• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Error 1923 installing Adobe Reader XI
New Here ,
Oct 15, 2012 Oct 15, 2012
When installing Adobe Reader XI I get:
Error 1923. Service Adobe Acrobat Update Service (AdobeARMUpdate) couldn't be installed. Verify that you have sufficient privileges to install system services.
This happens after UAC elevation dialog. Running the installer as administrator doesn't help. Even when I select to update manually, I still get the same error.
Views
34.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Deleted User
Oct 16, 2012 Oct 16, 2012
This error is coming because service might already be in use. The file can be in use by any anti-virus or  data back-up softwares. It is also possible that your previous un-install has been unsuccessful, and it was already using the service. You can try two things :
1. Reboot your system once. It should fix all scenarios.
2. Another thing which you can try is Go to Control Panel ->Administrative Tools ->View local Services. Select Adobe Acrobat Service, Right click and stop it. Then try insta
Votes
Translate
Translate
Advocate ,
Would you try to install MSI version from
ftp://ftp.adobe.com/pub/adobe/reader/win/11.x/11.0.00/en_US/
Would help if you provide your system information and what kind of a User are you on this system.
Votes
Translate
Translate
Report
Report
New Here ,
Already tried this version, same result. I'm using Windows 7 Professional, 64 bit. Running under a normal user account which is member of Administrators and HomeUsers groups.
Votes
Translate
Translate
Report
Report
Advocate ,
Here is what I would do-
1. Try latest Reader 10.1.4 from ftp://ftp.adobe.com/pub/adobe/reader/win/10.x/10.1.4/en_US/
If it installs fine, the problem is with Reader 11
2. You can try to install Reader 11 MSI without installing Service.
Here is the command line for that
msiexec /i [Path to MSI file] DISABLE_ARM_SERVICE_INSTALL="1"
This might prevent full automatic update in some cases, but you should be fine otherwise.
Good luck
Votes
Translate
Translate
Report
Report
Guest
2. Another thing which you can try is Go to Control Panel ->Administrative Tools ->View local Services. Select Adobe Acrobat Service, Right click and stop it. Then try installation.
You can try msiexec /i [Path to MSI file] DISABLE_ARM_SERVICE_INSTALL="1" as suggested by LeoAdobeX but I will not recommend this. We would like our users to be updated with latest update and service just helps in that.
Keep us posted about the outcome.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 17, 2012 Oct 17, 2012
I ran into this problem on two different machines. On one of them, the Adobe Acrobat Update Service was Disabled. I didn't check the other one, but the installation succeeded after a reboot.
Update: I rebooted the one with the disabled Update service. Installation of Reader XI then succeeded.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 19, 2012 Oct 19, 2012
Rebooting worked for me.
Votes
Translate
Translate
Report
Report
Guest
Oct 21, 2012 Oct 21, 2012
I had the same problem and a reboot helped, but this is really annoying and shouldn't happen.
@PankhriS: I had Reader X installed and when the setup for XI failed, it had already deinstalled X (which is kinda..."great" having no reader at all at that point) and when I looked at the services, ARM was deactivated and marked for deletion. I want to help but without any useful log files this seems quite hard.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 08, 2016 Aug 08, 2016
LATEST
I know this has been solved for awhile, but I had to delete the AdobeARMService service with the following command.
SC Delete AdobeARMService
After that I was able to install as normal.
Votes
Translate
Translate
Report
Report
