6 Replies Latest reply on Oct 19, 2012 6:46 AM by Sajeev Sridharan
    Figure placement
    hurix@123
      Hi All,
      We have more than 100 images need to place in indesign. Every time i need to place the images manualy.
      In my Indesign i have a xml tag like <graphics 1> the folowed be the figures caption. my Figure name is Grap01.eps.
      Kindly help me how to place the figures using script
      Ramki
        • 1. Re: Figure placement
          Sajeev Sridharan Level 4
          var testElement = myDoc.xmlElements.item(0);
          var testElements = testElement.evaluateXPathExpression("//graphics1");
          for(var i = testElements.length -1;i>=0;i--)
              var path = document.filePath;
              name = "Grap";
             testElements[i].insertionPoints[0].place (File (path + '/' + name + '.eps'));
          Hope this will help you...
          - Vandy
          • 2. Re: Figure placement
            hurix@123 Level 1
            Hi Vady,
            Thank you very much.
            I try above code, but it shows "The file path// Grap.eps not found"
                name = "Grap01";
            When i try above code 'Grap01' is place all places.
            Regards
            Ramakrishna.K
            • 3. Re: Figure placement
              hurix@123 Level 1
              My XML code is:
              <graphic src="10.4135_9781412980029-fig1601.jpg" alt="Figure 16.1 Devotees at the Shrine of Data Ganj Bukhsh Lahore."/>
              <graphic src="10.4135_9781412980029-fig1602.jpg" alt="Figure 16.2 Devotees at the Shrine of Data Ganj Bukhsh Lahore."/>
              Figure Name: Grap16.1, Grap16.2
              Ram
              • 4. Re: Figure placement
                var testElements = testElement.evaluateXPathExpression("//graphic");
                for(var i = 0; i< testElements.length; i++)
                        attr=testElements[i].xmlAttributes.itemByName("src").value;
                        var testfigName = attr.split("-fig");
                        var figName = testfigName[1].split("0");
                        var figureName = 'Grap' + figName[0] +  '.' + figName[1];
                   testElements[i].insertionPoints[0].place (File (path + '/' + figureName));
                - Vandy
                • 5. Re: Figure placement
                  hurix@123 Level 1
                  Yes got it.
                  Thank you.
                  Ram
                  • 6. Re: Figure placement
                    If my code helps you, make the discussion as answered... dont leave as it is...
                    - Vandy..
