9 Replies Latest reply on Oct 17, 2012 1:05 AM by Carl Sun
    Extension Manager and InDesign Problems
    kuhn_kuhn
      Hello,
      i have Problems with Extension Manager in CS6
      I installed Master Collection but there is no InDesign in Extension Manager.
      This is the Screen i get when i open the Extension Manager.
      It says something about an invalid Token......
      http://imageshack.us/a/img24/2306/creent.png
      Can someone help me?
      Systen 10.8.2
      CS6 Master with all updates
      THANKS!
        • 1. Re: Extension Manager and InDesign Problems
          Carl Sun Level 4
          Have you made any changes to "/Applications/Adobe InDesign CS6/Configuration/XManConfig.xml"? The following is this file from my machine. Please compare it with yours. It should be exactly same except that my locale is "en_US" while yours is "de_DE".
          <?xml version="1.0" encoding="UTF-8"?>
          <Configuration>
              <VariableForExMan>
                  <Data key="$indesign">$InstallFolder</Data>
                  <Data key="$indesign_user">$UserDataFolder/Adobe/Adobe InDesign CS6</Data>
                  <Data key="DisplayName">InDesign CS6</Data>
                  <Data key="GlobalProductName">Adobe InDesign CS6</Data>
                  <Data key="ProductName">InDesign</Data>
                  <Data key="ProductVersion">8.0</Data>
                  <Data key="HostNameForCSXS">IDSN</Data>
                  <Data key="IconPath">Configuration/Icon.png</Data>
                  <Data key="SupportedInSuite">CS6</Data>
                  <Data key="DefaultLocale">en_US</Data>
                  <Data key="NeedLockableExtension">true</Data>
                  <Data key="ShowInstalledFiles">true</Data>
                  <Data key="Bit">32</Data>
                  <Data key="PreExtensionFolder">$SharedCommonDataFolder/Adobe/InDesign/Version 8.0/en_US/Extensions</Data>
                  <Data key="PluginConfigFile">$UserLibraryFolder/Preferences/Adobe InDesign/Version 8.0/en_US/PlugInConfig.txt</Data>
              </VariableForExMan>
          </Configuration>
          If you cannto find any problem in this file, please generate log files to help troubleshooting. http://forums.adobe.com/message/4275082#4275082 describes how to generate log files.
          • 2. Re: Extension Manager and InDesign Problems
            kuhn_kuhn Level 1
            I am glad for your answer because i nearly can't sleep if something is wrong on my mac.
            Here is my File - i think it's the same:
            <Configuration>
                <VariableForExMan>
                    <Data key="DefaultLocale">de_DE</Data>
                    <Data key="PreExtensionFolder">$SharedCommonDataFolder/Adobe/InDesign/Version 8.0/de_DE/Extensions</Data>
                    <Data key="PluginConfigFile">$UserLibraryFolder/Preferences/Adobe InDesign/Version 8.0/de_DE/PlugInConfig.txt</Data>
                </VariableForExMan>
            </Configuration>
            And here the PlugInConfig.txt:
            =Path
            =Include
            =Exclude
            =ExcludeRequired
            =MorePluginConfiguration
            One Strange thing:
            If i delet the complete InDesign Folder in my User Preferences - the "PlugInConfig.txt" is the only file which doesn't come back if i start InDesgin after deleting the Prefs......
            I can't create a log file......
            I go step by step throug your advise - but the only thing i get is a 0 KB empty document "ExManLog.YES" in my user folder.....
            The Folder you said (/Users/<UserName>/Library/Application Support/Adobe/Extension Manager CS/) is no log file.....
            What next?
            • 3. Re: Extension Manager and InDesign Problems
              Carl Sun Level 4
              Sorry. The FAQ is not accurate. All "CS" should be replaced with "CS6" in your case. i.e., you should
              change directory to"/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS" to run command, and find log files in "/Users/<UserName>/Library/Application Support/Adobe/Extension Manager CS6/".
              • 4. Re: Extension Manager and InDesign Problems
                Carl Sun Level 4
                Does your user name contain any special characters?
                • 5. Re: Extension Manager and InDesign Problems
                  kuhn_kuhn Level 1
                  No - it is "harry"
                  • 6. Re: Extension Manager and InDesign Problems
                    kuhn_kuhn Level 1
                    hmmm - i did waht you said - but same result as before!
                    here my Terminal:
                    Last login: Tue Oct 16 13:44:18 on ttys000
                    home-MacPro:~ harry$ /Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS
                    -bash: /Applications/Adobe: is a directory
                    home-MacPro:~ harry$ sudo touch ExManLog.YES
                    Password:
                    • 7. Re: Extension Manager and InDesign Problems
                      Xiaoyi Tong Adobe Employee
                      HI Kuhn,
                      There are space characters in the path "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS", so the path must be enclosed in double quotation marks. Please follow the command below:
                      home-MacPro:~ harry$ cd "/Applications/Adobe Extension Manager CS6/Adobe Extension Manager CS6.app/Contents/MacOS"
                      Xiaoyi
                      • 8. Re: Extension Manager and InDesign Problems
                        kuhn_kuhn Level 1
                        OK thank you! I will try this when I am back on this machine!
                        Perhaps one thing:
                        Is it possible that the Problem has something to do i splittet the System and the User? I have a SSD with the System and Apps and my User on a second drive (HDD)?
                        Perhaps this causes the Problem?
                        • 9. Re: Extension Manager and InDesign Problems
                          Carl Sun Level 4
                          I think it's possible to have something to do with the two disks.
