33 Replies Latest reply on Jan 7, 2018 11:55 PM by ravenise
    [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
    Siuwongau Level 1
      I get the error when I reinstalled CS5.5. It shows "the installer failed to initialize".
      Then I downloaded Adobe Support Advisor but that didn't say anything was wrong.
      Also, I used Adobe Creative Suite Cleaner Tool to clear all the services installed.
      What should I do?
      Token number for support case:
      40-71747-190615102012
        • 3. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
          Arpit Kapoor Adobe Employee
          "Installer Failed to initialize" is a generic error and we need to figure out what is causing the trouble. Most of the time, its an issue with the download that it was not successful or downloaded properly. So, in such cases, download the software again and make sure to compare the file size of the downloaded file with the file on the server. Lets check that in this case as well and make sure the download is complete.
          If the file size is correct, As Mylenium said, we need the install.log file.
          Navigate to the log files in one of the following folders:
          • Windows 32 bit (XP, Vista, 7): \Program Files\Common Files\Adobe\Installers\
          • Windows 64 bit (XP, Vista, 7): \Program Files(x86)\Common Files\Adobe\Installers
          • Mac OS: /Library/Logs/Adobe/Installers/
          The log filename includes the product name and install date, followed by ".log.gz." The extension .gz indicates a compressed format.
          Use a decompression utility such as Winzip or StuffIt to decompress the .gz file. Once uncompressed, the log file is a plain text file.
          Open the .log file using WordPad (Windows) or TextEdit (Mac OS).
          Note: By default, log files open in Console on Mac OS. Select all of the text by pressing Command+A, and then copy and paste it into a text editor before continuing.
          Scroll to the bottom of the log. Look in the --- Summary --- section for lines that start with ERROR: or FATAL and indicate a failure during the installation process.
          Copy and Paste that SUMMARY section in here so that we can check the errors. You might also analyze the logs yourself. http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html
          • 4. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
            Siuwongau Level 1
            Would you please analyze the logs for me? Thanks. - 0 fatal error(s), 33 error(s), 0 warning(s) ----------- Payload: {08EF22BC-43B2-4B4E-BA12-52B18F418F38} Adobe Photoshop CS5.1 Core 12.1.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\Adobe Photoshop CS5.1". Error 145 The directory is not empty.(Seq 3506) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 3506) ----------- Payload: {D8CCCF4C-C227-427C-B4BE-736657D2AB7E} Adobe Flash Catalyst CS5.5 1.5.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Macromedia\Flash Player\#Security\FlashPlayerTrust". Error 145 The directory is not empty.(Seq 16) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 16) ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Macromedia\Flash Player\#Security". Error 145 The directory is not empty.(Seq 17) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 17) ----------- Payload: {6548A7DA-770A-4BCD-A6ED-719CC7B6FD1B} Adobe Media Encoder CS5.5 X64 5.5.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\Adobe Media Encoder". Error 145 The directory is not empty.(Seq 6) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 6) ERROR: DF037: Unable to delete directory "C:\Program Files\Adobe". Error 145 The directory is not empty.(Seq 1130) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 1130) ----------- Payload: {5FA850A4-02D6-1016-89BE-9DA43E267FC4} Adobe InDesign CS5.5 Application Feature Set Files 7.5.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\InDesign". Error 145 The directory is not empty.(Seq 12) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 12) ----------- Payload: {0094FC04-A548-4D8F-87C1-140431F76C2E} Adobe ExtendScript Toolkit CS5.5 3.6.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\ExtendScript Toolkit". Error 145 The directory is not empty.(Seq 393) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 393) ----------- Payload: {71BC8278-815D-4F8C-8FA5-C6F782C73892} Adobe CSXS Infrastructure CS5.5 2.5.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\Users\Elaine Kong\AppData\Roaming\Adobe\CS5.5ServiceManager". Error 145 The directory is not empty.(Seq 8) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 8) ----------- Payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 ----------- ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\LensProfiles\1.0\Nikon". Error 145 The directory is not empty.(Seq 241) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 241) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\LensProfiles\1.0". Error 145 The directory is not empty.(Seq 288) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 288) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\LensProfiles". Error 145 The directory is not empty.(Seq 289) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 289) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\CameraProfiles\Camera". Error 145 The directory is not empty.(Seq 712) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 712) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\CameraProfiles\Adobe Standard". Error 145 The directory is not empty.(Seq 954) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 954) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw\CameraProfiles". Error 145 The directory is not empty.(Seq 955) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 955) ERROR: DF037: Unable to delete directory "C:\ProgramData\Adobe\CameraRaw". Error 145 The directory is not empty.(Seq 956) ERROR: DW063: Command ARKDeleteDirectoryCommand failed.(Seq 956) ERROR: DW049: Payload {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} has an action "remove" but no resultState ERROR: DW049: Payload {A189C479-C7CD-4E08-8CCF-D999B68C0C71} has an action "remove" but no resultState ERROR: DW049: Payload {FD58D99B-9927-4226-8E00-959A4F76BD89} has an action "remove" but no resultState Please search the above error/warning string(s) to find when the error occurred. These errors resulted in installer Exit Code mentioned below. ------------------------------------------------------------------------------------- Exit Code: 0 - No error. *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* END - Installer Session *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*
            • 5. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
              Siuwongau Level 1
              After disabling UAC, doing selecting start up and enabling the root user in Window 7 64-bit, the installation can be proceed.
              Now the problem is resovled. Thank you Adobe Technical Support, Shenoy S!!!
              • 6. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                Creative Skull Level 1
                Please try these Steps and let me know can you install it.
                1. Disabling UAC.
                2. Disable the Startup Items and Services.
                3. Enabling the hidden Admin user in Window 7 64-bit.
                Run the installer again in the Hidden Admin in Windows 7.
                Sanjay M Suman
                Adobe technical Support
                • 7. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                  Siuwongau Level 1
                  The problem was sovled and installation was completed.
                  Anyway, thanks for your information.
                  • 8. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                    SamanthamChavez
                    Help got the same error on windows 8 brand new laptop and i need this software for work
                    1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Build Version - 1.5.115.0
                    1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Logging Level verbosity Set  to 4
                    1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\resources\setup.xml
                    1/8/2013 17:46:30 [INFO] PIM - XML is valid
                    1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Found 3 packages in setup manifest
                    1/8/2013 17:46:30 [INFO] BS-ASUInstaller - BEGIN pim_getInstallStatusAtPath...
                    1/8/2013 17:46:30 [INFO] BS-ASUInstaller - PIM CF PATH :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\
                    1/8/2013 17:46:30 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 17:46:30 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 17:46:30 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 17:46:30 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 17:46:30 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx
                    1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\UWA\UWA.pimx
                    1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\DWA\DWA.pimx
                    1/8/2013 17:46:30 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\LWA\LWA.pimx
                    1/8/2013 17:46:30 [INFO] BS-ASUInstaller - END pim_needsInstallRepairOrUpgradeAtPath...
                    1/8/2013 17:46:30 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Success in check install status, status is at path :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\
                    1/8/2013 17:46:30 [INFO] BS-ASUInstaller - Latest Version of Adobe Application Manager is present on the machine, no need to install
                    1/8/2013 22:08:51 [INFO] Setup - Build Version - 2.0.242.0
                    1/8/2013 22:08:51 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/8/2013 22:08:51 [INFO] Setup - Start Adobe Setup
                    1/8/2013 22:08:51 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/8/2013 22:08:51 [INFO] Setup - TimeLog: Start initial checks
                    1/8/2013 22:08:53 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/8/2013 22:08:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/8/2013 22:08:53 [INFO] PIM - XML is valid
                    1/8/2013 22:08:53 [WARN] PIM - Failed to find Node
                    1/8/2013 22:08:53 [INFO] Setup - Found 3 packages in setup manifest
                    1/8/2013 22:08:55 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 22:08:55 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 22:08:56 [INFO] Utilities - Folder does not exist
                    1/8/2013 22:08:56 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 22:08:56 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 22:08:56 [INFO] PIM - CREATE PIM Instance ...
                    1/8/2013 22:08:56 [INFO] Utilities - File does not exist
                    1/8/2013 22:08:56 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:08:58 [INFO] PIM - SUCCESS Created Tables.
                    1/8/2013 22:08:58 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 22:08:58 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/8/2013 22:08:58 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:08:58 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 22:08:58 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 22:08:58 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 22:08:58 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:08:59 [INFO] PIM - XML is valid
                    1/8/2013 22:08:59 [WARN] PIM - Failed to find Node
                    1/8/2013 22:08:59 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/8/2013 22:08:59 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/8/2013 22:08:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/8/2013 22:08:59 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/8/2013 22:08:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/8/2013 22:08:59 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/8/2013 22:08:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/8/2013 22:08:59 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/8/2013 22:09:00 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/8/2013 22:09:00 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/8/2013 22:09:00 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/8/2013 22:09:00 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/8/2013 22:09:00 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/8/2013 22:09:00 [INFO] Setup - TimeLog: End initial checks
                    1/8/2013 22:09:00 [INFO] Setup - TimeLog: Begin Installing
                    1/8/2013 22:09:00 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:09:00 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:09:00 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:09:00 [INFO] PIM - XML is valid
                    1/8/2013 22:09:00 [WARN] PIM - Failed to find Node
                    1/8/2013 22:09:00 [ERROR] PIM - Package folder does not exist on the system.
                    1/8/2013 22:09:00 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/8/2013 22:09:00 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    Return Value of pim_installPackage = -1
                    1/8/2013 22:09:00 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/8/2013 22:11:38 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 22:11:38 [INFO] PIM - FREE PIM Instance ...
                    1/8/2013 22:11:38 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/8/2013 22:11:38 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/8/2013 22:11:38 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/8/2013 22:11:38 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/8/2013 22:11:38 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/8/2013 22:11:38 [INFO] Setup - Build Version - 2.0.242.0
                    1/8/2013 22:11:38 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/8/2013 22:11:38 [INFO] Setup - Start Adobe Setup
                    1/8/2013 22:11:38 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/8/2013 22:11:38 [INFO] Setup - TimeLog: Start initial checks
                    1/8/2013 22:11:39 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/8/2013 22:11:39 [INFO] PIM - XML is valid
                    1/8/2013 22:11:39 [WARN] PIM - Failed to find Node
                    1/8/2013 22:11:39 [INFO] Setup - Found 3 packages in setup manifest
                    1/8/2013 22:11:39 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 22:11:39 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 22:11:39 [INFO] Utilities - Folder does not exist
                    1/8/2013 22:11:39 [INFO] PIM - CREATE PIM Instance ...
                    1/8/2013 22:11:39 [INFO] Utilities - File does not exist
                    1/8/2013 22:11:39 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:11:39 [INFO] PIM - SUCCESS Created Tables.
                    1/8/2013 22:11:39 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 22:11:39 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/8/2013 22:11:39 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 22:11:39 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 22:11:39 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:11:39 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/8/2013 22:11:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/8/2013 22:11:39 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/8/2013 22:11:39 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/8/2013 22:11:39 [INFO] Setup - TimeLog: End initial checks
                    1/8/2013 22:11:39 [INFO] Setup - TimeLog: Begin Installing
                    1/8/2013 22:11:39 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:11:39 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:11:39 [ERROR] PIM - Package folder does not exist on the system.
                    1/8/2013 22:11:39 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/8/2013 22:11:39 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/8/2013 22:11:39 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/8/2013 22:11:45 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 22:11:45 [INFO] PIM - FREE PIM Instance ...
                    1/8/2013 22:11:45 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/8/2013 22:11:45 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/8/2013 22:11:45 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/8/2013 22:11:45 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/8/2013 22:11:45 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/8/2013 22:12:48 [INFO] Setup - Build Version - 2.0.242.0
                    1/8/2013 22:12:48 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/8/2013 22:12:48 [INFO] Setup - Start Adobe Setup
                    1/8/2013 22:12:48 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/8/2013 22:12:48 [INFO] Setup - TimeLog: Start initial checks
                    1/8/2013 22:12:49 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/8/2013 22:12:49 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/8/2013 22:12:49 [INFO] PIM - XML is valid
                    1/8/2013 22:12:49 [WARN] PIM - Failed to find Node
                    1/8/2013 22:12:49 [INFO] Setup - Found 3 packages in setup manifest
                    1/8/2013 22:12:50 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 22:12:50 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 22:12:50 [INFO] Utilities - Folder does not exist
                    1/8/2013 22:12:50 [INFO] PIM - CREATE PIM Instance ...
                    1/8/2013 22:12:50 [INFO] Utilities - File does not exist
                    1/8/2013 22:12:50 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:12:50 [INFO] PIM - SUCCESS Created Tables.
                    1/8/2013 22:12:50 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 22:12:50 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/8/2013 22:12:50 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 22:12:50 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 22:12:50 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 22:12:50 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:12:50 [INFO] PIM - XML is valid
                    1/8/2013 22:12:50 [WARN] PIM - Failed to find Node
                    1/8/2013 22:12:50 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/8/2013 22:12:50 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/8/2013 22:12:50 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/8/2013 22:12:50 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/8/2013 22:12:50 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/8/2013 22:12:50 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/8/2013 22:12:50 [INFO] Setup - TimeLog: End initial checks
                    1/8/2013 22:12:50 [INFO] Setup - TimeLog: Begin Installing
                    1/8/2013 22:12:50 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:12:50 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:12:50 [ERROR] PIM - Package folder does not exist on the system.
                    1/8/2013 22:12:50 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/8/2013 22:12:50 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/8/2013 22:12:50 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/8/2013 22:13:51 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 22:13:51 [INFO] PIM - FREE PIM Instance ...
                    1/8/2013 22:13:51 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/8/2013 22:13:51 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/8/2013 22:13:51 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/8/2013 22:13:51 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/8/2013 22:13:51 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/8/2013 22:15:58 [INFO] Setup - Build Version - 2.0.242.0
                    1/8/2013 22:15:58 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/8/2013 22:15:58 [INFO] Setup - Start Adobe Setup
                    1/8/2013 22:15:58 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/8/2013 22:15:58 [INFO] Setup - TimeLog: Start initial checks
                    1/8/2013 22:15:59 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/8/2013 22:15:59 [INFO] PIM - XML is valid
                    1/8/2013 22:15:59 [WARN] PIM - Failed to find Node
                    1/8/2013 22:15:59 [INFO] Setup - Found 3 packages in setup manifest
                    1/8/2013 22:15:59 [WARN] Setup - Reboot is pending from earlier installation.
                    1/8/2013 22:15:59 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 22:15:59 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 22:15:59 [INFO] Utilities - Folder does not exist
                    1/8/2013 22:15:59 [INFO] PIM - CREATE PIM Instance ...
                    1/8/2013 22:15:59 [INFO] Utilities - File does not exist
                    1/8/2013 22:15:59 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:15:59 [INFO] PIM - SUCCESS Created Tables.
                    1/8/2013 22:15:59 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 22:15:59 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/8/2013 22:15:59 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 22:15:59 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 22:15:59 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:15:59 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/8/2013 22:15:59 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/8/2013 22:15:59 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/8/2013 22:15:59 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/8/2013 22:15:59 [INFO] Setup - TimeLog: End initial checks
                    1/8/2013 22:16:01 [INFO] Setup - TimeLog: Begin Installing
                    1/8/2013 22:16:01 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:16:01 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:16:01 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:16:01 [INFO] PIM - XML is valid
                    1/8/2013 22:16:01 [WARN] PIM - Failed to find Node
                    1/8/2013 22:16:01 [ERROR] PIM - Package folder does not exist on the system.
                    1/8/2013 22:16:01 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/8/2013 22:16:01 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/8/2013 22:16:01 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/8/2013 22:16:05 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 22:16:05 [INFO] PIM - FREE PIM Instance ...
                    1/8/2013 22:16:05 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/8/2013 22:16:05 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/8/2013 22:16:05 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/8/2013 22:16:05 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/8/2013 22:16:05 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/8/2013 22:20:57 [INFO] Setup - Build Version - 2.0.242.0
                    1/8/2013 22:20:57 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/8/2013 22:20:57 [INFO] Setup - Start Adobe Setup
                    1/8/2013 22:20:57 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/8/2013 22:20:57 [INFO] Setup - TimeLog: Start initial checks
                    1/8/2013 22:20:58 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/8/2013 22:20:58 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/8/2013 22:20:59 [INFO] PIM - XML is valid
                    1/8/2013 22:20:59 [WARN] PIM - Failed to find Node
                    1/8/2013 22:20:59 [INFO] Setup - Found 3 packages in setup manifest
                    1/8/2013 22:21:00 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 22:21:00 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 22:21:00 [INFO] Utilities - Folder does not exist
                    1/8/2013 22:21:00 [INFO] PIM - CREATE PIM Instance ...
                    1/8/2013 22:21:00 [INFO] Utilities - File does not exist
                    1/8/2013 22:21:01 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:21:01 [INFO] PIM - SUCCESS Created Tables.
                    1/8/2013 22:21:01 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 22:21:01 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/8/2013 22:21:03 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:21:03 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 22:21:03 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 22:21:03 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 22:21:03 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 22:21:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:21:03 [INFO] PIM - XML is valid
                    1/8/2013 22:21:03 [WARN] PIM - Failed to find Node
                    1/8/2013 22:21:03 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/8/2013 22:21:03 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/8/2013 22:21:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/8/2013 22:21:03 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/8/2013 22:21:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/8/2013 22:21:03 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/8/2013 22:21:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/8/2013 22:21:04 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/8/2013 22:21:04 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/8/2013 22:21:04 [INFO] Setup - TimeLog: End initial checks
                    1/8/2013 22:21:04 [INFO] Setup - TimeLog: Begin Installing
                    1/8/2013 22:21:04 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:21:04 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:21:04 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:21:04 [INFO] PIM - XML is valid
                    1/8/2013 22:21:04 [WARN] PIM - Failed to find Node
                    1/8/2013 22:21:04 [ERROR] PIM - Package folder does not exist on the system.
                    1/8/2013 22:21:04 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/8/2013 22:21:04 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/8/2013 22:21:04 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/8/2013 22:21:28 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 22:21:28 [INFO] PIM - FREE PIM Instance ...
                    1/8/2013 22:21:28 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/8/2013 22:21:28 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/8/2013 22:21:28 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/8/2013 22:21:28 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/8/2013 22:21:28 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/8/2013 22:22:01 [INFO] Setup - Build Version - 2.0.242.0
                    1/8/2013 22:22:01 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/8/2013 22:22:01 [INFO] Setup - Start Adobe Setup
                    1/8/2013 22:22:01 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/8/2013 22:22:01 [INFO] Setup - TimeLog: Start initial checks
                    1/8/2013 22:22:02 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/8/2013 22:22:02 [INFO] PIM - XML is valid
                    1/8/2013 22:22:02 [WARN] PIM - Failed to find Node
                    1/8/2013 22:22:02 [INFO] Setup - Found 3 packages in setup manifest
                    1/8/2013 22:22:02 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 22:22:02 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 22:22:02 [INFO] Utilities - Folder does not exist
                    1/8/2013 22:22:02 [INFO] PIM - CREATE PIM Instance ...
                    1/8/2013 22:22:02 [INFO] Utilities - File does not exist
                    1/8/2013 22:22:02 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:22:02 [INFO] PIM - SUCCESS Created Tables.
                    1/8/2013 22:22:02 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 22:22:02 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/8/2013 22:22:02 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 22:22:02 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 22:22:02 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:22:02 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/8/2013 22:22:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/8/2013 22:22:02 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/8/2013 22:22:02 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/8/2013 22:22:02 [INFO] Setup - TimeLog: End initial checks
                    1/8/2013 22:22:02 [INFO] Setup - TimeLog: Begin Installing
                    1/8/2013 22:22:02 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:22:02 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:22:02 [ERROR] PIM - Package folder does not exist on the system.
                    1/8/2013 22:22:02 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/8/2013 22:22:02 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/8/2013 22:22:02 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/8/2013 22:25:07 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 22:25:07 [INFO] PIM - FREE PIM Instance ...
                    1/8/2013 22:25:07 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/8/2013 22:25:07 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/8/2013 22:25:07 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/8/2013 22:25:07 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/8/2013 22:25:07 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/8/2013 22:27:39 [INFO] Setup - Build Version - 2.0.242.0
                    1/8/2013 22:27:39 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/8/2013 22:27:39 [INFO] Setup - Start Adobe Setup
                    1/8/2013 22:27:39 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/8/2013 22:27:39 [INFO] Setup - TimeLog: Start initial checks
                    1/8/2013 22:27:39 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/8/2013 22:27:39 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/8/2013 22:27:39 [INFO] PIM - XML is valid
                    1/8/2013 22:27:39 [WARN] PIM - Failed to find Node
                    1/8/2013 22:27:39 [INFO] Setup - Found 3 packages in setup manifest
                    1/8/2013 22:27:39 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 22:27:39 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 22:27:39 [INFO] Utilities - Folder does not exist
                    1/8/2013 22:27:39 [INFO] PIM - CREATE PIM Instance ...
                    1/8/2013 22:27:39 [INFO] Utilities - File does not exist
                    1/8/2013 22:27:39 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:27:40 [INFO] PIM - SUCCESS Created Tables.
                    1/8/2013 22:27:40 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 22:27:40 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/8/2013 22:27:40 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:27:40 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 22:27:40 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 22:27:40 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 22:27:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:27:40 [INFO] PIM - XML is valid
                    1/8/2013 22:27:40 [WARN] PIM - Failed to find Node
                    1/8/2013 22:27:40 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/8/2013 22:27:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/8/2013 22:27:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/8/2013 22:27:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/8/2013 22:27:40 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/8/2013 22:27:40 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/8/2013 22:27:40 [INFO] Setup - TimeLog: End initial checks
                    1/8/2013 22:27:40 [INFO] Setup - TimeLog: Begin Installing
                    1/8/2013 22:27:40 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:27:40 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:27:40 [ERROR] PIM - Package folder does not exist on the system.
                    1/8/2013 22:27:40 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/8/2013 22:27:40 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/8/2013 22:27:40 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/8/2013 22:27:43 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 22:27:43 [INFO] PIM - FREE PIM Instance ...
                    1/8/2013 22:27:43 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/8/2013 22:27:43 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/8/2013 22:27:43 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/8/2013 22:27:43 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/8/2013 22:27:43 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/8/2013 22:30:52 [INFO] Setup - Build Version - 2.0.242.0
                    1/8/2013 22:30:52 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/8/2013 22:30:52 [INFO] Setup - Start Adobe Setup
                    1/8/2013 22:30:52 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/8/2013 22:30:52 [INFO] Setup - TimeLog: Start initial checks
                    1/8/2013 22:30:52 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/8/2013 22:30:52 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/8/2013 22:30:52 [INFO] PIM - XML is valid
                    1/8/2013 22:30:52 [WARN] PIM - Failed to find Node
                    1/8/2013 22:30:52 [INFO] Setup - Found 3 packages in setup manifest
                    1/8/2013 22:30:53 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 22:30:53 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 22:30:53 [INFO] Utilities - Folder does not exist
                    1/8/2013 22:30:53 [INFO] PIM - CREATE PIM Instance ...
                    1/8/2013 22:30:53 [INFO] Utilities - File does not exist
                    1/8/2013 22:30:53 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 22:30:53 [INFO] PIM - SUCCESS Created Tables.
                    1/8/2013 22:30:53 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 22:30:53 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/8/2013 22:30:53 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 22:30:53 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 22:30:53 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 22:30:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:30:53 [INFO] PIM - XML is valid
                    1/8/2013 22:30:53 [WARN] PIM - Failed to find Node
                    1/8/2013 22:30:53 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/8/2013 22:30:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/8/2013 22:30:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/8/2013 22:30:53 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/8/2013 22:30:53 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/8/2013 22:30:53 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/8/2013 22:30:53 [INFO] Setup - TimeLog: End initial checks
                    1/8/2013 22:30:53 [INFO] Setup - TimeLog: Begin Installing
                    1/8/2013 22:30:53 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:30:53 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 22:30:53 [ERROR] PIM - Package folder does not exist on the system.
                    1/8/2013 22:30:53 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/8/2013 22:30:53 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/8/2013 22:30:53 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/8/2013 22:30:55 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 22:30:55 [INFO] PIM - FREE PIM Instance ...
                    1/8/2013 22:30:55 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/8/2013 22:30:55 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/8/2013 22:30:55 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/8/2013 22:30:55 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/8/2013 22:30:55 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/8/2013 23:59:25 [INFO] Setup - Build Version - 2.0.242.0
                    1/8/2013 23:59:25 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/8/2013 23:59:25 [INFO] Setup - Start Adobe Setup
                    1/8/2013 23:59:25 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/8/2013 23:59:25 [INFO] Setup - TimeLog: Start initial checks
                    1/8/2013 23:59:25 [INFO] Setup - Dictionary Path: C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/8/2013 23:59:25 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\resources\setup.xml
                    1/8/2013 23:59:25 [INFO] PIM - XML is valid
                    1/8/2013 23:59:25 [WARN] PIM - Failed to find Node
                    1/8/2013 23:59:25 [INFO] Setup - Found 3 packages in setup manifest
                    1/8/2013 23:59:28 [INFO] PIM - Build Version - 2.0.242.0
                    1/8/2013 23:59:28 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/8/2013 23:59:28 [INFO] Utilities - Folder does not exist
                    1/8/2013 23:59:28 [INFO] PIM - CREATE PIM Instance ...
                    1/8/2013 23:59:28 [INFO] Utilities - File does not exist
                    1/8/2013 23:59:28 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 23:59:29 [INFO] PIM - SUCCESS Created Tables.
                    1/8/2013 23:59:29 [INFO] PIM - PIM Database is Up To Date.
                    1/8/2013 23:59:29 [INFO] PIM - Updater Inventory location:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\resources\updaterinventory.dll
                    1/8/2013 23:59:29 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/8/2013 23:59:29 [INFO] PIM - Current db schema version on machine 1.
                    1/8/2013 23:59:29 [INFO] PIM - Current db schema version to install 1.
