3 Replies Latest reply on Oct 14, 2012 11:17 PM by Chris Cox
    program error when try to use 3D repousse in Photoshop CS5 extended?
    Gata62
      Please help!!!! Unable to use 3D repousse Photoshop CS5 Extended  (my system info is described below)
      I tried almost everything that is available in Adobe library help, also re-installed programs as requested by Adobe support (suspected to get rid of me), it did not solve the problem.
      I used to have 3D capabilities, and also crop tool worked well before (now it changes all layers when using crop even in background).  My PC is same,  nor I downloaded plugins or changed video cards (these things are too advanced for me!), also restored preferences many times.
      My system makes automatic updates, reviewed graphics and adobe as recommended.
      OpenGL settings is odd …only can access basic, other modes are not highlighted (normal or advanced).
      ERRORS (for 3D Text)
      1-“Your 3D scene now exceeds the limits of lights and/or textures for the video card’s hardware-accelerated 3D rendering. As long as the limits are exceeded, 3D rendering will be done in software only, and some features (e.g Repousse)will be disabled.”
      2- “Your video card does not meet the requirements for hardware-accelerated 3D rendering. All 3D will be rendered with software only “
      3-“ Could no complete the text layer command because of a program error”
      ERROR (for object)
      Open GL/GPU HARDWARE ACCELERATION IS CURRENTLY  DISABLED. 3D WILL NOW BE RENDERED WITH SOFTWARE ONLY.  TO ENABLE OPEN/GL  ACCELERATION, GO TO PREFERENCES > PERFORMANCE TAB AND CHECK THE “ENABLE OPENGL GRAWING” CHECK BOX.
      Is it possible that I have a GPU Sniffer? all these terms I have learned recently =)   but I have a healthy & capable graphic card and accepted by adobe standards.
      SYSTEM INFO
      Adobe Photoshop Version: 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch]) x64
      Operating System: Windows 7 64-bit
      Version: 6.1 Service Pack 1
      System architecture: Intel CPU Family:6, Model:5, Stepping:2 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
      Physical processor count: 4
      Processor speed: 2128 MHz
      Built-in memory: 3895 MB
      Free memory: 2210 MB
      Memory available to Photoshop: 3280 MB
      Memory used by Photoshop: 70 %
      Image tile size: 128K
      Image cache levels: 4
      OpenGL Drawing: Enabled.
      OpenGL Drawing Mode: Basic
      OpenGL Allow Normal Mode: True.
      OpenGL Allow Advanced Mode: False.
      OpenGL Crash File: Not Detected.
      OpenGL Allow Old GPUs: Not Detected.
      Video Card Vendor: Intel
      Video Card Renderer: Intel(R) Graphics Media Accelerator HD
      Display: 1
      Display Bounds:=  top: 0, left: 0, bottom: 768, right: 1360
      Video Card Number: 1
      Video Card: Intel(R) Graphics Media Accelerator HD
      Driver Version: 8.15.10.1968
      Driver Date: 20091008000000.000000-000
      Video Card Driver: igdumd64.dll,igd10umd64.dll,igdumdx32,igd10umd32
      Video Mode: 1360 x 768 x 4294967296 colors
      Video Card Caption: Intel(R) Graphics Media Accelerator HD
      Video Card Memory: 1723 MB
      Serial number:
      Application folder: C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\
      Temporary file path: C:\Users\Patricia\AppData\Local\Temp\
      Photoshop scratch has async I/O enabled
      Scratch volume(s):
        C:\, 284.6G, 218.5G free
      Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS5.1 (64 Bit)\Plug-ins\
      Additional Plug-ins folder: not set
      Installed components:
         A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
         ACE.dll   ACE 2010/12/13-23:37:10   64.449933 64.449933
         adbeape.dll   Adobe APE 2011/01/17-12:03:36   64.452786 64.452786
      AdobeLinguistic.dll   Adobe Linguisitc Library   5.0.0
         AdobeOwl.dll   Adobe Owl 2010/06/03-13:43:23   3.0.93 61.433187
      AdobeOwlCanvas.dll   Adobe Owl Canvas   3.0.68 61.2954
         AdobePDFL.dll   PDFL 2010/12/13-23:37:10   64.341419 64.341419
         AdobePIP.dll   Adobe Product Improvement Program   5.5.0.1265
         AdobeXMP.dll   Adobe XMP Core   5.0 64.140949
      AdobeXMPFiles.dll   Adobe XMP Files   5.0   64.140949
      AdobeXMPScript.dll   Adobe XMP Script   5.0   64.140949
         adobe_caps.dll   Adobe CAPS 4,0,42,0
