2 Replies Latest reply on Feb 28, 2008 10:02 PM by See4th
    No Charts in Flex 3 Pro
    See4th
      I just upgraded from Flex 2 (no charts) to Flex 3 Pro and I still get the watermark on the charts. Anyone have any idea how to remedy this?
      Jeff
        • 1. Re: No Charts in Flex 3 Pro
          Sreenivas R Adobe Employee
          Do you mean you have bought the licensed version and it is showing the watermark?
          • 2. No Charts in Flex 3 Pro
            See4th Level 1
            The problem was that I built a project with FB beta 3 plugin with no chart license. Then I upgraded to FB3 Pro plugin and tried to import my project into a new workspace. Any combination of import or new workspace would not remove the watermark and would not let go of cached file paths for cfcs. I spent the entire day with this mess.
            The solution is actually quite ridiculous but it's the only way I could get the project to work.
            - Uninstall any versions of Flex Builder
            - Create a clean install directory of eclipse
            - Install FB into the new eclipse dir
            - Create a new workspace different than one you've created before
            - Create a new project (use the same name as the old project)
            - Close eclipse
            - Copy all the old project files over to the new dir
            - Open eclipse and add all your plugins back in
            - Since I had already added my License in the previous install it was not required again.
            Piece of cake?@?!*