                    1/8/2013 23:59:29 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/8/2013 23:59:29 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 23:59:29 [INFO] PIM - XML is valid
                    1/8/2013 23:59:29 [WARN] PIM - Failed to find Node
                    1/8/2013 23:59:29 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/8/2013 23:59:29 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/8/2013 23:59:29 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/8/2013 23:59:29 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/8/2013 23:59:29 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/8/2013 23:59:29 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/8/2013 23:59:29 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/8/2013 23:59:30 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/8/2013 23:59:30 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/8/2013 23:59:31 [INFO] Setup - TimeLog: End initial checks
                    1/8/2013 23:59:31 [INFO] Setup - TimeLog: Begin Installing
                    1/8/2013 23:59:31 [INFO] Setup - Start Installing core package - C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 23:59:31 [INFO] PIM - START installPackage at file C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 23:59:31 [INFO] PIM - Trying to access xml at path:C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx
                    1/8/2013 23:59:31 [INFO] PIM - XML is valid
                    1/8/2013 23:59:31 [WARN] PIM - Failed to find Node
                    1/8/2013 23:59:31 [ERROR] PIM - Package folder does not exist on the system.
                    1/8/2013 23:59:31 [INFO] Setup - Finished Installing core package - C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/8/2013 23:59:31 [FATAL] Setup - Error installing C:\Users\Samantha\AppData\Local\Temp\Rar$EX53.912\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/8/2013 23:59:31 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/8/2013 23:59:35 [INFO] PIM - PIMSqlite closeDB status 0
                    1/8/2013 23:59:35 [INFO] PIM - FREE PIM Instance ...
                    1/8/2013 23:59:35 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/8/2013 23:59:35 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/8/2013 23:59:35 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/8/2013 23:59:35 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/8/2013 23:59:35 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 06:39:28 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 06:39:28 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 06:39:28 [INFO] Setup - Start Adobe Setup
                    1/9/2013 06:39:28 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 06:39:28 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 06:39:29 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 06:39:30 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 06:39:30 [INFO] PIM - XML is valid
                    1/9/2013 06:39:30 [WARN] PIM - Failed to find Node
                    1/9/2013 06:39:30 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 06:39:41 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 06:39:41 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 06:39:41 [INFO] Utilities - Folder does not exist
                    1/9/2013 06:39:41 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 06:39:41 [INFO] Utilities - File does not exist
                    1/9/2013 06:39:42 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 06:39:43 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 06:39:43 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 06:39:43 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 06:39:44 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 06:39:44 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 06:39:44 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 06:39:44 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 06:39:44 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 06:39:44 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:39:44 [INFO] PIM - XML is valid
                    1/9/2013 06:39:44 [WARN] PIM - Failed to find Node
                    1/9/2013 06:39:44 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 06:39:44 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 06:39:44 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 06:39:44 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 06:39:44 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 06:39:44 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 06:39:44 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 06:39:45 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 06:39:45 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 06:39:45 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 06:39:46 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 06:39:46 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 06:39:46 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 06:39:46 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 06:39:46 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 06:39:46 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:39:46 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:39:46 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:39:46 [INFO] PIM - XML is valid
                    1/9/2013 06:39:46 [WARN] PIM - Failed to find Node
                    1/9/2013 06:39:46 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 06:39:46 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 06:39:46 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 06:39:46 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 06:40:30 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 06:40:30 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 06:40:30 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 06:40:30 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 06:40:30 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 06:40:30 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 06:40:30 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 06:50:30 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 06:50:30 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 06:50:30 [INFO] Setup - Start Adobe Setup
                    1/9/2013 06:50:30 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 06:50:30 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 06:50:31 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 06:50:31 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 06:50:31 [INFO] PIM - XML is valid
                    1/9/2013 06:50:31 [WARN] PIM - Failed to find Node
                    1/9/2013 06:50:31 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 06:50:32 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 06:50:32 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 06:50:32 [INFO] Utilities - Folder does not exist
                    1/9/2013 06:50:32 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 06:50:32 [INFO] Utilities - File does not exist
                    1/9/2013 06:50:32 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 06:50:32 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 06:50:32 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 06:50:32 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 06:50:33 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 06:50:33 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 06:50:33 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 06:50:33 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 06:50:33 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 06:50:33 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:50:33 [INFO] PIM - XML is valid
                    1/9/2013 06:50:33 [WARN] PIM - Failed to find Node
                    1/9/2013 06:50:33 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 06:50:33 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 06:50:33 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 06:50:33 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 06:50:33 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 06:50:33 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 06:50:33 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 06:50:33 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 06:50:33 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:50:33 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:50:33 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 06:50:33 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 06:50:33 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 06:50:33 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 06:51:22 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 06:51:22 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 06:51:22 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 06:51:22 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 06:51:22 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 06:51:22 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 06:51:22 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 06:52:04 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 06:52:04 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 06:52:04 [INFO] Setup - Start Adobe Setup
                    1/9/2013 06:52:04 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 06:52:04 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 06:52:05 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 06:52:05 [INFO] PIM - XML is valid
                    1/9/2013 06:52:05 [WARN] PIM - Failed to find Node
                    1/9/2013 06:52:05 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 06:52:05 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 06:52:05 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 06:52:05 [INFO] Utilities - Folder does not exist
                    1/9/2013 06:52:05 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 06:52:05 [INFO] Utilities - File does not exist
                    1/9/2013 06:52:05 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 06:52:05 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 06:52:05 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 06:52:05 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 06:52:05 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 06:52:05 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 06:52:05 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:52:05 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 06:52:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 06:52:05 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 06:52:05 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 06:52:05 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 06:52:05 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 06:52:05 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:52:05 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:52:05 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 06:52:05 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 06:52:05 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 06:52:05 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 06:57:38 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 06:57:38 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 06:57:38 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 06:57:38 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 06:57:38 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 06:57:38 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 06:57:38 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 06:57:39 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 06:57:39 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 06:57:39 [INFO] Setup - Start Adobe Setup
                    1/9/2013 06:57:39 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 06:57:39 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 06:57:40 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 06:57:40 [INFO] PIM - XML is valid
                    1/9/2013 06:57:40 [WARN] PIM - Failed to find Node
                    1/9/2013 06:57:40 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 06:57:40 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 06:57:40 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 06:57:40 [INFO] Utilities - Folder does not exist
                    1/9/2013 06:57:40 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 06:57:40 [INFO] Utilities - File does not exist
                    1/9/2013 06:57:40 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 06:57:40 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 06:57:40 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 06:57:40 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 06:57:40 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 06:57:40 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 06:57:40 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:57:40 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 06:57:40 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 06:57:40 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 06:57:40 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 06:57:40 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 06:57:40 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 06:57:40 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:57:40 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 06:57:40 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 06:57:40 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 06:57:40 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 06:57:40 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 06:57:42 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 06:57:42 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 06:57:42 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 06:57:42 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 06:57:42 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 06:57:42 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 06:57:42 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 07:00:58 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 07:00:58 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 07:00:58 [INFO] Setup - Start Adobe Setup
                    1/9/2013 07:00:58 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 07:00:58 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 07:00:59 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 07:01:00 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 07:01:00 [INFO] PIM - XML is valid
                    1/9/2013 07:01:00 [WARN] PIM - Failed to find Node
                    1/9/2013 07:01:00 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 07:01:01 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 07:01:01 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 07:01:01 [INFO] Utilities - Folder does not exist
                    1/9/2013 07:01:01 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 07:01:01 [INFO] Utilities - File does not exist
                    1/9/2013 07:01:02 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:01:02 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 07:01:02 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:01:02 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 07:01:03 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:01:03 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 07:01:03 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 07:01:03 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 07:01:03 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:01:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:01:04 [INFO] PIM - XML is valid
                    1/9/2013 07:01:04 [WARN] PIM - Failed to find Node
                    1/9/2013 07:01:04 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 07:01:04 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 07:01:04 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 07:01:04 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 07:01:04 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 07:01:05 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 07:01:05 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 07:01:05 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 07:01:05 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 07:01:05 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 07:01:05 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:01:05 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:01:05 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:01:05 [INFO] PIM - XML is valid
                    1/9/2013 07:01:05 [WARN] PIM - Failed to find Node
                    1/9/2013 07:01:05 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 07:01:05 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 07:01:05 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    Return Value of pim_installPackage = -1
                    1/9/2013 07:01:05 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 07:04:10 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 07:04:10 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 07:04:10 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 07:04:10 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 07:04:10 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 07:04:10 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 07:04:10 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 07:04:17 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 07:04:17 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 07:04:17 [INFO] Setup - Start Adobe Setup
                    1/9/2013 07:04:17 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 07:04:17 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 07:04:18 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 07:04:18 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 07:04:18 [INFO] Setup - Start Adobe Setup
                    1/9/2013 07:04:18 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 07:04:18 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 07:04:18 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 07:04:19 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 07:04:19 [INFO] PIM - XML is valid
                    1/9/2013 07:04:19 [WARN] PIM - Failed to find Node
                    1/9/2013 07:04:19 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 07:04:20 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 07:04:20 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 07:04:20 [INFO] Utilities - Folder does not exist
                    1/9/2013 07:04:20 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 07:04:20 [INFO] Utilities - File does not exist
                    1/9/2013 07:04:20 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:04:20 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 07:04:20 [INFO] PIM - XML is valid
                    1/9/2013 07:04:20 [WARN] PIM - Failed to find Node
                    1/9/2013 07:04:20 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 07:04:20 [ERROR] Setup - Another Deployment workflow already running.
                    1/9/2013 07:04:20 [FATAL] Setup - Errors faced in OS requirement checks. Exiting...
                    1/9/2013 07:04:20 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 07:04:20 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:04:20 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 07:04:20 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 07:04:20 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 07:04:20 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:04:20 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 07:04:20 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 07:04:20 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 07:04:20 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 07:04:20 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 07:04:21 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 07:04:21 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 07:04:21 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 07:04:21 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 07:04:21 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:04:21 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:04:21 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:04:21 [INFO] PIM - XML is valid
                    1/9/2013 07:04:21 [WARN] PIM - Failed to find Node
                    1/9/2013 07:04:21 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 07:04:21 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 07:04:21 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 07:04:21 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 07:04:24 [ERROR] Setup - Another Deployment workflow already running.
                    1/9/2013 07:04:24 [FATAL] Setup - Errors faced in OS requirement checks. Exiting...
                    1/9/2013 07:04:26 [ERROR] Setup - Another Deployment workflow already running.
                    1/9/2013 07:04:26 [FATAL] Setup - Errors faced in OS requirement checks. Exiting...
                    1/9/2013 07:04:26 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 07:04:29 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 07:04:29 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 07:04:29 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 07:04:29 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 07:04:29 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 07:04:29 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 07:04:29 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 07:04:39 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 07:04:39 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 07:04:39 [INFO] Setup - Start Adobe Setup
                    1/9/2013 07:04:39 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 07:04:39 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 07:04:41 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 07:04:41 [INFO] PIM - XML is valid
                    1/9/2013 07:04:41 [WARN] PIM - Failed to find Node
                    1/9/2013 07:04:41 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 07:04:41 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 07:04:41 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 07:04:41 [INFO] Utilities - Folder does not exist
                    1/9/2013 07:04:41 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 07:04:41 [INFO] Utilities - File does not exist
                    1/9/2013 07:04:41 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:04:41 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 07:04:41 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:04:41 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 07:04:41 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 07:04:41 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 07:04:41 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:04:41 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 07:04:41 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 07:04:41 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 07:04:41 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 07:04:41 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 07:04:41 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 07:04:41 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:04:41 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:04:41 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 07:04:41 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 07:04:41 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 07:04:41 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 07:05:21 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 07:05:21 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 07:05:21 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 07:05:21 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 07:05:21 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 07:05:21 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 07:05:21 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 07:13:01 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 07:13:01 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 07:13:01 [INFO] Setup - Start Adobe Setup
                    1/9/2013 07:13:01 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 07:13:01 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 07:13:02 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 07:13:02 [INFO] PIM - XML is valid
                    1/9/2013 07:13:02 [WARN] PIM - Failed to find Node
                    1/9/2013 07:13:02 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 07:13:02 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 07:13:02 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 07:13:02 [INFO] Utilities - Folder does not exist
                    1/9/2013 07:13:02 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 07:13:02 [INFO] Utilities - File does not exist
                    1/9/2013 07:13:02 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:13:02 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 07:13:02 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:13:02 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 07:13:02 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 07:13:02 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 07:13:02 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:13:02 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 07:13:02 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 07:13:02 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 07:13:02 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 07:13:02 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 07:13:02 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 07:13:02 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:13:02 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:13:02 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 07:13:02 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 07:13:02 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 07:13:02 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 07:13:05 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 07:13:05 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 07:13:05 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 07:13:05 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 07:13:05 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 07:13:05 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 07:13:05 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 07:18:54 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 07:18:54 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 07:18:54 [INFO] Setup - Start Adobe Setup
                    1/9/2013 07:18:54 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 07:18:54 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 07:18:54 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 07:18:54 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 07:18:54 [INFO] PIM - XML is valid
                    1/9/2013 07:18:54 [WARN] PIM - Failed to find Node
                    1/9/2013 07:18:54 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 07:18:54 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 07:18:54 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 07:18:54 [INFO] Utilities - Folder does not exist
                    1/9/2013 07:18:54 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 07:18:54 [INFO] Utilities - File does not exist
                    1/9/2013 07:18:54 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:18:55 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 07:18:55 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:18:55 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 07:18:55 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:18:55 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 07:18:55 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 07:18:55 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 07:18:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:18:55 [INFO] PIM - XML is valid
                    1/9/2013 07:18:55 [WARN] PIM - Failed to find Node
                    1/9/2013 07:18:55 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 07:18:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 07:18:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 07:18:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 07:18:55 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 07:18:55 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 07:18:55 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 07:18:55 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 07:18:55 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:18:55 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:18:55 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 07:18:55 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 07:18:55 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 07:18:55 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 07:19:30 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 07:19:30 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 07:19:30 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 07:19:30 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 07:19:30 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 07:19:30 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 07:19:30 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 07:21:39 [INFO] PIM - Build Version - 1.5.115.0
                    1/9/2013 07:21:39 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 07:21:39 [INFO] Utilities - Folder does not exist
                    1/9/2013 07:21:39 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 07:21:39 [INFO] Utilities - File does not exist
                    1/9/2013 07:21:39 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:21:39 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 07:21:39 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:21:39 [INFO] PIM - Updater Inventory location:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\resources\updaterinventory.dll
                    1/9/2013 07:21:39 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 07:21:39 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 07:21:39 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 07:21:39 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx
                    1/9/2013 07:21:39 [INFO] PIM - XML is valid
                    1/9/2013 07:21:39 [WARN] PIM - Failed to find Node
                    1/9/2013 07:21:39 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Package id EA2BC663-B77E-49CD-A81D-1CBE763C9CE2 is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 07:21:39 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\UWA\UWA.pimx
                    1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Package id 7A28185C-2F17-48A0-A0AC-A470B17743CC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 07:21:39 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\DWA\DWA.pimx
                    1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Package id 28D6E8A4-E4EC-45B0-85C4-E749B884D817 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 07:21:39 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\LWA\LWA.pimx
                    1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Package id 42509BD9-5E28-4A2A-AEA7-2535481A969B is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 07:21:38 [INFO] Setup - Build Version - 1.5.115.0
                    1/9/2013 07:21:38 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 07:21:38 [INFO] Setup - Start Adobe Setup
                    1/9/2013 07:21:38 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 07:21:38 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 07:21:38 [INFO] Setup - Dictionary Path: C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 07:21:38 [INFO] PIM - Trying to access xml at path:C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\resources\setup.xml
                    1/9/2013 07:21:38 [INFO] PIM - XML is valid
                    1/9/2013 07:21:38 [WARN] PIM - Failed to find Node
                    1/9/2013 07:21:38 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 07:21:39 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 07:21:39 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 07:21:39 [INFO] Setup - Start Installing core package - C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx
                    1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 07:21:39 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 07:21:39 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 07:21:39 [INFO] PIM - START installPackage at file C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx
                    1/9/2013 07:21:39 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 07:21:41 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 07:21:41 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 07:21:39 [INFO] Setup - Finished Installing core package - C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 07:21:39 [FATAL] Setup - Error installing C:\Program Files (x86)\Common Files\Adobe\AdobeApplicationManager\AAMSetup\packages\core\PDApp.pimx package.
                    1/9/2013 07:21:39 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 07:21:41 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 07:21:41 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 07:21:41 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 07:21:41 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 07:21:41 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 07:21:55 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 07:21:55 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 07:21:55 [INFO] Setup - Start Adobe Setup
                    1/9/2013 07:21:55 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 07:21:55 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 07:21:55 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 07:21:55 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 07:21:55 [INFO] PIM - XML is valid
                    1/9/2013 07:21:55 [WARN] PIM - Failed to find Node
                    1/9/2013 07:21:55 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 07:21:56 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 07:21:56 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 07:21:56 [INFO] Utilities - Folder does not exist
                    1/9/2013 07:21:56 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 07:21:56 [INFO] Utilities - File does not exist
                    1/9/2013 07:21:56 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:21:56 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 07:21:56 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:21:56 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 07:21:56 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 07:21:56 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 07:21:56 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 07:21:56 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:21:56 [INFO] PIM - XML is valid
                    1/9/2013 07:21:56 [WARN] PIM - Failed to find Node
                    1/9/2013 07:21:56 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 07:21:56 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 07:21:56 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 07:21:56 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 07:21:56 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 07:21:56 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 07:21:56 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 07:21:56 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 07:21:56 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:21:56 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:21:56 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 07:21:56 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 07:21:56 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 07:21:56 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 07:22:00 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 07:22:00 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 07:22:00 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 07:22:00 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 07:22:00 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 07:22:00 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 07:22:00 [INFO] Setup - End Adobe Setup. Exit code: 1
                    1/9/2013 07:30:01 [INFO] Setup - Build Version - 2.0.242.0
                    1/9/2013 07:30:01 [INFO] Setup - Logging Level verbosity Set  to 4
                    1/9/2013 07:30:01 [INFO] Setup - Start Adobe Setup
                    1/9/2013 07:30:01 [INFO] Setup - TimeLog: Bootstrapper Start
                    1/9/2013 07:30:01 [INFO] Setup - TimeLog: Start initial checks
                    1/9/2013 07:30:03 [INFO] Setup - Dictionary Path: D:\Adobe CS5_5\resources\Dictionary\en_US\stringTable.zdct
                    1/9/2013 07:30:03 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\resources\setup.xml
                    1/9/2013 07:30:03 [INFO] PIM - XML is valid
                    1/9/2013 07:30:03 [WARN] PIM - Failed to find Node
                    1/9/2013 07:30:03 [INFO] Setup - Found 3 packages in setup manifest
                    1/9/2013 07:30:04 [INFO] PIM - Build Version - 2.0.242.0
                    1/9/2013 07:30:04 [INFO] PIM - Logging Level verbosity Set  to 4
                    1/9/2013 07:30:04 [INFO] Utilities - Folder does not exist
                    1/9/2013 07:30:04 [INFO] PIM - CREATE PIM Instance ...
                    1/9/2013 07:30:05 [INFO] Utilities - File does not exist
                    1/9/2013 07:30:05 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:30:06 [INFO] PIM - SUCCESS Created Tables.
                    1/9/2013 07:30:06 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:30:06 [INFO] PIM - Updater Inventory location:D:\Adobe CS5_5\resources\updaterinventory.dll
                    1/9/2013 07:30:07 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                    1/9/2013 07:30:07 [INFO] PIM - Current db schema version on machine 1.
                    1/9/2013 07:30:07 [INFO] PIM - Current db schema version to install 1.
                    1/9/2013 07:30:07 [INFO] PIM - PIM DB Schema is up to date. Current schema version is 1.
                    1/9/2013 07:30:07 [INFO] PIM - PIM Database is Up To Date.
                    1/9/2013 07:30:07 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:30:07 [INFO] PIM - XML is valid
                    1/9/2013 07:30:07 [WARN] PIM - Failed to find Node
                    1/9/2013 07:30:07 [ERROR] PIM - getInstalledPackageSize: Package folder does not exist on the system.
                    1/9/2013 07:30:07 [INFO] PIM - PackageCheck: Package id E09D47A9-4501-43C1-A50B-E264DB5E498D is a old Package, new is installed on the system. Size required: 0
                    1/9/2013 07:30:07 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\UWA\UWA.pimx
                    1/9/2013 07:30:07 [INFO] PIM - PackageCheck: Package id CC1D48BA-E659-42D4-9511-F208F19C3EDC is a old Package, new is installed on the system. Size required: 10166919
                    1/9/2013 07:30:07 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\DWA\DWA.pimx
                    1/9/2013 07:30:07 [INFO] PIM - PackageCheck: Package id 4F576A64-1680-4E79-B4A2-CFAC1A841C06 is a old Package, new is installed on the system. Size required: 4753339
                    1/9/2013 07:30:07 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\LWA\LWA.pimx
                    1/9/2013 07:30:09 [INFO] PIM - PackageCheck: Package id D2E20EE6-5E36-40A4-8CB2-EC0C2E0B6912 is a old Package, new is installed on the system. Size required: 11019801
                    1/9/2013 07:30:09 [INFO] PIM - PackageCheck: Extra Package id 54FD72DC-72EC-4CDC-8828-F07C4E9E6FA2 found in ACF. Size required: 3259607
                    1/9/2013 07:30:09 [INFO] PIM - PackageCheck: Extra Package id 6D2A548B-C50D-46BA-B83E-C8199C6A9406 found in ACF. Size required: 27251758
                    1/9/2013 07:30:10 [INFO] PIM - PackageCheck: Extra Package id FAFC744B-DDFB-4097-A41D-7E9539FEBAF9 found in ACF. Size required: 13472807
                    1/9/2013 07:30:10 [INFO] PIM - PackageCheck: Extra Package id F0158AAB-0779-4B40-A07D-3F2A21D47E74 found in ACF. Size required: 6728883
                    1/9/2013 07:30:10 [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 84318425
                    1/9/2013 07:30:10 [INFO] Setup - TimeLog: End initial checks
                    1/9/2013 07:30:10 [INFO] Setup - TimeLog: Begin Installing
                    1/9/2013 07:30:10 [INFO] Setup - Start Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:30:10 [INFO] PIM - START installPackage at file D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:30:10 [INFO] PIM - Trying to access xml at path:D:\Adobe CS5_5\packages\core\PDApp.pimx
                    1/9/2013 07:30:10 [INFO] PIM - XML is valid
                    1/9/2013 07:30:10 [WARN] PIM - Failed to find Node
                    1/9/2013 07:30:10 [ERROR] PIM - Package folder does not exist on the system.
                    1/9/2013 07:30:10 [INFO] Setup - Finished Installing core package - D:\Adobe CS5_5\packages\core\PDApp.pimx, Return status: -1
                    1/9/2013 07:30:10 [FATAL] Setup - Error installing D:\Adobe CS5_5\packages\core\PDApp.pimx package.
                    1/9/2013 07:30:10 [INFO] Setup - TimeLog: End Installing. Now launching PDApp
                    1/9/2013 07:30:39 [INFO] PIM - PIMSqlite closeDB status 0
                    1/9/2013 07:30:39 [INFO] PIM - FREE PIM Instance ...
                    1/9/2013 07:30:39 [INFO] Setup - cleanUSF: Deleting Path C:\Users\Samantha\AppData\Local\Adobe\OOBE\PDApp
                    1/9/2013 07:30:39 [INFO] Setup - Setting current directory to C:\Users\Samantha\AppData\Local\Adobe\OOBE
                    1/9/2013 07:30:39 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe\OOBE. Error Code:145
                    1/9/2013 07:30:39 [ERROR] Setup - Error in deleting folder C:\Users\Samantha\AppData\Local\Adobe. Error Code:145
                    1/9/2013 07:30:39 [INFO] Setup - End Adobe Setup. Exit code: 1
                    • 9. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                      pebble
                      I have the same problem using os x 10.9.
                      I checked the file size of the Akaimai Download Manage and it was 2.4GB, my file size is 2.57GB. Is that ok that it's larger?
                      I went to the Library to find the log files and there is no Adobe folder. Is there somewhere else I can look? Here's a screen shot of my Library/Logs folder.
