2 Replies Latest reply on Oct 17, 2012 11:38 AM by u005078
    How to add a document to the JCR Repository via Java API
    u005078
      I'm trying to get started with the JCR 2.0 " Content Repository Java Technology API Specification" It's really a great document but I miss a minimum of examples to visualize how it is all fits together.
      For a start I want to add a pdf-document to my local CRX repository. Form the book I see, that I must add a Node and add the Properties.
      File file = new File("/mypath/mydocument.pdf");
      FileInputStream is = new FileInputStream(file);
      ValueFactory valueFactory = session.getValueFactory();
      Binary myBinary = valFact.createBinary(is);
      Value valueFactory =valFact.createValue(myBinary);
      Node nodeCarl=content.addNode("Carl", "nt:file");
      Property pCarl=nodeCarl.setProperty("jcr:data", myBinary);
      The program fails with:
      javax.jcr.nodetype.ConstraintViolationException: no matching property definition found for {http://www.jcp.org/jcr/1.0}data in the lastt cited line.
      I don't know, why this comes up with ..jcr/1.0; The Classpath consists of JCR-2.0.jar and jackrabbit-standalone-2.2.13.jar.
      Any hint to get this stored is appreciated.
      Ulrich
        • 1. Re: How to add a document to the JCR Repository via Java API
          MarcelBoucher Adobe Employee
          The reason you are getting a ConstraintViolationException is because you are creating a node of type nt:file. The nt:file node as per the JCR specification[0], requires a child node jcr:content which contains the actual file contents.
          Here is an updated snippet of Java code I created to store a PDF file into CRX:
          Node node = _session.getNode(parentNode);
          Binary contentValue = valueFactory.createBinary(is);
          Node fileNode = node.addNode(fileName, "nt:file");
          fileNode.addMixin("mix:referenceable");
          Node resNode = fileNode.addNode("jcr:content", "nt:resource");
          resNode.setProperty("jcr:mimeType", mimeType);
          resNode.setProperty("jcr:data", contentValue);
          Calendar lastModified = Calendar.getInstance();
          lastModified.setTimeInMillis(lastModified.getTimeInMillis());
          resNode.setProperty("jcr:lastModified", lastModified);
          session.save();
          // Return the path to the document that was stored in CRX.
          return fileNode.getPath();
          Hope this helps
          [0] http://www.day.com/specs/jcr/2.0/3_Repository_Model.html#3.7.11.2 nt:file
          • 2. Re: How to add a document to the JCR Repository via Java API
            u005078 Level 1
            Thank you - this fixed it.
            Ulrich
