Spry Menu Vertical - Border thickness problem in IE 7
oicram Mar 1, 2008 8:05 AMHello,
No. I'm not using the last 1.6.1 file, because I have change the css vertical menu to fit my design style.
Errors that I get:
They are all with IE 7 versions. In Firefox, everything is great.
1) A weird refresh when I click on the submenu links.
2) I can't get the horizontal border line between the menus to get 1px in IE 7.
Here is the vertical menu css code:
@charset "UTF-8";
/* SpryMenuBarVertical.css - version 0.6 - Spry Pre-Release 1.5 */
/* Copyright (c) 2006. Adobe Systems Incorporated. All rights reserved. */
LAYOUT INFORMATION: describes box model, positioning, z-order
/* The outermost container of the Menu Bar, a fixed width box with no margin or padding */
ul.MenuBarVertical
margin: 0;
padding: 0;
list-style-type: none;
font-size: 100%;
cursor: default;
width: 10em;
/* Set the active Menu Bar with this class, currently setting z-index to accomodate IE rendering bug: http://therealcrisp.xs4all.nl/meuk/IE-zindexbug.html */
ul.MenuBarActive
z-index: 1000;
/* Menu item containers, position children relative to this container and are same fixed width as parent */
ul.MenuBarVertical li
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: 10em;
/* Submenus should appear slightly overlapping to the right (95%) and up (-5%) with a higher z-index, but they are initially off the left side of the screen (-1000em) */
ul.MenuBarVertical ul
margin: -5% 0 0 95%;
padding: 0;
font-size: 100%;
position: absolute;
z-index: 1020;
cursor: default;
width: 10em;
left: -1000em;
top: 0;
/* Submenu that is showing with class designation MenuBarSubmenuVisible, we set left to 0 so it comes onto the screen */
ul.MenuBarVertical ul.MenuBarSubmenuVisible
left: 0;
/* Menu item containers are same fixed width as parent */
ul.MenuBarVertical ul li
width: 10em;
DESIGN INFORMATION: describes color scheme, borders, fonts
/* Outermost menu container has borders on all sides */
ul.MenuBarVertical
border: 1px solid #000;
/* Submenu containers have borders on all sides */
border: 1px solid #CCC;
/* Menu items are a light gray block with padding and no text decoration */
ul.MenuBarVertical a
display: block;
cursor: pointer;
background-color: #333333;
padding: 0.6em 0.75em; /*primeiro pading vertical, segundo: horizontal*/
color: #FFFFFF;
text-decoration: none;
font-family: sans-serif;
text-align: center;
border: 1px solid white;
/* Menu items that have mouse over or focus have a blue background and white text */
ul.MenuBarVertical a:hover, ul.MenuBarVertical a:focus
background-color: #8E001C;
color: #FFF;
/* Menu items that are open with submenus are set to MenuBarItemHover with a blue background and white text */
ul.MenuBarVertical a.MenuBarItemHover, ul.MenuBarVertical a.MenuBarItemSubmenuHover, ul.MenuBarVertical a.MenuBarSubmenuVisible
color: #FFF;
SUBMENU INDICATION: styles if there is a submenu under a given menu item
/* Menu items that have a submenu have the class designation MenuBarItemSubmenu and are set to use a background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarRight.gif);
background-repeat: no-repeat;
background-position: 95% 50%;
/* Menu items that are open with submenus have the class designation MenuBarItemSubmenuHover and are set to use a "hover" background image positioned on the far left (95%) and centered vertically (50%) */
background-image: url(SpryMenuBarRightHover.gif);
BROWSER HACKS: the hacks below should not be changed unless you are an expert
/* HACK FOR IE: to make sure the sub menus show above form controls, we underlay each submenu with an iframe */
ul.MenuBarVertical iframe
position: absolute;
z-index: 1010;
filter:alpha(opacity:0.1);
/* HACK FOR IE: to stabilize appearance of menu items; the slash in float is to keep IE 5.0 from parsing */
@media screen, projection
ul.MenuBarVertical li.MenuBarItemIE
display: inline;
float: left;
background: #fff;
How can I give the same effect that happens in firefox, also in IE 7 ?
Please test the link in both: IE 7 and Firefox.
http://www.hundehilfe-portugal.de/hund.html
Errors that I get:
@charset "UTF-8";
ul.MenuBarVertical
margin: 0;
padding: 0;
font-size: 100%;
cursor: default;
width: 10em;
ul.MenuBarActive
z-index: 1000;
margin: 0;
padding: 0;
font-size: 100%;
position: relative;
text-align: left;
cursor: pointer;
width: 10em;
padding: 0;
font-size: 100%;
position: absolute;
z-index: 1020;
cursor: default;
width: 10em;
left: -1000em;
top: 0;
left: 0;
width: 10em;
ul.MenuBarVertical
display: block;
cursor: pointer;
color: #FFFFFF;
text-align: center;
color: #FFF;
color: #FFF;
position: absolute;
z-index: 1010;
display: inline;
float: left;
background: #fff;