                      Banners_and_Alerts_and_Logs_and_Adobe_Community__Edit_Message__Re___CS5.5__Installer_failed_to_initialize._Please_download_Adobe_Support_Advisor_to_detect_the_problem._.png
                      • 10. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                        pebble Level 1
                        I found this PDApp.log file which contained Adobe CS5... here is the log:   Wed Dec 11 22:38:04 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 22:38:04 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 22:38:04 2013     [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 22:38:04 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x23c430 {NSUnderlyingError=0x23c3d0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=(     Remove )}. Wed Dec 11 22:38:04 2013     [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 22:38:04 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 22:38:04 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 22:38:04 2013     [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 22:38:04 2013     [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 22:38:04 2013     [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 22:38:04 2013     [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 22:38:04 2013     [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 22:38:04 2013     [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 22:38:04 2013     [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 22:38:04 2013     [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 22:38:04 2013     [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 22:38:04 2013     [INFO] PIM - freeDiskSpace ... 250678407168 Wed Dec 11 22:38:04 2013     [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 22:38:04 2013     [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 22:38:04 2013     [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 22:38:05 2013     [FATAL] PIM - Error in copy. Wed Dec 11 22:38:04 2013     [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 22:38:04 2013     [INFO] Setup - Logging Level verbosity Set  to 4 Wed Dec 11 22:38:04 2013     [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 22:38:04 2013     [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 22:38:04 2013     [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 22:38:04 2013     [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 22:38:04 2013     [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 22:38:04 2013     [INFO] Setup - TimeLog: End initial checks Wed Dec 11 22:38:04 2013     [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 22:38:05 2013     [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 22:38:05 2013     [FATAL] Setup - Error installing Packages. Wed Dec 11 22:38:34 2013     [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x15f370 {NSUnderlyingError=0x15f050 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=(     Remove )} Wed Dec 11 22:38:05 2013     [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 22:38:05 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x455560 {NSUnderlyingError=0x44d1c0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=(     Remove )}. Wed Dec 11 22:38:05 2013     [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 22:38:34 2013     [INFO] PIM - PIMSqlite closeDB status 0  Wed Dec 11 22:38:34 2013     [INFO] PIM - FREE PIM Instance ... Wed Dec 11 22:38:34 2013     [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 22:41:02 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 22:41:02 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 22:41:02 2013     [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 22:41:02 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x38c330 {NSUnderlyingError=0x38c2d0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=(     Remove )}. Wed Dec 11 22:41:02 2013     [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 22:41:02 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 22:41:02 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 22:41:02 2013     [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 22:41:02 2013     [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 22:41:02 2013     [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 22:41:02 2013     [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 22:41:02 2013     [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 22:41:02 2013     [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 22:41:02 2013     [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 22:41:02 2013     [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 22:41:02 2013     [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 22:41:02 2013     [INFO] PIM - freeDiskSpace ... 249871843328 Wed Dec 11 22:41:02 2013     [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 22:41:02 2013     [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 22:41:02 2013     [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 22:41:03 2013     [FATAL] PIM - Error in copy. Wed Dec 11 22:48:01 2013     [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 22:48:01 2013     [INFO] Setup - Logging Level verbosity Set  to 4 Wed Dec 11 22:48:01 2013     [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 22:48:01 2013     [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 22:48:01 2013     [INFO] Setup - Launch Path set to /Applications Wed Dec 11 22:48:01 2013     [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 22:48:01 2013     [ERROR] Setup - Another Deployment workflow already running. Wed Dec 11 22:48:01 2013     [INFO] Setup - TimeLog: End initial checks Wed Dec 11 22:48:06 2013     [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 22:41:02 2013     [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 22:41:02 2013     [INFO] Setup - Logging Level verbosity Set  to 4 Wed Dec 11 22:41:02 2013     [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 22:41:02 2013     [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 22:41:02 2013     [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 22:41:02 2013     [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 22:41:02 2013     [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 22:41:02 2013     [INFO] Setup - TimeLog: End initial checks Wed Dec 11 22:41:02 2013     [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 22:41:03 2013     [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 22:41:03 2013     [FATAL] Setup - Error installing Packages. Wed Dec 11 22:49:46 2013     [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x384140 {NSUnderlyingError=0x3b70e0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=(     Remove )} Wed Dec 11 22:41:03 2013     [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 22:41:03 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x46f460 {NSUnderlyingError=0x4721e0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=(     Remove )}. Wed Dec 11 22:41:03 2013     [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 22:49:46 2013     [INFO] PIM - PIMSqlite closeDB status 0  Wed Dec 11 22:49:46 2013     [INFO] PIM - FREE PIM Instance ... Wed Dec 11 22:49:46 2013     [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 23:07:52 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:07:52 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 23:07:52 2013     [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 23:07:52 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x71e1b0 {NSUnderlyingError=0x71e150 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=(     Remove )}. Wed Dec 11 23:07:52 2013     [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 23:07:52 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:07:52 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 23:07:52 2013     [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 23:07:52 2013     [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 23:07:52 2013     [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 23:07:52 2013     [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 23:07:52 2013     [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 23:07:52 2013     [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 23:07:52 2013     [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 23:07:52 2013     [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 23:07:52 2013     [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 23:07:52 2013     [INFO] PIM - freeDiskSpace ... 248216338432 Wed Dec 11 23:07:52 2013     [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 23:07:52 2013     [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 23:07:52 2013     [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 23:07:53 2013     [FATAL] PIM - Error in copy. Wed Dec 11 23:07:51 2013     [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 23:07:51 2013     [INFO] Setup - Logging Level verbosity Set  to 4 Wed Dec 11 23:07:51 2013     [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 23:07:52 2013     [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 23:07:52 2013     [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 23:07:52 2013     [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 23:07:52 2013     [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 23:07:52 2013     [INFO] Setup - TimeLog: End initial checks Wed Dec 11 23:07:52 2013     [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 23:07:53 2013     [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 23:07:53 2013     [FATAL] Setup - Error installing Packages. Wed Dec 11 23:07:56 2013     [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x733f60 {NSUnderlyingError=0x73a570 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=(     Remove )} Wed Dec 11 23:07:53 2013     [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 23:07:53 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x65edb0 {NSUnderlyingError=0x65efd0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=(     Remove )}. Wed Dec 11 23:07:53 2013     [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 23:07:56 2013     [INFO] PIM - PIMSqlite closeDB status 0  Wed Dec 11 23:07:56 2013     [INFO] PIM - FREE PIM Instance ... Wed Dec 11 23:07:56 2013     [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 23:18:17 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:18:17 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 23:18:17 2013     [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 23:18:17 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x45f040 {NSUnderlyingError=0x45ef30 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=(     Remove )}. Wed Dec 11 23:18:17 2013     [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 23:18:17 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:18:17 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 23:18:17 2013     [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 23:18:17 2013     [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 23:18:17 2013     [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 23:18:17 2013     [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 23:18:17 2013     [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 23:18:17 2013     [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 23:18:17 2013     [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 23:18:17 2013     [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 23:18:17 2013     [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 23:18:17 2013     [INFO] PIM - freeDiskSpace ... 247905804288 Wed Dec 11 23:18:17 2013     [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 23:18:17 2013     [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 23:18:17 2013     [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 23:18:19 2013     [FATAL] PIM - Error in copy. Wed Dec 11 23:18:17 2013     [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 23:18:17 2013     [INFO] Setup - Logging Level verbosity Set  to 4 Wed Dec 11 23:18:17 2013     [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 23:18:17 2013     [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 23:18:17 2013     [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 23:18:17 2013     [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 23:18:17 2013     [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 23:18:17 2013     [INFO] Setup - TimeLog: End initial checks Wed Dec 11 23:18:17 2013     [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 23:18:19 2013     [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 23:18:19 2013     [FATAL] Setup - Error installing Packages. Wed Dec 11 23:18:20 2013     [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x47bd70 {NSUnderlyingError=0x47c5b0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=(     Remove )} Wed Dec 11 23:18:19 2013     [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 23:18:19 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x424e120 {NSUnderlyingError=0x424e350 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=(     Remove )}. Wed Dec 11 23:18:19 2013     [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 23:18:20 2013     [INFO] PIM - PIMSqlite closeDB status 0  Wed Dec 11 23:18:20 2013     [INFO] PIM - FREE PIM Instance ... Wed Dec 11 23:18:20 2013     [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 23:21:43 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:21:43 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 23:21:43 2013     [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 23:21:43 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x6358d0 {NSUnderlyingError=0x634180 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=(     Remove )}. Wed Dec 11 23:21:43 2013     [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 23:21:43 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:21:43 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 23:21:43 2013     [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 23:21:43 2013     [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 23:21:43 2013     [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 23:21:43 2013     [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 23:21:43 2013     [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 23:21:43 2013     [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 23:21:43 2013     [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 23:21:43 2013     [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 23:21:43 2013     [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 23:21:43 2013     [INFO] PIM - freeDiskSpace ... 248414744576 Wed Dec 11 23:21:43 2013     [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 23:21:43 2013     [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 23:21:43 2013     [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 23:21:44 2013     [FATAL] PIM - Error in copy. Wed Dec 11 23:21:43 2013     [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 23:21:43 2013     [INFO] Setup - Logging Level verbosity Set  to 4 Wed Dec 11 23:21:43 2013     [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 23:21:43 2013     [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 23:21:43 2013     [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 23:21:43 2013     [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 23:21:43 2013     [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 23:21:43 2013     [INFO] Setup - TimeLog: End initial checks Wed Dec 11 23:21:43 2013     [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 23:21:44 2013     [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 23:21:44 2013     [FATAL] Setup - Error installing Packages. Wed Dec 11 23:21:47 2013     [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x255f90 {NSUnderlyingError=0x2534b0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=(     Remove )} Wed Dec 11 23:21:44 2013     [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 23:21:44 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x254870 {NSUnderlyingError=0x255710 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=(     Remove )}. Wed Dec 11 23:21:44 2013     [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 23:21:47 2013     [INFO] PIM - PIMSqlite closeDB status 0  Wed Dec 11 23:21:47 2013     [INFO] PIM - FREE PIM Instance ... Wed Dec 11 23:21:47 2013     [INFO] Setup - Exiting Installer with Code: 0 Wed Dec 11 23:26:07 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:26:07 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 23:26:07 2013     [WARN] PIM - Detected Old content in USF trying to delte it... Wed Dec 11 23:26:07 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x24a810 {NSUnderlyingError=0x24a7a0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=(     Remove )}. Wed Dec 11 23:26:07 2013     [WARN] PIM - Failed to delete Old content in USF. Wed Dec 11 23:26:07 2013     [INFO] PIM - Build Version - 1.0.175.0 Wed Dec 11 23:26:07 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Wed Dec 11 23:26:07 2013     [INFO] PIM - CREATE PIM Instance ... Wed Dec 11 23:26:07 2013     [INFO] PIM - trying to createOrUpdatePIMDbSchema. Wed Dec 11 23:26:07 2013     [INFO] PIM - SUCCESS Created Tables. Wed Dec 11 23:26:07 2013     [INFO] PIM - PIM Database is Up To Date. Wed Dec 11 23:26:07 2013     [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Wed Dec 11 23:26:07 2013     [INFO] PIM - BEGIN pim_requireUpdateAtPath... Wed Dec 11 23:26:07 2013     [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Wed Dec 11 23:26:07 2013     [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Wed Dec 11 23:26:07 2013     [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Wed Dec 11 23:26:07 2013     [INFO] PIM - freeDiskSpace ... 248442183680 Wed Dec 11 23:26:07 2013     [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Wed Dec 11 23:26:07 2013     [INFO] PIM - SUCCESS insertPackageUpdateList. Wed Dec 11 23:26:07 2013     [INFO] PIM - SUCCESS insertAppletRegInfoList. Wed Dec 11 23:26:08 2013     [FATAL] PIM - Error in copy. Wed Dec 11 23:26:07 2013     [INFO] Setup - Build Version - 1.0.175.0 Wed Dec 11 23:26:07 2013     [INFO] Setup - Logging Level verbosity Set  to 4 Wed Dec 11 23:26:07 2013     [INFO] Setup - TimeLog: Bootstrapper Start Wed Dec 11 23:26:07 2013     [INFO] Setup - TimeLog: Start initial checks Wed Dec 11 23:26:07 2013     [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Wed Dec 11 23:26:07 2013     [INFO] Setup - Found 3 packages in setup manifest Wed Dec 11 23:26:07 2013     [INFO] Setup - Latest Build not installed in ACF. Wed Dec 11 23:26:07 2013     [INFO] Setup - TimeLog: End initial checks Wed Dec 11 23:26:07 2013     [INFO] Setup - TimeLog: Begin Installing Wed Dec 11 23:26:08 2013     [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Wed Dec 11 23:26:08 2013     [FATAL] Setup - Error installing Packages. Wed Dec 11 23:43:37 2013     [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x45a1e0 {NSUnderlyingError=0x44e760 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=(     Remove )} Wed Dec 11 23:26:08 2013     [FATAL] PIM - Error Failed to extract assets... Wed Dec 11 23:26:08 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x24a410 {NSUnderlyingError=0x2476d0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=(     Remove )}. Wed Dec 11 23:26:08 2013     [FATAL] PIM - Error Failed to remove the Package copied Wed Dec 11 23:43:37 2013     [INFO] PIM - PIMSqlite closeDB status 0  Wed Dec 11 23:43:37 2013     [INFO] PIM - FREE PIM Instance ... Wed Dec 11 23:43:37 2013     [INFO] Setup - Exiting Installer with Code: 0 Thu Dec 12 09:16:11 2013     [INFO] PIM - Build Version - 1.0.175.0 Thu Dec 12 09:16:11 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Thu Dec 12 09:16:11 2013     [WARN] PIM - Detected Old content in USF trying to delte it... Thu Dec 12 09:16:11 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x34e5e0 {NSUnderlyingError=0x3446f0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/, NSUserStringVariant=(     Remove )}. Thu Dec 12 09:16:11 2013     [WARN] PIM - Failed to delete Old content in USF. Thu Dec 12 09:16:11 2013     [INFO] PIM - Build Version - 1.0.175.0 Thu Dec 12 09:16:11 2013     [INFO] PIM - Logging Level verbosity Set  to 4 Thu Dec 12 09:16:11 2013     [INFO] PIM - CREATE PIM Instance ... Thu Dec 12 09:16:11 2013     [INFO] PIM - trying to createOrUpdatePIMDbSchema. Thu Dec 12 09:16:11 2013     [INFO] PIM - SUCCESS Created Tables. Thu Dec 12 09:16:11 2013     [INFO] PIM - PIM Database is Up To Date. Thu Dec 12 09:16:11 2013     [INFO] PIM - Updater Inventory location:/Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/Install.app/Contents/Frameworks/UpdaterInventory.framework/UpdaterInventory Thu Dec 12 09:16:11 2013     [INFO] PIM - BEGIN pim_requireUpdateAtPath... Thu Dec 12 09:16:11 2013     [INFO] PIM - PIM CF PATH :/Library/Application Support/Adobe/OOBE/PDApp Thu Dec 12 09:16:11 2013     [INFO] PIM - PIM db doesnot exits at the destination ... req update YES. Thu Dec 12 09:16:11 2013     [INFO] PIM - pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 103182610 Thu Dec 12 09:16:11 2013     [INFO] PIM - freeDiskSpace ... 241479671808 Thu Dec 12 09:16:11 2013     [INFO] PIM - START installPackage at file /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx Thu Dec 12 09:16:11 2013     [INFO] PIM - SUCCESS insertPackageUpdateList. Thu Dec 12 09:16:11 2013     [INFO] PIM - SUCCESS insertAppletRegInfoList. Thu Dec 12 09:16:12 2013     [FATAL] PIM - Error in copy. Thu Dec 12 09:16:11 2013     [INFO] Setup - Build Version - 1.0.175.0 Thu Dec 12 09:16:11 2013     [INFO] Setup - Logging Level verbosity Set  to 4 Thu Dec 12 09:16:11 2013     [INFO] Setup - TimeLog: Bootstrapper Start Thu Dec 12 09:16:11 2013     [INFO] Setup - TimeLog: Start initial checks Thu Dec 12 09:16:11 2013     [INFO] Setup - Launch Path set to /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard Thu Dec 12 09:16:11 2013     [INFO] Setup - Found 3 packages in setup manifest Thu Dec 12 09:16:11 2013     [INFO] Setup - Latest Build not installed in ACF. Thu Dec 12 09:16:11 2013     [INFO] Setup - TimeLog: End initial checks Thu Dec 12 09:16:11 2013     [INFO] Setup - TimeLog: Begin Installing Thu Dec 12 09:16:12 2013     [FATAL] Setup - Error installing core /Volumes/Adobe CS5 Design Standard/Adobe CS5 Design Standard/packages/core/PDApp.pimx package. pim_installPackage returned -8 Thu Dec 12 09:16:12 2013     [FATAL] Setup - Error installing Packages. Thu Dec 12 09:16:22 2013     [ERROR] Setup - Error while cleaning up. Error: Error Domain=NSCocoaErrorDomain Code=513 "“PDApp” couldn’t be removed because you don’t have permission to access it." UserInfo=0x37f300 {NSUnderlyingError=0x344dd0 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp, NSUserStringVariant=(     Remove )} Thu Dec 12 09:16:12 2013     [FATAL] PIM - Error Failed to extract assets... Thu Dec 12 09:16:12 2013     [INFO] Native-Utils - NOTE Could not remove existing backup path. Error Error Domain=NSCocoaErrorDomain Code=513 "“core” couldn’t be removed because you don’t have permission to access it." UserInfo=0x7335e0 {NSUnderlyingError=0x735530 "The operation couldn’t be completed. Permission denied", NSFilePath=/Users/caitlinmann/Applications/Adobe/OOBE/PDApp/core, NSUserStringVariant=(     Remove )}. Thu Dec 12 09:16:12 2013     [FATAL] PIM - Error Failed to remove the Package copied Thu Dec 12 09:16:22 2013     [INFO] PIM - PIMSqlite closeDB status 0  Thu Dec 12 09:16:22 2013     [INFO] PIM - FREE PIM Instance ... Thu Dec 12 09:16:22 2013     [INFO] Setup - Exiting Installer with Code: 0
                        • 11. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                          polave
                          Hello,
                          I have the disc version.
                          I have just upgraded iMac's and I'm trying to install CS5 into my new iMac....and get the same response.
                          When I run Support, it tells me there is no issue.
                          This is my error log SUMMARY. If you could analyze it and provide suggestions please?
                          Many thanks,
                          Patrick
                          SUMMARY
                          - 0 fatal error(s), 3 error(s), 0 warning(s)
                          ----------- Payload: {AD7623FD-F90A-4181-A37C-63342ACC3FA7} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul 15.0.2.0 -----------
                          ERROR: DF019: Unable to locate file to patch at "/Applications/Adobe Illustrator CS5/Adobe Illustrator.app/Contents/Resources/es.lproj/InfoPlist.strings"(Seq 52)
                          ERROR: DW063: Command ARKPatchCommand failed.(Seq 52)
                          ERROR: DW050: The following payload errors were found during install:
                          ERROR: DW050:  - Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul: Install failed
                          Please search the above error/warning string(s) to find when the error occurred.
                          These errors resulted in installer Exit Code mentioned below.
                          • 13. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                            RNLDEdits
                            I have the same problem.. with any kind of After Effects from CS6 to CC (2013).. whats the deal?
                            • 14. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                              abdullh47
                              I have more than one file (after effect).
                              Any files intended?
                              Then, what's next?
                              • 15. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                Trompie
                                This is my log files. Please analyse
                                2014/10/26 9:21:54,261 PM CoreServicesUIAgent[3428]: Error -60005 creating authorization
                                2014/10/26 9:21:54,605 PM CoreServicesUIAgent[3428]: Error: qtn_file_apply_to_path error: Read-only file system
                                What should I do to fix?
                                • 19. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                  mohammeda7838692
                                  hi
                                  i was installing Dreamweaver  then i cancelled to change the language
                                  now i see the message when i try to install
                                  • 20. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                    mohammeda7838692 Level 1
                                    8/6/1436 22:20:39 [INFO] Setup - Build Version - 6.0.335.0
                                    8/6/1436 22:20:39 [INFO] Setup - Logging Level verbosity Set  to 4
                                    8/6/1436 22:20:39 [INFO] Setup - Start Adobe Setup
                                    8/6/1436 22:20:39 [INFO] Setup - TimeLog: Bootstrapper Start
                                    8/6/1436 22:20:39 [INFO] Setup - TimeLog: Start initial checks
                                    8/6/1436 22:20:39 [INFO] Setup - Dictionary Path: C:\Users\nawaf\Desktop\Adobe DW\ADOBE\resources\Dictionary\en_AE\stringTable.zdct
                                    8/6/1436 22:20:39 [INFO] PIM - Trying to access xml at path:C:\Users\nawaf\Desktop\Adobe DW\ADOBE\resources\setup.xml
                                    8/6/1436 22:20:39 [INFO] PIM - XML is valid
                                    8/6/1436 22:20:39 [WARN] PIM - Failed to find Node
                                    8/6/1436 22:20:39 [INFO] Setup - Found 6 packages in setup manifest
                                    8/6/1436 22:20:40 [INFO] PIM - Build Version - 6.0.335.0
                                    8/6/1436 22:20:40 [INFO] PIM - Logging Level verbosity Set  to 4
                                    8/6/1436 22:20:40 [INFO] Utilities - Folder does not exist
                                    8/6/1436 22:20:40 [INFO] PIM - CREATE PIM Instance ...
                                    8/6/1436 22:20:40 [INFO] Utilities - File does not exist
                                    8/6/1436 22:20:40 [INFO] PIM - trying to createOrUpdatePIMDbSchema.
                                    8/6/1436 22:20:40 [INFO] PIM - SUCCESS Created Tables.
                                    8/6/1436 22:20:40 [INFO] PIM - PIM Database is Up To Date.
                                    8/6/1436 22:20:40 [INFO] PIM - Updater Inventory location:C:\Users\nawaf\Desktop\Adobe DW\ADOBE\resources\updaterinventory.dll
                                    8/6/1436 22:20:40 [FATAL] PIM - Error could not executeGeneralSQLQuery.
                                    8/6/1436 22:20:40 [FATAL] PIM - Failed select count(*) from sqlite_master.
                                    8/6/1436 22:20:40 [FATAL] PIM -  unable to open database file.
                                    8/6/1436 22:20:40 [FATAL] PIM - Error in Get Table count.
                                    8/6/1436 22:20:40 [FATAL] PIM - ERROR Failed select count(*) from sqlite_master.
                                    8/6/1436 22:20:40 [ERROR] PIM - Could not createOrUpdatePIMDbSchema.
                                    8/6/1436 22:20:40 [INFO] PIM - PIMSqlite closeDB status 0
                                    8/6/1436 22:20:40 [ERROR] PIM - Failed to initialize ACF pim.db. Database is corrupted. Download a new copy of Adobe Application Manager from http://www.adobe.com,or install this product again.
                                    8/6/1436 22:20:40 [FATAL] Setup - Unable to perform Disk space check
                                    8/6/1436 22:20:40 [FATAL] Setup - Errors faced in OS requirement checks. Exiting...
                                    8/6/1436 22:20:41 [INFO] PIM - PIMSqlite closeDB status 0
                                    8/6/1436 22:20:41 [INFO] PIM - FREE PIM Instance ...
                                    8/6/1436 22:20:41 [INFO] Setup - cleanUSF: Deleting Path C:\Users\nawaf\AppData\Local\Adobe\OOBE\PDApp
                                    8/6/1436 22:20:41 [INFO] Setup - Setting current directory to C:\Users\nawaf\AppData\Local\Adobe\OOBE
                                    8/6/1436 22:20:41 [ERROR] Setup - Error in deleting folder C:\Users\nawaf\AppData\Local\Adobe. Error Code:145
                                    8/6/1436 22:20:41 [INFO] Setup - =================  End Adobe Setup. Exit code: -3  =================
                                    • 21. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                      jakkritp82785322
                                      Windows 64 bit (XP, Vista, 7): \Program Files(x86)\Common Files\Adobe\Installers
                                      - I rename to \Program Files(x86)\Common Files\Adobe2\Installers and i can install
                                      • 23. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                        jjjjjjjjjjjjjjjjjjjjj34
                                        Renaming the Common Files\Adobe\Installer folder did the trick! Thank you!
                                        • 24. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                          EvTheProducer
                                          Renaming it to Common Files/Adobe2/Installer worked thanks, I was kinda scared for a sec
                                          • 25. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                            bot81708769
                                            So CS5 will not work on El Capitan either? I am having the same issue trying to install my disc version of CS5 on my MacBook Pro with 10.11.2 (ElCapitan).
                                            Is there any workaround available without buying all new software, as this was expensive enough?
                                            • 27. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                              jamesf73103913
                                              I have followed these steps and this is all I got??
                                              I am installing Photoshop Elements two and just getting a window opening up saying,
                                              "Installer failed to initialize. Please download Adobe Support Advisor to detect the problem."
                                              Please Help!!!
