5 Replies Latest reply on Nov 30, 2012 6:18 AM by Gonterman1201
    Conditional Operator for else if?
    Gonterman1201 Level 1
      I used the google compiler on one of my scripts. It worked fine except I am getting hung up on some of the conditional statements it made. Originally I had a series of if else if statements. When changed to Conditional Operator it changes the fuctionality of it. Here we go if anyone can help I will take any tips.
      My version:
      if(myYear.selection.text=="10"){yearSelect=0;}
               else if(myYear.selection.text=="11"){yearSelect=1;}
               else if(myYear.selection.text=="12"){yearSelect=2;}
               else if(myYear.selection.text=="13"){yearSelect=3;}
               else if(myYear.selection.text=="14"){yearSelect=4;}
              else{yearSelect=5;}
      Google version:
      yearSelect="10"==b.selection.text?0:"11"==b.selection.text?1:"12"==b.selection.text?2:"13"==b.selection.text?3:"14"==b.selection.text?4:5,
      Thanks in advance for any advice.
      Brett.
        • 1. Re: Conditional Operator for else if?
          Common Javascript syntax.
          a = b ? c : d;
          is equal to
          if (b == true)
            a = c;
          else
            a = d;
          What does "it changes the fuctionality of it" mean? Doesn't it work anymore?
          • 2. Re: Conditional Operator for else if?
            .. Apart from that, there is no need for your original long list of "if .. else". For a list of possible inputs, you should consider something like this:
            switch(myYear.selection.text)
             case "10": yearSelect=0; break;
             case "11": yearSelect=1; break;
             case "12": yearSelect=2; break;
             case "13": yearSelect=3; break;
             case "14": yearSelect=4; break;
             default: yearSelect=5;
            or, with your input and output, something as simple as
            yearSelect = Number(myYear.selection.text)-10;
            -- but I don't know what your possible range of inputs is. If it's "anything goes", you have to check for a not-in-range and then set it to your default of 5.
            • 3. Re: Conditional Operator for else if?
              I just tried this and it worked thanks you for your help!
              yearSelect = yearSelect="10"==b.selection.text?0:
                        yearSelect="11"==b.selection.text?1:
                        yearSelect="12"==b.selection.text?2:
                        yearSelect="13"==b.selection.text?3:
                        yearSelect="14"==b.selection.text?4:
                                     5,
              I will also consider the switch. Thank you.
              • 4. Re: Conditional Operator for else if?
                Peter Kahrel Adobe Community Professional & MVP
                Brett,
                The difference between Jongware's version and your last one is that Jongware's version is easy to understand, while your last version is not. Why would you entertain such a braintwister when there's such a clear method available? that Google comes up with those constructions doesn't mean much.
                Peter
                • 5. Re: Conditional Operator for else if?
                  Thanks Peter. Very good to have your perspective.
