4 Replies Latest reply on Feb 21, 2008 5:17 AM by robowriter
    Merging Projects in RH7
    robowriter Level 1
      Hi. I'm just in the process of looking into an upgrade from version 5 to 7. I have a critical client project that involves merging their RH5 help system into our RH5 help system, and I've been accomplishing this by using Peter Grainge's techniques (thank you, Peter).
      My questions are:
      Will this technique continue to work seamlessly if I upgrade to RoboHelp 7?
      If yes to the last question, and if our client does NOT upgrade to 7, will I be able to import their help system project files into 7 (pretty much as I do now in 5) and then perform the merge using that same technique and with the same good results?
      Or, will there be an even easier way to accomplish this in 7?
      Thank you!