                                              Thanks, James
                                              • 28. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                                viennali
                                                10/23/16 21:50:36:426 | [INFO] |  | HDSetup | HDSetup | AppContext |  | HDSetup | 974021 | ************************* START Adobe Setup *************************
                                                10/23/16 21:50:36:427 | [INFO] |  | HDSetup | HDSetup | AppContext |  | HDSetup | 974021 | Adobe Setup Version: 3.9.0.334
                                                10/23/16 21:50:38:046 | [INFO] |  | HDSetup | HDPIM | HDPIMSessionManager |  | HDPIM | 974026 | Inside hdpimCreateSession
                                                10/23/16 21:50:38:046 | [INFO] |  | HDSetup | HDPIM | HDPIMSessionManager |  | HDPIM | 974026 | Entering into 'createHDPIMSession'
                                                10/23/16 21:50:38:046 | [INFO] |  | HDSetup | HDPIM | HDPIMSessionManager |  | HDPIM | 974026 | new session '476993E6-BC5D-4B25-AD14-EF37FEC6EDDD' created
                                                10/23/16 21:50:38:046 | [INFO] |  | HDSetup | HDPIM | HDPIMSessionManager |  | HDPIM | 974026 | Exiting hdpimCreateSession, new session ID is '476993E6-BC5D-4B25-AD14-EF37FEC6EDDD'
                                                10/23/16 21:50:43:273 | [INFO] |  | HDSetup | HDPIM | HDPIMSessionManager |  | HDPIM | 974026 | Inside hdpimInstallProduct with request <?xml version="1.0" encoding="UTF-8"?>
                                                <DriverInfo>
                                                    <ProductInfo>
                                                        <SAPCode>ILST</SAPCode>
                                                        <CodexVersion>20.1.0</CodexVersion>
                                                        <Platform>osx10-64</Platform>
                                                        <BuildVersion>20.1.0.174</BuildVersion>
                                                        <Dependencies>
                                                            <Dependency>
        <SAPCode>COCM</SAPCode>
        <CodexVersion>1.0</CodexVersion>
        <Platform>osx10</Platform>
        <BuildVersion>1.0.4</BuildVersion>
                                                            </Dependency>
                                                            <Dependency>
        <SAPCode>CORE</SAPCode>
        <BuildVersion>1.0.12</BuildVersion>
                                                            </Dependency>
                                                            <Dependency>
        <SAPCode>CORG</SAPCode>
                                                            </Dependency>
                                                        </Dependencies>
                                                    </ProductInfo>
                                                    <RequestInfo>
                                                        <ClientWorkingDirectory>/tmp/E8DB77EF-D617-4535-B05A-105B31DACAAC</ClientWorkingDirectory >
                                                        <InstallLanguage>en_US</InstallLanguage>
                                                        <InstallDir></InstallDir>
                                                        <PackageServiceURL>https://prod-rel-ffc-ccm.oobesaas.adobe.com/adobe-ffc-external/core/v2/applications</PackageServiceURL>
                                                        <x-api-key>CreativeCloudInstaller_v1_0</x-api-key>
                                                        <prefMigration>FALSE</prefMigration>
                                                        <PreserveInstallData>true</PreserveInstallData>
                                                        <ConflictXML>/tmp/E8DB77EF-D617-4535-B05A-105B31DACAAC/20F3BCD6-66EE-4B7E-97B7-A99B767172 56</ConflictXML>
                                                    </RequestInfo>
                                                </DriverInfo>
                                                10/23/16 21:50:43:278 | [INFO] |  | HDSetup | HDPIM | HDPIMSessionManager |  | HDPIM | 974026 | Exiting hdpimInstallProduct with status '0'
                                                10/23/16 21:50:44:805 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974097 | Successfully deleted directory from path: /tmp/D3FAE963-D2A8-4604-A671-B4459F30078F. Recursive: 1
                                                10/23/16 21:50:46:132 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974097 | Successfully deleted directory from path: /tmp/A38183A1-7802-4190-B732-6A9DE46CB8C3. Recursive: 1
                                                10/23/16 21:50:47:353 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974097 | Successfully deleted directory from path: /tmp/DF4DDD44-B023-4170-B05A-253F3025E7AB. Recursive: 1
                                                10/23/16 21:50:48:575 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974097 | Successfully deleted directory from path: /tmp/3E2ED34C-6776-4630-ACEC-4B7CE6C8069D. Recursive: 1
                                                10/23/16 21:50:48:575 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Populating install data from Application JSON
                                                10/23/16 21:50:48:579 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Populating install data from Application JSON
                                                10/23/16 21:50:48:580 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Populating install data from Application JSON
                                                10/23/16 21:50:48:581 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Populating install data from Application JSON
                                                10/23/16 21:50:48:592 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Sanitizing data for product-'Adobe Illustrator CC 2015.3'
                                                10/23/16 21:50:48:592 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Sanitizing data for product-'STI_ColorCommonSet_CMYK_HD'
                                                10/23/16 21:50:48:592 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Sanitizing data for product-'STI_Color_HD'
                                                10/23/16 21:50:48:592 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Sanitizing data for product-'STI_ColorCommonSet_RGB_HD'
                                                10/23/16 21:50:48:609 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Sorting packages to install
                                                10/23/16 21:50:48:611 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Package (Name: AdobeIllustrator20-Core Version: 20.1.0.174) selected for install
                                                10/23/16 21:50:48:612 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Package (Name: AdobeIllustrator20-Settings Version: 20.0.0.141) selected for install
                                                10/23/16 21:50:48:614 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Package (Name: AdobeIllustrator20-en_US Version: 20.1.0.174) selected for install
                                                10/23/16 21:50:48:616 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Package (Name: AdobeColorCommonSetCMYK_1_0-mul Version: 1.0.4) selected for install
                                                10/23/16 21:50:48:618 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Package (Name: AdobeColorEU_ExtraSettings_1_0-mul Version: 1.0.12) selected for install
                                                10/23/16 21:50:48:619 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Package (Name: AdobeColorJA_ExtraSettings_1_0-mul Version: 1.0.12) selected for install
                                                10/23/16 21:50:48:621 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Package (Name: AdobeColorNA_Recommended_1_0-mul Version: 1.0.12) selected for install
                                                10/23/16 21:50:48:622 | [INFO] |  | HDSetup | HDPIM | ApplicationManager |  | HDPIM | 974097 | Package (Name: AdobeColorCommonSetRGB_1_0-mul Version: 1.0.4) selected for install
                                                10/23/16 21:50:48:624 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Starting 'DOWNLOAD' task for Package (Name: AdobeColorCommonSetCMYK_1_0-mul Version: 1.0.4)
                                                10/23/16 21:50:48:625 | [INFO] |  | HDSetup | HDPIM | DownloadManager |  | HDPIM | 974162 | Package (Name: AdobeColorCommonSetCMYK_1_0-mul Version: 1.0.4) Download info - DownloadSize: 8345618, DownloadPath:'/tmp/F6672851-1F1D-436C-B44A-ED48DBEF75C5'
                                                10/23/16 21:50:53:458 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Starting 'EXTRACT' task for Package (Name: AdobeColorCommonSetCMYK_1_0-mul Version: 1.0.4)
                                                10/23/16 21:50:53:458 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Completed 'DOWNLOAD' task for Package (Name: AdobeColorCommonSetCMYK_1_0-mul Version: 1.0.4), Time taken '5' sec
                                                10/23/16 21:50:53:458 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Starting 'DOWNLOAD' task for Package (Name: AdobeColorEU_ExtraSettings_1_0-mul Version: 1.0.12)
                                                10/23/16 21:50:53:459 | [INFO] |  | HDSetup | HDPIM | DownloadManager |  | HDPIM | 974162 | Package (Name: AdobeColorEU_ExtraSettings_1_0-mul Version: 1.0.12) Download info - DownloadSize: 4756653, DownloadPath:'/tmp/56B9B4B3-DB02-4832-8439-8F0ECD2CDCF7'
                                                10/23/16 21:50:53:459 | [INFO] |  | HDSetup | HDPIM | ExtractManager |  | HDPIM | 974163 | Package (Name: AdobeColorCommonSetCMYK_1_0-mul Version: 1.0.4) Extract info - ExtractSize: 11937444, ExtractPath:'/.adobeTemp/3C7C059A-6E5B-41C0-853A-1D7376C1447C'
                                                10/23/16 21:50:53:501 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | starting decompression of file /tmp/F6672851-1F1D-436C-B44A-ED48DBEF75C5/AdobeColorCommonSetCMYK_1_0-mul.zip to folder /.adobeTemp/3C7C059A-6E5B-41C0-853A-1D7376C1447C with type
                                                10/23/16 21:50:53:743 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | completed decompression of file /tmp/F6672851-1F1D-436C-B44A-ED48DBEF75C5/AdobeColorCommonSetCMYK_1_0-mul.zip at folder /.adobeTemp/3C7C059A-6E5B-41C0-853A-1D7376C1447C with type  with status code 0
                                                10/23/16 21:50:53:746 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974163 | Successfully deleted directory from path: /tmp/F6672851-1F1D-436C-B44A-ED48DBEF75C5. Recursive: 1
                                                10/23/16 21:50:53:746 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Starting 'INSTALL' task for Package (Name: AdobeColorCommonSetCMYK_1_0-mul Version: 1.0.4)
                                                10/23/16 21:50:53:747 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Completed 'EXTRACT' task for Package (Name: AdobeColorCommonSetCMYK_1_0-mul Version: 1.0.4), Time taken '0' sec
                                                10/23/16 21:50:54:059 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974164 | Successfully deleted directory from path: /.adobeTemp/3C7C059A-6E5B-41C0-853A-1D7376C1447C. Recursive: 1
                                                10/23/16 21:50:54:059 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Completed 'INSTALL' task for Package (Name: AdobeColorCommonSetCMYK_1_0-mul Version: 1.0.4), Time taken '1' sec
                                                10/23/16 21:50:57:701 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Starting 'EXTRACT' task for Package (Name: AdobeColorEU_ExtraSettings_1_0-mul Version: 1.0.12)
                                                10/23/16 21:50:57:701 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Completed 'DOWNLOAD' task for Package (Name: AdobeColorEU_ExtraSettings_1_0-mul Version: 1.0.12), Time taken '4' sec
                                                10/23/16 21:50:57:701 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Starting 'DOWNLOAD' task for Package (Name: AdobeColorJA_ExtraSettings_1_0-mul Version: 1.0.12)
                                                10/23/16 21:50:57:701 | [INFO] |  | HDSetup | HDPIM | ExtractManager |  | HDPIM | 974163 | Package (Name: AdobeColorEU_ExtraSettings_1_0-mul Version: 1.0.12) Extract info - ExtractSize: 5997500, ExtractPath:'/.adobeTemp/77AEF35E-EB4F-4C42-AEA5-660B01AAD90A'
                                                10/23/16 21:50:57:702 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | starting decompression of file /tmp/56B9B4B3-DB02-4832-8439-8F0ECD2CDCF7/AdobeColorEU_ExtraSettings_1_0-mul.zip to folder /.adobeTemp/77AEF35E-EB4F-4C42-AEA5-660B01AAD90A with type
                                                10/23/16 21:50:57:702 | [INFO] |  | HDSetup | HDPIM | DownloadManager |  | HDPIM | 974162 | Package (Name: AdobeColorJA_ExtraSettings_1_0-mul Version: 1.0.12) Download info - DownloadSize: 1895572, DownloadPath:'/tmp/1E62A1DD-4262-4C05-B9D6-E71D0A31E7F8'
                                                10/23/16 21:50:57:790 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | completed decompression of file /tmp/56B9B4B3-DB02-4832-8439-8F0ECD2CDCF7/AdobeColorEU_ExtraSettings_1_0-mul.zip at folder /.adobeTemp/77AEF35E-EB4F-4C42-AEA5-660B01AAD90A with type  with status code 0
                                                10/23/16 21:50:57:791 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974163 | Successfully deleted directory from path: /tmp/56B9B4B3-DB02-4832-8439-8F0ECD2CDCF7. Recursive: 1
                                                10/23/16 21:50:57:791 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Starting 'INSTALL' task for Package (Name: AdobeColorEU_ExtraSettings_1_0-mul Version: 1.0.12)
                                                10/23/16 21:50:57:792 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Completed 'EXTRACT' task for Package (Name: AdobeColorEU_ExtraSettings_1_0-mul Version: 1.0.12), Time taken '0' sec
                                                10/23/16 21:50:57:965 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974164 | Successfully deleted directory from path: /.adobeTemp/77AEF35E-EB4F-4C42-AEA5-660B01AAD90A. Recursive: 1
                                                10/23/16 21:50:57:965 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Completed 'INSTALL' task for Package (Name: AdobeColorEU_ExtraSettings_1_0-mul Version: 1.0.12), Time taken '0' sec
                                                10/23/16 21:51:00:721 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Completed 'DOWNLOAD' task for Package (Name: AdobeColorJA_ExtraSettings_1_0-mul Version: 1.0.12), Time taken '3' sec
                                                10/23/16 21:51:00:721 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Starting 'DOWNLOAD' task for Package (Name: AdobeColorNA_Recommended_1_0-mul Version: 1.0.12)
                                                10/23/16 21:51:00:722 | [INFO] |  | HDSetup | HDPIM | DownloadManager |  | HDPIM | 974162 | Package (Name: AdobeColorNA_Recommended_1_0-mul Version: 1.0.12) Download info - DownloadSize: 1643827, DownloadPath:'/tmp/0595A9AE-DFB9-49AA-AF76-ACC5A4BAD4A5'
                                                10/23/16 21:51:00:722 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Starting 'EXTRACT' task for Package (Name: AdobeColorJA_ExtraSettings_1_0-mul Version: 1.0.12)
                                                10/23/16 21:51:00:722 | [INFO] |  | HDSetup | HDPIM | ExtractManager |  | HDPIM | 974163 | Package (Name: AdobeColorJA_ExtraSettings_1_0-mul Version: 1.0.12) Extract info - ExtractSize: 2866988, ExtractPath:'/.adobeTemp/C27CE6BA-C808-4151-87FE-7F4960AA3651'
                                                10/23/16 21:51:00:723 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | starting decompression of file /tmp/1E62A1DD-4262-4C05-B9D6-E71D0A31E7F8/AdobeColorJA_ExtraSettings_1_0-mul.zip to folder /.adobeTemp/C27CE6BA-C808-4151-87FE-7F4960AA3651 with type
                                                10/23/16 21:51:00:777 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | completed decompression of file /tmp/1E62A1DD-4262-4C05-B9D6-E71D0A31E7F8/AdobeColorJA_ExtraSettings_1_0-mul.zip at folder /.adobeTemp/C27CE6BA-C808-4151-87FE-7F4960AA3651 with type  with status code 0
                                                10/23/16 21:51:00:788 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974163 | Successfully deleted directory from path: /tmp/1E62A1DD-4262-4C05-B9D6-E71D0A31E7F8. Recursive: 1
                                                10/23/16 21:51:00:791 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Starting 'INSTALL' task for Package (Name: AdobeColorJA_ExtraSettings_1_0-mul Version: 1.0.12)
                                                10/23/16 21:51:00:791 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Completed 'EXTRACT' task for Package (Name: AdobeColorJA_ExtraSettings_1_0-mul Version: 1.0.12), Time taken '0' sec
                                                10/23/16 21:51:01:184 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974164 | Successfully deleted directory from path: /.adobeTemp/C27CE6BA-C808-4151-87FE-7F4960AA3651. Recursive: 1
                                                10/23/16 21:51:01:184 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Completed 'INSTALL' task for Package (Name: AdobeColorJA_ExtraSettings_1_0-mul Version: 1.0.12), Time taken '1' sec
                                                10/23/16 21:51:03:441 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Completed 'DOWNLOAD' task for Package (Name: AdobeColorNA_Recommended_1_0-mul Version: 1.0.12), Time taken '3' sec
                                                10/23/16 21:51:03:441 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Starting 'EXTRACT' task for Package (Name: AdobeColorNA_Recommended_1_0-mul Version: 1.0.12)
                                                10/23/16 21:51:03:442 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Starting 'DOWNLOAD' task for Package (Name: AdobeColorCommonSetRGB_1_0-mul Version: 1.0.4)
                                                10/23/16 21:51:03:442 | [INFO] |  | HDSetup | HDPIM | ExtractManager |  | HDPIM | 974163 | Package (Name: AdobeColorNA_Recommended_1_0-mul Version: 1.0.12) Extract info - ExtractSize: 2390004, ExtractPath:'/.adobeTemp/3451D4F6-DE00-41D8-8EEB-E50F9DCE1D40'
                                                10/23/16 21:51:03:442 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | starting decompression of file /tmp/0595A9AE-DFB9-49AA-AF76-ACC5A4BAD4A5/AdobeColorNA_Recommended_1_0-mul.zip to folder /.adobeTemp/3451D4F6-DE00-41D8-8EEB-E50F9DCE1D40 with type
                                                10/23/16 21:51:03:442 | [INFO] |  | HDSetup | HDPIM | DownloadManager |  | HDPIM | 974162 | Package (Name: AdobeColorCommonSetRGB_1_0-mul Version: 1.0.4) Download info - DownloadSize: 7690, DownloadPath:'/tmp/401CC398-7C1A-40D4-9E7E-223B62CC359B'
                                                10/23/16 21:51:03:476 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | completed decompression of file /tmp/0595A9AE-DFB9-49AA-AF76-ACC5A4BAD4A5/AdobeColorNA_Recommended_1_0-mul.zip at folder /.adobeTemp/3451D4F6-DE00-41D8-8EEB-E50F9DCE1D40 with type  with status code 0
                                                10/23/16 21:51:03:477 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974163 | Successfully deleted directory from path: /tmp/0595A9AE-DFB9-49AA-AF76-ACC5A4BAD4A5. Recursive: 1
                                                10/23/16 21:51:03:477 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Starting 'INSTALL' task for Package (Name: AdobeColorNA_Recommended_1_0-mul Version: 1.0.12)
                                                10/23/16 21:51:03:477 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Completed 'EXTRACT' task for Package (Name: AdobeColorNA_Recommended_1_0-mul Version: 1.0.12), Time taken '0' sec
                                                10/23/16 21:51:03:612 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974164 | Successfully deleted directory from path: /.adobeTemp/3451D4F6-DE00-41D8-8EEB-E50F9DCE1D40. Recursive: 1
                                                10/23/16 21:51:03:612 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Completed 'INSTALL' task for Package (Name: AdobeColorNA_Recommended_1_0-mul Version: 1.0.12), Time taken '0' sec
                                                10/23/16 21:51:05:564 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Starting 'EXTRACT' task for Package (Name: AdobeColorCommonSetRGB_1_0-mul Version: 1.0.4)
                                                10/23/16 21:51:05:564 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Completed 'DOWNLOAD' task for Package (Name: AdobeColorCommonSetRGB_1_0-mul Version: 1.0.4), Time taken '2' sec
                                                10/23/16 21:51:05:564 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Starting 'DOWNLOAD' task for Package (Name: AdobeIllustrator20-Core Version: 20.1.0.174)
                                                10/23/16 21:51:05:564 | [INFO] |  | HDSetup | HDPIM | ExtractManager |  | HDPIM | 974163 | Package (Name: AdobeColorCommonSetRGB_1_0-mul Version: 1.0.4) Extract info - ExtractSize: 7972, ExtractPath:'/.adobeTemp/FA2C5C33-1389-4FBC-B750-A7874DD25415'
                                                10/23/16 21:51:05:564 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | starting decompression of file /tmp/401CC398-7C1A-40D4-9E7E-223B62CC359B/AdobeColorCommonSetRGB_1_0-mul.zip to folder /.adobeTemp/FA2C5C33-1389-4FBC-B750-A7874DD25415 with type
                                                10/23/16 21:51:05:565 | [INFO] |  | HDSetup | HDPIM | DownloadManager |  | HDPIM | 974162 | Package (Name: AdobeIllustrator20-Core Version: 20.1.0.174) Download info - DownloadSize: 510327936, DownloadPath:'/tmp/AA226589-B472-44A2-A732-E9BF521B9E70'
                                                10/23/16 21:51:05:567 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | completed decompression of file /tmp/401CC398-7C1A-40D4-9E7E-223B62CC359B/AdobeColorCommonSetRGB_1_0-mul.zip at folder /.adobeTemp/FA2C5C33-1389-4FBC-B750-A7874DD25415 with type  with status code 0
                                                10/23/16 21:51:05:568 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974163 | Successfully deleted directory from path: /tmp/401CC398-7C1A-40D4-9E7E-223B62CC359B. Recursive: 1
                                                10/23/16 21:51:05:568 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Starting 'INSTALL' task for Package (Name: AdobeColorCommonSetRGB_1_0-mul Version: 1.0.4)
                                                10/23/16 21:51:05:568 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Completed 'EXTRACT' task for Package (Name: AdobeColorCommonSetRGB_1_0-mul Version: 1.0.4), Time taken '0' sec
                                                10/23/16 21:51:05:704 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974164 | Successfully deleted directory from path: /.adobeTemp/FA2C5C33-1389-4FBC-B750-A7874DD25415. Recursive: 1
                                                10/23/16 21:51:05:704 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Completed 'INSTALL' task for Package (Name: AdobeColorCommonSetRGB_1_0-mul Version: 1.0.4), Time taken '0' sec
                                                10/23/16 21:53:53:787 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Starting 'EXTRACT' task for Package (Name: AdobeIllustrator20-Core Version: 20.1.0.174)
                                                10/23/16 21:53:53:788 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Completed 'DOWNLOAD' task for Package (Name: AdobeIllustrator20-Core Version: 20.1.0.174), Time taken '168' sec
                                                10/23/16 21:53:53:789 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Starting 'DOWNLOAD' task for Package (Name: AdobeIllustrator20-Settings Version: 20.0.0.141)
                                                10/23/16 21:53:53:789 | [INFO] |  | HDSetup | HDPIM | ExtractManager |  | HDPIM | 974163 | Package (Name: AdobeIllustrator20-Core Version: 20.1.0.174) Extract info - ExtractSize: 1153975667, ExtractPath:'/.adobeTemp/061D0144-55F1-4E39-8ADB-7D5BAB197883'
                                                10/23/16 21:53:53:790 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | starting decompression of file /tmp/AA226589-B472-44A2-A732-E9BF521B9E70/AdobeIllustrator20-Core.zip to folder /.adobeTemp/061D0144-55F1-4E39-8ADB-7D5BAB197883 with type
                                                10/23/16 21:53:53:791 | [INFO] |  | HDSetup | HDPIM | DownloadManager |  | HDPIM | 974162 | Package (Name: AdobeIllustrator20-Settings Version: 20.0.0.141) Download info - DownloadSize: 1100, DownloadPath:'/tmp/41BEF3FC-FB52-4D04-82A2-A4C24AA38CCF'
                                                10/23/16 21:53:55:902 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Completed 'DOWNLOAD' task for Package (Name: AdobeIllustrator20-Settings Version: 20.0.0.141), Time taken '2' sec
                                                10/23/16 21:53:55:902 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Starting 'DOWNLOAD' task for Package (Name: AdobeIllustrator20-en_US Version: 20.1.0.174)
                                                10/23/16 21:53:55:903 | [INFO] |  | HDSetup | HDPIM | DownloadManager |  | HDPIM | 974162 | Package (Name: AdobeIllustrator20-en_US Version: 20.1.0.174) Download info - DownloadSize: 51196261, DownloadPath:'/tmp/CB8CB1A8-0A83-4AC6-AD05-2C4C8B11DA7D'
                                                10/23/16 21:54:11:905 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974162 | Completed 'DOWNLOAD' task for Package (Name: AdobeIllustrator20-en_US Version: 20.1.0.174), Time taken '16' sec
                                                10/23/16 21:54:24:755 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | completed decompression of file /tmp/AA226589-B472-44A2-A732-E9BF521B9E70/AdobeIllustrator20-Core.zip at folder /.adobeTemp/061D0144-55F1-4E39-8ADB-7D5BAB197883 with type  with status code 0
                                                10/23/16 21:54:24:794 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974163 | Successfully deleted directory from path: /tmp/AA226589-B472-44A2-A732-E9BF521B9E70. Recursive: 1
                                                10/23/16 21:54:24:794 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Starting 'INSTALL' task for Package (Name: AdobeIllustrator20-Core Version: 20.1.0.174)
                                                10/23/16 21:54:24:794 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Completed 'EXTRACT' task for Package (Name: AdobeIllustrator20-Core Version: 20.1.0.174), Time taken '31' sec
                                                10/23/16 21:54:24:794 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Starting 'EXTRACT' task for Package (Name: AdobeIllustrator20-Settings Version: 20.0.0.141)
                                                10/23/16 21:54:24:795 | [INFO] |  | HDSetup | HDPIM | ExtractManager |  | HDPIM | 974163 | Package (Name: AdobeIllustrator20-Settings Version: 20.0.0.141) Extract info - ExtractSize: 0, ExtractPath:'/.adobeTemp/E3894148-0993-4C3A-A5DC-9E17D242ED25'
                                                10/23/16 21:54:24:795 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | starting decompression of file /tmp/41BEF3FC-FB52-4D04-82A2-A4C24AA38CCF/AdobeIllustrator20-Settings.zip to folder /.adobeTemp/E3894148-0993-4C3A-A5DC-9E17D242ED25 with type
                                                10/23/16 21:54:24:798 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | completed decompression of file /tmp/41BEF3FC-FB52-4D04-82A2-A4C24AA38CCF/AdobeIllustrator20-Settings.zip at folder /.adobeTemp/E3894148-0993-4C3A-A5DC-9E17D242ED25 with type  with status code 0
                                                10/23/16 21:54:24:799 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974163 | Successfully deleted directory from path: /tmp/41BEF3FC-FB52-4D04-82A2-A4C24AA38CCF. Recursive: 1
                                                10/23/16 21:54:24:800 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Completed 'EXTRACT' task for Package (Name: AdobeIllustrator20-Settings Version: 20.0.0.141), Time taken '0' sec
                                                10/23/16 21:54:24:800 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Starting 'EXTRACT' task for Package (Name: AdobeIllustrator20-en_US Version: 20.1.0.174)
                                                10/23/16 21:54:24:800 | [INFO] |  | HDSetup | HDPIM | ExtractManager |  | HDPIM | 974163 | Package (Name: AdobeIllustrator20-en_US Version: 20.1.0.174) Extract info - ExtractSize: 55155066, ExtractPath:'/.adobeTemp/1B003ED6-804F-4A21-96C3-7D6A0057778F'
                                                10/23/16 21:54:24:800 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | starting decompression of file /tmp/CB8CB1A8-0A83-4AC6-AD05-2C4C8B11DA7D/AdobeIllustrator20-en_US.zip to folder /.adobeTemp/1B003ED6-804F-4A21-96C3-7D6A0057778F with type
                                                10/23/16 21:54:26:107 | [INFO] |  | HDSetup | HDPIM | HDZIPHelper |  | HDPIM | 974163 | completed decompression of file /tmp/CB8CB1A8-0A83-4AC6-AD05-2C4C8B11DA7D/AdobeIllustrator20-en_US.zip at folder /.adobeTemp/1B003ED6-804F-4A21-96C3-7D6A0057778F with type  with status code 0
                                                10/23/16 21:54:26:113 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974163 | Successfully deleted directory from path: /tmp/CB8CB1A8-0A83-4AC6-AD05-2C4C8B11DA7D. Recursive: 1
                                                10/23/16 21:54:26:113 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974163 | Completed 'EXTRACT' task for Package (Name: AdobeIllustrator20-en_US Version: 20.1.0.174), Time taken '2' sec
                                                10/23/16 21:54:34:736 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974164 | Successfully deleted directory from path: /.adobeTemp/061D0144-55F1-4E39-8ADB-7D5BAB197883. Recursive: 1
                                                10/23/16 21:54:34:736 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Completed 'INSTALL' task for Package (Name: AdobeIllustrator20-Core Version: 20.1.0.174), Time taken '10' sec
                                                10/23/16 21:54:34:736 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Starting 'INSTALL' task for Package (Name: AdobeIllustrator20-Settings Version: 20.0.0.141)
                                                10/23/16 21:54:34:901 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974164 | Successfully deleted directory from path: /.adobeTemp/E3894148-0993-4C3A-A5DC-9E17D242ED25. Recursive: 1
                                                10/23/16 21:54:34:901 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Completed 'INSTALL' task for Package (Name: AdobeIllustrator20-Settings Version: 20.0.0.141), Time taken '0' sec
                                                10/23/16 21:54:34:902 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Starting 'INSTALL' task for Package (Name: AdobeIllustrator20-en_US Version: 20.1.0.174)
                                                10/23/16 21:54:35:107 | [INFO] |  | HDSetup | OOBEUtils | FileUtils |  | OOBEUtils | 974164 | Successfully deleted directory from path: /.adobeTemp/1B003ED6-804F-4A21-96C3-7D6A0057778F. Recursive: 1
                                                10/23/16 21:54:35:107 | [INFO] |  | HDSetup | HDPIM | TaskManager |  | HDPIM | 974164 | Completed 'INSTALL' task for Package (Name: AdobeIllustrator20-en_US Version: 20.1.0.174), Time taken '1' sec
                                                10/23/16 21:54:36:990 | [INFO] |  | HDSetup | HDSetup | AppContext |  | HDSetup | 974096 | Exit Code: 0
                                                -------------------------------------- Summary --------------------------------------
                                                - 0 fatal error(s), 0 error(s), 0 warnings(s)
                                                10/23/16 21:54:38:524 | [INFO] |  | HDSetup | HDPIM | HDPIMSessionManager |  | HDPIM | 974026 | Inside hdpimTerminateSession
                                                10/23/16 21:54:38:559 | [INFO] |  | HDSetup | HDPIM | HDPIMSessionManager |  | HDPIM | 974026 | Exiting hdpimTerminateSession, successfully closed session '0'
                                                10/23/16 21:54:38:566 | [INFO] |  | HDSetup | HDSetup | AppContext |  | HDSetup | 974021 | Exit Code: 0
                                                10/23/16 21:54:38:576 | [INFO] |  | HDSetup | HDSetup | AppContext |  | HDSetup | 974021 | *************************  END Adobe Setup  *************************
                                                This is from a mac. since it says "0 errors," what do I do next?
