20 Replies Latest reply on Aug 27, 2016 4:47 AM by ananggadipa
    Reworking Photoshop layer renaming script for Illustrator
    Navarro Parker Level 3
      The Photoshop scripting guru Paul R over at RetouchPro has created a really cool script to batch rename and number selected Photoshop layers. I haven't found anything similar on the Illustrator side.
      He's given permission for me to post it here in my hopes that some Illustrator scripting genius could come up with a similar script for Illustrator. Would it be terribly difficult to convert this into something Illustrator could use?
      http://www.mediafire.com/file/g7usr73u0236p0a/Rename_&_Renumber_Selected_Layers.jsx
      http://www.mediafire.com/file/dbah74x13bsa74c/Rename_&_Renumber_Selected_Layers.jsx.zip
        • 1. Re: Reworking Photoshop layer renaming script for Illustrator
          W_J_T Level 4
          I didn't look at the script you provided, but this thread with code should be helpful as a starting point, by Muppet Mark, Jongware, Larry, etc:
          http://forums.adobe.com/message/2639824
          You could always add a prompt, or script a UI window, otherwise it seems to have everything (based on the screen grab you posted) to get going. Hope it's helpful.
          • 2. Re: Reworking Photoshop layer renaming script for Illustrator
            CarlosCanto Adobe Community Professional & MVP
            it seems posible, we can't tell if more than one layer is active, but there are work arounds like in the thread posted above.
            but yeah, it seems very doable.
            • 3. Re: Reworking Photoshop layer renaming script for Illustrator
              here you go, as I said, there's no access to "active layers" in illustrator, so we have to resort to workarounds. In this case the script will change the "visible" layers, hide layers you want to keep unchanged.
              #target illustrator
              main();
              function main(){
                  if(!documents.length) return;
                  var allLayers = app.activeDocument.layers;
                  var win = new Window( 'dialog', '' );
                  g = win.graphics;
                  var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.99, 0.99, 0.99, 1]);
                  g.backgroundColor = myBrush;
                  win.orientation='stack';
                  win.p1= win.add("panel", undefined, undefined, {borderStyle:"black"});
                  win.g1 = win.p1.add('group');
                  win.g1.orientation = "row";
                  win.title = win.g1.add('statictext',undefined,'Rename Layers');
                  win.title.alignment="fill";
                  var g = win.title.graphics;
                  g.font = ScriptUI.newFont("Georgia","BOLDITALIC",22);
                  win.g5 =win.p1.add('group');
                  win.g5.orientation = "column";
                  win.g5.alignChildren='left';
                  win.g5.spacing=10;
                  win.g5.st1 = win.g5.add('statictext',undefined,'New layer name');
                  win.g5.et1 = win.g5.add('edittext');
                  win.g5.et1.preferredSize=[250,20];
                  win.g10 =win.p1.add('group');
                  win.g10.orientation = "row";
                  win.g10.alignment='fill';
                  win.g10.spacing=10;
                  win.g10.st1 = win.g10.add('statictext',undefined,'Serial Number');
                  win.g10.et1 = win.g10.add('edittext',undefined,'1');
                  win.g10.et1.preferredSize=[50,20];
                  win.g10.et1.onChanging = function() {
                    if (this.text.match(/[^\-\.\d]/)) {
                      this.text = this.text.replace(/[^\-\.\d]/g, '');
                  win.g10.st1 = win.g10.add('statictext',undefined,'Length');
                  var nums=[2,3,4,5];
                  win.g10.dl1 = win.g10.add('dropdownlist',undefined,nums);
                  win.g10.dl1.selection=0;
                  win.g15 =win.p1.add('group');
                  win.g15.orientation = "row";
                  win.g15.alignment='fill';
                  win.g15.cb1 = win.g15.add('checkbox',undefined,'Reverse layer order');
                  win.g100 =win.p1.add('group');
                  win.g100.orientation = "row";
                  win.g100.alignment='center';
                  win.g100.spacing=10;
                  win.g100.bu1 = win.g100.add('button',undefined,'Rename');
                  win.g100.bu1.preferredSize=[120,30];
                  win.g100.bu2 = win.g100.add('button',undefined,'Cancel');
                  win.g100.bu2.preferredSize=[120,30];
                  win.g100.bu1.onClick=function(){
                      if(win.g5.et1.text == ''){
                          alert("No layer name has been entered!");
                          return;
                      win.close(0);
                      var visibleLayers = [];
                      for(a=0; a<allLayers.length; a++){
                          var ilayer = allLayers[a];
                          if (ilayer.visible) {
                              visibleLayers.push(ilayer);
                      if(win.g15.cb1.value) visibleLayers.reverse();
                      for(b=0; b<visibleLayers.length; b++){
                          var LayerName = win.g5.et1.text + zeroPad((Number(win.g10.et1.text)+Number(b)), Number(win.g10.dl1.selection.text));
                          visibleLayers[b].name = LayerName;
                  win.center();
                  win.show();
              function zeroPad(n, s) {
                  n = n.toString();
                  while (n.length < s) n = '0' + n;
                  return n;
              • 4. Re: Reworking Photoshop layer renaming script for Illustrator
                W_J_T Level 4
                Nice conversion CarlosCanto.
