate extends MenuAutomationImpl
              public static function init(root:DisplayObject):void
                  Automation.registerDelegateClass(ScrollableMenu, TestScrollableMenuDelegate);
              public function TestScrollableMenuDelegate(obj:ScrollableMenu){
                  super(obj);
      Now, everything is working(scroll, select main menu item) except the action on submenu cannot be recorded.
      I do not know what I  should add to my delegate class to make it work.
      Hope someone can give a hint!