                                                • 29. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                                  lornab8765729
                                                  Hi there
                                                  I am receiving the same error about initialization failed. I am on Windows 8.1 and CS5.5 - can you help me please?
                                                  Kind regards
                                                  Lorna
                                                  • 30. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                                    filipav6471203
                                                    I can't find the folder: Logs/Adobe/Installers. I find Logs's folder but there isn't a log filename with ".log.gz".
                                                    Anyone can help me ?
                                                    • 31. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                                      sophiefercical
                                                      Hello, I have an installation problem (I can't install any adobe application because of an initialisation error message) and find in the log file :
                                                      - 1 fatal error(s), 0 error(s), 3 warnings(s)
                                                      FATAL: Error occured in uninstall product workflow with error code 130 error message
                                                      WARN: Unable to parse conflicting process XML ''
                                                      WARN: There is no package to proccess
                                                      WARN: Directory to delete not present at location 'C:\Program Files (x86)\Common Files\Adobe\PCF'
                                                      What can I do to resolve the problem please?
                                                      Sophie F.
                                                      • 32. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                                        ravenise Level 1
                                                        Not answered, nothing here works. I tried all the steps above; admin account, renaming oobe; also adobe/instalI and a few others, and 'm having the same issue, just started with the cc2018 releases; seems to happen with the older installations now too, which once worked!
                                                        01/07/18 23:55:47:846 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4372 | Build Version - 1.13.0.59
                                                        01/07/18 23:55:47:846 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4372 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:55:47:873 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4372 | Successfully fetched the optionXML content from MSI database ...
                                                        01/07/18 23:55:50:073 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 8068 | Build Version - 1.13.0.59
                                                        01/07/18 23:55:50:073 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 8068 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:55:50:073 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 8068 | Executing immediate custom action for install mode.
                                                        01/07/18 23:55:50:073 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 8068 | The CustomActionData string is : mode=install;sourceDir=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\;installDir=;origDB=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Adobe.msi;installLang=
                                                        01/07/18 23:55:50:074 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 8068 | Successfully executed the immediate custom action for install mode .
                                                        01/07/18 23:55:56:912 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Build Version - 1.13.0.59
                                                        01/07/18 23:55:56:912 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:55:56:912 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Executing the deferred custom action.
                                                        01/07/18 23:55:56:922 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Obtained the following as CustomActionData
                                                        01/07/18 23:55:56:922 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | (mode=install;sourceDir=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\;installDir=;origDB=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Adobe.msi;installLang=)
                                                        01/07/18 23:55:56:922 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Original database path is : F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Adobe.msi
                                                        01/07/18 23:55:56:929 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | OptionXML saved at location :: C:\Users\Ty\AppData\Local\Temp\{4F6598C7-468F-4822-9227-30B5BDC73D03}\\{F8E804BF-03A8-491 4-A1DE-9E59F8FE10E6}
                                                        01/07/18 23:55:56:951 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Build Version - 1.13.0.59
                                                        01/07/18 23:55:56:951 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:55:56:951 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | CustomAction Parameters obtained...
                                                        01/07/18 23:55:56:951 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 |  optXMLPath :: C:\Users\Ty\AppData\Local\Temp\{4F6598C7-468F-4822-9227-30B5BDC73D03}\\{F8E804BF-03A8-491 4-A1DE-9E59F8FE10E6}
                                                        01/07/18 23:55:56:951 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 |  setupBasePath :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\
                                                        01/07/18 23:55:56:951 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 |  installDirPath ::
                                                        01/07/18 23:55:56:951 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 |  installLang ::
                                                        01/07/18 23:55:56:951 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Initializing Custom Action Data from parameters
                                                        01/07/18 23:55:56:951 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Provisioning Tool path is (C:\Users\Ty\AppData\Local\Temp\{4F6598C7-468F-4822-9227-30B5BDC73D03}\\{AD846C1D-F100-43 73-8DFA-5CAAEC6F153C}).
                                                        01/07/18 23:55:56:952 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Starting to run the custom action for install mode
                                                        01/07/18 23:55:56:952 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | STEP 1: Starting to parse Option XML.
                                                        01/07/18 23:55:56:956 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Latest AAM version with the package is (4.3.0.256)...
                                                        01/07/18 23:55:56:957 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Install language fallback contains following languages :
                                                        01/07/18 23:55:56:957 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 |     (en_GB)
                                                        01/07/18 23:55:56:957 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Self-Update BootStrapper Relative Path doesn't exist.
                                                        01/07/18 23:55:56:957 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | No of updates found (0).
                                                        01/07/18 23:55:56:957 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | No of HD products found (2).
                                                        01/07/18 23:55:56:959 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Failed to get value for conflicting processes...
                                                        01/07/18 23:55:56:959 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Failed to parse the conflictProcessInfo for HD media (COSY2.4.3)...
                                                        01/07/18 23:55:56:966 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Custom deployment path doesnt exist in options XML
                                                        01/07/18 23:55:56:966 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Failed to find Royalty Bearing attribute info.
                                                        01/07/18 23:55:56:966 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Found the AppsPanel attribute info (true)
                                                        01/07/18 23:55:56:966 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Found the AdminPrivilege attribute info (true)
                                                        01/07/18 23:55:56:966 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Number of Medias found = 0
                                                        01/07/18 23:55:56:966 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Deployment Manager is running in Install Mode.
                                                        01/07/18 23:55:56:966 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | STEP 2: Starting to launch ASU AAM.
                                                        01/07/18 23:55:56:966 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Bootstrapper launch location is :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU\Set-up.dat
                                                        01/07/18 23:55:57:082 | [INFO] |  | ASU | OPM | OPM |  |  | 8160 | Build Version - 10.0.0.99
                                                        01/07/18 23:55:57:082 | [INFO] |  | ASU | OPM | OPM |  |  | 8160 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:55:57:084 | [INFO] |  | ASU | OPM | OPM |  |  | 8160 | Schema version and schema compatibility version are same or greater than current
                                                        01/07/18 23:55:57:289 | [INFO] |  | ASU | OPM | OPM |  |  | 8160 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
                                                        01/07/18 23:55:57:289 | [INFO] |  | ASU | OPM | OPM |  |  | 8160 | No Record found for the input fields in opm_getValueForKey
                                                        01/07/18 23:55:59:336 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Build Version - 1.13.0.59
                                                        01/07/18 23:55:59:336 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:55:59:336 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | The return code from the Bootstrapper Process is (0).
                                                        01/07/18 23:55:59:338 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Created file with ACC Panel Masked C:\Program Files (x86)\Common Files\Adobe\OOBE\Configs\ServiceConfig.xml
                                                        01/07/18 23:55:59:338 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Starting apply CCP ASU.
                                                        01/07/18 23:55:59:338 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Bootstrapper launch location is :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\Set-up.dat
                                                        01/07/18 23:55:59:400 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | Build Version - 10.0.0.49
                                                        01/07/18 23:55:59:400 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:55:59:403 | [INFO] |  | ASU | Setup |  |  |  | 7180 | Event Guid generated is: '762a913a-2ab1-4268-ac78-fdf5055c93d1'
                                                        01/07/18 23:55:59:403 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | Start Adobe Setup
                                                        01/07/18 23:55:59:403 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | TimeLog: Bootstrapper Start
                                                        01/07/18 23:55:59:403 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | TimeLog: Start initial checks
                                                        01/07/18 23:55:59:403 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | Action specified - "install"
                                                        01/07/18 23:55:59:404 | [INFO] |  | ASU | Setup | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:404 | [WARN] |  | ASU | Setup | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:405 | [WARN] |  | ASU | Setup | Setup |  |  | 7180 | Reboot is pending from earlier installation.
                                                        01/07/18 23:55:59:406 | [INFO] |  | ASU | Setup | Utilities |  |  | 7180 | Semaphore is not locked
                                                        01/07/18 23:55:59:407 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Build Version - 10.0.0.151
                                                        01/07/18 23:55:59:408 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:55:59:408 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Build Version - 10.0.0.151
                                                        01/07/18 23:55:59:408 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | CREATE PIM Instance ...
                                                        01/07/18 23:55:59:409 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | trying to createOrUpdatePIMDbSchema.
                                                        01/07/18 23:55:59:410 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Current db schema version on machine 1.
                                                        01/07/18 23:55:59:410 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Current db schema version to install 1.
                                                        01/07/18 23:55:59:410 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | PIM DB Schema is up to date. Current schema version is 1.
                                                        01/07/18 23:55:59:410 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | PIM Database is Up To Date.
                                                        01/07/18 23:55:59:410 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Updater Inventory location:F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\resources\updaterinventory.dll
                                                        01/07/18 23:55:59:411 | [INFO] |  | ASU | Setup |  |  |  | 9188 | Event with guid '762a913a-2ab1-4268-ac78-fdf5055c93d1' is being sent
                                                        01/07/18 23:55:59:412 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Acquired System level ACF lock ...
                                                        01/07/18 23:55:59:412 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | TimeLog: End initial checks
                                                        01/07/18 23:55:59:412 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | TimeLog: Begin Installing
                                                        01/07/18 23:55:59:412 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Current OS version is: Major:6, Minor:1, ServicePack:1
                                                        01/07/18 23:55:59:418 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:419 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:420 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 9188 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/07/18 23:55:59:420 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 2D07B44E-5043-413A-BF8F-127DDB5B61EC is already installed
                                                        01/07/18 23:55:59:435 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:436 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:436 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 1B3D24F6-3654-4EB4-A783-101CD2162E7C is already installed
                                                        01/07/18 23:55:59:446 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:446 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:447 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id FB270CC2-4272-4706-890F-2829237CBB06 is already installed
                                                        01/07/18 23:55:59:451 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:451 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:452 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id E1991EA9-E359-43BA-9DBE-F2657FFAABF4 is already installed
                                                        01/07/18 23:55:59:459 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:460 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:460 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id CE50F807-977B-4BC7-8ABD-CAD97273A9EC is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:55:59:462 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:462 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:463 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 71796FCB-CA48-4BD1-9D93-D51093659A17 is already installed
                                                        01/07/18 23:55:59:491 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:491 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:492 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 399F5D01-3BF2-4310-A624-3B5DB12FAA13 is already installed
                                                        01/07/18 23:55:59:506 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:506 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:506 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id A3B57320-15AD-4AF5-897D-6C9D7C6B7353 is already installed
                                                        01/07/18 23:55:59:510 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:511 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:511 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 2F2AFF87-CCBC-420C-8B97-4831EFD329DF is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:55:59:512 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:512 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:513 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 21693786-66E8-4A21-A57B-8085FF9ACD07 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:55:59:513 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 40409899
                                                        01/07/18 23:55:59:513 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Executing Adobe Genuine Validation for all the AAM packages
                                                        01/07/18 23:55:59:513 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pimx'
                                                        01/07/18 23:55:59:515 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pima'
                                                        01/07/18 23:55:59:515 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pimx'
                                                        01/07/18 23:55:59:516 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pima'
                                                        01/07/18 23:55:59:517 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pimx'
                                                        01/07/18 23:55:59:518 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pima'
                                                        01/07/18 23:55:59:519 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pimx'
                                                        01/07/18 23:55:59:519 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pima'
                                                        01/07/18 23:55:59:520 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P6\P6.pimx'
                                                        01/07/18 23:55:59:521 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P6\P6.pima'
                                                        01/07/18 23:55:59:523 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pimx'
                                                        01/07/18 23:55:59:523 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pima'
                                                        01/07/18 23:55:59:525 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pimx'
                                                        01/07/18 23:55:59:526 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pima'
                                                        01/07/18 23:55:59:527 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pimx'
                                                        01/07/18 23:55:59:528 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pima'
                                                        01/07/18 23:55:59:528 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P7\P7.pimx'
                                                        01/07/18 23:55:59:529 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P7\P7.pima'
                                                        01/07/18 23:55:59:530 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\AdobeGCClient\AdobeGCClient.pimx'
                                                        01/07/18 23:55:59:530 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\AdobeGCClient\AdobeGCClient.pima'
                                                        01/07/18 23:55:59:532 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Adobe Genuine Validation PASSED for all the AAM packages
                                                        01/07/18 23:55:59:532 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pimx
                                                        01/07/18 23:55:59:537 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 9188 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/07/18 23:55:59:537 | [ERROR] |  | ASU | Setup |  |  |  | 9188 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/07/18 23:55:59:537 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:55:59:538 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:55:59:539 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 2D07B44E-5043-413A-BF8F-127DDB5B61EC is already installed
                                                        01/07/18 23:55:59:673 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/07/18 23:55:59:873 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/07/18 23:55:59:873 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/07/18 23:56:00:047 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertPackageUpdateList.
                                                        01/07/18 23:56:00:048 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:00:048 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertAppletRegInfoList.
                                                        01/07/18 23:56:00:052 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Backup Folder Created
                                                        01/07/18 23:56:00:361 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Directory not present
                                                        01/07/18 23:56:00:361 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | ERROR Failed Delete backed up assets
                                                        01/07/18 23:56:00:361 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core_bkp1'
                                                        01/07/18 23:56:00:619 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMCustomHook.exe" --createInventory=1 --doPostInstallStep=1
                                                        01/07/18 23:56:00:627 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Success in CreateProcess
                                                        01/07/18 23:56:00:636 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4996 | Build Version - 10.0.0.49
                                                        01/07/18 23:56:00:636 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4996 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:56:00:636 | [INFO] |  | ASU | AAMCustomHook |  |  | CommandLineParser | 4996 | Parsing the command line provided. Number of command line arguments is 3
                                                        01/07/18 23:56:00:650 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4996 | Updater Inventory location: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\UWA\updaterinventory.dll'
                                                        01/07/18 23:56:00:659 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4996 | Going to create or update inventory
                                                        01/07/18 23:56:00:677 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4996 | Inventory Already present on the machine...
                                                        01/07/18 23:56:00:681 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Sucessfully launched and executed process...
                                                        01/07/18 23:56:00:681 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMCustomHook.exe'
                                                        01/07/18 23:56:00:682 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pimx.
                                                        01/07/18 23:56:00:690 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pimx
                                                        01/07/18 23:56:00:693 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:56:00:693 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:00:693 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 1B3D24F6-3654-4EB4-A783-101CD2162E7C is already installed
                                                        01/07/18 23:56:00:706 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/07/18 23:56:00:735 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/07/18 23:56:00:736 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/07/18 23:56:00:805 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertPackageUpdateList.
                                                        01/07/18 23:56:00:806 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertAppletRegInfoList.
                                                        01/07/18 23:56:00:811 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Backup Folder Created
                                                        01/07/18 23:56:00:869 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Directory not present
                                                        01/07/18 23:56:00:869 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | ERROR Failed Delete backed up assets
                                                        01/07/18 23:56:00:869 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\D6_bkp1'
                                                        01/07/18 23:56:00:947 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pimx.
                                                        01/07/18 23:56:00:960 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pimx
                                                        01/07/18 23:56:00:963 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:56:00:963 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:00:963 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id FB270CC2-4272-4706-890F-2829237CBB06 is already installed
                                                        01/07/18 23:56:00:971 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/07/18 23:56:01:008 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/07/18 23:56:01:008 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/07/18 23:56:01:075 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertPackageUpdateList.
                                                        01/07/18 23:56:01:076 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:01:076 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertAppletRegInfoList.
                                                        01/07/18 23:56:01:079 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Backup Folder Created
                                                        01/07/18 23:56:01:461 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Directory not present
                                                        01/07/18 23:56:01:461 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | ERROR Failed Delete backed up assets
                                                        01/07/18 23:56:01:461 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore_bkp1'
                                                        01/07/18 23:56:01:539 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pimx.
                                                        01/07/18 23:56:01:554 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pimx
                                                        01/07/18 23:56:01:555 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:56:01:556 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:01:556 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id E1991EA9-E359-43BA-9DBE-F2657FFAABF4 is already installed
                                                        01/07/18 23:56:01:564 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/07/18 23:56:01:574 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/07/18 23:56:01:575 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/07/18 23:56:01:596 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertPackageUpdateList.
                                                        01/07/18 23:56:01:597 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertAppletRegInfoList.
                                                        01/07/18 23:56:01:599 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Backup Folder Created
                                                        01/07/18 23:56:01:601 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:01:655 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Directory not present
                                                        01/07/18 23:56:01:655 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | ERROR Failed Delete backed up assets
                                                        01/07/18 23:56:01:655 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DWA_bkp1'
                                                        01/07/18 23:56:01:718 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pimx.
                                                        01/07/18 23:56:01:728 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P6\P6.pimx
                                                        01/07/18 23:56:01:730 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:56:01:730 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:01:731 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | NOTE package id CE50F807-977B-4BC7-8ABD-CAD97273A9EC is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:01:731 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pimx
                                                        01/07/18 23:56:01:732 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:56:01:732 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:01:732 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 71796FCB-CA48-4BD1-9D93-D51093659A17 is already installed
                                                        01/07/18 23:56:01:740 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/07/18 23:56:01:758 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/07/18 23:56:01:758 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/07/18 23:56:01:779 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertPackageUpdateList.
                                                        01/07/18 23:56:01:779 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertAppletRegInfoList.
                                                        01/07/18 23:56:01:782 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Backup Folder Created
                                                        01/07/18 23:56:01:783 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:01:990 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Directory not present
                                                        01/07/18 23:56:01:990 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | ERROR Failed Delete backed up assets
                                                        01/07/18 23:56:01:990 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\LWA_bkp1'
                                                        01/07/18 23:56:02:206 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pimx.
                                                        01/07/18 23:56:02:220 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pimx
                                                        01/07/18 23:56:02:224 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:56:02:224 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:02:225 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id 399F5D01-3BF2-4310-A624-3B5DB12FAA13 is already installed
                                                        01/07/18 23:56:02:238 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/07/18 23:56:02:270 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/07/18 23:56:02:270 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/07/18 23:56:02:370 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertPackageUpdateList.
                                                        01/07/18 23:56:02:371 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertAppletRegInfoList.
                                                        01/07/18 23:56:02:374 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Backup Folder Created
                                                        01/07/18 23:56:02:520 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Directory not present
                                                        01/07/18 23:56:02:521 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | ERROR Failed Delete backed up assets
                                                        01/07/18 23:56:02:521 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA_bkp1'
                                                        01/07/18 23:56:02:638 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pimx.
                                                        01/07/18 23:56:02:649 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pimx
                                                        01/07/18 23:56:02:650 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:56:02:650 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:02:651 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Package id A3B57320-15AD-4AF5-897D-6C9D7C6B7353 is already installed
                                                        01/07/18 23:56:02:666 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/07/18 23:56:02:678 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/07/18 23:56:02:679 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/07/18 23:56:02:706 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertPackageUpdateList.
                                                        01/07/18 23:56:02:707 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:02:707 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS insertAppletRegInfoList.
                                                        01/07/18 23:56:02:710 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Backup Folder Created
                                                        01/07/18 23:56:02:738 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Directory not present
                                                        01/07/18 23:56:02:738 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | ERROR Failed Delete backed up assets
                                                        01/07/18 23:56:02:738 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC_bkp1'
                                                        01/07/18 23:56:02:777 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe" -uninstall
                                                        01/07/18 23:56:02:785 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Success in CreateProcess
                                                        01/07/18 23:56:02:807 | [INFO] |  | ASU | PIM | Utilities |  |  | 7180 | Sucessfully launched and executed process...
                                                        01/07/18 23:56:02:807 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe'
                                                        01/07/18 23:56:02:808 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pimx.
                                                        01/07/18 23:56:02:823 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P7\P7.pimx
                                                        01/07/18 23:56:02:826 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:56:02:826 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:02:826 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | NOTE package id 2F2AFF87-CCBC-420C-8B97-4831EFD329DF is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:02:827 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\AdobeGCClient\AdobeGCClient.pimx
                                                        01/07/18 23:56:02:828 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | XML is valid
                                                        01/07/18 23:56:02:828 | [WARN] |  | ASU | PIM | PIM |  |  | 7180 | Failed to find Node
                                                        01/07/18 23:56:02:828 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | NOTE package id 21693786-66E8-4A21-A57B-8085FF9ACD07 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:02:843 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Processing ... _pimCreateOrUpdateAAMInventory
                                                        01/07/18 23:56:02:852 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | Inventory Already present on the machine...
                                                        01/07/18 23:56:02:852 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | TimeLog: End Installing. Now launching PDApp
                                                        01/07/18 23:56:03:352 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | Deployment File Path not specified in command line arguments. Skipping payload deployment part
                                                        01/07/18 23:56:03:352 | [INFO] |  | ASU | Setup |  |  |  | 7180 | Event Guid generated is: '695fa6ea-12fa-4a13-8198-03745f07ddd8'
                                                        01/07/18 23:56:03:352 | [INFO] |  | ASU | Setup | Setup |  |  | 7180 | =================  End Adobe Setup. Exit code: 0  =================
                                                        01/07/18 23:56:03:353 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | PIMSqlite closeDB status 0
                                                        01/07/18 23:56:03:353 | [INFO] |  | ASU | PIM | PIM |  |  | 7180 | FREE PIM Instance ...
                                                        01/07/18 23:56:03:354 | [INFO] |  | ASU | Setup |  |  |  | 7180 | Waiting for the async thread to get the task completed
                                                        01/07/18 23:56:03:365 | [INFO] |  | ASU | Setup |  |  |  | 9188 | Event with guid '695fa6ea-12fa-4a13-8198-03745f07ddd8' is being sent
                                                        01/07/18 23:56:03:373 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 9188 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/07/18 23:56:03:388 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 9188 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/07/18 23:56:03:388 | [ERROR] |  | ASU | Setup |  |  |  | 9188 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/07/18 23:56:03:388 | [INFO] |  | ASU | Setup |  |  |  | 9188 | Async thread is completed. Now exiting from function.
                                                        01/07/18 23:56:03:453 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Build Version - 1.13.0.59
                                                        01/07/18 23:56:03:453 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:56:03:453 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | The return code from the Bootstrapper Process is (0).
                                                        01/07/18 23:56:03:453 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Starting apply ASU Self-Update.
                                                        01/07/18 23:56:03:453 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | SelfUpdate Path - F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14
                                                        01/07/18 23:56:03:453 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Bootstrapper launch location is :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\Set-up.dat
                                                        01/07/18 23:56:03:478 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | Build Version - 9.0.0.141
                                                        01/07/18 23:56:03:478 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:56:03:482 | [INFO] |  | ASU | Setup |  |  |  | 8156 | Event Guid generated is: '89705ed0-2a72-4276-a403-412e0bcbdddf'
                                                        01/07/18 23:56:03:482 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | Start Adobe Setup
                                                        01/07/18 23:56:03:482 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | TimeLog: Bootstrapper Start
                                                        01/07/18 23:56:03:482 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | TimeLog: Start initial checks
                                                        01/07/18 23:56:03:482 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | Action specified - "install"
                                                        01/07/18 23:56:03:482 | [INFO] |  | ASU | Setup | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:483 | [WARN] |  | ASU | Setup | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:483 | [WARN] |  | ASU | Setup | Setup |  |  | 8156 | Reboot is pending from earlier installation.
                                                        01/07/18 23:56:03:484 | [INFO] |  | ASU | Setup | Utilities |  |  | 8156 | Semaphore is not locked
                                                        01/07/18 23:56:03:485 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Build Version - 9.0.0.141
                                                        01/07/18 23:56:03:486 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:56:03:486 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Build Version - 9.0.0.141
                                                        01/07/18 23:56:03:486 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | CREATE PIM Instance ...
                                                        01/07/18 23:56:03:487 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | trying to createOrUpdatePIMDbSchema.
                                                        01/07/18 23:56:03:488 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Current db schema version on machine 1.
                                                        01/07/18 23:56:03:488 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Current db schema version to install 1.
                                                        01/07/18 23:56:03:488 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | PIM DB Schema is up to date. Current schema version is 1.
                                                        01/07/18 23:56:03:488 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | PIM Database is Up To Date.
                                                        01/07/18 23:56:03:488 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Updater Inventory location:F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\resources\updaterinventory.dll
                                                        01/07/18 23:56:03:489 | [INFO] |  | ASU | Setup |  |  |  | 9372 | Event with guid '89705ed0-2a72-4276-a403-412e0bcbdddf' is being sent
                                                        01/07/18 23:56:03:490 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Acquired System level ACF lock ...