                • 5. Re: Reworking Photoshop layer renaming script for Illustrator
                  Brilliant! Thank you so much!!
                  I would suggest changing this line so the background is grey.
                  var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.50, 0.50, 0.50, 1]);
                  Otherwise, I get white text on white background:
                  • 6. Re: Reworking Photoshop layer renaming script for Illustrator
                    this is how it originally looked in CS5, I didn't mess with the colors.
                    • 7. Re: Reworking Photoshop layer renaming script for Illustrator
                      Muppet Mark Level 5
                      UI fine on my CS5 too Carlos…
                      • 8. Re: Reworking Photoshop layer renaming script for Illustrator
                        thanks Mark, I wonder if that's how it looks in CS6.
                        • 10. Re: Reworking Photoshop layer renaming script for Illustrator
                          julioc4816867 Level 1
                          it's possible rename sublayers? thanks, sorry my bad english
                          • 11. Re: Reworking Photoshop layer renaming script for Illustrator
                            you can write in your language (español?)
                            it might be possible, show a screen shot of your layers expanded
                            • 12. Re: Reworking Photoshop layer renaming script for Illustrator
                              Larry G. Schneider Adobe Community Professional & MVP
                              It may be associated with the bug in CS5 and Yosemite. If you are on a Mac, try going to System Preferences/Accessibility/Display and check the box that says Reduce Transparency.
                              • 13. Re: Reworking Photoshop layer renaming script for Illustrator
                                I need rename only visible sublayers, It's possible? thanks carlos
                                Necesito solo renombrar las subcapas visibles, es eso posible? gracias
                                • 14. Re: Reworking Photoshop layer renaming script for Illustrator
                                  Hola Julio, I updated the script to rename visible Layers or Sublayers, and also fixed the Color
                                  #target illustrator
                                  main();
                                  function main(){
                                      //var allLayers = app.activeDocument.layers;
                                      g = win.graphics;
                                      //  var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.99, 0.99, 0.99, 1]); // CS5
                                      var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.50, 0.50, 0.50, 1]); // CS6
                                      win.title = win.g1.add('statictext',undefined,'Rename Visible Layers or Sublayers');
                                      win.g5.spacing=10;
                                      win.g10.spacing=10;
                                      var nums=[2,3,4,5];
                                      win.g15.cb2 = win.g15.add('checkbox',undefined,'Rename Sublayers Only');
                                              return;
                                          win.close(0);
                                          var sublayersOnly = win.g15.cb2.value;
                                          getVisibleLayers (app.activeDocument, visibleLayers, sublayersOnly);
                                      win.center();
                                      win.show();
                                      function getVisibleLayers(container, visibleLayers, sublayersOnly) {
                                          for(var a=0; a<container.layers.length; a++){
                                              var ilayer = container.layers[a];
                                                  if (sublayersOnly) {
                                                      getVisibleLayers (ilayer, visibleLayers, false); // false to process only 1 sublayer depth
                                                  else
                                      n = n.toString();
                                      return n;
                                  2 people found this helpful
                                  • 15. Re: Reworking Photoshop layer renaming script for Illustrator
                                    awesome, thanks you very much Carlos, you are outstanding
                                    • 16. Re: Reworking Photoshop layer renaming script for Illustrator
                                      StrongBeaver Level 3
                                      Nice script, am I suppose to select all the sub-layers followed by running the script, if so the script doesn't rename the sub-layers ?
                                      • 17. Re: Reworking Photoshop layer renaming script for Illustrator
                                        JOMANI Level 1
                                        Carlos, you a amazing! This script is a TIME saver :-D I feel like i owe you something. Thanks a lot man!
                                        • 18. Re: Reworking Photoshop layer renaming script for Illustrator
                                          Climberfx Level 1
                                          Thank you very much.
                                          I was surprise that there isn't built in multiple layer renaming in Illustrator since the version one.
                                          This will help a lot. Thank's again!
                                          • 19. Re: Reworking Photoshop layer renaming script for Illustrator
                                            Ton Frederiks Adobe Community Professional
                                            Illustrator version one did not have layers :-)
                                            • 20. Re: Reworking Photoshop layer renaming script for Illustrator
                                              ananggadipa Level 1
                                              Great script, instead of visible layer could it set for layer with object selected?
                                              Btw update color for CC 2015:
                                              var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.28, 0.28, 0.28, 1]);
