1 Reply Latest reply on Oct 16, 2012 11:31 AM by avdave
    How to rotate a rectangle around centroid in flex 3
    avdave
      I am using matrix.rotate method to rotate the rectangle (box in my case). My rotate event looks like below:
      public function transformObject(transformEvent:TransformEvent):void{
              var numChildrn:int = _markedObjectLayer.numChildren;
      var tempMatrix: Matrix = null;
      var tempx:Number;
      var tempy:Number;
      for(var i:int = 0; i < numChildrn; i++){
      var chld:MarkedObject = UIComponent.getChildAt(i) MarkedObject
      if (chld.selected){
      var  height:int = (BoxObject) chld.height;
      var  width:int = (BoxObject) chld.width;
                      tempMatrix
      = chld.transform.matrix;
                                      tempx = chld.x;
                                    tempy= chld.y ;
                      tempMatrix
      = MatrixTransformer.transform(tempMatrix,transformEvent.angle);
                      tempMatrix
      .tx=tempx;
                      tempMatrix
      .ty=tempy
                      chld
      .transform.matrix = tempMatrix;
              invalidateDisplayList
      The Matrix.transform method calls matrix.rotate method
      public static function transform(sourceMatrix:Matrix, rotation:Number=0 ):Matrix {
              sourceMatrix = MatrixTransformer.rotate(sourceMatrix, rotation, "degrees");
      return sourceMatrix;
           * Rotates a matrix and returns the result. The unit parameter lets the user specify "degrees",
           * "gradients", or "radians".
      public static function rotate(sourceMatrix:Matrix, angle:Number, unit:String = "radians"):Matrix {
      if (unit == "degrees")
                  angle
      = Math.PI * 2 *( angle / 360);
              sourceMatrix
      . rotate(angle)
      The issue is that x and y are left corener of the box and hence it is rotating around left corner. However, if I try to give temp.x and temp.y as centroid value it does not rotate around centroid?
      I would really appreciate if someone can tell me what am I doing wrong here
      Thanks Akshay
        • 1. Re: How to rotate a rectangle around centroid in flex 3
          avdave Level 1
          Figured it out:
            Use following code:
          tempMatrix = chld.transform.matrix;
          tempx = chld.x + widht/2;
          tempy= chld.y +height/2 ;
          //the important step is to translate the code to appropriate position before and after rotation
              tempMatrix.translate(-1*tempx,-1*tempy);
              tempMatrix = MatrixTransformer.transform(tempMatrix,transformEvent.angle);
          tempMatrix.translate(tempx,tempy);
          chld.transform.matrix = tempMatrix;
