2 Replies Latest reply on Oct 13, 2012 10:27 AM by Steven L. Gotz
    iPhone footage zoomed in Multi Cam monitor
    AngelusDesigns86
      I am editing a wedding for a friend on CS6, for the first dance I used a camcorder on a tripod and my iPhone 4s. I have synced them in multi cam but when using the multi cam monitor the iPhone footage has zoomed in, how do I zoom it back out?
        • 1. Re: iPhone footage zoomed in Multi Cam monitor
          Jim_Simon Level 8
          Best guess is the two resolutions don't match.  Check that.
          • 2. Re: iPhone footage zoomed in Multi Cam monitor
            Steven L. Gotz Level 5
            More specifically, based on your explanation, the camera is probably DV at 720X480, or maybe the smaller HD at 1280X720 while the iPhone is 1920X1080.
            You have two basic choices. Context click on the larger footage and select "Scale to Frame Size" or better yet, click on the footage and go to the Effect Controls panel and use the Motion effect's Scale parameter to scale it down.
            You may choose to scale it exactly, or you may decide to leave it a little larger if that frames the picture better. It depends on the footage. I often find that I want to focus the viewer's attention on the better part of the larger frame. I can do this better if I edit in a smaller frame. Once again, it depends on the footage as well as the distribution method.
