• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Flash Player 11 Error:Failed to register
New Here ,
Oct 16, 2012 Oct 16, 2012
I have a few machines that I cannot get Flashplayer to update and install on.  Windows7 32, IE 8 or 9.   I have tried the subinacl and reset_fp11.bat and it does not help.  I have ran the uninstall for FP and no difference. Any further assistance would be great.
Views
20.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
1. Uninstall flash player using control panel.
2. Browse the Flash folder in the location   "C:\Windows\System32\Macromed\"    and delete.
3. Restart your computer and install Flash player from www.adobe.com
Votes
Translate
Translate
Report
Report
LEGEND ,
If reset_fp11.bat did not resolve the problem, you may be out of luck...
But one last try: download the MSI installer from http://www.adobe.com/products/flashplayer/distribution3.html then right-click on it and select Run as Administrator.
If that also fails to register, can you post the contents of the FlashInstall.log file from C:\Windows\system32\Macromed\Flash - there may be some information in there that could help to identify which registry key cannot be accessed.
Votes
Translate
Translate
Report
Report
New Here ,
Oct 22, 2012 Oct 22, 2012
I could not get my login to work so created a new one.
Here is a copy of the log -
=O====== M/11.4.402.287 2012-10-22+14-37-54.725 ========
0000 00000010 "C:\Users\kmarino\AppData\Local\Temp\InstallAX.exe" -install -msi
0001 00001036 Software\Macromedia\FlashPlayer\SafeVersions/11.0 2
0002 00001036 Software\Macromedia\FlashPlayerActiveX/PlayerPath 2
0003 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0004 00001037 SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Adobe Flash Player ActiveX/ 2
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash32_11_4_402_287.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_287_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil32_11_4_402_287_ActiveX.dll
0008 00000019 C:\Windows\system32\FlashPlayerCPLApp.cpl
0009 00001032 C:\Windows\system32\Macromed\Flash\Flash32_11_4_402_287.ocx 8002801C
0010 00000018
0011 00001032 C:\Windows\system32\Macromed\Flash\Flash32_11_4_402_287.ocx 8002801C
=X====== M/11.4.402.287 2012-10-22+14-37-56.917 ========
This was the error message when trying the MSI.
The user installing this is a local admin of the machine.  I also have a copy of the Processmonitor log.
Votes
Translate
Translate
Report
Report
LEGEND ,
Oct 23, 2012 Oct 23, 2012
Does the file C:\Windows\system32\Macromed\Flash\Flash32_11_4_402_287.ocx actually exist?
If so, can you try to register it manually, as follows:
  • Start | type 'cmd' into the search field
  • right-click on cmd.exe and select Run as Administrator
  • in the Command Prompt type
    • cd C:\Windows\system32\Macromed\Flash
    • regsvr32 Flash32_11_4_402_287.ocx
    • exit
Votes
Translate
Translate
Report
Report
New Here ,
Oct 24, 2012 Oct 24, 2012
the ocx was there and performed the steps listed above.
Ran as Admin. Did not go.
Votes
Translate
Translate
Report
Report
LEGEND ,
If even 'Run as Administrator' did not allow registering the OCX, then you may have some registry permission problems that could not be addressed by the SubInACL prodcedure.
The only idea I have left is trying to use Microsoft Fixit to find and repair any problems in your registry.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Nov 13, 2013 Nov 13, 2013
LATEST
Votes
Translate
Translate
Report
Report
