I have an urgent problem that the client has just uncovered.
Our pages in RH9 consist of some buttons at the top in a one-row table, including one for Print this Page - javascript:window.print() - then a title in Heading 1 style, then another table containing the steps.
This particular client has very long, detailed instructions, so the table runs over one page. The pages are printing out with a page break above and below the heading. There is nothing in the Heading 1 style that would lead to this, and it doesn't show up in the preview, just in the published version.
I looked into the default setting of "page-break-inside: avoid;" which seems to be used in every row of the table. Could this be the source of the problem?
Does anyone have any suggestions? Please? Please?
Where are you seeing that "page-break-inside: avoid;" setting? That looks like part of the javascript, it certainly is not any RoboHelp setting that I am familiar with.
Try a page without that script. If that prints OK, why not try using a toolbar button for Print? There is a script on my site in Snippets that will print the viewed page without this problem.
Hi Peter,
It's not part of the javascript - it's part of the table. It seems to be
repeated in every row.
s check is requested by
Sorry but how does the heading "Reading a Conflicts Report help?
Are you replying by email and trying to include an image? Can't be done. You have to reply via the web to include images. What I would like to see is an image of the HTML where this problem is occurring.
I just included that to show where the heading fits into the page. A page
break inserts itself before and after the heading.
I tried removing the Print button, and using File Print, and the page
printed correctly. However, now I'm in a bind - the client expects to have
that button.
I'm going to try restyling the heading and see if that helps.
I think I've fixed it by changing the heading to another style and then
changing it back. When the document was imported from Word, it seems to
have carried page breaks with it. I've noticed that, when you import a Word
document, it carries some formatting with it that's very hard to get rid of.
Going out for a few minutes now - I'll let you know later if it works.
Thanks, as always, for the help, Peter.
Argh! You didn't mention the document source. Yes it can bring in unwanted garbage.
I wasn't suggesting your client uses File > Print. Rather that instead of putting a button on every page, you put one button on the toolbar. See http://www.grainge.org/pages/authoring/rh_tour/index.htm for an example.
Hi Peter,
I just used File > Print as a test. I really like your toolbar button, but
I can't find the script on your site. Can you point me to it?
THANK YOU!
Item 3 at http://www.grainge.org/pages/snippets/snippets.htm#webhelp
Thanks, Peter. Sadly, it didn't work. It printed, but still with the page
breaks. It has to be in the table definition, but I've checked the sites
for other clients that have multi-page topics done the same way, and they're
fine.
I'll keep plugging.
The idea was to use the toolbar button instead of the one that is causing the problem. Until the latter is removed, you are going to have this problem.
Unfortunately, even with it removed, it still has the problem. I like the
toolbar button, though - I think I'll incorporate that in future.
Can you create this problem in a new project with just one or two topics?
If you can, see the Contact page on my site.
