5 Replies Latest reply on Oct 16, 2012 12:25 AM by Laubender
    Textbox properties
    bala281972 Level 1
      Hi Guys
      i'm working on a script which will add check box / combo box / text box etc at a predefined places and export it as a interactive pdf. Now i'm wondering what could be the code which will change the style of the check box / combo box / text box to 'inset', 'underlined', 'bevel' etc. Could not get any help from the data browser or from the Object Model Viewer in extended tool kit. Any help on this ?
      Attached the screen shot of the same for your ready reference as well as the code too
      var myLibrary = app.open("/Applications/Adobe\ InDesign\ CS6/Presets/Button\ Library/ButtonLibrary.indl") /*opening the sample button library, where i've added my own check box/combo box/text box*/
      myNames = myLibrary.assets.everyItem().name;
      var myObj = app.libraries[0].assets[0].placeAsset(app.documents[0])[0]; /*assets[0] will fetch the last item from the library, assets[1] will fetch last but one from the library and so on */
      myObj.fontSize = 4;
      myObj.fillColor=app.activeDocument.swatches.item("Paper");
      myObj.strokeColor=app.activeDocument.swatches.item("Paper");
      none of the below mentioned codes work
      //   myObj.strokeType.properties.name="Inset"
      //   myObj.strokeType.strokeStyleType.name="Inset"
      //   myObj.strokeType.name="Inset"
      //   myObj.strokeType="Inset"
      Screen Shot 2012-10-15 at 9.48.32 AM.pngScreen Shot 2012-10-15 at 9.54.34 AM.png
      Btw, the screen captures shown above are from adobe acrobat and not from indesign
      Rgs
      Bala
        • 1. Re: Textbox properties
          Green4ever Level 3
          Did you tried like this
          myObj.strokeWeight = "2pt";
          I have tested it with a rectangular frame, it worked for me.
          Green4ever
          • 2. Re: Textbox properties
            bala281972 Level 1
            Hi
            Thanks for your effort. Yes. I tried that too. if the line thickness is 2pt, the line thickness dialog box will change to 'medium' and if pt size is 3 then the property of line thickness will change to 'thick' but the line style remains 'solid' and i would like to change to 'bevel' or 'inset' depends on the condition.
            • 3. Re: Textbox properties
              Green4ever Level 3
              Can you just me the example of what you want in indesign (not in PDF). I am not clear what you mean. May be I understand wrongly.
              obj1.strokeWeight = "2pt";
              obj1..strokeType = app.activeDocument.strokeStyles.item("Dotted");
              obj2.strokeWeight = "2pt";
              obj2.strokeType = app.activeDocument.strokeStyles.item("Solid");
              Try the above line to apply a stroke style to a frame object.
              Green4ever
              • 4. Re: Textbox properties
                bala281972 Level 1
                Hi
                Thanks. Unfortunately this is not what i require. What i require is, i would like my forms to use the effect 'inset', 'bevelled' in acrobat. Since the PDF been created using indesign, i would like to know how to do this using indesign. For example the below attached form layout has a bevelled rectangular box due to the property 'inset'. I would like to know how to set value for 'line style column' the default value is 'solid'
                • 5. Re: Textbox properties
                  @bala281972 – I fear you have to script Acrobat to get the effects you want…
                  Uwe
