• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
XML Post from Crystal Xcelcius
Explorer ,
Jul 10, 2006 Jul 10, 2006
I am needing to parse an XML post from Crystal Xcelcius with CF. Xcelsius sends the data as a form post, but CF doesn't see the form variable(s). Below is the XML (a sample) and code in VB that works to handle the post. I need to accomplosh the same thing with CF. Can you help me translate this to CF? Again, CF just doesn't see the form variable(s), so I am dead in the water.
I have tried referencing the post with the following variables: #form.data#, #form.PriceTable#, #PriceTable#, etc. CF doesn't see any of these as existing.
Here's the XML:
XML data sent: <data><variable name="PriceTable"><row><column>undefined</column><column>North</column><column>South</column><column>East</column><column>West</column></row><row><column>Wholesale</column><column>10</column><column>20</column><column>25</column><column>22.5</column></row><row><column>Markup</column><column>1</column><column>2</column><column>2.5</column><column>2.25</column></row><row><column>Retail</column><column>11</column><column>22</column><column>27.5</column><column>24.75</column></row><row><column>Units Sold</column><column>20</column><column>30</column><column>40</column><column>50</column></row></variable></data>
Here's the first part of the VB that works just fine...
'Get XML that was send from SWF file
Dim sXMLString
dim item as String
For Each item In Request.Form
'Response.Write(item & " = " & Request.Form(item) & VbCrLf)
sXMLString = sXMLString & item & " = " & Request.Form(item)
Next
TOPICS
Advanced techniques
Views
763
Translate
Translate
Report
Report
Community guidelines
community guidelines
Participant ,
What do you get if you dump the form scope
<cfdump var="#form#">
Votes
Translate
Translate
Report
Report
Explorer ,
Kevin: The Xcelsius post works in such a way that the page being posted to is not actually displayed in the browser. So, I can only see the results of my "script" (cf code). Here's my CF code on the page receivng the post:
<CFIF IsDefined("form")>
<cfset var_xmlData = "YES, we have a form">
<cfelse>
<cfset var_xmlData = "NOPE, no form">
</cfif>
<cffile action="write" file="C:\Inetpub\wwwroot\veritascdh\gtTest\xmlDataButton\data.xml"
output="#var_xmlData#" nameconflict="overwrite">
The data.xml file shows "Yes..."
So, then I tried:
<cfset var_xmlData = xmlParse(form, yes)>
But it does not work. We are close here. What do you advise?
Thank you.
Votes
Translate
Translate
Report
Report
Participant ,
The problem here is that you are trying to parse the form structure itself.
Based on what I'm seeing in the VB code, give this a shot.
<cfset xmlToParse = "">
<cfloop collection="#form#" item="i">
<cfset xmlToParse = xmlToParse & i>
</cfloop>
Try writing the xmlToParse to the file and see what you get, then run the xmlParse function.
<cfset var_xmlData = xmlParse(xmlToParse)>
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks, but the code doesn't run. Here is exaclty what I have now:
</cfloop>
<cfelse>
</cfif>
Votes
Translate
Translate
Report
Report
Participant ,
One caveat, you may need to check to make sure that i is not equal to fieldnames
Votes
Translate
Translate
Report
Report
Participant ,
change
to
<cfset var_xmlData = xmlToParse>
And let me know what you get.
Votes
Translate
Translate
Report
Report
Explorer ,
When I view the data.xml file in the browser it shows:
The XML page cannot be displayed
Cannot view XML input using style sheet. Please correct the error and then click the Refresh button, or try again later.
Invalid at the top level of the document. Error processing resource ' http://vhs0043/veritascdh/gttest/xmlDataButton/data.xm...
FIELDNAMES<DATA><VARIABLE NAME
Which is more output than I have been able to get up to this point.
The actual content of the data.xml file is simply:
Votes
Translate
Translate
Report
Report
Participant ,
Ok, don't open it in the browser, open it in notepad. And I goofed too you need the value of i not i itself.
Add this to your code:
Votes
Translate
Translate
Report
Report
Explorer ,
OK, did that and and the code did not run, so I trided repalcing form with i as in:
instead of
<cfset xmlToParse = xmlToParse & form>
with that the data.xml file contains only the following
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Email me your code - if you can - schmidt <at> hungrycow . com
Votes
Translate
Translate
Report
Report
Resources
Documentation
