3 Replies Latest reply on Oct 12, 2012 12:48 PM by Ned Murphy
    Input Text and trace
      I am trying to make a math equation in as2 for Flash. I want it so when someone enters a number into the input text box and presses the button, it adds up that number with another set number(5).
      This is the code that I have for the stage.
      var number2:Number = 5;
      var number1:Number = parseInt(text_txt.text);
      button_btn.onRelease = function()
          trace(number1 + number2);
      button_btn is the instance name button that I press.
      text_txt is the instance name for the input text
      In the output box is just says NaN(not a number). It doesn't matter what number I put in for the text box.
      When I switch the parseInt(text_txt.text) with a number it works perfectly fine but in that way it doesn't use the input text box
      Take in note that I am still very much a noob at Flash. I know very little about coding.
      Thanks in advance for whoever can help.
