• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
how to display table grid in PDF - RH10
New Here ,
Oct 12, 2012 Oct 12, 2012
I've created a new table style but the grids inside the table aren't showing when I generated a PDF file. I can't seem to find the setup to show the grids from the Styles settings below. I clicked Format > Boarders and Shading but there's no settings to make the grids visible.
Here's the actual PDF result:
I wanted the grids inside to display so the rows and columns have division lines.
Is there a way to resolve this? Thanks in advance.
Views
1.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast ,
Hi
You have cretaed a table in your style sheet and under style sheet you have this type of table style only. So in order to get the type of table you want, you need to create a table in the topic itself.
If you want to use the same table in multiple topics later on, you can copy and paste the same table across multiple topics.
http://help.adobe.com/en_US/RoboHelp/8.0/RoboHTML/WS491ADD30-89AF-409c-9EFC-93D4EBE521EB.html
Hope it helps
VJ
Votes
Translate
Translate
Report
Report
New Here ,
Oct 16, 2012 Oct 16, 2012
ohhhh so I couldn't customize this specific table property directly in the table style that I created? I think It would be better to have this feature  (I mean customizing directly in the table style) so If we want to insert a table in a topic, just have to select the Table style that we have created from the list of table styles instead of copy-paste.
Votes
Translate
Translate
Report
Report
Community Expert ,
I don't know why VJ has suggested copying and pasting as it is not necessary. Once you have created a table style you can insert it into other topics directly. VJ's link is to a RoboHelp 8 topic whereas you are using 10 where things are different.
Also adding tables is not your problem. As I understand it you have the tables in your topics, it's just that in PDF the borders are not showing, correct?
First generate to Word and see if the borders appear in the same way as in the topic.
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Oct 24, 2012 Oct 24, 2012
The borders are in PDF, the grids inside the table are not displaying (the table just looks like a rectangular box). I wanted to create my own table style and not use the existing table style templates.
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 25, 2012 Oct 25, 2012
Whole Table is not what you might think. It does not mean every cell in the table, it means the outer borders of the whole table.
Try settting a colour for Bottom Right of even rows and the same for odd rows. Then set Top Left for Whole Table.
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
Thanks for being helpful, Peter. It worked . But why can't RoboHelp have this feature of setting up the table as a whole (including the cells) so we don't have to format the cells one by one?
Votes
Translate
Translate
Report
Report
New Here ,
another thing, i set up the font in the table style as Adobe Garamond, but when I generate a pdf, the font in the table becomes Arial.
Votes
Translate
Translate
Report
Report
Community Expert ,
I agree it is not intuitive but as I said, I think maybe the term Whole Table is specific in the CSS world and the borders for Whole Table are simply the outer borders. In other words Adobe are following convention.
On the font question, generate to Word and see what you get there first.
@petergrainge
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
about the font, I generated it to Word and it still displays Arial. I created my second table style and I set the font to Adobe Garamond, and the font on that seems okay when I converted to PDF. I just find it weird that sometimes the PDF adapts, sometimes not.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