                                                        01/07/18 23:56:03:490 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | TimeLog: End initial checks
                                                        01/07/18 23:56:03:490 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | TimeLog: Begin Installing
                                                        01/07/18 23:56:03:490 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Current OS version is: Major:6, Minor:1, ServicePack:1
                                                        01/07/18 23:56:03:495 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 9372 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/07/18 23:56:03:495 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:496 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:496 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id B12B2FC7-66D0-4766-BF19-081A48A2F372 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:500 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:500 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:500 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id B948115B-424C-443F-8047-B30C8B90BCA8 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:503 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 9372 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/07/18 23:56:03:503 | [ERROR] |  | ASU | Setup |  |  |  | 9372 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/07/18 23:56:03:504 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:505 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:505 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id 0CDA4C3B-0E1F-49E0-A88A-FA6AA9979424 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:507 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:507 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:507 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id DE9FAA6B-94F6-42A7-A9FD-B0D716ED3EED is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:509 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:509 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:510 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id 062E98C1-1625-4373-BC41-0831335A5A2B is already installed
                                                        01/07/18 23:56:03:545 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:546 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:546 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id B322281B-C04F-438E-82D7-7DA34A359526 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:549 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:550 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:550 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id A8F3EA33-B0E0-43B2-990D-3DA2B0317B82 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:552 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:553 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:553 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id 3F9C8B10-559B-46D3-8053-9208FF459C01 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:554 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:554 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:554 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id 6A7BA94E-D704-4182-89A2-0C430D86D676 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:557 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:557 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:557 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id EFCC1FE1-DD11-4531-AF33-B3DC7A08B625 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:558 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:558 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id A1683289-8BD1-420E-8B0F-D32C6F436249 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:558 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 15941768
                                                        01/07/18 23:56:03:558 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Executing Adobe Genuine Validation for all the AAM packages
                                                        01/07/18 23:56:03:558 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\core\PDApp.pimx'
                                                        01/07/18 23:56:03:559 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\core\PDApp.pima'
                                                        01/07/18 23:56:03:560 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\D6\D6.pimx'
                                                        01/07/18 23:56:03:561 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\D6\D6.pima'
                                                        01/07/18 23:56:03:562 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DECore\DECore.pimx'
                                                        01/07/18 23:56:03:562 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DECore\DECore.pima'
                                                        01/07/18 23:56:03:563 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DWA\DWA.pimx'
                                                        01/07/18 23:56:03:564 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DWA\DWA.pima'
                                                        01/07/18 23:56:03:565 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pimx'
                                                        01/07/18 23:56:03:566 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pima'
                                                        01/07/18 23:56:03:568 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\LWA\LWA.pimx'
                                                        01/07/18 23:56:03:569 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\LWA\LWA.pima'
                                                        01/07/18 23:56:03:570 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\UWA\UWA.pimx'
                                                        01/07/18 23:56:03:571 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\UWA\UWA.pima'
                                                        01/07/18 23:56:03:573 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\CCM\CCM.pimx'
                                                        01/07/18 23:56:03:574 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\CCM\CCM.pima'
                                                        01/07/18 23:56:03:576 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\IPC\IPC.pimx'
                                                        01/07/18 23:56:03:577 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\IPC\IPC.pima'
                                                        01/07/18 23:56:03:581 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P7\P7.pimx'
                                                        01/07/18 23:56:03:582 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P7\P7.pima'
                                                        01/07/18 23:56:03:584 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\AdobeGCClient\AdobeGCCli ent.pimx'
                                                        01/07/18 23:56:03:585 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\AdobeGCClient\AdobeGCCli ent.pima'
                                                        01/07/18 23:56:03:587 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Adobe Genuine Validation PASSED for all the AAM packages
                                                        01/07/18 23:56:03:587 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\core\PDApp.pimx
                                                        01/07/18 23:56:03:592 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:592 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:593 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id B12B2FC7-66D0-4766-BF19-081A48A2F372 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:594 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\D6\D6.pimx
                                                        01/07/18 23:56:03:597 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:598 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:598 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id B948115B-424C-443F-8047-B30C8B90BCA8 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:599 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DECore\DECore.pimx
                                                        01/07/18 23:56:03:602 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:602 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:603 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id 0CDA4C3B-0E1F-49E0-A88A-FA6AA9979424 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:603 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DWA\DWA.pimx
                                                        01/07/18 23:56:03:604 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:605 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:605 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id DE9FAA6B-94F6-42A7-A9FD-B0D716ED3EED is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:03:605 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pimx
                                                        01/07/18 23:56:03:607 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:03:607 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:03:607 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Package id 062E98C1-1625-4373-BC41-0831335A5A2B is already installed
                                                        01/07/18 23:56:03:619 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/07/18 23:56:03:637 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/07/18 23:56:03:637 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/07/18 23:56:03:676 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | SUCCESS insertPackageUpdateList.
                                                        01/07/18 23:56:03:677 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | SUCCESS insertAppletRegInfoList.
                                                        01/07/18 23:56:03:681 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Backup Folder Created
                                                        01/07/18 23:56:04:006 | [INFO] |  | ASU | PIM | Utilities |  |  | 8156 | Directory not present
                                                        01/07/18 23:56:04:006 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | ERROR Failed Delete backed up assets
                                                        01/07/18 23:56:04:007 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\P6_bkp1'
                                                        01/07/18 23:56:04:259 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pimx.
                                                        01/07/18 23:56:04:270 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\LWA\LWA.pimx
                                                        01/07/18 23:56:04:271 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:04:272 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:04:272 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id B322281B-C04F-438E-82D7-7DA34A359526 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:04:272 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\UWA\UWA.pimx
                                                        01/07/18 23:56:04:275 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:04:276 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:04:276 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id A8F3EA33-B0E0-43B2-990D-3DA2B0317B82 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:04:277 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\CCM\CCM.pimx
                                                        01/07/18 23:56:04:278 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:04:278 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:04:279 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id 3F9C8B10-559B-46D3-8053-9208FF459C01 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:04:279 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\IPC\IPC.pimx
                                                        01/07/18 23:56:04:280 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:04:280 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:04:280 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id 6A7BA94E-D704-4182-89A2-0C430D86D676 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:04:280 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P7\P7.pimx
                                                        01/07/18 23:56:04:282 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:04:282 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:04:283 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id EFCC1FE1-DD11-4531-AF33-B3DC7A08B625 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:04:283 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\AdobeGCClient\AdobeGCCli ent.pimx
                                                        01/07/18 23:56:04:283 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | XML is valid
                                                        01/07/18 23:56:04:283 | [WARN] |  | ASU | PIM | PIM |  |  | 8156 | Failed to find Node
                                                        01/07/18 23:56:04:284 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | NOTE package id A1683289-8BD1-420E-8B0F-D32C6F436249 is a Old Package, a newer package is installed in the system.
                                                        01/07/18 23:56:04:295 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Processing ... _pimCreateOrUpdateAAMInventory
                                                        01/07/18 23:56:04:302 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Higher version of AAM Updater inventory is already present in the machine. So skipping the creation of AAM Updater Inventory
                                                        01/07/18 23:56:04:302 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | Return ... SUCCESS _pimCreateOrUpdateAAMInventory
                                                        01/07/18 23:56:04:302 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | TimeLog: End Installing. Now launching PDApp
                                                        01/07/18 23:56:04:802 | [INFO] |  | ASU | Setup |  |  |  | 8156 | Event Guid generated is: '2f33d869-4850-4d99-925e-8a9003643fbc'
                                                        01/07/18 23:56:04:802 | [INFO] |  | ASU | Setup | Setup |  |  | 8156 | =================  End Adobe Setup. Exit code: 0  =================
                                                        01/07/18 23:56:04:803 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | PIMSqlite closeDB status 0
                                                        01/07/18 23:56:04:803 | [INFO] |  | ASU | PIM | PIM |  |  | 8156 | FREE PIM Instance ...
                                                        01/07/18 23:56:04:803 | [INFO] |  | ASU | Setup |  |  |  | 8156 | Waiting for the async thread to get the task completed
                                                        01/07/18 23:56:04:806 | [INFO] |  | ASU | Setup |  |  |  | 9372 | Event with guid '2f33d869-4850-4d99-925e-8a9003643fbc' is being sent
                                                        01/07/18 23:56:04:808 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 9372 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/07/18 23:56:04:810 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 9372 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/07/18 23:56:04:810 | [ERROR] |  | ASU | Setup |  |  |  | 9372 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/07/18 23:56:04:810 | [INFO] |  | ASU | Setup |  |  |  | 9372 | Async thread is completed. Now exiting from function.
                                                        01/07/18 23:56:04:815 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Build Version - 1.13.0.59
                                                        01/07/18 23:56:04:815 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:56:04:815 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | The return code from the Bootstrapper Process is (0).
                                                        01/07/18 23:56:04:816 | [ERROR] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 1652 | Failed to initialize HDPIM wrapper, failed to load HDPIM library/Setup () (C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\Setup.exe)...
                                                        01/07/18 23:56:04:816 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Failed to initialize HDPIM for conflict processes handling ...
                                                        01/07/18 23:56:04:833 | [ERROR] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 1652 | Failed to initialize HDPIM wrapper, failed to load HDPIM library/Setup () (C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\Setup.exe)...
                                                        01/07/18 23:56:04:833 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Failed to initialize HDPIM library ...
                                                        01/07/18 23:56:04:833 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Starting to clean the partially installed payloads.
                                                        01/07/18 23:56:04:833 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | No payloads are required to be cleaned up. So Adobe Installer is not invoked.
                                                        01/07/18 23:56:04:833 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | Failed to initialize HDPIM library in cleanup mode ...
                                                        01/07/18 23:56:04:861 | [INFO] |  | ASU | OPM | OPM |  |  | 1652 | Build Version - 10.0.0.130
                                                        01/07/18 23:56:04:861 | [INFO] |  | ASU | OPM | OPM |  |  | 1652 | Logging Level verbosity Set  to 4
                                                        01/07/18 23:56:04:867 | [INFO] |  | ASU | OPM | OPM |  |  | 1652 | Schema version and schema compatibility version are same or greater than current
                                                        01/07/18 23:56:05:040 | [INFO] |  | ASU | OPM | OPM |  |  | 1652 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
                                                        01/07/18 23:56:05:040 | [INFO] |  | ASU | OPM | OPM |  |  | 1652 | No Record found for the input fields in opm_getValueForKey
                                                        01/07/18 23:56:05:104 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 1652 | The output of process received  in execWithOutput :
                                                        Microsoft Windows [Version 6.1.7601]
                                                        01/07/18 23:56:05:105 | [INFO] |  | ASU | DeploymentManager |  |  |  | 1652 | Event Guid generated is: '89961201-2ace-4676-a302-813a6b3c8c36'
                                                        01/07/18 23:56:05:115 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 1652 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/07/18 23:56:05:865 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 8620 | HTTP Request Status code 200.
                                                        01/07/18 23:56:05:865 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 1652 | The http request returned HTTP_Status:0 HttpCommunicator error:0
                                                        01/07/18 23:56:05:866 | [INFO] |  | ASU | DeploymentManager |  |  |  | 1652 | Waiting for the async thread to get the task completed
                                                        01/07/18 23:56:05:866 | [INFO] |  | ASU | DeploymentManager |  |  |  | 6760 | Async thread is completed. Now exiting from function.
                                                        01/07/18 23:56:05:914 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 1652 | The install workflow is terminating.
                                                        01/07/18 23:56:06:729 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 4372 | Process creation completed.
                                                        01/07/18 23:56:06:729 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4372 |  The return Code from Create Process (1603).
                                                        01/08/18 00:04:32:027 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 4372 | Setup exiting with return code (6)
                                                        01/08/18 00:04:35:685 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 2348 | Build Version - 1.13.0.59
                                                        01/08/18 00:04:35:685 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 2348 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:35:715 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 2348 | Successfully fetched the optionXML content from MSI database ...
                                                        01/08/18 00:04:37:317 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 9676 | Build Version - 1.13.0.59
                                                        01/08/18 00:04:37:317 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 9676 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:37:317 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 9676 | Executing immediate custom action for install mode.
                                                        01/08/18 00:04:37:318 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 9676 | The CustomActionData string is : mode=install;sourceDir=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\;installDir=;origDB=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Adobe.msi;installLang=
                                                        01/08/18 00:04:37:318 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 9676 | Successfully executed the immediate custom action for install mode .
                                                        01/08/18 00:04:44:296 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Build Version - 1.13.0.59
                                                        01/08/18 00:04:44:296 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:44:296 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Executing the deferred custom action.
                                                        01/08/18 00:04:44:300 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Obtained the following as CustomActionData
                                                        01/08/18 00:04:44:300 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | (mode=install;sourceDir=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\;installDir=;origDB=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Adobe.msi;installLang=)
                                                        01/08/18 00:04:44:300 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Original database path is : F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Adobe.msi
                                                        01/08/18 00:04:44:308 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | OptionXML saved at location :: C:\Users\Ty\AppData\Local\Temp\{471B6E82-F11B-4692-A9BE-29BEF01B2EEF}\\{D2AA8EEF-E3AD-440 6-914E-9F67F0B21B9D}
                                                        01/08/18 00:04:44:330 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Build Version - 1.13.0.59
                                                        01/08/18 00:04:44:330 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:44:330 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | CustomAction Parameters obtained...
                                                        01/08/18 00:04:44:330 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 |  optXMLPath :: C:\Users\Ty\AppData\Local\Temp\{471B6E82-F11B-4692-A9BE-29BEF01B2EEF}\\{D2AA8EEF-E3AD-440 6-914E-9F67F0B21B9D}
                                                        01/08/18 00:04:44:330 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 |  setupBasePath :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\
                                                        01/08/18 00:04:44:330 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 |  installDirPath ::
                                                        01/08/18 00:04:44:330 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 |  installLang ::
                                                        01/08/18 00:04:44:330 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Initializing Custom Action Data from parameters
                                                        01/08/18 00:04:44:330 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Provisioning Tool path is (C:\Users\Ty\AppData\Local\Temp\{471B6E82-F11B-4692-A9BE-29BEF01B2EEF}\\{8F6B5D53-9651-44 16-BE60-716DEEC45D9C}).
                                                        01/08/18 00:04:44:331 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Starting to run the custom action for install mode
                                                        01/08/18 00:04:44:331 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | STEP 1: Starting to parse Option XML.
                                                        01/08/18 00:04:44:337 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Latest AAM version with the package is (4.3.0.256)...
                                                        01/08/18 00:04:44:338 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Install language fallback contains following languages :
                                                        01/08/18 00:04:44:338 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 |     (en_GB)
                                                        01/08/18 00:04:44:338 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Self-Update BootStrapper Relative Path doesn't exist.
                                                        01/08/18 00:04:44:338 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | No of updates found (0).
                                                        01/08/18 00:04:44:338 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | No of HD products found (2).
                                                        01/08/18 00:04:44:339 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Failed to get value for conflicting processes...
                                                        01/08/18 00:04:44:339 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Failed to parse the conflictProcessInfo for HD media (COSY2.4.3)...
                                                        01/08/18 00:04:44:346 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Custom deployment path doesnt exist in options XML
                                                        01/08/18 00:04:44:346 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Failed to find Royalty Bearing attribute info.
                                                        01/08/18 00:04:44:346 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Found the AppsPanel attribute info (true)
                                                        01/08/18 00:04:44:346 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Found the AdminPrivilege attribute info (true)
                                                        01/08/18 00:04:44:346 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Number of Medias found = 0
                                                        01/08/18 00:04:44:346 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Deployment Manager is running in Install Mode.
                                                        01/08/18 00:04:44:346 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | STEP 2: Starting to launch ASU AAM.
                                                        01/08/18 00:04:44:346 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Bootstrapper launch location is :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU\Set-up.dat
                                                        01/08/18 00:04:44:460 | [INFO] |  | ASU | OPM | OPM |  |  | 10184 | Build Version - 10.0.0.99
                                                        01/08/18 00:04:44:460 | [INFO] |  | ASU | OPM | OPM |  |  | 10184 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:44:462 | [INFO] |  | ASU | OPM | OPM |  |  | 10184 | Schema version and schema compatibility version are same or greater than current
                                                        01/08/18 00:04:44:651 | [INFO] |  | ASU | OPM | OPM |  |  | 10184 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
                                                        01/08/18 00:04:44:651 | [INFO] |  | ASU | OPM | OPM |  |  | 10184 | No Record found for the input fields in opm_getValueForKey
                                                        01/08/18 00:04:46:147 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Build Version - 1.13.0.59
                                                        01/08/18 00:04:46:148 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:46:148 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | The return code from the Bootstrapper Process is (0).
                                                        01/08/18 00:04:46:149 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Created file with ACC Panel Masked C:\Program Files (x86)\Common Files\Adobe\OOBE\Configs\ServiceConfig.xml
                                                        01/08/18 00:04:46:149 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Starting apply CCP ASU.
                                                        01/08/18 00:04:46:149 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Bootstrapper launch location is :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\Set-up.dat
                                                        01/08/18 00:04:46:189 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | Build Version - 10.0.0.49
                                                        01/08/18 00:04:46:189 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:46:192 | [INFO] |  | ASU | Setup |  |  |  | 9384 | Event Guid generated is: '9866c585-c5e3-4725-b6aa-ea8ae912e6a0'
                                                        01/08/18 00:04:46:192 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | Start Adobe Setup
                                                        01/08/18 00:04:46:192 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | TimeLog: Bootstrapper Start
                                                        01/08/18 00:04:46:192 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | TimeLog: Start initial checks
                                                        01/08/18 00:04:46:193 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | Action specified - "install"
                                                        01/08/18 00:04:46:194 | [INFO] |  | ASU | Setup | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:194 | [WARN] |  | ASU | Setup | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:194 | [WARN] |  | ASU | Setup | Setup |  |  | 9384 | Reboot is pending from earlier installation.
                                                        01/08/18 00:04:46:200 | [INFO] |  | ASU | Setup |  |  |  | 7916 | Event with guid '9866c585-c5e3-4725-b6aa-ea8ae912e6a0' is being sent
                                                        01/08/18 00:04:46:203 | [INFO] |  | ASU | Setup | Utilities |  |  | 9384 | Semaphore is not locked
                                                        01/08/18 00:04:46:206 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Build Version - 10.0.0.151
                                                        01/08/18 00:04:46:207 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:46:208 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Build Version - 10.0.0.151
                                                        01/08/18 00:04:46:208 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:46:208 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | CREATE PIM Instance ...
                                                        01/08/18 00:04:46:211 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 7916 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:04:46:213 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | trying to createOrUpdatePIMDbSchema.
                                                        01/08/18 00:04:46:215 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Current db schema version on machine 1.
                                                        01/08/18 00:04:46:215 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Current db schema version to install 1.
                                                        01/08/18 00:04:46:215 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | PIM DB Schema is up to date. Current schema version is 1.
                                                        01/08/18 00:04:46:215 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | PIM Database is Up To Date.
                                                        01/08/18 00:04:46:215 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Updater Inventory location:F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\resources\updaterinventory.dll
                                                        01/08/18 00:04:46:220 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Acquired System level ACF lock ...
                                                        01/08/18 00:04:46:220 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | TimeLog: End initial checks
                                                        01/08/18 00:04:46:220 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | TimeLog: Begin Installing
                                                        01/08/18 00:04:46:221 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Current OS version is: Major:6, Minor:1, ServicePack:1
                                                        01/08/18 00:04:46:227 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:228 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:229 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 2D07B44E-5043-413A-BF8F-127DDB5B61EC is already installed
                                                        01/08/18 00:04:46:245 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:245 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:246 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 1B3D24F6-3654-4EB4-A783-101CD2162E7C is already installed
                                                        01/08/18 00:04:46:256 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:257 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:258 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id FB270CC2-4272-4706-890F-2829237CBB06 is already installed
                                                        01/08/18 00:04:46:261 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:261 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:262 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id E1991EA9-E359-43BA-9DBE-F2657FFAABF4 is already installed
                                                        01/08/18 00:04:46:269 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:269 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:270 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id CE50F807-977B-4BC7-8ABD-CAD97273A9EC is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:46:272 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:272 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:273 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 71796FCB-CA48-4BD1-9D93-D51093659A17 is already installed
                                                        01/08/18 00:04:46:291 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:292 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:293 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 399F5D01-3BF2-4310-A624-3B5DB12FAA13 is already installed
                                                        01/08/18 00:04:46:306 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:307 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:307 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id A3B57320-15AD-4AF5-897D-6C9D7C6B7353 is already installed
                                                        01/08/18 00:04:46:312 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:313 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:313 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 2F2AFF87-CCBC-420C-8B97-4831EFD329DF is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:46:315 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:315 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:316 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 21693786-66E8-4A21-A57B-8085FF9ACD07 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:46:316 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 40409899
                                                        01/08/18 00:04:46:316 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Executing Adobe Genuine Validation for all the AAM packages
                                                        01/08/18 00:04:46:316 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pimx'
                                                        01/08/18 00:04:46:319 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pima'
                                                        01/08/18 00:04:46:324 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pimx'
                                                        01/08/18 00:04:46:326 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pima'
                                                        01/08/18 00:04:46:335 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pimx'
                                                        01/08/18 00:04:46:337 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pima'
                                                        01/08/18 00:04:46:344 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pimx'
                                                        01/08/18 00:04:46:345 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pima'
                                                        01/08/18 00:04:46:355 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P6\P6.pimx'
                                                        01/08/18 00:04:46:356 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P6\P6.pima'
                                                        01/08/18 00:04:46:376 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pimx'
                                                        01/08/18 00:04:46:377 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pima'
                                                        01/08/18 00:04:46:394 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pimx'
                                                        01/08/18 00:04:46:395 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 7916 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/08/18 00:04:46:395 | [ERROR] |  | ASU | Setup |  |  |  | 7916 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/08/18 00:04:46:396 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pima'
                                                        01/08/18 00:04:46:416 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pimx'
                                                        01/08/18 00:04:46:417 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pima'
                                                        01/08/18 00:04:46:422 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P7\P7.pimx'
                                                        01/08/18 00:04:46:423 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P7\P7.pima'
                                                        01/08/18 00:04:46:428 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\AdobeGCClient\AdobeGCClient.pimx'
                                                        01/08/18 00:04:46:429 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\AdobeGCClient\AdobeGCClient.pima'
                                                        01/08/18 00:04:46:446 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Adobe Genuine Validation PASSED for all the AAM packages
                                                        01/08/18 00:04:46:446 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pimx
                                                        01/08/18 00:04:46:451 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:46:452 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:453 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 2D07B44E-5043-413A-BF8F-127DDB5B61EC is already installed
                                                        01/08/18 00:04:46:466 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:04:46:642 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:04:46:642 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:04:46:834 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:04:46:835 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:46:835 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:04:46:839 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Backup Folder Created
                                                        01/08/18 00:04:47:145 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Directory not present
                                                        01/08/18 00:04:47:145 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:04:47:145 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core_bkp1'
                                                        01/08/18 00:04:47:269 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMCustomHook.exe" --createInventory=1 --doPostInstallStep=1
                                                        01/08/18 00:04:47:279 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Success in CreateProcess
                                                        01/08/18 00:04:47:287 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 6336 | Build Version - 10.0.0.49
                                                        01/08/18 00:04:47:287 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 6336 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:47:287 | [INFO] |  | ASU | AAMCustomHook |  |  | CommandLineParser | 6336 | Parsing the command line provided. Number of command line arguments is 3
                                                        01/08/18 00:04:47:307 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 6336 | Updater Inventory location: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\UWA\updaterinventory.dll'
                                                        01/08/18 00:04:47:311 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 6336 | Going to create or update inventory
                                                        01/08/18 00:04:47:328 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 6336 | Inventory Already present on the machine...
                                                        01/08/18 00:04:47:330 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Sucessfully launched and executed process...
                                                        01/08/18 00:04:47:330 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMCustomHook.exe'
                                                        01/08/18 00:04:47:331 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pimx.
                                                        01/08/18 00:04:47:341 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pimx
                                                        01/08/18 00:04:47:344 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:47:344 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:47:346 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 1B3D24F6-3654-4EB4-A783-101CD2162E7C is already installed
                                                        01/08/18 00:04:47:439 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:04:47:475 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:04:47:475 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:04:47:547 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:04:47:548 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:04:47:552 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Backup Folder Created
                                                        01/08/18 00:04:47:613 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Directory not present
                                                        01/08/18 00:04:47:613 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:04:47:613 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\D6_bkp1'
                                                        01/08/18 00:04:47:709 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pimx.
                                                        01/08/18 00:04:47:721 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pimx
                                                        01/08/18 00:04:47:724 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:47:724 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:47:725 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id FB270CC2-4272-4706-890F-2829237CBB06 is already installed
                                                        01/08/18 00:04:47:739 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:04:47:780 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:04:47:780 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:04:47:851 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:04:47:852 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:47:852 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:04:47:856 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Backup Folder Created
                                                        01/08/18 00:04:48:159 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Directory not present
                                                        01/08/18 00:04:48:159 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:04:48:159 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore_bkp1'
                                                        01/08/18 00:04:48:228 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pimx.
                                                        01/08/18 00:04:48:241 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pimx
                                                        01/08/18 00:04:48:243 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:48:243 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:48:243 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id E1991EA9-E359-43BA-9DBE-F2657FFAABF4 is already installed
                                                        01/08/18 00:04:48:256 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:04:48:266 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:04:48:266 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:04:48:287 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:04:48:287 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:04:48:291 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Backup Folder Created
                                                        01/08/18 00:04:48:293 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:48:354 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Directory not present
                                                        01/08/18 00:04:48:354 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:04:48:355 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DWA_bkp1'
                                                        01/08/18 00:04:48:423 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pimx.
                                                        01/08/18 00:04:48:430 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P6\P6.pimx
                                                        01/08/18 00:04:48:432 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:48:432 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:48:433 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | NOTE package id CE50F807-977B-4BC7-8ABD-CAD97273A9EC is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:48:433 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pimx
                                                        01/08/18 00:04:48:435 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:48:435 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:48:435 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 71796FCB-CA48-4BD1-9D93-D51093659A17 is already installed
                                                        01/08/18 00:04:48:480 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:04:48:495 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:04:48:495 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:04:48:516 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:04:48:516 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:04:48:520 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Backup Folder Created
                                                        01/08/18 00:04:48:522 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:48:772 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Directory not present
                                                        01/08/18 00:04:48:772 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:04:48:772 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\LWA_bkp1'
                                                        01/08/18 00:04:48:992 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pimx.
