2 Replies Latest reply on Oct 17, 2012 6:58 AM by steve de rivas
    how to create drop down metadata in which fields are getting populated dynamically?.
    steve de rivas
      I am creating a metadata of drop down type in which the options are getting populated dynamaiclly. following are the steps which i followed.But the dropdown option is not getting populated . whats the problem?
      xtype=selection
      type=select
      optionsProvider=path to json file(/apps/dam/content/asseteditors/image/jpeg/formitems/dropdown2/options.json)
      optionsTextField=text
      optionsValueField=value
      optionsRoot=options
      in the json file(options.json)
      "options": [{
      "value": "String",
      "text": "String"
      "value": "Long",
      "text": "Number"
        • 1. Re: how to create drop down metadata in which fields are getting populated dynamically?.
          kasq Level 3
          try to use following configuration for the field in the dialog:
          <metadata
              jcr:primaryType="cq:Widget"
              fieldDescription="some description of the field"
              fieldLabel="field label"
              name="./metadata"
              options="/apps/dam/content/asseteditors/image/jpeg/formitems/dropdown2/options.json"
              type="select"
              xtype="selection"/>
          and your options.json file should have following structure:
            {"value" : "String","text" : "String"},
            {"value" : "Long","text" : "Number"}
          this is way how we populate dropdown list using static json file. Of course json can generated dynamically.
          Regards,
          kasq
          • 2. Re: how to create drop down metadata in which fields are getting populated dynamically?.
            steve de rivas Level 1
            if we dynamically create json for example through query builder ,
            response.setContentType("application/json");
            SlingHttpServletRequest slingReq = (SlingHttpServletRequest) request;
            String strpath = properties.get("path","").toString();
            Session session = slingReq.getResourceResolver().adaptTo(Session.class);
            QueryBuilder builder =
            resource.getResourceResolver().adaptTo(QueryBuilder.class);
            Map<String, String> map = new HashMap<String, String>();
            map.put("type", "cq:Page");
            map.put("path", "/content");
            Query query = builder.createQuery(PredicateGroup.create(map),session);
            result = query.getResult();
            String delim = "";
            for (Hit hit : result.getHits())
            %><%= delim %><%
            %>"value":"<%= hit.getPath() %>"<%
            %>"text":"<%= hit.getTitle() %>",<%
            %>"qtip":"",<%
            if ("".equals(delim))
            delim = ",";
            and the configuration be like
                name="./metadata
            xtype=selection
            type=select
            optionsRoot=hits
            optionsQTipField=qtip
            i have done the above step.It is not populating. where i have gone wrong?
