5 Replies Latest reply on Oct 18, 2012 5:34 AM by jfb00
    Access DataField in Itemrenderer when submitting to Database
    BrianJ011980
      Hello,
      I'm really stuck on this one. I have setup an Itemrenderer in a Datagrid which manages a DateField. Users can enter a date and other values directly in the datagrid. When they click 'submit', I want to populate a row in a database and I have setup a service for this. A row is created in the db as expected however the date is not populated despite users having entered a value. Below is a code snippet:
      Datagrid
      <s:GridColumn dataField="datf" headerText="Period From" rendererIsEditable="true">
           <s:itemRenderer>
                <fx:Component>
                     <s:GridItemRenderer dataChange="updateRenderer()">
                          <fx:Script>
                               <![CDATA[
                                         public function updateRenderer():void {
                                              periodFrom.text = outerDocument.dtf1.format(data.datf);
                                         private function dateField_labelFunc(item:Date):String {
                                              periodFrom.text = outerDocument.dtf1.format(item);
                                              return outerDocument.dtf1.format(item);
                          </fx:Script>
                               <mx:DateField horizontalCenter="0" verticalCenter="0" width="90%" id="periodFrom" labelFunction="dateField_labelFunc"/>
                     </s:GridItemRenderer>
                </fx:Component>
      </s:itemRenderer>
      </s:GridColumn>
      Handler
      protected function createBillResult_resultHandler(event:ResultEvent):void
                                              var dataProvider = itemsDg.dataProvider;
                                              var item = null;
                                              for (var i:int = 0; i < dataProvider.length; i++){
                                                        item = dataProvider.getItemAt(i);
                                                        trace(item.datf); <--- THIS IS 'UNDEFINED'
                                                        billItems.days = item.days;
                                                        billItems.ratu = item.ratu;
                                                        billItems.lnid = item.lnid;
                                                        trace(billItems.datf = dtf2.format(item.datf));
                                                        createBillItemsResult.token = billingService.createBillItems(billItems);
      I would have thought that I can access the value from the itemrenderer using the dataField property like I do with the other items.
      Please, please, please help.
      Brian
        • 1. Re: Access DataField in Itemrenderer when submitting to Database
          jfb00 Level 3
          Try this:
                              <s:itemRenderer>
                                  <fx:Component>
                                      <s:GridItemRenderer>
                                          <fx:Script>
                                              <![CDATA[
                                                  public function updateData():void {
                                                      data.datf = periodFrom.selectedDate;
                                          </fx:Script>
                                          <mx:DateField horizontalCenter="0" verticalCenter="0" width="90%" id="periodFrom" formatString="MM/DD/YYYY" text="{data.datf}" change="updateData()" />
                                  </fx:Component>
                              </s:itemRenderer>
                          </s:GridColumn>
          • 2. Re: Access DataField in Itemrenderer when submitting to Database
            BrianJ011980 Level 1
            Hello jfb00,
            Thanks for your help, it worked for the most part, however, I got two errors:
            1. When I added one item to the datagrid, I got a general warning but when I submitted the data, the database was updated as expected - great!:
            "warning: unable to bind to property 'datf' on class 'Object' (class is not an IEventDispatcher)".
            2. In the scenario when I try to add a row to the datagrid, enter data, then add another row, an exception gets thrown:
            "TypeError: Error #1009: Cannot access a property or method of a null object reference"
            Any further ideas?
            Brian
            • 3. Re: Access DataField in Itemrenderer when submitting to Database
              jfb00 Level 3
              This error "TypeError: Error #1009: Cannot access a property or method of a null object reference" usually show when you are trying to set something that doesn't exist at the time of calling.
              I create a test code and it works for me. Try to replicate you issue here:
                             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                  <fx:Declarations>
                      <!-- Place non-visual elements (e.g., services, value objects) here -->
                  </fx:Declarations>
                  <fx:Script>
                      <![CDATA[
                          import mx.collections.ArrayCollection;
                          import mx.controls.Alert;
                          // Data includes URL to album cover.
                          [Bindable]
                          private var initDG:ArrayCollection = new ArrayCollection([
                              { Artist:'Pavement', Album:'Slanted and Enchanted', Price:11.99, datf:'01/01/2012'},
                              { Artist:'Pavement', Album:'Brighten the Corners',     Price:11.99, datf:'01/01/2012'}
                          private function addEmptyRow():void{
                              myGrid.dataProvider.addItem({
                                  'Artist':'',
                                  'Album':'',
                                  'Price':0,
                                  'datf':''
                          private function showData():void{
                              Alert.show('Done');
                  </fx:Script>
                  <s:VGroup>
                  <s:DataGrid id="myGrid" dataProvider="{initDG}" width="100%" variableRowHeight="true" editable="true">
                      <s:columns>
                          <s:ArrayList>
                              <s:GridColumn dataField="Artist"/>
                              <s:GridColumn dataField="Album"/>
                              <s:GridColumn dataField="Price"/>
                                  <s:itemRenderer>
                                      <fx:Component>
                                              <fx:Script>
                                                  <![CDATA[
                                              </fx:Script>
                                      </fx:Component>
                                  </s:itemRenderer>
                              </s:GridColumn>
                          </s:ArrayList>
                      </s:columns>
                  </s:DataGrid>
                  <s:Button label="Add Row" click="addEmptyRow()" />
                  <s:Button label="submit" click="showData()" />
                  </s:VGroup>
              </s:Application>
              • 4. Re: Access DataField in Itemrenderer when submitting to Database
                jfb00, you are a legend, words can not expres my gratitude. The problem was that I was not setting the default values of the datafields when creating a new row.
                Could you please explain to me why I get the: "warning: unable to bind to property 'datf' on class 'Object' (class is not an IEventDispatcher)" and what the impact is? I'm planning to re-use the datagrid to display the data returned from the database for an update process.
                Thanks again,
                Brian
                • 5. Re: Access DataField in Itemrenderer when submitting to Database
                  jfb00 Level 3
                  I don't see you code so it is hard to guess. Maybe an object doesn't dispatch even, try to declare [Bindable] in front.
                  Best,