                                                        01/08/18 00:04:49:000 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pimx
                                                        01/08/18 00:04:49:004 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:49:005 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:49:006 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id 399F5D01-3BF2-4310-A624-3B5DB12FAA13 is already installed
                                                        01/08/18 00:04:49:015 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:04:49:047 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:04:49:047 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:04:49:151 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:04:49:152 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:04:49:157 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Backup Folder Created
                                                        01/08/18 00:04:49:326 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Directory not present
                                                        01/08/18 00:04:49:326 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:04:49:326 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA_bkp1'
                                                        01/08/18 00:04:49:547 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pimx.
                                                        01/08/18 00:04:49:558 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pimx
                                                        01/08/18 00:04:49:560 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:49:560 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:49:560 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Package id A3B57320-15AD-4AF5-897D-6C9D7C6B7353 is already installed
                                                        01/08/18 00:04:49:568 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:04:49:581 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:04:49:581 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:04:49:611 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:04:49:612 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:49:612 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:04:49:616 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Backup Folder Created
                                                        01/08/18 00:04:49:649 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Directory not present
                                                        01/08/18 00:04:49:649 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:04:49:649 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC_bkp1'
                                                        01/08/18 00:04:49:702 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe" -uninstall
                                                        01/08/18 00:04:49:712 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Success in CreateProcess
                                                        01/08/18 00:04:49:736 | [INFO] |  | ASU | PIM | Utilities |  |  | 9384 | Sucessfully launched and executed process...
                                                        01/08/18 00:04:49:736 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe'
                                                        01/08/18 00:04:49:736 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pimx.
                                                        01/08/18 00:04:49:756 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P7\P7.pimx
                                                        01/08/18 00:04:49:759 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:49:759 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:49:760 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | NOTE package id 2F2AFF87-CCBC-420C-8B97-4831EFD329DF is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:49:760 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\AdobeGCClient\AdobeGCClient.pimx
                                                        01/08/18 00:04:49:761 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | XML is valid
                                                        01/08/18 00:04:49:761 | [WARN] |  | ASU | PIM | PIM |  |  | 9384 | Failed to find Node
                                                        01/08/18 00:04:49:761 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | NOTE package id 21693786-66E8-4A21-A57B-8085FF9ACD07 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:49:787 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Processing ... _pimCreateOrUpdateAAMInventory
                                                        01/08/18 00:04:49:800 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | Inventory Already present on the machine...
                                                        01/08/18 00:04:49:800 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | TimeLog: End Installing. Now launching PDApp
                                                        01/08/18 00:04:50:300 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | Deployment File Path not specified in command line arguments. Skipping payload deployment part
                                                        01/08/18 00:04:50:300 | [INFO] |  | ASU | Setup |  |  |  | 9384 | Event Guid generated is: '82901be7-1e6f-47e9-838f-ea8662fc0d36'
                                                        01/08/18 00:04:50:300 | [INFO] |  | ASU | Setup | Setup |  |  | 9384 | =================  End Adobe Setup. Exit code: 0  =================
                                                        01/08/18 00:04:50:301 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | PIMSqlite closeDB status 0
                                                        01/08/18 00:04:50:301 | [INFO] |  | ASU | PIM | PIM |  |  | 9384 | FREE PIM Instance ...
                                                        01/08/18 00:04:50:302 | [INFO] |  | ASU | Setup |  |  |  | 9384 | Waiting for the async thread to get the task completed
                                                        01/08/18 00:04:50:309 | [INFO] |  | ASU | Setup |  |  |  | 7916 | Event with guid '82901be7-1e6f-47e9-838f-ea8662fc0d36' is being sent
                                                        01/08/18 00:04:50:312 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 7916 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:04:50:313 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 7916 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/08/18 00:04:50:313 | [ERROR] |  | ASU | Setup |  |  |  | 7916 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/08/18 00:04:50:313 | [INFO] |  | ASU | Setup |  |  |  | 7916 | Async thread is completed. Now exiting from function.
                                                        01/08/18 00:04:50:318 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Build Version - 1.13.0.59
                                                        01/08/18 00:04:50:319 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:50:319 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | The return code from the Bootstrapper Process is (0).
                                                        01/08/18 00:04:50:319 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Starting apply ASU Self-Update.
                                                        01/08/18 00:04:50:319 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | SelfUpdate Path - F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14
                                                        01/08/18 00:04:50:319 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Bootstrapper launch location is :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\Set-up.dat
                                                        01/08/18 00:04:50:356 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | Build Version - 9.0.0.141
                                                        01/08/18 00:04:50:356 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:50:360 | [INFO] |  | ASU | Setup |  |  |  | 8668 | Event Guid generated is: '8cd69e24-f82c-4dee-8406-422bd5f22a09'
                                                        01/08/18 00:04:50:361 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | Start Adobe Setup
                                                        01/08/18 00:04:50:361 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | TimeLog: Bootstrapper Start
                                                        01/08/18 00:04:50:361 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | TimeLog: Start initial checks
                                                        01/08/18 00:04:50:361 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | Action specified - "install"
                                                        01/08/18 00:04:50:362 | [INFO] |  | ASU | Setup | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:363 | [WARN] |  | ASU | Setup | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:363 | [WARN] |  | ASU | Setup | Setup |  |  | 8668 | Reboot is pending from earlier installation.
                                                        01/08/18 00:04:50:368 | [INFO] |  | ASU | Setup |  |  |  | 5192 | Event with guid '8cd69e24-f82c-4dee-8406-422bd5f22a09' is being sent
                                                        01/08/18 00:04:50:369 | [INFO] |  | ASU | Setup | Utilities |  |  | 8668 | Semaphore is not locked
                                                        01/08/18 00:04:50:372 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Build Version - 9.0.0.141
                                                        01/08/18 00:04:50:373 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 5192 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:04:50:373 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:50:374 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Build Version - 9.0.0.141
                                                        01/08/18 00:04:50:374 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:50:374 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | CREATE PIM Instance ...
                                                        01/08/18 00:04:50:378 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | trying to createOrUpdatePIMDbSchema.
                                                        01/08/18 00:04:50:381 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Current db schema version on machine 1.
                                                        01/08/18 00:04:50:381 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Current db schema version to install 1.
                                                        01/08/18 00:04:50:381 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | PIM DB Schema is up to date. Current schema version is 1.
                                                        01/08/18 00:04:50:381 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | PIM Database is Up To Date.
                                                        01/08/18 00:04:50:381 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Updater Inventory location:F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\resources\updaterinventory.dll
                                                        01/08/18 00:04:50:385 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Acquired System level ACF lock ...
                                                        01/08/18 00:04:50:385 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | TimeLog: End initial checks
                                                        01/08/18 00:04:50:385 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | TimeLog: Begin Installing
                                                        01/08/18 00:04:50:386 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Current OS version is: Major:6, Minor:1, ServicePack:1
                                                        01/08/18 00:04:50:386 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 5192 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/08/18 00:04:50:386 | [ERROR] |  | ASU | Setup |  |  |  | 5192 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/08/18 00:04:50:392 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:393 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:393 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id B12B2FC7-66D0-4766-BF19-081A48A2F372 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:398 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:398 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:399 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id B948115B-424C-443F-8047-B30C8B90BCA8 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:403 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:403 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:403 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id 0CDA4C3B-0E1F-49E0-A88A-FA6AA9979424 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:406 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:406 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:406 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id DE9FAA6B-94F6-42A7-A9FD-B0D716ED3EED is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:408 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:408 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:409 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id 062E98C1-1625-4373-BC41-0831335A5A2B is already installed
                                                        01/08/18 00:04:50:425 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:425 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:425 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id B322281B-C04F-438E-82D7-7DA34A359526 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:430 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:430 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:430 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id A8F3EA33-B0E0-43B2-990D-3DA2B0317B82 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:434 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:434 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:435 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id 3F9C8B10-559B-46D3-8053-9208FF459C01 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:437 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:437 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:437 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id 6A7BA94E-D704-4182-89A2-0C430D86D676 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:440 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:441 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:441 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id EFCC1FE1-DD11-4531-AF33-B3DC7A08B625 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:442 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:442 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:442 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id A1683289-8BD1-420E-8B0F-D32C6F436249 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:442 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 15941768
                                                        01/08/18 00:04:50:442 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Executing Adobe Genuine Validation for all the AAM packages
                                                        01/08/18 00:04:50:442 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\core\PDApp.pimx'
                                                        01/08/18 00:04:50:445 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\core\PDApp.pima'
                                                        01/08/18 00:04:50:451 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\D6\D6.pimx'
                                                        01/08/18 00:04:50:452 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\D6\D6.pima'
                                                        01/08/18 00:04:50:460 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DECore\DECore.pimx'
                                                        01/08/18 00:04:50:461 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DECore\DECore.pima'
                                                        01/08/18 00:04:50:467 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DWA\DWA.pimx'
                                                        01/08/18 00:04:50:468 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DWA\DWA.pima'
                                                        01/08/18 00:04:50:477 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pimx'
                                                        01/08/18 00:04:50:478 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pima'
                                                        01/08/18 00:04:50:496 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\LWA\LWA.pimx'
                                                        01/08/18 00:04:50:497 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\LWA\LWA.pima'
                                                        01/08/18 00:04:50:513 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\UWA\UWA.pimx'
                                                        01/08/18 00:04:50:515 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\UWA\UWA.pima'
                                                        01/08/18 00:04:50:533 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\CCM\CCM.pimx'
                                                        01/08/18 00:04:50:535 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\CCM\CCM.pima'
                                                        01/08/18 00:04:50:553 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\IPC\IPC.pimx'
                                                        01/08/18 00:04:50:554 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\IPC\IPC.pima'
                                                        01/08/18 00:04:50:561 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P7\P7.pimx'
                                                        01/08/18 00:04:50:562 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P7\P7.pima'
                                                        01/08/18 00:04:50:587 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\AdobeGCClient\AdobeGCCli ent.pimx'
                                                        01/08/18 00:04:50:588 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\AdobeGCClient\AdobeGCCli ent.pima'
                                                        01/08/18 00:04:50:605 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Adobe Genuine Validation PASSED for all the AAM packages
                                                        01/08/18 00:04:50:605 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\core\PDApp.pimx
                                                        01/08/18 00:04:50:610 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:610 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:611 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id B12B2FC7-66D0-4766-BF19-081A48A2F372 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:612 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\D6\D6.pimx
                                                        01/08/18 00:04:50:615 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:615 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:615 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id B948115B-424C-443F-8047-B30C8B90BCA8 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:616 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DECore\DECore.pimx
                                                        01/08/18 00:04:50:619 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:620 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:620 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id 0CDA4C3B-0E1F-49E0-A88A-FA6AA9979424 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:621 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DWA\DWA.pimx
                                                        01/08/18 00:04:50:622 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:622 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:622 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id DE9FAA6B-94F6-42A7-A9FD-B0D716ED3EED is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:50:622 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pimx
                                                        01/08/18 00:04:50:624 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:50:624 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:50:625 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Package id 062E98C1-1625-4373-BC41-0831335A5A2B is already installed
                                                        01/08/18 00:04:50:638 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:04:50:658 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:04:50:658 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:04:50:699 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:04:50:700 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:04:50:704 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Backup Folder Created
                                                        01/08/18 00:04:51:026 | [INFO] |  | ASU | PIM | Utilities |  |  | 8668 | Directory not present
                                                        01/08/18 00:04:51:026 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:04:51:026 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\P6_bkp1'
                                                        01/08/18 00:04:51:312 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pimx.
                                                        01/08/18 00:04:51:320 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\LWA\LWA.pimx
                                                        01/08/18 00:04:51:321 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:51:321 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:51:321 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id B322281B-C04F-438E-82D7-7DA34A359526 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:51:321 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\UWA\UWA.pimx
                                                        01/08/18 00:04:51:325 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:51:325 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:51:325 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id A8F3EA33-B0E0-43B2-990D-3DA2B0317B82 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:51:326 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\CCM\CCM.pimx
                                                        01/08/18 00:04:51:328 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:51:328 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:51:328 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id 3F9C8B10-559B-46D3-8053-9208FF459C01 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:51:329 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\IPC\IPC.pimx
                                                        01/08/18 00:04:51:330 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:51:330 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:51:330 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id 6A7BA94E-D704-4182-89A2-0C430D86D676 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:51:330 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P7\P7.pimx
                                                        01/08/18 00:04:51:332 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:51:332 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:51:332 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id EFCC1FE1-DD11-4531-AF33-B3DC7A08B625 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:51:333 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\AdobeGCClient\AdobeGCCli ent.pimx
                                                        01/08/18 00:04:51:333 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | XML is valid
                                                        01/08/18 00:04:51:333 | [WARN] |  | ASU | PIM | PIM |  |  | 8668 | Failed to find Node
                                                        01/08/18 00:04:51:333 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | NOTE package id A1683289-8BD1-420E-8B0F-D32C6F436249 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:04:51:417 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Processing ... _pimCreateOrUpdateAAMInventory
                                                        01/08/18 00:04:51:425 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Higher version of AAM Updater inventory is already present in the machine. So skipping the creation of AAM Updater Inventory
                                                        01/08/18 00:04:51:425 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | Return ... SUCCESS _pimCreateOrUpdateAAMInventory
                                                        01/08/18 00:04:51:425 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | TimeLog: End Installing. Now launching PDApp
                                                        01/08/18 00:04:51:925 | [INFO] |  | ASU | Setup |  |  |  | 8668 | Event Guid generated is: 'cae59356-ff92-44de-aa20-51b45b4aef3d'
                                                        01/08/18 00:04:51:925 | [INFO] |  | ASU | Setup | Setup |  |  | 8668 | =================  End Adobe Setup. Exit code: 0  =================
                                                        01/08/18 00:04:51:927 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | PIMSqlite closeDB status 0
                                                        01/08/18 00:04:51:927 | [INFO] |  | ASU | PIM | PIM |  |  | 8668 | FREE PIM Instance ...
                                                        01/08/18 00:04:51:928 | [INFO] |  | ASU | Setup |  |  |  | 5192 | Event with guid 'cae59356-ff92-44de-aa20-51b45b4aef3d' is being sent
                                                        01/08/18 00:04:51:928 | [INFO] |  | ASU | Setup |  |  |  | 8668 | Waiting for the async thread to get the task completed
                                                        01/08/18 00:04:51:930 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 5192 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:04:51:932 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 5192 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/08/18 00:04:51:932 | [ERROR] |  | ASU | Setup |  |  |  | 5192 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/08/18 00:04:51:932 | [INFO] |  | ASU | Setup |  |  |  | 5192 | Async thread is completed. Now exiting from function.
                                                        01/08/18 00:04:51:937 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Build Version - 1.13.0.59
                                                        01/08/18 00:04:51:937 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:51:937 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | The return code from the Bootstrapper Process is (0).
                                                        01/08/18 00:04:51:938 | [ERROR] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3708 | Failed to initialize HDPIM wrapper, failed to load HDPIM library/Setup () (C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\Setup.exe)...
                                                        01/08/18 00:04:51:938 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Failed to initialize HDPIM for conflict processes handling ...
                                                        01/08/18 00:04:51:965 | [ERROR] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3708 | Failed to initialize HDPIM wrapper, failed to load HDPIM library/Setup () (C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\Setup.exe)...
                                                        01/08/18 00:04:51:965 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Failed to initialize HDPIM library ...
                                                        01/08/18 00:04:51:965 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Starting to clean the partially installed payloads.
                                                        01/08/18 00:04:51:966 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | No payloads are required to be cleaned up. So Adobe Installer is not invoked.
                                                        01/08/18 00:04:51:966 | [ERROR] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 3708 | Failed to initialize HDPIM wrapper, failed to load HDPIM library/Setup () (C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\Setup.exe)...
                                                        01/08/18 00:04:51:966 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | Failed to initialize HDPIM library in cleanup mode ...
                                                        01/08/18 00:04:52:008 | [INFO] |  | ASU | OPM | OPM |  |  | 3708 | Build Version - 10.0.0.130
                                                        01/08/18 00:04:52:008 | [INFO] |  | ASU | OPM | OPM |  |  | 3708 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:04:52:016 | [INFO] |  | ASU | OPM | OPM |  |  | 3708 | Schema version and schema compatibility version are same or greater than current
                                                        01/08/18 00:04:52:203 | [INFO] |  | ASU | OPM | OPM |  |  | 3708 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
                                                        01/08/18 00:04:52:203 | [INFO] |  | ASU | OPM | OPM |  |  | 3708 | No Record found for the input fields in opm_getValueForKey
                                                        01/08/18 00:04:52:273 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 3708 | The output of process received  in execWithOutput :
                                                        Microsoft Windows [Version 6.1.7601]
                                                        01/08/18 00:04:52:275 | [INFO] |  | ASU | DeploymentManager |  |  |  | 3708 | Event Guid generated is: '9c5346db-817f-4f26-bbe0-95ca22228874'
                                                        01/08/18 00:04:52:284 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 3708 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:04:52:961 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 9236 | HTTP Request Status code 200.
                                                        01/08/18 00:04:52:961 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 3708 | The http request returned HTTP_Status:0 HttpCommunicator error:0
                                                        01/08/18 00:04:52:961 | [INFO] |  | ASU | DeploymentManager |  |  |  | 3708 | Waiting for the async thread to get the task completed
                                                        01/08/18 00:04:52:961 | [INFO] |  | ASU | DeploymentManager |  |  |  | 8664 | Async thread is completed. Now exiting from function.
                                                        01/08/18 00:04:52:999 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3708 | The install workflow is terminating.
                                                        01/08/18 00:04:53:846 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 2348 | Process creation completed.
                                                        01/08/18 00:04:53:847 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 2348 |  The return Code from Create Process (1603).
                                                        01/08/18 00:04:56:735 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 2348 | Setup exiting with return code (6)
                                                        01/08/18 00:20:05:455 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 6756 | Build Version - 1.13.0.59
                                                        01/08/18 00:20:05:456 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 6756 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:05:482 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 6756 | Successfully fetched the optionXML content from MSI database ...
                                                        01/08/18 00:20:07:825 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3420 | Build Version - 1.13.0.59
                                                        01/08/18 00:20:07:825 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3420 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:07:825 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3420 | Executing immediate custom action for install mode.
                                                        01/08/18 00:20:07:825 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3420 | The CustomActionData string is : mode=install;sourceDir=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\;installDir=;origDB=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Adobe.msi;installLang=
                                                        01/08/18 00:20:07:825 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 3420 | Successfully executed the immediate custom action for install mode .
                                                        01/08/18 00:20:13:698 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Build Version - 1.13.0.59
                                                        01/08/18 00:20:13:699 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:13:699 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Executing the deferred custom action.
                                                        01/08/18 00:20:13:704 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Obtained the following as CustomActionData
                                                        01/08/18 00:20:13:704 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | (mode=install;sourceDir=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\;installDir=;origDB=F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Adobe.msi;installLang=)
                                                        01/08/18 00:20:13:704 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Original database path is : F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Adobe.msi
                                                        01/08/18 00:20:13:711 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | OptionXML saved at location :: C:\Users\Ty\AppData\Local\Temp\{BE14AA2E-F2FC-43D5-859D-32C52ADF9009}\\{B82D6421-5B70-413 5-8095-15E608DC38EF}
                                                        01/08/18 00:20:13:726 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Build Version - 1.13.0.59
                                                        01/08/18 00:20:13:726 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:13:726 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | CustomAction Parameters obtained...
                                                        01/08/18 00:20:13:726 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 |  optXMLPath :: C:\Users\Ty\AppData\Local\Temp\{BE14AA2E-F2FC-43D5-859D-32C52ADF9009}\\{B82D6421-5B70-413 5-8095-15E608DC38EF}
                                                        01/08/18 00:20:13:726 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 |  setupBasePath :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\
                                                        01/08/18 00:20:13:727 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 |  installDirPath ::
                                                        01/08/18 00:20:13:727 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 |  installLang ::
                                                        01/08/18 00:20:13:727 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Initializing Custom Action Data from parameters
                                                        01/08/18 00:20:13:727 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Provisioning Tool path is (C:\Users\Ty\AppData\Local\Temp\{BE14AA2E-F2FC-43D5-859D-32C52ADF9009}\\{F1658075-00D5-44 E3-8637-BEE26662892A}).
                                                        01/08/18 00:20:13:728 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Starting to run the custom action for install mode
                                                        01/08/18 00:20:13:728 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | STEP 1: Starting to parse Option XML.
                                                        01/08/18 00:20:13:736 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Latest AAM version with the package is (4.3.0.256)...
                                                        01/08/18 00:20:13:736 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Install language fallback contains following languages :
                                                        01/08/18 00:20:13:736 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 |     (en_GB)
                                                        01/08/18 00:20:13:737 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Self-Update BootStrapper Relative Path doesn't exist.
                                                        01/08/18 00:20:13:737 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | No of updates found (0).
                                                        01/08/18 00:20:13:737 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | No of HD products found (2).
                                                        01/08/18 00:20:13:737 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Failed to get value for conflicting processes...
                                                        01/08/18 00:20:13:738 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Failed to parse the conflictProcessInfo for HD media (COSY2.4.3)...
                                                        01/08/18 00:20:13:744 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Custom deployment path doesnt exist in options XML
                                                        01/08/18 00:20:13:744 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Failed to find Royalty Bearing attribute info.
                                                        01/08/18 00:20:13:744 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Found the AppsPanel attribute info (true)
                                                        01/08/18 00:20:13:744 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Found the AdminPrivilege attribute info (true)
                                                        01/08/18 00:20:13:744 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Number of Medias found = 0
                                                        01/08/18 00:20:13:744 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Deployment Manager is running in Install Mode.
                                                        01/08/18 00:20:13:744 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | STEP 2: Starting to launch ASU AAM.
                                                        01/08/18 00:20:13:744 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Bootstrapper launch location is :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU\Set-up.dat
                                                        01/08/18 00:20:13:850 | [INFO] |  | ASU | OPM | OPM |  |  | 6128 | Build Version - 10.0.0.99
                                                        01/08/18 00:20:13:850 | [INFO] |  | ASU | OPM | OPM |  |  | 6128 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:13:852 | [INFO] |  | ASU | OPM | OPM |  |  | 6128 | Schema version and schema compatibility version are same or greater than current
                                                        01/08/18 00:20:14:011 | [INFO] |  | ASU | OPM | OPM |  |  | 6128 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
                                                        01/08/18 00:20:14:011 | [INFO] |  | ASU | OPM | OPM |  |  | 6128 | No Record found for the input fields in opm_getValueForKey
                                                        01/08/18 00:20:15:521 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Build Version - 1.13.0.59
                                                        01/08/18 00:20:15:521 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:15:522 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | The return code from the Bootstrapper Process is (0).
                                                        01/08/18 00:20:15:523 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Created file with ACC Panel Masked C:\Program Files (x86)\Common Files\Adobe\OOBE\Configs\ServiceConfig.xml
                                                        01/08/18 00:20:15:523 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Starting apply CCP ASU.
                                                        01/08/18 00:20:15:523 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Bootstrapper launch location is :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\Set-up.dat
                                                        01/08/18 00:20:15:563 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | Build Version - 10.0.0.49
                                                        01/08/18 00:20:15:563 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:15:565 | [INFO] |  | ASU | Setup |  |  |  | 4184 | Event Guid generated is: '33936ab8-cc3e-49f1-944e-3529d0838632'
                                                        01/08/18 00:20:15:566 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | Start Adobe Setup
                                                        01/08/18 00:20:15:566 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | TimeLog: Bootstrapper Start
                                                        01/08/18 00:20:15:566 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | TimeLog: Start initial checks
                                                        01/08/18 00:20:15:566 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | Action specified - "install"
                                                        01/08/18 00:20:15:567 | [INFO] |  | ASU | Setup | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:567 | [WARN] |  | ASU | Setup | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:574 | [INFO] |  | ASU | Setup |  |  |  | 4220 | Event with guid '33936ab8-cc3e-49f1-944e-3529d0838632' is being sent
                                                        01/08/18 00:20:15:581 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 4220 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:20:15:597 | [INFO] |  | ASU | Setup | Utilities |  |  | 4184 | Semaphore is not locked
                                                        01/08/18 00:20:15:599 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Build Version - 10.0.0.151
                                                        01/08/18 00:20:15:600 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:15:601 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Build Version - 10.0.0.151
                                                        01/08/18 00:20:15:601 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:15:601 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | CREATE PIM Instance ...
                                                        01/08/18 00:20:15:603 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | trying to createOrUpdatePIMDbSchema.
                                                        01/08/18 00:20:15:606 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Current db schema version on machine 1.
                                                        01/08/18 00:20:15:606 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Current db schema version to install 1.
                                                        01/08/18 00:20:15:606 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | PIM DB Schema is up to date. Current schema version is 1.
                                                        01/08/18 00:20:15:606 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | PIM Database is Up To Date.
                                                        01/08/18 00:20:15:606 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Updater Inventory location:F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\resources\updaterinventory.dll
                                                        01/08/18 00:20:15:609 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Acquired System level ACF lock ...
