I receive this error when trying to open an .acsm file on my Mac: "Error getting License. License Server Communication Problem: E_ADEPT_DOCUMENT_TYPE_UNKNOWN:" I am running Mac OS X 10.8.2. When I open the ACSM file it is in XML format and is looking for a PDF document.
What do I need to do to actually download the file? Everything else seems to be configured properly in terms of authorization.
Message was edited by: JFS-NJ
Sorry I left that part out! I am using Adobe Digital Editions 2.0 on a Mac running OS X 10.8.2.
can anyone explain what this error is?
I am using Windows 7 on a PC and trying to open the the .acsm file in Adobe Digital Editions v 2.0.67532
I keep getting the error E_ADEPT_DOCUMENT_TYPE_UNKNOWN
I bought a pdf from elsevier (outlook programming) as i was wasting time trying to find a solution to my problem online - tried to save the organisation dollars by buying a book with the answers - buying the book was simple, actually being able to view the PDF - altogether different matter. I've now wasted more time trying to actually ACCESS the book! No dollars saved at all
it seems anyone who has posted this question has received no answer
I click customer support from adobe and get thrown here, their forum WITH NO ANSWERS TO THE QUESTION - vicious cycle!
I am having the same problem at the moment. Using Windows 7 64 bit pc and trying to open an .acsm file that I bought from Kobo. My ADE is v 2.0.1
I keep getting the same error E_ADEPT_DOCUMENT_TYPE_UNKNOWN.
No solutions found as well.
I'm not at all sure this will help that particlular problem, but worth a try as there don't seem any alternative suggestions.
There are lots of bugs in ADE2.0. Try replacing ADE2.0 with the older but more reliable v1.7.2.
(You can have them both installed at once if you like.)
Version 1.7.2, it is a little difficult to find, available on Adobe site for Windows and for Mac.
http://helpx.adobe.com/digital-editions/kb/cant-install-digital-editions.html
The forum software is sometimes corrupting the link above. There shouldn't be a blank in 'editio ns.html'. The following redirects to the same page: http://tinyurl.com/diged172
I received this error on my PC using Windows 7 when I tried to open the .acsm file that I downloaded when I purchased an ebook from Sainsburysebooks.co.uk. I contacted them without much help. I followed the lead of one of the respondents to your question who suggested installing an older version of digital editions. I did that and then tried to open the .acsm file. This time I got a slightly different error message (I forgot to write it down but it said it was an io error), the important thing was that it contained some more information. It stated that it could not access the actual location of the .epub file which was something like this (I've modified it) http://fulfillment.anobii.com/adobe-acs/ad7cf32a-fe40-4fce-fg5-d4e02572f4dc.epub. So I pasted this url into my browser and then got a message from my ISP to say that page was blocked by my parental controls - so I simply had to allow access to that page and was then able to download the book. I hope this might help.
Thanks for the Tip Peter, I too had purchased from Sainsburys and found i had the error as being discussed.
I followed your advice and added the web link to my Sky Bradband sheild settings and hey presto it downloaded!
Many thanks
I went thru this error as well
when I tryed to download a purchased book from KOBO and import it in Adobe Digital Editions 2.0.
It never happened before while I get it now both on mac and on a Windows 7 PC.
Found nowhere a solution.
The working procedure usually was:
I get the above error.
Fixing:
Do 1. 2. of the above procedure.
3'. right click the .acsm file on windows or <ctrl> click on mac and select "open with adobe digital editions" (or simply double click on it). It downloads the epub file and opens it in Digital editions without the above error.
Don't know why, but that's it.
Have fun
Try to find if you have a download file with extension .acsm with the same name in your computer, erase it and download the new file. I had the same problem and I solved it. You can also download the new in different place, but I did the first better.
If that don't resolve the problem, Ctrl/Command+Shift+D in desk of Adobe Digital Editions to erase the authorized computer and start doing that I told you first.
I had the following error just today: Error getting License. License Server Communication Problem: E_ADEPT_DOCUMENT_TYPE_UNKNOWN.
I am using a Macbook Pro (2010) OS 10.10.3 and I have downloaded 100 books from KOBO using the ascm format. Usually, as soon as I click on the file in the downloads it opens up Adobe Digital Editions 2.0 and the ascm file loads into my library and opens. Not today with my 101st and 102nd books.
Having read some of the suggestions here I tried a mixture of a few suggestions and had success:
I have no idea why this happened after 100 other books have been downloaded normally. Weird but somewhat easily fixed for me. Hope this helps someone.
Gente!! ami sí me funciono!! solo tuve que intentar descargarlo repetidas veces.
I tried all of the above suggestions and unfortunately I am still getting this error "Error getting License. License Server Communication Problem: E_ADEPT_DOCUMENT_TYPE_UNKNOWN:" Can someone please help?
To provide some background, I am trying to download a Adobe Digital Edition eBook. I have a Mac OX Yosemite Process 1.3 Ghz Intel Core i5 and I followed all of the necessary steps which include:
1. Creating an Adobe Account
2. Downloading the Adobe Digital Editions 4.0 (I also tried 5.0)
3. Click "File" "Add to Library" Click on the "URLlink.acsm" file as an "ACSM" file, I receive an error that states E_ADEPT_DOCUMENT_TYPE_UNKNOWN:"
I tried calling the Adobe helpline and chatting with a representative but no one has been able to help. Can someone please assist as soon as possible?
I've been getting the same error for the past 2 months. Have tried all the above suggestions. Contacted Adobe Help chat but the person (bot?) said that help was only for Creative Cloud and they didn't support Adobe Digital Editions! Told me to look in the forums. Anyone had any luck resolving the issue?
@christopherm7902945
Had the same issue. These d!cks from support don`t know what the problem is.
