1. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
Harm Millaard Oct 14, 2012 12:55 PM (in response to HeavyTheory.com)Remove one 580 card.
2. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 14, 2012 1:03 PM (in response to Harm Millaard)Within a setting, or physically from my machine?
3. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
ExactImage Oct 14, 2012 1:24 PM (in response to HeavyTheory.com)Try reducing the playback resolution to 1/2. Don't be concerned about this, as soon as you pause it goes back to full res. You're unlikely to need full resolution during editing anyway, unless you need to pixel peep (which you can pause for) and are playing at full 1920x1080 resolution on screen.
4. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 14, 2012 1:43 PM (in response to ExactImage)As per your advice I've tried that. It seems I may be getting a slightly higher framecount - which is of course a good thing. I still see solid red, but maybe that is just how it is with my video cards. I tried "The Hack" and added my card to the list, but that did nothing. I still can't select Mercury.
Either way, thanks for the quick reply ExactImage.
Cheers.
5. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
ExactImage Oct 14, 2012 1:44 PM (in response to HeavyTheory.com)Have you actually installed the CUDA drivers? These are not the same as the general GPU drivers.....
6. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 14, 2012 1:50 PM (in response to ExactImage)Looking into it now. I'm running 306.02, which I imagine is a general driver? Downloading a CUDA driver now. There are also CUDA 5 RC developer drivers in the CUDA toolkit. I may try these and get back to this post. Thanks again.
7. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
JSS1138 Oct 14, 2012 2:46 PM (in response to HeavyTheory.com)surely I should not see solid red in the sequence window.
For clips without any effects, you normally won't. That you do suggests there is a mismatch between your media and your sequence settings.
Try correcting that.
8. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 14, 2012 2:59 PM (in response to JSS1138)Thanks for your reply Jim. I'm not using any effects and I only see red. Where can I correct a mismatch between media and sequence settings?
9. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
JSS1138 Oct 14, 2012 3:12 PM (in response to HeavyTheory.com)Create a new sequence that's correct for your media. Copy/Paste everything into it.
10. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 14, 2012 3:32 PM (in response to JSS1138)Thanks Jim. I've done so. I created a new sequence that should be suitable for some stills and video from a Canon Mark2. I get the same results. I'm going to keep researching this. Thanks for your input.
11. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 14, 2012 3:33 PM (in response to ExactImage)After installing a CUDA driver I have to say I do not notice any improvments. Thanks for your help.
12. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
JSS1138 Oct 14, 2012 6:23 PM (in response to HeavyTheory.com)I get the same results.
You mean the red bar, or the laggy playback? (Or both?)
13. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 14, 2012 8:27 PM (in response to JSS1138)Both. I can't seem to effect the performance in any way. I have a lot to learn about this software. I've tried changing the scratch disk set up as well. I take my play back quality down to 1/4 and it still is shakey.
14. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
JSS1138 Oct 14, 2012 9:01 PM (in response to HeavyTheory.com)If you still have the red bar, then you still haven't matched the sequence settings properly. With a proper match (and no effects), you'll get a yellow bar, or none at all.
15. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 14, 2012 9:15 PM (in response to JSS1138)I find that encouraging. I just need to learn more about what settings to use. I will expiriment with this and I'm looking forward to finding the answer. Thanks Jim. I will keep you posted.
16. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 15, 2012 6:42 AM (in response to JSS1138)I've played around with a few different settings. I was able to get at least the video interview to go yellow in the bar. It seems to be the full rez JPEGS that are causing the strain and they are still solid red. I'm doing a Ken Burns effect and then panning within layers for a faux 3D effect. Oddly enough the setting that gave me the yellow bar over the video also got much more jerky on my stills. I'm not giving up though and thanks for your help Jim.
17. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 15, 2012 6:43 AM (in response to ExactImage)Hey I reread my last comment to you and I hope I didn't seem sarcastic. Thought I replied in more detail. Thanks so much for your help.
18. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
JSS1138 Oct 15, 2012 9:05 AM (in response to HeavyTheory.com)It seems to be the full rez JPEGS that are causing the strain and they are still solid red.
That part is not surprising, and probably not fixable outside of rendering the sequence.
19. Re: Slow Playback and Scrubbing on Fast System in Premiere CS6
HeavyTheory.com Oct 15, 2012 9:08 AM (in response to JSS1138)That sounds definitive to me. Thanks for helping me sort it out Jim.