                                                        01/08/18 00:20:15:609 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | TimeLog: End initial checks
                                                        01/08/18 00:20:15:609 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | TimeLog: Begin Installing
                                                        01/08/18 00:20:15:610 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Current OS version is: Major:6, Minor:1, ServicePack:1
                                                        01/08/18 00:20:15:616 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:616 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:617 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 2D07B44E-5043-413A-BF8F-127DDB5B61EC is already installed
                                                        01/08/18 00:20:15:632 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:633 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:634 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 1B3D24F6-3654-4EB4-A783-101CD2162E7C is already installed
                                                        01/08/18 00:20:15:643 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:643 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:644 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id FB270CC2-4272-4706-890F-2829237CBB06 is already installed
                                                        01/08/18 00:20:15:648 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:648 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:649 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id E1991EA9-E359-43BA-9DBE-F2657FFAABF4 is already installed
                                                        01/08/18 00:20:15:656 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:656 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:657 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id CE50F807-977B-4BC7-8ABD-CAD97273A9EC is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:15:659 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:659 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:659 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 71796FCB-CA48-4BD1-9D93-D51093659A17 is already installed
                                                        01/08/18 00:20:15:674 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 4220 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/08/18 00:20:15:674 | [ERROR] |  | ASU | Setup |  |  |  | 4220 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/08/18 00:20:15:677 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:678 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:679 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 399F5D01-3BF2-4310-A624-3B5DB12FAA13 is already installed
                                                        01/08/18 00:20:15:686 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:686 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:687 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id A3B57320-15AD-4AF5-897D-6C9D7C6B7353 is already installed
                                                        01/08/18 00:20:15:691 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:691 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:691 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 2F2AFF87-CCBC-420C-8B97-4831EFD329DF is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:15:693 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:693 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:693 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 21693786-66E8-4A21-A57B-8085FF9ACD07 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:15:693 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 40409899
                                                        01/08/18 00:20:15:694 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Executing Adobe Genuine Validation for all the AAM packages
                                                        01/08/18 00:20:15:694 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pimx'
                                                        01/08/18 00:20:15:696 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pima'
                                                        01/08/18 00:20:15:701 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pimx'
                                                        01/08/18 00:20:15:702 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pima'
                                                        01/08/18 00:20:15:709 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pimx'
                                                        01/08/18 00:20:15:711 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pima'
                                                        01/08/18 00:20:15:717 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pimx'
                                                        01/08/18 00:20:15:718 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pima'
                                                        01/08/18 00:20:15:726 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P6\P6.pimx'
                                                        01/08/18 00:20:15:727 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P6\P6.pima'
                                                        01/08/18 00:20:15:745 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pimx'
                                                        01/08/18 00:20:15:746 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pima'
                                                        01/08/18 00:20:15:762 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pimx'
                                                        01/08/18 00:20:15:763 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pima'
                                                        01/08/18 00:20:15:791 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pimx'
                                                        01/08/18 00:20:15:793 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pima'
                                                        01/08/18 00:20:15:798 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P7\P7.pimx'
                                                        01/08/18 00:20:15:799 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P7\P7.pima'
                                                        01/08/18 00:20:15:804 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\AdobeGCClient\AdobeGCClient.pimx'
                                                        01/08/18 00:20:15:805 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\AdobeGCClient\AdobeGCClient.pima'
                                                        01/08/18 00:20:15:821 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Adobe Genuine Validation PASSED for all the AAM packages
                                                        01/08/18 00:20:15:821 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pimx
                                                        01/08/18 00:20:15:826 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:15:827 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:15:828 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 2D07B44E-5043-413A-BF8F-127DDB5B61EC is already installed
                                                        01/08/18 00:20:15:856 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:20:16:015 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:20:16:015 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:20:16:188 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:20:16:189 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:16:189 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:20:16:196 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Backup Folder Created
                                                        01/08/18 00:20:16:584 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Directory not present
                                                        01/08/18 00:20:16:584 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:20:16:584 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\core_bkp1'
                                                        01/08/18 00:20:16:726 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMCustomHook.exe" --createInventory=1 --doPostInstallStep=1
                                                        01/08/18 00:20:16:737 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Success in CreateProcess
                                                        01/08/18 00:20:16:747 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4252 | Build Version - 10.0.0.49
                                                        01/08/18 00:20:16:747 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4252 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:16:748 | [INFO] |  | ASU | AAMCustomHook |  |  | CommandLineParser | 4252 | Parsing the command line provided. Number of command line arguments is 3
                                                        01/08/18 00:20:16:767 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4252 | Updater Inventory location: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\UWA\updaterinventory.dll'
                                                        01/08/18 00:20:16:771 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4252 | Going to create or update inventory
                                                        01/08/18 00:20:16:795 | [INFO] |  | ASU | AAMCustomHook | AAMCustomHook |  |  | 4252 | Inventory Already present on the machine...
                                                        01/08/18 00:20:16:798 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Sucessfully launched and executed process...
                                                        01/08/18 00:20:16:798 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\core\AAMCustomHook.exe'
                                                        01/08/18 00:20:16:799 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\core\PDApp.pimx.
                                                        01/08/18 00:20:16:813 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pimx
                                                        01/08/18 00:20:16:816 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:16:816 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:16:817 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 1B3D24F6-3654-4EB4-A783-101CD2162E7C is already installed
                                                        01/08/18 00:20:16:827 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:20:16:856 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:20:16:857 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:20:16:928 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:20:16:929 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:20:16:933 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Backup Folder Created
                                                        01/08/18 00:20:16:992 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Directory not present
                                                        01/08/18 00:20:16:992 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:20:16:992 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\D6_bkp1'
                                                        01/08/18 00:20:17:063 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\D6\D6.pimx.
                                                        01/08/18 00:20:17:074 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pimx
                                                        01/08/18 00:20:17:077 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:17:077 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:17:078 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id FB270CC2-4272-4706-890F-2829237CBB06 is already installed
                                                        01/08/18 00:20:17:089 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:20:17:122 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:20:17:123 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:20:17:189 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:20:17:189 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:17:189 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:20:17:194 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Backup Folder Created
                                                        01/08/18 00:20:17:484 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Directory not present
                                                        01/08/18 00:20:17:484 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:20:17:484 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DECore_bkp1'
                                                        01/08/18 00:20:17:558 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DECore\DECore.pimx.
                                                        01/08/18 00:20:17:576 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pimx
                                                        01/08/18 00:20:17:578 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:17:578 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:17:578 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id E1991EA9-E359-43BA-9DBE-F2657FFAABF4 is already installed
                                                        01/08/18 00:20:17:596 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:20:17:606 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:20:17:606 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:20:17:628 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:20:17:629 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:20:17:633 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Backup Folder Created
                                                        01/08/18 00:20:17:635 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:17:700 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Directory not present
                                                        01/08/18 00:20:17:700 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:20:17:700 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\DWA_bkp1'
                                                        01/08/18 00:20:17:768 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\DWA\DWA.pimx.
                                                        01/08/18 00:20:17:776 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P6\P6.pimx
                                                        01/08/18 00:20:17:778 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:17:778 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:17:778 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | NOTE package id CE50F807-977B-4BC7-8ABD-CAD97273A9EC is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:17:778 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pimx
                                                        01/08/18 00:20:17:780 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:17:780 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:17:780 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 71796FCB-CA48-4BD1-9D93-D51093659A17 is already installed
                                                        01/08/18 00:20:17:802 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:20:17:816 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:20:17:816 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:20:17:837 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:20:17:837 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:20:17:842 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Backup Folder Created
                                                        01/08/18 00:20:17:843 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:18:063 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Directory not present
                                                        01/08/18 00:20:18:063 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:20:18:063 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\LWA_bkp1'
                                                        01/08/18 00:20:18:266 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\LWA\LWA.pimx.
                                                        01/08/18 00:20:18:272 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pimx
                                                        01/08/18 00:20:18:276 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:18:276 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:18:277 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id 399F5D01-3BF2-4310-A624-3B5DB12FAA13 is already installed
                                                        01/08/18 00:20:18:285 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:20:18:320 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:20:18:320 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:20:18:425 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:20:18:427 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:20:18:433 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Backup Folder Created
                                                        01/08/18 00:20:18:591 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Directory not present
                                                        01/08/18 00:20:18:591 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:20:18:591 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\UWA_bkp1'
                                                        01/08/18 00:20:18:706 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\UWA\UWA.pimx.
                                                        01/08/18 00:20:18:718 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pimx
                                                        01/08/18 00:20:18:719 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:18:719 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:18:720 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Package id A3B57320-15AD-4AF5-897D-6C9D7C6B7353 is already installed
                                                        01/08/18 00:20:18:727 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:20:18:740 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:20:18:740 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:20:18:767 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:20:18:768 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:18:768 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:20:18:772 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Backup Folder Created
                                                        01/08/18 00:20:18:799 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Directory not present
                                                        01/08/18 00:20:18:799 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:20:18:799 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC_bkp1'
                                                        01/08/18 00:20:18:833 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Path to Process :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe Process Directory :C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook arguments being passed :"C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe" -uninstall
                                                        01/08/18 00:20:18:841 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Success in CreateProcess
                                                        01/08/18 00:20:18:858 | [INFO] |  | ASU | PIM | Utilities |  |  | 4184 | Sucessfully launched and executed process...
                                                        01/08/18 00:20:18:858 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Successfully executed install modifier at path: 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\\IPC\customhook\AdobeIPCBrokerCustomHook.exe'
                                                        01/08/18 00:20:18:859 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\IPC\IPC.pimx.
                                                        01/08/18 00:20:18:867 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\P7\P7.pimx
                                                        01/08/18 00:20:18:870 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:18:870 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:18:870 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | NOTE package id 2F2AFF87-CCBC-420C-8B97-4831EFD329DF is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:18:871 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\ASU2\packages\AdobeGCClient\AdobeGCClient.pimx
                                                        01/08/18 00:20:18:871 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | XML is valid
                                                        01/08/18 00:20:18:872 | [WARN] |  | ASU | PIM | PIM |  |  | 4184 | Failed to find Node
                                                        01/08/18 00:20:18:872 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | NOTE package id 21693786-66E8-4A21-A57B-8085FF9ACD07 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:18:890 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Processing ... _pimCreateOrUpdateAAMInventory
                                                        01/08/18 00:20:18:900 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | Inventory Already present on the machine...
                                                        01/08/18 00:20:18:900 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | TimeLog: End Installing. Now launching PDApp
                                                        01/08/18 00:20:19:400 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | Deployment File Path not specified in command line arguments. Skipping payload deployment part
                                                        01/08/18 00:20:19:400 | [INFO] |  | ASU | Setup |  |  |  | 4184 | Event Guid generated is: '74605c63-1b6d-4617-8b3e-90268551f702'
                                                        01/08/18 00:20:19:400 | [INFO] |  | ASU | Setup | Setup |  |  | 4184 | =================  End Adobe Setup. Exit code: 0  =================
                                                        01/08/18 00:20:19:402 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | PIMSqlite closeDB status 0
                                                        01/08/18 00:20:19:402 | [INFO] |  | ASU | PIM | PIM |  |  | 4184 | FREE PIM Instance ...
                                                        01/08/18 00:20:19:402 | [INFO] |  | ASU | Setup |  |  |  | 4184 | Waiting for the async thread to get the task completed
                                                        01/08/18 00:20:19:405 | [INFO] |  | ASU | Setup |  |  |  | 4220 | Event with guid '74605c63-1b6d-4617-8b3e-90268551f702' is being sent
                                                        01/08/18 00:20:19:407 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 4220 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:20:19:409 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 4220 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/08/18 00:20:19:409 | [ERROR] |  | ASU | Setup |  |  |  | 4220 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/08/18 00:20:19:409 | [INFO] |  | ASU | Setup |  |  |  | 4220 | Async thread is completed. Now exiting from function.
                                                        01/08/18 00:20:19:414 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Build Version - 1.13.0.59
                                                        01/08/18 00:20:19:414 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:19:414 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | The return code from the Bootstrapper Process is (0).
                                                        01/08/18 00:20:19:414 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Starting apply ASU Self-Update.
                                                        01/08/18 00:20:19:414 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | SelfUpdate Path - F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14
                                                        01/08/18 00:20:19:414 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Bootstrapper launch location is :: F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\Set-up.dat
                                                        01/08/18 00:20:19:450 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | Build Version - 9.0.0.141
                                                        01/08/18 00:20:19:450 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:19:453 | [INFO] |  | ASU | Setup |  |  |  | 4392 | Event Guid generated is: '6cdbd4cf-43f2-4035-be46-78dcb2ab13fe'
                                                        01/08/18 00:20:19:453 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | Start Adobe Setup
                                                        01/08/18 00:20:19:453 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | TimeLog: Bootstrapper Start
                                                        01/08/18 00:20:19:453 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | TimeLog: Start initial checks
                                                        01/08/18 00:20:19:453 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | Action specified - "install"
                                                        01/08/18 00:20:19:455 | [INFO] |  | ASU | Setup | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:455 | [WARN] |  | ASU | Setup | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:461 | [INFO] |  | ASU | Setup |  |  |  | 4396 | Event with guid '6cdbd4cf-43f2-4035-be46-78dcb2ab13fe' is being sent
                                                        01/08/18 00:20:19:465 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 4396 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:20:19:474 | [INFO] |  | ASU | Setup | Utilities |  |  | 4392 | Semaphore is not locked
                                                        01/08/18 00:20:19:477 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Build Version - 9.0.0.141
                                                        01/08/18 00:20:19:478 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 4396 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/08/18 00:20:19:478 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:19:478 | [ERROR] |  | ASU | Setup |  |  |  | 4396 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/08/18 00:20:19:479 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Build Version - 9.0.0.141
                                                        01/08/18 00:20:19:479 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:19:479 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | CREATE PIM Instance ...
                                                        01/08/18 00:20:19:481 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | trying to createOrUpdatePIMDbSchema.
                                                        01/08/18 00:20:19:484 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Current db schema version on machine 1.
                                                        01/08/18 00:20:19:484 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Current db schema version to install 1.
                                                        01/08/18 00:20:19:484 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | PIM DB Schema is up to date. Current schema version is 1.
                                                        01/08/18 00:20:19:484 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | PIM Database is Up To Date.
                                                        01/08/18 00:20:19:484 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Updater Inventory location:F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\resources\updaterinventory.dll
                                                        01/08/18 00:20:19:488 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Acquired System level ACF lock ...
                                                        01/08/18 00:20:19:488 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | TimeLog: End initial checks
                                                        01/08/18 00:20:19:488 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | TimeLog: Begin Installing
                                                        01/08/18 00:20:19:488 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Current OS version is: Major:6, Minor:1, ServicePack:1
                                                        01/08/18 00:20:19:494 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:494 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:495 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id B12B2FC7-66D0-4766-BF19-081A48A2F372 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:499 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:500 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:500 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id B948115B-424C-443F-8047-B30C8B90BCA8 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:504 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:504 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:504 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id 0CDA4C3B-0E1F-49E0-A88A-FA6AA9979424 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:506 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:506 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:507 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id DE9FAA6B-94F6-42A7-A9FD-B0D716ED3EED is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:509 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:509 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:509 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id 062E98C1-1625-4373-BC41-0831335A5A2B is already installed
                                                        01/08/18 00:20:19:525 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:525 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:525 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id B322281B-C04F-438E-82D7-7DA34A359526 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:530 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:530 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:531 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id A8F3EA33-B0E0-43B2-990D-3DA2B0317B82 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:534 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:534 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:534 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id 3F9C8B10-559B-46D3-8053-9208FF459C01 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:536 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:536 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:536 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id 6A7BA94E-D704-4182-89A2-0C430D86D676 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:538 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:539 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:539 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id EFCC1FE1-DD11-4531-AF33-B3DC7A08B625 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:540 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:540 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:540 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id A1683289-8BD1-420E-8B0F-D32C6F436249 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:540 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | pim_haveEnoughDiskSpaceToInstallPackages reqSize ... 15941768
                                                        01/08/18 00:20:19:540 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Executing Adobe Genuine Validation for all the AAM packages
                                                        01/08/18 00:20:19:540 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\core\PDApp.pimx'
                                                        01/08/18 00:20:19:542 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\core\PDApp.pima'
                                                        01/08/18 00:20:19:548 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\D6\D6.pimx'
                                                        01/08/18 00:20:19:550 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\D6\D6.pima'
                                                        01/08/18 00:20:19:557 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DECore\DECore.pimx'
                                                        01/08/18 00:20:19:558 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DECore\DECore.pima'
                                                        01/08/18 00:20:19:564 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DWA\DWA.pimx'
                                                        01/08/18 00:20:19:565 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DWA\DWA.pima'
                                                        01/08/18 00:20:19:574 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pimx'
                                                        01/08/18 00:20:19:575 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pima'
                                                        01/08/18 00:20:19:593 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\LWA\LWA.pimx'
                                                        01/08/18 00:20:19:594 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\LWA\LWA.pima'
                                                        01/08/18 00:20:19:609 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\UWA\UWA.pimx'
                                                        01/08/18 00:20:19:610 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\UWA\UWA.pima'
                                                        01/08/18 00:20:19:630 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\CCM\CCM.pimx'
                                                        01/08/18 00:20:19:631 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\CCM\CCM.pima'
                                                        01/08/18 00:20:19:647 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\IPC\IPC.pimx'
                                                        01/08/18 00:20:19:648 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\IPC\IPC.pima'
                                                        01/08/18 00:20:19:655 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P7\P7.pimx'
                                                        01/08/18 00:20:19:657 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P7\P7.pima'
                                                        01/08/18 00:20:19:683 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\AdobeGCClient\AdobeGCCli ent.pimx'
                                                        01/08/18 00:20:19:684 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Validating package file: 'F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\AdobeGCClient\AdobeGCCli ent.pima'
                                                        01/08/18 00:20:19:700 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Adobe Genuine Validation PASSED for all the AAM packages
                                                        01/08/18 00:20:19:700 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\core\PDApp.pimx
                                                        01/08/18 00:20:19:705 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:705 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:705 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id B12B2FC7-66D0-4766-BF19-081A48A2F372 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:706 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\D6\D6.pimx
                                                        01/08/18 00:20:19:709 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:709 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:709 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id B948115B-424C-443F-8047-B30C8B90BCA8 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:710 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DECore\DECore.pimx
                                                        01/08/18 00:20:19:712 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:712 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:713 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id 0CDA4C3B-0E1F-49E0-A88A-FA6AA9979424 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:713 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\DWA\DWA.pimx
                                                        01/08/18 00:20:19:714 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:714 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:715 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id DE9FAA6B-94F6-42A7-A9FD-B0D716ED3EED is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:19:715 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pimx
                                                        01/08/18 00:20:19:717 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:19:717 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:19:717 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Package id 062E98C1-1625-4373-BC41-0831335A5A2B is already installed
                                                        01/08/18 00:20:19:736 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | SUCCESS deleteAppletRegInfoRecords.
                                                        01/08/18 00:20:19:757 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | SUCCESS deletePackageUpgradeInfoRecords.
                                                        01/08/18 00:20:19:757 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | SUCCESS deletePackageInstallationInfoRecords.
                                                        01/08/18 00:20:19:793 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | SUCCESS insertPackageUpdateList.
                                                        01/08/18 00:20:19:793 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | SUCCESS insertAppletRegInfoList.
                                                        01/08/18 00:20:19:799 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Backup Folder Created
                                                        01/08/18 00:20:20:092 | [INFO] |  | ASU | PIM | Utilities |  |  | 4392 | Directory not present
                                                        01/08/18 00:20:20:092 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | ERROR Failed Delete backed up assets
                                                        01/08/18 00:20:20:092 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Trying to delete back up folder 'C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\P6_bkp1'
                                                        01/08/18 00:20:20:313 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | SUCCESS installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P6\P6.pimx.
                                                        01/08/18 00:20:20:320 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\LWA\LWA.pimx
                                                        01/08/18 00:20:20:321 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:20:321 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:20:322 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id B322281B-C04F-438E-82D7-7DA34A359526 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:20:322 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\UWA\UWA.pimx
                                                        01/08/18 00:20:20:325 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:20:325 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:20:326 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id A8F3EA33-B0E0-43B2-990D-3DA2B0317B82 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:20:326 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\CCM\CCM.pimx
                                                        01/08/18 00:20:20:328 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:20:328 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:20:329 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id 3F9C8B10-559B-46D3-8053-9208FF459C01 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:20:329 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\IPC\IPC.pimx
                                                        01/08/18 00:20:20:330 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:20:330 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:20:330 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id 6A7BA94E-D704-4182-89A2-0C430D86D676 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:20:330 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\P7\P7.pimx
                                                        01/08/18 00:20:20:332 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:20:332 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:20:332 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id EFCC1FE1-DD11-4531-AF33-B3DC7A08B625 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:20:333 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | START installPackage at file F:\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018 v11.0.0 incl Patches [Xforce + Painter]\Adobe Audition CC 2018\Build\Patches\AdobeApplicationManager-1.0_update14\packages\AdobeGCClient\AdobeGCCli ent.pimx
                                                        01/08/18 00:20:20:333 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | XML is valid
                                                        01/08/18 00:20:20:333 | [WARN] |  | ASU | PIM | PIM |  |  | 4392 | Failed to find Node
                                                        01/08/18 00:20:20:333 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | NOTE package id A1683289-8BD1-420E-8B0F-D32C6F436249 is a Old Package, a newer package is installed in the system.
                                                        01/08/18 00:20:20:355 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Processing ... _pimCreateOrUpdateAAMInventory
                                                        01/08/18 00:20:20:364 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Higher version of AAM Updater inventory is already present in the machine. So skipping the creation of AAM Updater Inventory
                                                        01/08/18 00:20:20:364 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | Return ... SUCCESS _pimCreateOrUpdateAAMInventory
                                                        01/08/18 00:20:20:364 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | TimeLog: End Installing. Now launching PDApp
                                                        01/08/18 00:20:20:864 | [INFO] |  | ASU | Setup |  |  |  | 4392 | Event Guid generated is: 'dade579c-8649-4313-953d-0e9629af4520'
                                                        01/08/18 00:20:20:864 | [INFO] |  | ASU | Setup | Setup |  |  | 4392 | =================  End Adobe Setup. Exit code: 0  =================
                                                        01/08/18 00:20:20:866 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | PIMSqlite closeDB status 0
                                                        01/08/18 00:20:20:866 | [INFO] |  | ASU | PIM | PIM |  |  | 4392 | FREE PIM Instance ...
                                                        01/08/18 00:20:20:866 | [INFO] |  | ASU | Setup |  |  |  | 4392 | Waiting for the async thread to get the task completed
                                                        01/08/18 00:20:20:871 | [INFO] |  | ASU | Setup |  |  |  | 4396 | Event with guid 'dade579c-8649-4313-953d-0e9629af4520' is being sent
                                                        01/08/18 00:20:20:873 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 4396 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:20:20:874 | [INFO] |  | ASU | Setup |  |  | HTTPConnector | 4396 | The http request returned HTTP_Status:0 HttpCommunicator error:68
                                                        01/08/18 00:20:20:875 | [ERROR] |  | ASU | Setup |  |  |  | 4396 | SendEvent failed. HTTPConnectorResponse is : 68
                                                        01/08/18 00:20:20:875 | [INFO] |  | ASU | Setup |  |  |  | 4396 | Async thread is completed. Now exiting from function.
                                                        01/08/18 00:20:20:879 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Build Version - 1.13.0.59
                                                        01/08/18 00:20:20:879 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:20:879 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | The return code from the Bootstrapper Process is (0).
                                                        01/08/18 00:20:20:880 | [ERROR] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 6112 | Failed to initialize HDPIM wrapper, failed to load HDPIM library/Setup () (C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\Setup.exe)...
                                                        01/08/18 00:20:20:880 | [WARN] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Failed to initialize HDPIM for conflict processes handling ...
                                                        01/08/18 00:20:20:894 | [ERROR] |  | ASU | DeploymentManager | HDPIMWrapper |  |  | 6112 | Failed to initialize HDPIM wrapper, failed to load HDPIM library/Setup () (C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\Setup.exe)...
                                                        01/08/18 00:20:20:894 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Failed to initialize HDPIM library ...
                                                        01/08/18 00:20:20:894 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Starting to clean the partially installed payloads.
                                                        01/08/18 00:20:20:894 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | No payloads are required to be cleaned up. So Adobe Installer is not invoked.
                                                        01/08/18 00:20:20:894 | [ERROR] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | Failed to initialize HDPIM library in cleanup mode ...
                                                        01/08/18 00:20:20:918 | [INFO] |  | ASU | OPM | OPM |  |  | 6112 | Build Version - 10.0.0.130
                                                        01/08/18 00:20:20:918 | [INFO] |  | ASU | OPM | OPM |  |  | 6112 | Logging Level verbosity Set  to 4
                                                        01/08/18 00:20:20:923 | [INFO] |  | ASU | OPM | OPM |  |  | 6112 | Schema version and schema compatibility version are same or greater than current
                                                        01/08/18 00:20:21:077 | [INFO] |  | ASU | OPM | OPM |  |  | 6112 | _opm_handle_OPDReturnedStatus called with opdStatus as:0
                                                        01/08/18 00:20:21:077 | [INFO] |  | ASU | OPM | OPM |  |  | 6112 | No Record found for the input fields in opm_getValueForKey
                                                        01/08/18 00:20:21:137 | [INFO] |  | ASU | DeploymentManager | AAMEEUtilities |  |  | 6112 | The output of process received  in execWithOutput :
                                                        Microsoft Windows [Version 6.1.7601]
                                                        01/08/18 00:20:21:139 | [INFO] |  | ASU | DeploymentManager |  |  |  | 6112 | Event Guid generated is: '4a1c6388-0a0a-4779-95e5-ec2302d9eb45'
                                                        01/08/18 00:20:21:152 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 6112 | GetIEProxyInfo - No default proxy present on the user machine
                                                        01/08/18 00:20:21:511 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 4308 | HTTP Request Status code 200.
                                                        01/08/18 00:20:21:511 | [INFO] |  | ASU | DeploymentManager |  |  | HTTPConnector | 6112 | The http request returned HTTP_Status:0 HttpCommunicator error:0
                                                        01/08/18 00:20:21:512 | [INFO] |  | ASU | DeploymentManager |  |  |  | 6112 | Waiting for the async thread to get the task completed
                                                        01/08/18 00:20:21:512 | [INFO] |  | ASU | DeploymentManager |  |  |  | 3920 | Async thread is completed. Now exiting from function.
                                                        01/08/18 00:20:21:620 | [INFO] |  | ASU | DeploymentManager | DeploymentManager |  |  | 6112 | The install workflow is terminating.
                                                        01/08/18 00:20:22:197 | [INFO] |  | ASU | MSIInvoker | AAMEEUtilities |  |  | 6756 | Process creation completed.
                                                        01/08/18 00:20:22:197 | [INFO] |  | ASU | MSIInvoker | MSIInvoker |  |  | 6756 |  The return Code from Create Process (1603).
                                                        • 33. Re: [CS5.5] Installer failed to initialize. Please download Adobe Support Advisor to detect the problem.
                                                          ravenise Level 1
                                                          FIXED: AdobeCreativeCloudCleanerTool fixed my problem! Without even having to uninstall any existing programs, just ran this and everything worked fine!
