3 Replies Latest reply on Oct 17, 2012 2:36 AM by Jonas Hummelstrand
    Warning: "not enough memory to create shadow map vertice"
    jmcall10
      First of all I am not too technically minded and not a great expert at after effects so keep this in mind when answering
      I will post as much info to give a comprehensive idea of my setup and issue.
      What I am basically asking is if I have after effects setup correctly for the spec I am running to achieve maximum benefit and performance?
      And Is this perhaps a project composition error?
      I have an after effects project that fails about 2.5 hours into rendering with this warning:
      Now just a bit of background. I had 4gb and have upgraded to 8gb. The reason I upgraded was due to this error however I still have same issue (to be honest I dont see any improvement with ram previews etc).
      This is my current PC spec:
      I have changed virtual memory to double the RAM which I believe is what is recommended?
      Now this is what after effects looks like on start up: Should it not utalise the 8gb?
      When rendering it also just says using 4gb also:
      Here are my multi processing and memory settings:
      I hope this is detailed enough for someone to troubleshoot and help me out.
      Kind Regards,
      jmcall10
