1 Reply Latest reply on Oct 15, 2012 1:44 AM by try67
    Script to Hyperlink Words to a Bookmark?
    NJT_125
      Hello Everyone,
      I am trying to write an Acrobat script that will search a PDF document for certain words and then hyperlink them to a particular page bookmark. I am not that experienced in writing Java code, only very simple scripts.
      Thanks for your help.
        • 1. Re: Script to Hyperlink Words to a Bookmark?
          Bookmarks can't be "linked to", since they are just triggers to a command. What you can do, though, is have the links (or buttons) that you create above the words you're searching for perform the same action that a bookmark does. However, if you're doing this with a script you're limited to using JS-based commands. You can't use the "Go to page view"-command, for example.