      adobe_OOBE_Launcher.dll   Adobe OOBE Launcher   2.0.0.36 (BuildVersion: 2.0; BuildDate: Mon Jan 24 2011 21:49:00) 1.000000
         AFlame.dll   AFlame 2011/01/10-23:33:35   64.444140 64.444140
         AFlamingo.dll   AFlamingo 2011/01/10-23:33:35   64.436825 64.436825
         AGM.dll   AGM 2010/12/13-23:37:10   64.449933 64.449933
         ahclient.dll    AdobeHelp Dynamic Link Library   1,6,0,20
         aif_core.dll   AIF 2.0   53.422628
         aif_ogl.dll   AIF 2.0   53.422628
         amtlib.dll   AMTLib (64 Bit)   4.0.0.21 (BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00)   1.000000
      amtservices.dll   AMTServices (64 Bit)   4.0.0.21 (BuildVersion: 4.0; BuildDate: Mon Jan 24 2011 21:49:00) 1.000000
         ARE.dll   ARE 2010/12/13-23:37:10   64.449933 64.449933
         asneu.dll    AsnEndUser Dynamic Link Library   1, 7, 0, 1
         AXE8SharedExpat.dll   AXE8SharedExpat 2011/01/10-23:33:35   64.436825 64.436825
         AXEDOMCore.dll   AXEDOMCore 2011/01/10-23:33:35   64.436825 64.436825
         Bib.dll   BIB 2010/12/13-23:37:10   64.449933 64.449933
         BIBUtils.dll   BIBUtils 2010/12/13-23:37:10   64.449933 64.449933
      boost_threads.dll   DVA Product   5.0.0
         cg.dll   NVIDIA Cg Runtime   2.0.0015
         cgGL.dll   NVIDIA Cg Runtime   2.0.0015
         CoolType.dll   CoolType 2010/12/13-23:37:10   64.449933 64.449933
         data_flow.dll   AIF   2.0 53.422628
         dvaadameve.dll   DVA Product 5.0.0
         dvacore.dll   DVA Product 5.0.0
         dvaui.dll   DVA Product 5.0.0
      ExtendScript.dll   ExtendScript 2011/01/17-17:14:10   61.452840   61.452840
         FileInfo.dll   Adobe XMP FileInfo   5.0 64.140949
         icucnv36.dll   International Components for Unicode 2009/06/17-13:21:03    Build gtlib_main.9896
         icudt36.dll   International Components for Unicode 2009/06/17-13:21:03    Build gtlib_main.9896
         image_flow.dll   AIF 2.0   53.422628
      image_runtime.dll   AIF   2.0 53.422628
         JP2KLib.dll   JP2KLib 2010/12/13-23:37:10   64.181312 64.181312
      libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
         libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
         LogSession.dll   LogSession 2.1.2.1263
         MPS.dll   MPS 2010/12/13-23:37:10   64.450375 64.450375
         msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.4940
         msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.6161
         msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.4940
         msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.6161
         msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.4940
         msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.6161
      pdfsettings.dll   Adobe PDFSettings   1.04
         Photoshop.dll   Adobe Photoshop CS5.1   CS5.1
         Plugin.dll   Adobe Photoshop CS5   CS5
         PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   2.5.0.232
         PSArt.dll   Adobe Photoshop CS5.1   CS5.1
         PSViews.dll   Adobe Photoshop CS5.1   CS5.1
         SCCore.dll   ScCore 2011/01/17-17:14:10   61.452840 61.452840
         tbb.dll   Threading Building Blocks   2, 1, 2009, 0201
         TfFontMgr.dll   FontMgr 9.3.0.113
         TfKernel.dll   Kernel 9.3.0.113
         TFKGEOM.dll   Kernel Geom 9.3.0.113
         TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
      updaternotifications.dll   Adobe Updater Notifications Library   2.0.0.15 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   2.0.0.15
         WRServices.dll   WRServices Thursday January 21 2010 12:13:3   Build 0.11423   0.11423
         wu3d.dll   U3D Writer 9.3.0.113
      Installed plug-ins:
         3D Studio 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Accented Edges 12.0
         ADM 3.11x01
         Angled Strokes 12.0
         Average 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Bas Relief 12.0
         BMP 12.0.2
         Camera Raw 6.3
         Chalk & Charcoal 12.0
         Charcoal 12.0
         Chrome 12.0
         Cineon 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Clouds 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Collada 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Color Halftone 12.0.2
         Colored Pencil 12.0
         CompuServe GIF 12.0.2
         Conté Crayon 12.0
         Craquelure 12.0
         Crop and Straighten Photos 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Crop and Straighten Photos Filter 12.0.2
         Crosshatch 12.0
         Crystallize 12.0.2
         Cutout 12.0
         Dark Strokes 12.0
         De-Interlace 12.0.2
         Dicom 12.0
         Difference Clouds 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Diffuse Glow 12.0
         Displace 12.0.2
         Dry Brush 12.0
         Eazel Acquire 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Embed Watermark 4.0
         Entropy 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Extrude 12.0.2
         FastCore Routines 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Fibers 12.0.2
         Film Grain 12.0
         Filter Gallery 12.0
         Fresco 12.0
         Glass 12.0
         Glowing Edges 12.0
         Google Earth 4 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Grain 12.0
         Graphic Pen 12.0
         Halftone Pattern 12.0
         HDRMergeUI 12.0
         IFF Format 12.0.2
         Ink Outlines 12.0
         JPEG 2000 2.0
         Kurtosis 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Lens Blur 12.0
         Lens Correction 12.0.2
         Lens Flare 12.0.2
         Lighting Effects 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Liquify 12.0.1
         Matlab Operation 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Maximum 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Mean 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Measurement Core 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Median 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Mezzotint 12.0.2
         Minimum 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         MMXCore Routines 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Mosaic Tiles 12.0
         Multiprocessor Support 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Neon Glow 12.0
         Note Paper 12.0
         NTSC Colors 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Ocean Ripple 12.0
         OpenEXR 12.0.2
         Paint Daubs 12.0
         Palette Knife 12.0
         Patchwork 12.0
         Paths to Illustrator 12.0.2
         PCX 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Photocopy 12.0
         Photoshop 3D Engine 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Picture Package Filter 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Pinch 12.0.2
         Pixar 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Plaster 12.0
         Plastic Wrap 12.0
         PNG 12.0.2
         Pointillize 12.0.2
         Polar Coordinates 12.0.2
         Portable Bit Map 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Poster Edges 12.0
         Radial Blur 12.0.2
         Radiance 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Range 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Read Watermark 4.0
         Reticulation 12.0
         Ripple 12.0.2
         Rough Pastels 12.0
         Save for Web & Devices 12.0
         ScriptingSupport 12.1
         Shear 12.0.2
         Skewness 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Smart Blur 12.0.2
         Smudge Stick 12.0
         Solarize 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Spatter 12.0
         Spherize 12.0.2
         Sponge 12.0
         Sprayed Strokes 12.0
         Stained Glass 12.0
         Stamp 12.0
         Standard Deviation 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Sumi-e 12.0
         Summation 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Targa 12.0.2
         Texturizer 12.0
         Tiles 12.0.2
         Torn Edges 12.0
         Twirl 12.0.2
         U3D 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Underpainting 12.0
         Vanishing Point 12.0
         Variance 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Variations 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Water Paper 12.0
         Watercolor 12.0
         Wave 12.0.2
         Wavefront|OBJ 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         WIA Support 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         Wind 12.0.2
         Wireless Bitmap 12.1 (12.1x20110328 [20110328.r.145 2011/03/28:10:30:00 cutoff; r branch])
         ZigZag 12.0.2
      Plug-ins that failed to load: NONE
      Flash:
         Mini Bridge
         Access CS Live
         Flash
         Kuler
         CS Review
      Installed TWAIN devices: NONE
